Android asking for pairing after DFU
Using SDK 15.3 on the embedded side and Android 10 I think it is on the mobile side.
We've implemented whitelists and hanging onto the bonding information on the embedded side.  The idea is that once the mobile side is talking to us we only want to talk to that particular device until we explicitly change to another one.
This works fine across power cycles on both sides.  Once paired and bonded and everything, the mobile side and embedded side exist in married bliss.
Now, pull up nRF connect and run a DFU on the embedded side. Once the embedded side comes back (and it is keeping all the bonding information and whitelists and all that across this as far as I can tell), Android wants to pair again...
I just don't understand why this is.  We've got the bonding information both sides as far as I know. Why does the Android side really want to pair again?  Am I missing something on the embedded side?
  • Bootloader has that set to default size of 12288
    application has
    #define FDS_VIRTUAL_PAGES 3
    #define FDS_VIRTUAL_PAGE_SIZE 1024
  • Ok. Then you need to start investigating the other things that I have mentioned:
    Edvin said:
    Do you see whether the peripheral device has changed anything? Or did you try to debug the applciation? Is the bonding data still present on the peripheral? Does the peripheral use the same Bluetooth LE address as before the DFU update took place?
    Edvin said:
    You can also make your application to tell you how many peers that are stored in the beginning of your application, to verify that it is in fact the nRF that has lost the bonding data. What does it say?
    And also, what does the log from your application say? Please copy paste the log from before you DFU, i.e. when you don't have to pair again and when you do have to pair again. Do they look the same?
    Does this only happen on Android? Did you try with iOS?
    BR,
    Edvin
  • And also, what does the log from your application say?
    Attached is the log from nRFconnect on Android.  This has a complicated connection scheme so I have not attempted this on iOS to see if there is a difference in it.
    1. Once the device is paired and bonded through our application, close the application and then connect back up with nRFconnect (this bypasses all the oddities of our application
    2. Then put the device into DFU mode via struct command 0x0000000007 in nRF Connect (line 53). This causes the device to change to bootloader mode.  In this mode, we aren't using the whitelists and such...
    3. run DFU
    4. Allow reconnect of nRFconnect when done (line 985- ~994)
    5. Android asks pairing again (starting at line 995 or so)...
    I'll be looking at the embedded side to answer some questions a bit later (this is going to take awhile to do here so you'll have to bear with me please)
    Thank you for your help so far in this.
    Log 6.txt
    I was actually thinking of the log from the nRF chip, if you have any.
    I see from the log 6.txt that it receives a pairing request. The address of the nRF chip is the same before and after the DFU (I 13:14:35.703 Connected to DF:A0:E4:ED:42:5C), so that should not be the issue. Perhaps the the nRF doesn't have the bonding data after the DFU process.
    Please check that delete_bonds() is not called after the DFU. Try setting a breakpoint or add some logging in the delete_bonds() function to see whether this is triggered.
    Also, you can add this before you start advertising:
    static void check_bonds(void)
        ret_code_t err_code;
        uint32_t peer_count;
        pm_peer_id_t peer_id = PM_PEER_ID_INVALID;
        pm_peer_data_bonding_t peer_data;
        peer_count = pm_peer_count();
        NRF_LOG_INFO("peer_count: %d", peer_count);
        peer_id = pm_next_peer_id_get(PM_PEER_ID_INVALID);
        if (peer_id != PM_PEER_ID_INVALID)
            while (peer_id != PM_PEER_ID_INVALID)
                NRF_LOG_INFO("peer id %d is valid", peer_id);
                err_code = pm_peer_data_bonding_load(peer_id, &peer_data);
                NRF_LOG_INFO("peer address: %02x:%02x:%02x:%02x:%02x:%02x", peer_data.peer_ble_id.id_addr_info.addr[5],
        peer_data.peer_ble_id.id_addr_info.addr[4],
        peer_data.peer_ble_id.id_addr_info.addr[3],
        peer_data.peer_ble_id.id_addr_info.addr[2],
        peer_data.peer_ble_id.id_addr_info.addr[1],
        peer_data.peer_ble_id.id_addr_info.addr[0]);
                peer_id = pm_next_peer_id_get(peer_id);
            NRF_LOG_INFO("no valid peers");
    It will print the address of all the peers that are bonded with the nRF. Add it right before you start advertising.
    BR,
    Edvin
  • One of my other engineers managed to grab the following logs (before I had time to get your suggested code in them) which might shed some light on things.  On the Baby Logs, you can ignore the RFID: lines as those are the application itself and have nothing to do with BLE..
    00> [1655195676.403] Play Sound 102
    00> [1655195677.904] Play Sound 102
    00> [1655195679.404] BLE: Entering promiscuous mode
    00> [1655195679.404] Whitelist: Applied whitelist with addr_cnt=0 irk_cnt=0
    00> <debug> nrf_ble_gatt: Requesting to update ATT MTU to 247 bytes on connection 0x0.
