Unable to use the DTM example for nRF5340 DK (PCA10095)
I am trying to use the DTM example for nRF5340 DK (PCA10095). The example is located at "C:\v1.7.0\nrf\samples\bluetooth\direct_test_mode", but I am facing "NRF_RADIO_Type" error along with few more errors with 1.7.0 as well as 1.9.0 SDK. I have attached the error log files' links below.
SDK 1.7.0 error log: https://drive.google.com/file/d/1m75QjX6ug_ym6KEYMkzjd8zMPitysDJz/view?usp=sharing
SDK 1.9.0 error log: https://drive.google.com/file/d/1epy6gnY7Dz73dMOb64afPjl9ZBsMckIp/view?usp=sharing
I have also tried using SDK 1.9.1, however I am unable to open the DTM project in it.
Thanks.
  • HI,
    MarienMup said:
    How do I change/reassign the UART pins from within the DTM project itself?
    Pin control is the feature in NCS v2.0.0 that makes this possible. More information about dynamic pin control is available in Zephyr documentation.
    For demonstration, you can take a look at the dynamic pin control sample and documentation.
    In order to change the configuration, resetting the chip is needed after reconfiguring of pins has been done.
    Dejan
  • Hi Dejans,
    In V2.0.0, for nRF5340 DK, I am able to flash the example and start the test too.
    However, I get the response "DTM setup tx power command failed with XX dbm" where XX is greater than 0. i.e. For Tx power of 0 dbm and lesser I am able to transmit it. So is the maximum TX power limit for nRF5340 is 0 dbm?
    I am attaching the TX commands and respective responses.
    Thanks
    Sending 0x0000 DTM command	Received 0x0000 DTM event
    Sending 0x820B DTM command	Received 0x0001 DTM event
    Sending 0x0104 DTM command	Received 0x0000 DTM event
    Sending 0x0300 DTM command	Received 0x0000 DTM event
    Sending 0x0204 DTM command	Received 0x0000 DTM event
    Sending 0x813C DTM command	Received 0x0000 DTM event
    Sending 0xC000 DTM command	Received 0x8000 DTM event
    Sending 0x800B DTM command	Received 0x0000 DTM event
    Maximum supported value of the radio output power for nRF5340 has been increased from 0 dBm to 3 dBm starting from NCS v1.6.0 as specified in the Changelog
    You could try adding the following lines to your code
    NRF_VREQCTRL->VREGRADIO.VREQH = 1;
    while(NRF_VREQCTRL->VREGRADIO.VREQHREADY == 0);
    There is more information about TXPOWER and VREQCTRL in the documentation.
    Dejan
  • Hi Dejan,
    Adding the lines in before calling dtm_init() in main.c or inside dtm_init() did not help me.
    Shubham
    It should work when added to the init() function. Could you check again?
    Dejan
