nRF connect-VS code error for nRF5340DK
Executing task: nRF Connect: Generate config bl5340_dvk_cpuapp for d:\VSCodePrograms\broadcaster <
Building broadcaster
west build --build-dir d:\VSCodePrograms\broadcaster\build d:\VSCodePrograms\broadcaster --pristine --board bl5340_dvk_cpuapp -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="d:/VSCodePrograms/broadcaster" -DBOARD_ROOT:STRING="d:/VSCodePrograms/broadcaster"
Including boilerplate (Zephyr base): C:/ncs/v1.9.1/zephyr/cmake/app/boilerplate.cmake
-- Application: D:/VSCodePrograms/broadcaster
-- Zephyr version: 2.7.99 (C:/ncs/v1.9.1/zephyr), build: v2.7.99-ncs1-1
-- Found Python3: C:/ncs/v1.9.1/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.12.0", minimum required is "0.7.1")
-- Board: bl5340_dvk_cpuapp
-- Cache files will be written to: C:/ncs/v1.9.1/zephyr/.cache
-- Found dtc: C:/ncs/v1.9.1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (c:/ncs/v1.9.1/toolchain/opt)
-- Found BOARD.dts: C:/ncs/v1.9.1/zephyr/boards/arm/bl5340_dvk/bl5340_dvk_cpuapp.dts
-- Generated zephyr.dts: D:/VSCodePrograms/broadcaster/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: D:/VSCodePrograms/broadcaster/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: D:/VSCodePrograms/broadcaster/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: D:/VSCodePrograms/broadcaster/build/zephyr/dts.cmake
Parsing C:/ncs/v1.9.1/zephyr/Kconfig
Loaded configuration 'C:/ncs/v1.9.1/zephyr/boards/arm/bl5340_dvk/bl5340_dvk_cpuapp_defconfig'
Merged configuration 'D:/VSCodePrograms/broadcaster/prj.conf'
Configuration saved to 'D:/VSCodePrograms/broadcaster/build/zephyr/.config'
Kconfig header saved to 'D:/VSCodePrograms/broadcaster/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: C:/ncs/v1.9.1/toolchain/opt/bin/arm-none-eabi-gcc.exe
=== child image hci_rpmsg - CPUNET begin ===
loading initial cache file D:/VSCodePrograms/broadcaster/build/hci_rpmsg/child_image_preload.cmake
-- Application: C:/ncs/v1.9.1/zephyr/samples/bluetooth/hci_rpmsg
-- Board: bl5340_dvk_cpunet
-- Found BOARD.dts: C:/ncs/v1.9.1/zephyr/boards/arm/bl5340_dvk/bl5340_dvk_cpunet.dts
-- Generated zephyr.dts: D:/VSCodePrograms/broadcaster/build/hci_rpmsg/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: D:/VSCodePrograms/broadcaster/build/hci_rpmsg/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: D:/VSCodePrograms/broadcaster/build/hci_rpmsg/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: D:/VSCodePrograms/broadcaster/build/hci_rpmsg/zephyr/dts.cmake
Loaded configuration 'C:/ncs/v1.9.1/zephyr/boards/arm/bl5340_dvk/bl5340_dvk_cpunet_defconfig'
Merged configuration 'C:/ncs/v1.9.1/zephyr/samples/bluetooth/hci_rpmsg/prj.conf'
Merged configuration 'C:/ncs/v1.9.1/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Configuration saved to 'D:/VSCodePrograms/broadcaster/build/hci_rpmsg/zephyr/.config'
Kconfig header saved to 'D:/VSCodePrograms/broadcaster/build/hci_rpmsg/zephyr/include/generated/autoconf.h'
-- Build type:
-- Host: Windows/AMD64
-- Target: Generic/arm
-- Machine: arm
-- libmetal version: 1.1.0 (C:/ncs/v1.9.1/zephyr/samples/bluetooth/hci_rpmsg)
-- Looking for include file stdatomic.h
-- Looking for include file stdatomic.h - found
-- open-amp version: 1.1.0 (C:/ncs/v1.9.1/modules/lib/open-amp/open-amp)
-- Machine: arm
-- C_FLAGS : -Wall -Wextra
-- Looking for include file fcntl.h
-- Looking for include file fcntl.h - found
CMake Warning at C:\ncs\v1.9.1\nrfxlib\softdevice_controller\CMakeLists.txt:29 (message):
No SoftDevice Controller variant selected
-- Configuring done
-- Generating done
-- Build files have been written to: D:/VSCodePrograms/broadcaster/build/hci_rpmsg
=== child image hci_rpmsg - CPUNET end ===
-- libmetal version: 1.1.0 (D:/VSCodePrograms/broadcaster)
-- Build type:
-- Machine: arm
-- Machine: arm
-- Configuring done
-- Generating done
[1/244] Creating directories for 'hci_rpmsg_subimage'
[2/244] No download step for 'hci_rpmsg_subimage'
[3/244] No update step for 'hci_rpmsg_subimage'
[4/244] No patch step for 'hci_rpmsg_subimage'
[5/244] No configure step for 'hci_rpmsg_subimage'
[5/244] Performing build step for 'hci_rpmsg_subimage'
[6/244] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
FAILED: modules/nrf/samples/hci_rpmsg_subimage-prefix/src/hci_rpmsg_subimage-stamp/hci_rpmsg_subimage-build hci_rpmsg/zephyr/zephyr.hex hci_rpmsg/zephyr/zephyr.elf hci_rpmsg/zephyr/merged_CPUNET.hex
cmd.exe /C "cd /D D:\VSCodePrograms\broadcaster\build\hci_rpmsg && C:\ncs\v1.9.1\toolchain\opt\bin\cmake.exe --build . --"
[8/244] Generating include/generated/driver-validation.h
[9/244] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
ninja: error: 'C:/ncs/v1.9.1/nrfxlib/softdevice_controller/lib/cortex-m33+nodsp/soft-float/libsoftdevice_controller_.a', needed by 'zephyr/zephyr_pre0.elf', missing and no known rule to make it
[10/244] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
FATAL ERROR: command exited with status 1: 'c:\ncs\v1.9.1\toolchain\opt\bin\cmake.EXE' --build 'd:\VSCodePrograms\broadcaster\build'
The terminal process terminated with exit code: 1.