    00> [1655195696.006] BLE: Peer connected
    00> <debug> nrf_ble_gatt: Peer on connection 0x0 requested a data length of 27 bytes.
    00> <debug> nrf_ble_gatt: Updating data length to 27 on connection 0x0.
    00> <debug> nrf_ble_gatt: ATT MTU updated to 247 bytes on connection 0x0 (response).
    00> [1655195697.196] BLE: Data len is set to 0xF4(244)
    00> <debug> nrf_ble_gatt: Data length updated to 251 on connection 0x0.
    00> <debug> nrf_ble_gatt: max_rx_octets: 27
    00> <debug> nrf_ble_gatt: max_tx_octets: 251
    00> <debug> nrf_ble_gatt: max_rx_time: 328
    00> <debug> nrf_ble_gatt: max_tx_time: 2120
    00> <info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Encryption
    00> <debug> nrf_ble_gatt: Peer on connection 0x0 requested a data length of 251 bytes.
    00> <debug> nrf_ble_gatt: max_rx_octets: 251
    00> <debug> nrf_ble_gatt: max_rx_time: 2120
    00> [1655195706.684] Whitelist: Setting whitelist from current connection ...
    00> [1655195706.686] Whitelist: File found. Writing data into it
    00> [1655195706.686] Whitelist: Write succeeded.
    00> [1655195706.687] Whitelist: Setting whitelist from current connection done
    00> [1655195706.687] BLE: Whitelist for connected peer set successfully
    00> [1655195706.687] BLE: Exiting promiscuous mode
    00> [1655195708.928] Vbat: 100% (2.44V)
    00> [1655195720.389] Reboot into bootloader in 1 sec...
    00> [1655195721.013] POR Vbat: (2.44V)
    00> <debug> nrf_sdh_freertos: Creating a SoftDevice task.
    00> <debug> ble_scan: Adding filter on RWStudentID name
    00> <debug> nrf_sdh_freertos: Enter softdevice_task.
    00> [1655195721.263] Whitelist: File found
    00> [1655195721.263] Whitelist: File read successfully
    00> [1655195721.263] Whitelist: Whitelist file found. peer_id=1
    00> [1655195721.265] Whitelist: File found. Writing data into it
    00> [1655195721.265] Whitelist: Write succeeded.
    00> [1655195721.270] Baby service: Version=0.8.4.6, Family=91, ProgramChecksum=D6DBF55D
    00> [1655195721.273] Whitelist: File found
    00> [1655195721.273] Whitelist: File read successfully
    00> [1655195721.273] BLE: Whitelist contains a peer. Start advertising.
    00> [1655195721.273] Whitelist: Applied whitelist with addr_cnt=1 irk_cnt=1
    00> [1634809200.285] POR
    00> [1634809200.287] BLE: Peer connected
    00> [1634809200.289] temperature: 26.0C
    00> [1634809200.289] Vbat: 100% (2.43V)
    00> [1634809200.307] LOG: 242,9,0x00,0x00
    00> [1634809200.434] RFID: tagPWD 804C27B1 timeout
    00> [1634809200.434] RFID: tag 6 data = 0x00000000
    00> [1634809200.477] BLE: Data len is set to 0xF4(244)
    00> [1634809200.521] RFID: tagPWD 804C27B1 timeout
    00> [1634809200.521] RFID: tag 6 data = 0x00000000
    00> [1634809200.531] Switched from event 0 to event 11
    00> [1634809200.551] LOG: 11,9,0x00,0x00
    00> [1634809200.716] RFID: tagPWD 804C27B1 timeout
    00> [1634809200.716] RFID: tag 6 data = 0x00000000
    00> [1634809200.803] RFID: tagPWD 804C27B1 timeout
    00> [1634809200.803] RFID: tag 6 data = 0x00000000
    00> [1634809200.940] RFID: tagPWD 804C27B1 timeout
    00> [1634809200.940] RFID: tag 6 data = 0x00000000
    00> [1634809201.027] RFID: tagPWD 804C27B1 timeout
    00> [1634809201.027] RFID: tag 6 data = 0x00000000
    00> [1634809201.165] RFID: tagPWD 804C27B1 timeout
    00> [1634809201.165] RFID: tag 6 data = 0x00000000
    00> [1634809201.252] RFID: tagPWD 804C27B1 timeout
    00> [1634809201.252] RFID: tag 6 data = 0x00000000
    00> [1634809201.389] RFID: tagPWD 804C27B1 timeout
    00> [1634809201.389] RFID: tag 6 data = 0x00000000
    00> [1634809201.476] RFID: tagPWD 804C27B1 timeout
