Android asking for pairing after DFU
Using SDK 15.3 on the embedded side and Android 10 I think it is on the mobile side.
We've implemented whitelists and hanging onto the bonding information on the embedded side.  The idea is that once the mobile side is talking to us we only want to talk to that particular device until we explicitly change to another one.
This works fine across power cycles on both sides.  Once paired and bonded and everything, the mobile side and embedded side exist in married bliss.
Now, pull up nRF connect and run a DFU on the embedded side. Once the embedded side comes back (and it is keeping all the bonding information and whitelists and all that across this as far as I can tell), Android wants to pair again...
I just don't understand why this is.  We've got the bonding information both sides as far as I know. Why does the Android side really want to pair again?  Am I missing something on the embedded side?
  • Yes, I get that... interestingly enough a couple of times...
    00> [1634809769.258] Baby service: Version=0.8.4.10, Family=91, ProgramChecksum=05107740
    00> [1634809769.261] BLE: bounds: peer_count: 1
    00> [1634809769.261] BLE: bounds: peer id 0 is valid
    00> [1634809769.261] BLE: bounds: peer address: f0:5c:77:f5:2f:63
    00> [1634809769.262] FDS: File found
    00> [1634809769.262] FDS: File read successfully
    00> [1634809769.262] BLE: Whitelist contains a peer. Start advertising.
    00> [1634809769.262] Whitelist: Applied whitelist with addr_cnt=1 irk_cnt=1
    00> [1634809200.272] SIM Restart
    00> [1634809200.274] temperature: 26.0C
    00> [1634809200.275] Vbat: 100% (2.52V)
    00> [1634809200.290] LOG: 242,9,0x00,0x00
    00> [1634809200.345] Motion set: a=-0.158072, A[xyz]=0.005859,-0.115234,-0.833984
    00> [1634809200.516] Switched from event 0 to event 11
    00> [1634809200.536] LOG: 11,9,0x00,0x00
    00> [1634809201.766] BLE: Unhandled PeerManager event 5 (PM_EVT_CONN_SEC_PARAMS_REQ?)
    00> [1634809201.766] BLE: Unhandled PeerManager event 8 (PM_EVT_PEER_DATA_UPDATE_SUCCEEDED)
    00> [1634809201.766] BLE: Bonded Peer Connected (PM_EVT_PEER_DATA_UPDATE_SUCCEEDED)
    00> [1634809201.767] BLE: Unhandled PeerManager event 14 (PM_EVT_LOCAL_DB_CACHE_APPLIED)
    00> <debug> nrf_ble_gatt: Requesting to update ATT MTU to 247 bytes on connection 0x0.
    00> [1634809201.768] BLE: Peer connected (PM_EVT_BONDED_PEER_CONNECTED)
    00> <debug> nrf_ble_gatt: Peer on connection 0x0 requested a data length of 27 bytes.
    00> <debug> nrf_ble_gatt: Updating data length to 27 on connection 0x0.
    00> <debug> nrf_ble_gatt: ATT MTU updated to 247 bytes on connection 0x0 (response).
    00> [1634809201.951] BLE: Data len is set to 0xF4(244)
    00> <debug> nrf_ble_gatt: Data length updated to 251 on connection 0x0.
    00> <debug> nrf_ble_gatt: max_rx_octets: 27
    00> <debug> nrf_ble_gatt: max_tx_octets: 251
    00> <debug> nrf_ble_gatt: max_rx_time: 328
    00> <debug> nrf_ble_gatt: max_tx_time: 2120
    00> <debug> nrf_ble_gatt: Peer on connection 0x0 requested a data length of 251 bytes.
    00> <debug> nrf_ble_gatt: max_rx_octets: 251
    00> <debug> nrf_ble_gatt: max_rx_time: 2120
    00> [1634809204.405] BLE: Unhandled PeerManager event 1 (PM_EVT_CONN_SEC_START)
    00> [1634809204.409] BLE: Unhandled PeerManager event 5 (PM_EVT_CONN_SEC_PARAMS_REQ)
    00> [1634809204.410] FDS: File found
    00> [1634809204.410] FDS: File read successfully
    00> [1634809204.410] Whitelist: check Whitelist file found. peer_id=0
    00> [1634809204.410] BLE: Allow repairing: 1
    00> <info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Bonding
    00> [1634809206.511] BLE: Unhandled PeerManager event 8 (PM_EVT_PEER_DATA_UPDATE_SUCCEEDED)
    00> [1634809206.511] BLE: Unhandled PeerManager event 2 (PM_EVT_CONN_SEC_SUCCEEDED)
    00> [1634809206.515] BLE: Unhandled PeerManager event 8 (PM_EVT_PEER_DATA_UPDATE_SUCCEEDED)
    00> [1634809206.519] BLE: Unhandled PeerManager event 8 (PM_EVT_PEER_DATA_UPDATE_SUCCEEDED)
    00> [1634809207.347] BLE: Unhandled PeerManager event 8
    00> [1634809211.634] Play Sound 13, 0xD
    00> [1634809216.951] Whitelist: Applied whitelist with addr_cnt=1 irk_cnt=1
    00> [1634809216.952] BLE: Peer disconnected
  • I assume that since the log says "Allow repairing: 1", that the phone requests to pair again, as if it has lost the bonding information. Exactly why the phone decides to do that, I am not sure.
    1: Did you test this with different android phones? If not, can you please do?
    2: Is there some way for me to reproduce this? Did you try to reproduce it using the ble_app_buttonless_dfu example? If so, can you zip that modified ble_app_buttonless_dfu example so that I can try to reproduce the issue, preferably without doing too many changes to the rest of the SDK?
    I am sorry for the long response time. We are a bit understaffed during the summer holidays. Sorry for the inconvenience.
    Edvin
  • The "Allow repairing" thing is a code note to myself meaning, in this case, that we've got something in the whitelist and to allow that MAC address to talk to me.  The app is very locked down here using whitelists to not allow anyone to connect to it unless it's gone through some serious upper level handshakes.  This notation just says that, yes, the whitelists survived the update.  Those whitelists use fds so that are hasn't been wiped (this was a previous bug that we had in the code)
    1) Yes, we're using a couple of different ones. One team tends to use a Pixel and most of the other teams tend to use a Lenovo tablet.  Different versions of Android.
    2) The bootstrap here is effectively the buttonless dfu using SDK15.3 (with a couple of mods backporting some SDK17 fixes). 5707.bootloader.zip
  • Oh, and, I understand the time thing in the summer.... Thank you for being able to keep following this thing...
    Ok. I am back (and will stay for a while this time).
    Can you please try to capture a sniffer trace of the connection being entered. Preferably one after a DFU, and one with a normal connection (where the bonding is not requested). Please note that in order for the sniffer to be able to follow into a bonded connection, you probably need to erase the bonds, connect -> bond -> disconnect -> reconnect for the sniffer to be able to capture the LTK. If you are using OOB (6-digit passkey), you need to enter this manually in the sniffer.
    To capture a sniffer trace, you can use the nRF Sniffer for Bluetooth LE.
    And again, if there is some way for me to reproduce this, please zip a project application that can reproduce the issue. You say that it is a slightly modified ble_app_buttonless_dfu application, but please zip the one that is used for reproducing the issue. I also see that you are mixing a few different SDK versions. Can you please try to stick to one, and see if it is still reproducible, just to make sure that it is not the backport that is causing something to behave weirdly?
    Edvin