Terminal will be reused by tasks, press any key to close it.
> Executing task: nRF Connect: Generate config nrf5340dk_nrf5340_cpuapp for d:\VSCodePrograms\beacon <
Building beacon
west build --build-dir d:\VSCodePrograms\beacon\build d:\VSCodePrograms\beacon --pristine --board nrf5340dk_nrf5340_cpuapp -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="d:/VSCodePrograms/broadcaster;d:/VSCodePrograms/beacon"
-- Application: D:/VSCodePrograms/beacon
-- Board: nrf5340dk_nrf5340_cpuapp
-- Found BOARD.dts: C:/ncs/v1.9.1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
-- Generated zephyr.dts: D:/VSCodePrograms/beacon/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: D:/VSCodePrograms/beacon/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: D:/VSCodePrograms/beacon/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: D:/VSCodePrograms/beacon/build/zephyr/dts.cmake
Loaded configuration 'C:/ncs/v1.9.1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration 'D:/VSCodePrograms/beacon/prj.conf'
Configuration saved to 'D:/VSCodePrograms/beacon/build/zephyr/.config'
Kconfig header saved to 'D:/VSCodePrograms/beacon/build/zephyr/include/generated/autoconf.h'
loading initial cache file D:/VSCodePrograms/beacon/build/hci_rpmsg/child_image_preload.cmake
-- Board: nrf5340dk_nrf5340_cpunet
-- Found BOARD.dts: C:/ncs/v1.9.1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet.dts
-- Generated zephyr.dts: D:/VSCodePrograms/beacon/build/hci_rpmsg/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: D:/VSCodePrograms/beacon/build/hci_rpmsg/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: D:/VSCodePrograms/beacon/build/hci_rpmsg/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: D:/VSCodePrograms/beacon/build/hci_rpmsg/zephyr/dts.cmake
Loaded configuration 'C:/ncs/v1.9.1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet_defconfig'
Configuration saved to 'D:/VSCodePrograms/beacon/build/hci_rpmsg/zephyr/.config'
Kconfig header saved to 'D:/VSCodePrograms/beacon/build/hci_rpmsg/zephyr/include/generated/autoconf.h'
-- Build type:
-- Machine: arm
-- Machine: arm
-- Configuring done
-- Generating done
-- Build files have been written to: D:/VSCodePrograms/beacon/build/hci_rpmsg
-- libmetal version: 1.1.0 (D:/VSCodePrograms/beacon)
-- Build type:
-- Machine: arm
-- Machine: arm
-- Configuring done
-- Generating done
[1/238] Creating directories for 'hci_rpmsg_subimage'
[2/238] No download step for 'hci_rpmsg_subimage'
[3/238] No update step for 'hci_rpmsg_subimage'
[4/238] No patch step for 'hci_rpmsg_subimage'
[5/238] No configure step for 'hci_rpmsg_subimage'
[5/238] Performing build step for 'hci_rpmsg_subimage'
[6/238] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
cmd.exe /C "cd /D D:\VSCodePrograms\beacon\build\hci_rpmsg && C:\ncs\v1.9.1\toolchain\opt\bin\cmake.exe --build . --"
[8/238] Generating include/generated/driver-validation.h
[9/238] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[10/238] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
FATAL ERROR: command exited with status 1: 'c:\ncs\v1.9.1\toolchain\opt\bin\cmake.EXE' --build 'd:\VSCodePrograms\beacon\build'
I'm getting this error when building sample program broadcaster in VS Code for nRF5340 DK. When building, it is not taking as compatible board. Is sample program nRF5340 compatible? Or any thing missed in installation?
Any support will be appreciated.
    Another thing: could you give me the prj.conf file of your broadcaster project, as well as you autoconf.h if you have one? (it should be in the folder  build/zephyr/include/generated/).
    Yashwanth said:
    I don't know the reason that SDKs installed from Tool chain Manager are missing some folders when I installed.
    So the same error is showing, but additionally that folder is missing? That is strange. I have heard others experiencing the same thing, but simply re-installing fixes it all. The issue might be related to downloading through a VPN or a proxy.
    Elfving