    00> [1634809201.476] RFID: tag 6 data = 0x00000000
    00> [1634809201.613] RFID: tagPWD 804C27B1 timeout
    00> [1634809201.613] RFID: tag 6 data = 0x00000000
    00> [1634809201.700] RFID: tagPWD 804C27B1 timeout
    00> [1634809201.700] RFID: tag 6 data = 0x00000000
    00> [1634809201.837] RFID: tagPWD 804C27B1 timeout
    00> [1634809201.837] RFID: tag 6 data = 0x00000000
    00> [1634809201.924] RFID: tagPWD 804C27B1 timeout
    00> [1634809201.924] RFID: tag 6 data = 0x00000000
    00> [1634809202.061] RFID: tagPWD 804C27B1 timeout
    00> [1634809202.061] RFID: tag 6 data = 0x00000000
    00> [1634809202.148] RFID: tagPWD 804C27B1 timeout
    00> [1634809202.148] RFID: tag 6 data = 0x00000000
    00> [1634809202.286] RFID: tagPWD 804C27B1 timeout
    00> [1634809202.286] RFID: tag 6 data = 0x00000000
    00> [1634809202.373] RFID: tagPWD 804C27B1 timeout
    00> [1634809202.373] RFID: tag 6 data = 0x00000000
    00> [1634809202.510] RFID: tagPWD 804C27B1 timeout
    00> [1634809202.510] RFID: tag 6 data = 0x00000000
    00> [1634809202.597] RFID: tagPWD 804C27B1 timeout
    00> [1634809202.597] RFID: tag 6 data = 0x00000000
    00> [1634809202.734] RFID: tagPWD 804C27B1 timeout
    00> [1634809202.734] RFID: tag 6 data = 0x00000000
    00> [1634809202.821] RFID: tagPWD 804C27B1 timeout
    00> [1634809202.821] RFID: tag 6 data = 0x00000000
    00> [1634809202.958] RFID: tagPWD 804C27B1 timeout
    00> [1634809202.958] RFID: tag 6 data = 0x00000000
    00> [1634809203.045] RFID: tagPWD 804C27B1 timeout
    00> [1634809203.045] RFID: tag 6 data = 0x00000000
    00> [1634809203.182] RFID: tagPWD 804C27B1 timeout
    00> [1634809203.182] RFID: tag 6 data = 0x00000000
    00> [1634809203.269] RFID: tagPWD 804C27B1 timeout
    00> [1634809203.269] RFID: tag 6 data = 0x00000000
    00> [1634809203.406] RFID: tagPWD 804C27B1 timeout
    00> [1634809203.406] RFID: tag 6 data = 0x00000000
    00> [1634809203.493] RFID: tagPWD 804C27B1 timeout
    00> [1634809203.493] RFID: tag 6 data = 0x00000000
    00> [1634809203.630] RFID: tagPWD 804C27B1 timeout
    00> [1634809203.630] RFID: tag 6 data = 0x00000000
    00> [1634809203.717] RFID: tagPWD 804C27B1 timeout
    00> [1634809203.717] RFID: tag 6 data = 0x00000000
    00> [1634809203.854] RFID: tagPWD 804C27B1 timeout
    00> [1634809203.854] RFID: tag 6 data = 0x00000000
    00> [1634809203.941] RFID: tagPWD 804C27B1 timeout
    00> [1634809203.941] RFID: tag 6 data = 0x00000000
    00> [1634809204.078] RFID: tagPWD 804C27B1 timeout
    00> [1634809204.078] RFID: tag 6 data = 0x00000000
    00> [1634809204.165] RFID: tagPWD 804C27B1 timeout
    00> [1634809204.165] RFID: tag 6 data = 0x00000000
    00> [1634809204.186] BLE: Allow repairing: 0
    00> [1634809204.187] Whitelist: File found
    00> [1634809204.187] Whitelist: File read successfully
    00> [1634809204.187] Whitelist: check Whitelist file found. peer_id=1
    00> [1634809204.302] RFID: tagPWD 804C27B1 timeout
    00> [1634809204.302] RFID: tag 6 data = 0x00000000
    00> [1634809204.389] RFID: tagPWD 804C27B1 timeout
    00> [1634809204.389] RFID: tag 6 data = 0x00000000
    00> [1634809204.526] RFID: tagPWD 804C27B1 timeout
    00> [1634809204.526] RFID: tag 6 data = 0x00000000
    00> [1634809204.613] RFID: tagPWD 804C27B1 timeout
    00> [1634809204.613] RFID: tag 6 data = 0x00000000
    00> [1634809204.750] RFID: tagPWD 804C27B1 timeout
    00> [1634809204.750] RFID: tag 6 data = 0x00000000
    00> [1634809204.837] RFID: tagPWD 804C27B1 timeout
    00> [1634809204.837] RFID: tag 6 data = 0x00000000
    00> [1634809204.975] RFID: tagPWD 804C27B1 timeout
    00> [1634809204.975] RFID: tag 6 data = 0x00000000
    00> [1634809205.062] RFID: tagPWD 804C27B1 timeout
    00> [1634809205.062] RFID: tag 6 data = 0x00000000
    00> [1634809205.199] RFID: tagPWD 804C27B1 timeout
    00> [1634809205.199] RFID: tag 6 data = 0x00000000
    00> [1634809205.287] RFID: tagPWD 804C27B1 timeout
    00> [1634809205.287] RFID: tag 6 data = 0x00000000
    00> [1634809205.424] RFID: tagPWD 804C27B1 timeout
    00> [1634809205.424] RFID: tag 6 data = 0x00000000
    00> [1634809205.511] RFID: tagPWD 804C27B1 timeout
    00> [1634809205.511] RFID: tag 6 data = 0x00000000
    00> [1634809205.648] RFID: tagPWD 804C27B1 timeout
    00> [1634809205.648] RFID: tag 6 data = 0x00000000
    00> [1634809205.736] RFID: tagPWD 804C27B1 timeout
    00> [1634809205.736] RFID: tag 6 data = 0x00000000
    00> [1634809205.873] RFID: tagPWD 804C27B1 timeout
    00> [1634809205.873] RFID: tag 6 data = 0x00000000
    00> [1634809205.960] RFID: tagPWD 804C27B1 timeout
    00> [1634809205.960] RFID: tag 6 data = 0x00000000
    00> <info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Bonding
    00> [1634809206.097] RFID: tagPWD 804C27B1 timeout
    00> [1634809206.097] RFID: tag 6 data = 0x00000000
    00> [1634809206.185] RFID: tagPWD 804C27B1 timeout
    00> [1634809206.185] RFID: tag 6 data = 0x00000000
    00> [1634809206.322] RFID: tagPWD 804C27B1 timeout
    00> [1634809206.322] RFID: tag 6 data = 0x00000000
    00> [1634809206.409] RFID: tagPWD 804C27B1 timeout
    00> [1634809206.409] RFID: tag 6 data = 0x00000000
    00> [1634809206.546] RFID: tagPWD 804C27B1 timeout
    00> [1634809206.546] RFID: tag 6 data = 0x00000000
    00> [1634809206.633] RFID: tagPWD 804C27B1 timeout
    00> [1634809206.633] RFID: tag 6 data = 0x00000000
    00> [1634809206.771] RFID: tagPWD 804C27B1 timeout
    00> [1634809206.771] RFID: tag 6 data = 0x00000000
    00> [1634809206.859] RFID: tagPWD 804C27B1 timeout
    00> [1634809206.859] RFID: tag 6 data = 0x00000000
    00> [1634809206.996] RFID: tagPWD 804C27B1 timeout
    00> [1634809206.996] RFID: tag 6 data = 0x00000000
    00> [1634809207.083] RFID: tagPWD 804C27B1 timeout
    00> [1634809207.083] RFID: tag 6 data = 0x00000000
    00> [1634809207.220] RFID: tagPWD 804C27B1 timeout
    00> [1634809207.220] RFID: tag 6 data = 0x00000000
    00> [1634809207.307] RFID: tagPWD 804C27B1 timeout
    00> [1634809207.307] RFID: tag 6 data = 0x00000000
    00> [1634809207.444] RFID: tagPWD 804C27B1 timeout
    00> [1634809207.444] RFID: tag 6 data = 0x00000000
    00> [1634809207.531] RFID: tagPWD 804C27B1 timeout
    00> [1634809207.531] RFID: tag 6 data = 0x00000000
    00> [1634809207.668] RFID: tagPWD 804C27B1 timeout
    00> [1634809207.668] RFID: tag 6 data = 0x00000000
    00> [1634809207.755] RFID: tagPWD 804C27B1 timeout
    00> [1634809207.755] RFID: tag 6 data = 0x00000000
    00> [1634809207.892] RFID: tagPWD 804C27B1 timeout
    00> [1634809207.892] RFID: tag 6 data = 0x00000000
    00> [1634809207.979] RFID: tagPWD 804C27B1 timeout
    00> [1634809207.979] RFID: tag 6 data = 0x00000000
    00> [1634809208.116] RFID: tagPWD 804C27B1 timeout
    00> [1634809208.116] RFID: tag 6 data = 0x00000000
    00> [1634809208.203] RFID: tagPWD 804C27B1 timeout
    00> [1634809208.203] RFID: tag 6 data = 0x00000000
    00> [1634809208.340] RFID: tagPWD 804C27B1 timeout
    00> [1634809208.340] RFID: tag 6 data = 0x00000000
    00> [1634809208.427] RFID: tagPWD 804C27B1 timeout
    00> [1634809208.427] RFID: tag 6 data = 0x00000000
    00> [1634809208.565] RFID: tagPWD 804C27B1 timeout
    00> [1634809208.565] RFID: tag 6 data = 0x00000000
    00> [1634809208.652] RFID: tagPWD 804C27B1 timeout
    00> [1634809208.652] RFID: tag 6 data = 0x00000000
    00> [1634809208.789] RFID: tagPWD 804C27B1 timeout
    00> [1634809208.789] RFID: tag 6 data = 0x00000000
    00> [1634809208.876] RFID: tagPWD 804C27B1 timeout
    00> [1634809208.876] RFID: tag 6 data = 0x00000000
    00> [1634809209.013] RFID: tagPWD 804C27B1 timeout
    00> [1634809209.013] RFID: tag 6 data = 0x00000000
    00> [1634809209.100] RFID: tagPWD 804C27B1 timeout
    00> [1634809209.100] RFID: tag 6 data = 0x00000000
    00> [1634809209.237] RFID: tagPWD 804C27B1 timeout
    00> [1634809209.237] RFID: tag 6 data = 0x00000000
    00> [1634809209.324] RFID: tagPWD 804C27B1 timeout
    00> [1634809209.324] RFID: tag 6 data = 0x00000000
    00> [1634809209.461] RFID: tagPWD 804C27B1 timeout
    00> [1634809209.461] RFID: tag 6 data = 0x00000000
    00> [1634809209.548] RFID: tagPWD 804C27B1 timeout
    00> [1634809209.548] RFID: tag 6 data = 0x00000000
    00> [1634809209.686] RFID: tagPWD 804C27B1 timeout
    00> [1634809209.686] RFID: tag 6 data = 0x00000000
    00> [1634809209.775] RFID: tagPWD 804C27B1 timeout
    00> [1634809209.775] RFID: tag 6 data = 0x00000000
    00> [1634809209.912] RFID: tagPWD 804C27B1 timeout
    00> [1634809209.912] RFID: tag 6 data = 0x00000000
    00> [1634809209.999] RFID: tagPWD 804C27B1 timeout
    00> [1634809209.999] RFID: tag 6 data = 0x00000000
    00> [1634809210.136] RFID: tagPWD 804C27B1 timeout
    00> [1634809210.136] RFID: tag 6 data = 0x00000000
    00> [1634809210.223] RFID: tagPWD 804C27B1 timeout
    00> [1634809210.223] RFID: tag 6 data = 0x00000000
    00> [1634809210.360] RFID: tagPWD 804C27B1 timeout
    00> [1634809210.360] RFID: tag 6 data = 0x00000000
    00> [1634809210.448] RFID: tagPWD 804C27B1 timeout
    00> [1634809210.448] RFID: tag 6 data = 0x00000000
    00> [1634809210.585] RFID: tagPWD 804C27B1 timeout
    00> [1634809210.585] RFID: tag 6 data = 0x00000000
    00> [1634809210.672] RFID: tagPWD 804C27B1 timeout
    00> [1634809210.672] RFID: tag 6 data = 0x00000000
    00> [1634809210.810] RFID: tagPWD 804C27B1 timeout
    00> [1634809210.810] RFID: tag 6 data = 0x00000000
    00> [1634809210.898] RFID: tagPWD 804C27B1 timeout
    00> [1634809210.898] RFID: tag 6 data = 0x00000000
    00> [1634809211.035] RFID: tagPWD 804C27B1 timeout
    00> [1634809211.035] RFID: tag 6 data = 0x00000000
    00> [1634809211.123] RFID: tagPWD 804C27B1 timeout
    00> [1634809211.123] RFID: tag 6 data = 0x00000000
    00> [1634809211.260] RFID: tagPWD 804C27B1 timeout
    00> [1634809211.260] RFID: tag 6 data = 0x00000000
    00> [1634809211.347] RFID: tagPWD 804C27B1 timeout
    00> [1634809211.347] RFID: tag 6 data = 0x00000000
    00> [1634809211.484] RFID: tagPWD 804C27B1 timeout
    00> [1634809211.484] RFID: tag 6 data = 0x00000000
    00> [1634809211.571] RFID: tagPWD 804C27B1 timeout
    00> [1634809211.571] RFID: tag 6 data = 0x00000000
    00> [1634809211.709] RFID: tagPWD 804C27B1 timeout
    00> [1634809211.709] RFID: tag 6 data = 0x00000000
    00> [1634809211.796] RFID: tagPWD 804C27B1 timeout
    00> [1634809211.796] RFID: tag 6 data = 0x00000000
    00> [1634809211.933] RFID: tagPWD 804C27B1 timeout
    00> [1634809211.933] RFID: tag 6 data = 0x00000000
    00> [1634809212.020] RFID: tagPWD 804C27B1 timeout
    00> [1634809212.020] RFID: tag 6 data = 0x00000000
    00> [1634809212.158] RFID: tagPWD 804C27B1 timeout
    00> [1634809212.158] RFID: tag 6 data = 0x00000000
    00> [1634809212.245] RFID: tagPWD 804C27B1 timeout
    00> [1634809212.245] RFID: tag 6 data = 0x00000000
    00> [1634809212.382] RFID: tagPWD 804C27B1 timeout
    00> [1634809212.382] RFID: tag 6 data = 0x00000000
    00> [1634809212.469] RFID: tagPWD 804C27B1 timeout
    00> [1634809212.469] RFID: tag 6 data = 0x00000000
    00> [1634809212.606] RFID: tagPWD 804C27B1 timeout
    00> [1634809212.606] RFID: tag 6 data = 0x00000000
    00> [1634809212.693] RFID: tagPWD 804C27B1 timeout
    00> [1634809212.693] RFID: tag 6 data = 0x00000000
    00> [1634809212.830] RFID: tagPWD 804C27B1 timeout
    00> [1634809212.830] RFID: tag 6 data = 0x00000000
    00> [1634809212.917] RFID: tagPWD 804C27B1 timeout
    00> [1634809212.917] RFID: tag 6 data = 0x00000000
    00> [1634809213.054] RFID: tagPWD 804C27B1 timeout
    00> [1634809213.054] RFID: tag 6 data = 0x00000000
    00> [1634809213.141] RFID: tagPWD 804C27B1 timeout
    00> [1634809213.141] RFID: tag 6 data = 0x00000000
    00> [1634809213.278] RFID: tagPWD 804C27B1 timeout
    00> [1634809213.278] RFID: tag 6 data = 0x00000000
    00> [1634809213.365] RFID: tagPWD 804C27B1 timeout
    00> [1634809213.365] RFID: tag 6 data = 0x00000000
    00> [1634809213.502] RFID: tagPWD 804C27B1 timeout
    00> [1634809213.502] RFID: tag 6 data = 0x00000000
    00> [1634809213.589] RFID: tagPWD 804C27B1 timeout
    00> [1634809213.589] RFID: tag 6 data = 0x00000000
    00> [1634809213.643] Whitelist: Applied whitelist with addr_cnt=1 irk_cnt=1
    00> [1634809213.646] BLE: Peer disconnected
    00> [1634809213.726] RFID: tagPWD 804C27B1 timeout
    00> [1634809213.726] RFID: tag 6 data = 0x00000000
    00> [1634809213.813] RFID: tagPWD 804C27B1 timeout
    00> [1634809213.813] RFID: tag 6 data = 0x00000000
    00> [1634809213.950] RFID: tagPWD 804C27B1 timeout
    00> [1634809213.950] RFID: tag 6 data = 0x00000000
    00> [1634809214.037] RFID: tagPWD 804C27B1 timeout
    00> [1634809214.037] RFID: tag 6 data = 0x00000000
    00> [1634809214.174] RFID: tagPWD 804C27B1 timeout
    00> [1634809214.174] RFID: tag 6 data = 0x00000000
    00> [1634809214.261] RFID: tagPWD 804C27B1 timeout
    00> [1634809214.261] RFID: tag 6 data = 0x00000000
    00> [1634809214.400] RFID: tagPWD 804C27B1 timeout
    00> [1634809214.400] RFID: tag 6 data = 0x00000000
    00> [1634809214.487] RFID: tagPWD 804C27B1 timeout
    00> [1634809214.487] RFID: tag 6 data = 0x00000000
    00> [1634809214.624] RFID: tagPWD 804C27B1 timeout
    00> [1634809214.624] RFID: tag 6 data = 0x00000000
    00> [1634809214.711] RFID: tagPWD 804C27B1 timeout
    00> [1634809214.711] RFID: tag 6 data = 0x00000000
    00> [1634809214.848] RFID: tagPWD 804C27B1 timeout
    00> [1634809214.848] RFID: tag 6 data = 0x00000000
    00> [1634809214.935] RFID: tagPWD 804C27B1 timeout
    00> [1634809214.935] RFID: tag 6 data = 0x00000000
    00> [1634809215.073] RFID: tagPWD 804C27B1 timeout
    00> [1634809215.073] RFID: tag 6 data = 0x00000000
    00> [1634809215.160] RFID: tagPWD 804C27B1 timeout
    00> [1634809215.160] RFID: tag 6 data = 0x00000000
    00> [1634809215.297] RFID: tagPWD 804C27B1 timeout
    00> [1634809215.297] RFID: tag 6 data = 0x00000000
    00> [1634809215.384] RFID: tagPWD 804C27B1 timeout
    00> [1634809215.384] RFID: tag 6 data = 0x00000000
    00> [1634809215.521] RFID: tagPWD 804C27B1 timeout
    00> [1634809215.521] RFID: tag 6 data = 0x00000000
    00> [1634809215.608] RFID: tagPWD 804C27B1 timeout
    00> [1634809215.608] RFID: tag 6 data = 0x00000000
    00> [1634809215.745] RFID: tagPWD 804C27B1 timeout
    00> [1634809215.745] RFID: tag 6 data = 0x00000000
    00> [1634809215.832] RFID: tagPWD 804C27B1 timeout
    00> [1634809215.832] RFID: tag 6 data = 0x00000000
    00> [1634809215.969] RFID: tagPWD 804C27B1 timeout
    00> [1634809215.969] RFID: tag 6 data = 0x00000000
    00> [1634809216.056] RFID: tagPWD 804C27B1 timeout
    00> [1634809216.056] RFID: tag 6 data = 0x00000000
    00> [1634809216.193] RFID: tagPWD 804C27B1 timeout
    00> [1634809216.193] RFID: tag 6 data = 0x00000000
    00> [1634809216.280] RFID: tagPWD 804C27B1 timeout
    00> [1634809216.280] RFID: tag 6 data = 0x00000000
    00> [1634809216.417] RFID: tagPWD 804C27B1 timeout
    00> [1634809216.417] RFID: tag 6 data = 0x00000000
    00> [1634809216.504] RFID: tagPWD 804C27B1 timeout
    00> [1634809216.504] RFID: tag 6 data = 0x00000000
    00> [1634809216.641] RFID: tagPWD 804C27B1 timeout
    00> [1634809216.641] RFID: tag 6 data = 0x00000000
    00> [1634809216.728] RFID: tagPWD 804C27B1 timeout
    00> [1634809216.728] RFID: tag 6 data = 0x00000000
    00> [1634809216.865] RFID: tagPWD 804C27B1 timeout
    00> [1634809216.865] RFID: tag 6 data = 0x00000000
    00> [1634809216.952] RFID: tagPWD 804C27B1 timeout
    00> [1634809216.952] RFID: tag 6 data = 0x00000000
    00> [1634809217.089] RFID: tagPWD 804C27B1 timeout
    00> [1634809217.089] RFID: tag 6 data = 0x00000000
    00> [1634809217.177] RFID: tagPWD 804C27B1 timeout
    00> [1634809217.177] RFID: tag 6 data = 0x00000000
    00> [1634809217.314] RFID: tagPWD 804C27B1 timeout
    00> [1634809217.314] RFID: tag 6 data = 0x00000000
    00> [1634809217.402] RFID: tagPWD 804C27B1 timeout
    00> [1634809217.402] RFID: tag 6 data = 0x00000000
    00> [1634809217.539] RFID: tagPWD 804C27B1 timeout
    00> [1634809217.539] RFID: tag 6 data = 0x00000000
    00> [1634809217.626] RFID: tagPWD 804C27B1 timeout
    00> [1634809217.626] RFID: tag 6 data = 0x00000000
    00> [1634809217.763] RFID: tagPWD 804C27B1 timeout
    00> [1634809217.763] RFID: tag 6 data = 0x00000000
    00> [1634809217.851] RFID: tagPWD 804C27B1 timeout
    00> [1634809217.851] RFID: tag 6 data = 0x00000000
    00> [1634809217.988] RFID: tagPWD 804C27B1 timeout
    00> [1634809217.988] RFID: tag 6 data = 0x00000000
    00> [1634809218.075] RFID: tagPWD 804C27B1 timeout
    00> [1634809218.075] RFID: tag 6 data = 0x00000000
    00> [1634809218.213] RFID: tagPWD 804C27B1 timeout
    00> [1634809218.213] RFID: tag 6 data = 0x00000000
    00> [1634809218.301] RFID: tagPWD 804C27B1 timeout
    00> [1634809218.301] RFID: tag 6 data = 0x00000000
    00> [1634809218.439] RFID: tagPWD 804C27B1 timeout
    00> [1634809218.439] RFID: tag 6 data = 0x00000000
    00> [1634809218.526] RFID: tagPWD 804C27B1 timeout
    00> [1634809218.526] RFID: tag 6 data = 0x00000000
    00> [1634809218.663] RFID: tagPWD 804C27B1 timeout
    00> [1634809218.663] RFID: tag 6 data = 0x00000000
    00> [1634809218.752] RFID: tagPWD 804C27B1 timeout
    00> [1634809218.752] RFID: tag 6 data = 0x00000000
    00> [1634809218.889] RFID: tagPWD 804C27B1 timeout
    00> [1634809218.889] RFID: tag 6 data = 0x00000000
    00> [1634809218.976] RFID: tagPWD 804C27B1 timeout
    00> [1634809218.976] RFID: tag 6 data = 0x00000000
    00> [1634809219.114] RFID: tagPWD 804C27B1 timeout
    00> [1634809219.114] RFID: tag 6 data = 0x00000000
    00> [1634809219.201] RFID: tagPWD 804C27B1 timeout
    00> [1634809219.201] RFID: tag 6 data = 0x00000000
    00> [1634809219.338] RFID: tagPWD 804C27B1 timeout
    00> [1634809219.338] RFID: tag 6 data = 0x00000000
    00> [1634809219.425] RFID: tagPWD 804C27B1 timeout
    00> [1634809219.425] RFID: tag 6 data = 0x00000000
    00> [1634809219.562] RFID: tagPWD 804C27B1 timeout
    00> [1634809219.562] RFID: tag 6 data = 0x00000000
    00> [1634809219.650] RFID: tagPWD 804C27B1 timeout
    00> [1634809219.650] RFID: tag 6 data = 0x00000000
    00> [1634809219.788] RFID: tagPWD 804C27B1 timeout
    00> [1634809219.788] RFID: tag 6 data = 0x00000000
    00> [1634809219.875] RFID: tagPWD 804C27B1 timeout
    00> [1634809219.875] RFID: tag 6 data = 0x00000000
    00> [1634809220.012] RFID: tagPWD 804C27B1 timeout
    00> [1634809220.012] RFID: tag 6 data = 0x00000000
    00> [1634809220.099] RFID: tagPWD 804C27B1 timeout
    00> [1634809220.099] RFID: tag 6 data = 0x00000000
    00> [1634809220.236] RFID: tagPWD 804C27B1 timeout
    00> [1634809220.236] RFID: tag 6 data = 0x00000000
    00> [1634809220.323] RFID: tagPWD 804C27B1 timeout
    00> [1634809220.323] RFID: tag 6 data = 0x00000000
    00> [1634809220.461] RFID: tagPWD 804C27B1 timeout
    00> [1634809220.461] RFID: tag 6 data = 0x00000000
    00> [1634809220.548] RFID: tagPWD 804C27B1 timeout
    00> [1634809220.548] RFID: tag 6 data = 0x00000000
    00> [1634809220.685] RFID: tagPWD 804C27B1 timeout
    00> [1634809220.685] RFID: tag 6 data = 0x00000000
    00> [1634809220.772] RFID: tagPWD 804C27B1 timeout
    00> [1634809220.772] RFID: tag 6 data = 0x00000000
    00> [1634809220.909] RFID: tagPWD 804C27B1 timeout
    00> [1634809220.909] RFID: tag 6 data = 0x00000000
    00> [1634809220.996] RFID: tagPWD 804C27B1 timeout
    00> [1634809220.996] RFID: tag 6 data = 0x00000000
    00> [1634809221.133] RFID: tagPWD 804C27B1 timeout
    00> [1634809221.133] RFID: tag 6 data = 0x00000000
    00> [1634809221.220] RFID: tagPWD 804C27B1 timeout
    00> [1634809221.220] RFID: tag 6 data = 0x00000000
    00> [1634809221.357] RFID: tagPWD 804C27B1 timeout
    00> [1634809221.357] RFID: tag 6 data = 0x00000000
    00> [1634809221.445] RFID: tagPWD 804C27B1 timeout
    00> [1634809221.445] RFID: tag 6 data = 0x00000000
    00> [1634809221.582] RFID: tagPWD 804C27B1 timeout
    00> [1634809221.582] RFID: tag 6 data = 0x00000000
    00> [1634809221.669] RFID: tagPWD 804C27B1 timeout
    00> [1634809221.669] RFID: tag 6 data = 0x00000000
    00> [1634809221.806] RFID: tagPWD 804C27B1 timeout
    00> [1634809221.806] RFID: tag 6 data = 0x00000000
    00> [1634809221.893] RFID: tagPWD 804C27B1 timeout
    00> [1634809221.893] RFID: tag 6 data = 0x00000000
    00> [1634809222.030] RFID: tagPWD 804C27B1 timeout
    00> [1634809222.030] RFID: tag 6 data = 0x00000000
    00> [1634809222.117] RFID: tagPWD 804C27B1 timeout
    00> [1634809222.117] RFID: tag 6 data = 0x00000000
    00> [1634809222.254] RFID: tagPWD 804C27B1 timeout
    00> [1634809222.254] RFID: tag 6 data = 0x00000000
    00> [1634809222.341] RFID: tagPWD 804C27B1 timeout
    00> [1634809222.341] RFID: tag 6 data = 0x00000000
    00> [1634809222.478] RFID: tagPWD 804C27B1 timeout
    00> [1634809222.478] RFID: tag 6 data = 0x00000000
    00> [1634809222.565] RFID: tagPWD 804C27B1 timeout
    00> [1634809222.565] RFID: tag 6 data = 0x00000000
    00> [1634809222.702] RFID: tagPWD 804C27B1 timeout
    00> [1634809222.702] RFID: tag 6 data = 0x00000000
    00> [1634809222.789] RFID: tagPWD 804C27B1 timeout
    00> [1634809222.789] RFID: tag 6 data = 0x00000000
    00> [1634809222.927] RFID: tagPWD 804C27B1 timeout
    00> [1634809222.927] RFID: tag 6 data = 0x00000000
    00> [1634809223.014] RFID: tagPWD 804C27B1 timeout
    00> [1634809223.014] RFID: tag 6 data = 0x00000000
    00> [1634809223.151] RFID: tagPWD 804C27B1 timeout
    00> [1634809223.151] RFID: tag 6 data = 0x00000000
    00> [1634809223.238] RFID: tagPWD 804C27B1 timeout
    00> [1634809223.238] RFID: tag 6 data = 0x00000000
    00> [1634809223.376] RFID: tagPWD 804C27B1 timeout
    00> [1634809223.376] RFID: tag 6 data = 0x00000000
    00> [1634809223.463] RFID: tagPWD 804C27B1 timeout
    00> [1634809223.463] RFID: tag 6 data = 0x00000000
    (Connection lost)
    Android logs.txt
