nRF9160 HTTP clien slow response
hi:
Use the https_client routine to send data after the socket is established, and then send the data after getting the response. The errno returns as 128, which can confirm that the cloud platform is not disconnected. In addition, the time from sending the request to getting the response is nearly 2 minutes, which is too long to receive. How can I improve the problem I'm encountering now, thank you
void main(void)
int err;
int fd;
char *p;
int bytes;
size_t off;
struct addrinfo *res;
struct addrinfo hints = {
.ai_family = AF_INET,
.ai_socktype = SOCK_STREAM,
struct timeval timeout;//666
int data_len;
uint32_t connect_attempt = 0;
printk("http link onenet sample started\n\r");
printk("Waiting for network.. ");
do{
err = lte_lc_init_and_connect();
if (err) {
printk("Failed to connect to the LTE network, err %d\n", err);
k_sleep(K_SECONDS(CONFIG_HTTP_RECONNECT_DELAY_S));
}while(err);
printk("OK\n");
if (connect_attempt++ > 0) {
printk("Reconnecting in %d seconds...",CONFIG_HTTP_RECONNECT_DELAY_S);
err = getaddrinfo(HTTP_HOSTNAME, NULL, &hints, &res);
if (err) {
printk("getaddrinfo() failed, err %d\n", errno);
goto clean_up;
((struct sockaddr_in *)res->ai_addr)->sin_port = htons(HTTP_PORT);
if (IS_ENABLED(CONFIG_SAMPLE_TFM_MBEDTLS)) {
fd = socket(AF_INET, SOCK_STREAM | SOCK_NATIVE_TLS, IPPROTO_TLS_1_2);
} else {
fd = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);// IPPROTO_TLS_1_2
if (fd == -1) {
printk("Failed to open socket!\n");
goto clean_up;
/*666*/
timeout.tv_sec = WEBCLIENT_DEFAULT_TIMEO;
timeout.tv_usec = 0;
/* set recv timeout option */
setsockopt(fd, SOL_SOCKET, SO_RCVTIMEO, (void*) &timeout,
sizeof(timeout));
//setsockopt(fd, SOL_SOCKET, SO_SNDTIMEO, (void*) &timeout,
// sizeof(timeout));
/*666*/
/* Setup TLS socket options */
//err = tls_setup(fd);
//if (err) {
// goto clean_up;
printk("Connecting to %s\n", HTTP_HOSTNAME);
err = connect(fd, res->ai_addr, sizeof(struct sockaddr_in));
if (err) {
printk("connect() failed, err: %d\n", errno);
goto clean_up;
data_len = snprintf(send_buf,SEND_BUF_SIZE,"%s",HTTP_GET_DETECT);
off = 0;
do {
bytes = send(fd, &send_buf[off], data_len - off, 0);
if (bytes < 0) {
printk("send() failed, err %d\n", errno);
goto clean_up;
off += bytes;
} while (off < data_len);
printk("Sent %d bytes\n", off);
off = 0;
do {
bytes = recv(fd, &recv_buf[off], RECV_BUF_SIZE - off, 0);
if (bytes < 0) {
printk("recv() failed, err %d\n", errno);
goto clean_up;
off += bytes;
} while (bytes != 0 /* peer closed connection */);
printk("Received %d bytes\n", off);
/* Print HTTP response */
p = strstr(recv_buf, "\r\n");
if (p) {
off = p - recv_buf;
recv_buf[off + 1] = '\0';
printk("\n>\t %s\n\n", recv_buf);
off = 0;
do {
if (bytes < 0) {
printk("2.send() failed, err %d\n", errno);
goto clean_up;
off += bytes;
printk("2.Sent %d bytes\n", off);
off = 0;
do {
if (bytes < 0) {
printk("2.recv() failed, err %d\n", errno);
goto clean_up;
off += bytes;
printk("2.Received %d bytes\n", off);
if (p) {
off = p - recv_buf;
printk("Finished, closing socket.\n");
clean_up:
freeaddrinfo(res);
(void)close(fd);
lte_lc_power_off();
  • void main(void)
    int err;
    int fd;
    char *p;
    int bytes;
    size_t off;
    int data_len;
    int link_status = 0;
    int recv_data_len = 0;
    int result;
    //int result_bit;
    cJSON *root = NULL, *object = NULL, *item = NULL;
    epd_spi_init();
    //k_sched_lock();
    epd_init();
    As in the above code, when the modem is turned on, epd_init() is executed,
    Will other tasks interrupt the execution of epd_init()?
    If so, how to protect it. In my project, there are no other threads.
    When the modem function is turned on, it takes a long time to boot to the application, it takes four minutes, is this normal?
    If Failed to open socket occurs, I find that calling lte_lc_init_and_connect() has no effect. Do I need to power off and restart the modem at this time?
    You need to evaluate your own firmware and how it runs in general.
    Any interrupt that occurs in your application can potentially interrupt that function. However, it seems that very little else is running in your main function at the time of calling that function.
    It can be if you're waiting for the LTE Link to connect, ie. if CONFIG_LTE_AUTO_INIT_AND_CONNECT is set to 'y'.
    Calling that function again will not help. You're already enabled and have previously been connected, and the modem is highly likely trying to reconnect to the network. However:
    Without any debug information about the link status at this time, it is hard to say what happens.
    Please see my former responses on how to get detailed information about your link, ie. via CEREG or possibly the lte_lc handler.
    Håkon
  • CONFIG_LTE_AUTO_INIT_AND_CONNECT is set to 'n' in my project.
    When "Failed to open socket" appears, I make socket link every 20 seconds, but can't recover from "Failed to open socket", what should I do?
    When CONFIG_LTE_AUTO_INIT_AND_CONNECT is set to 'y', when "Failed to open socket" appears, it will always stop at "Failed to open socket" and cannot be recovered.
  • If you do not properly close() former sockets, this can happen. Is your code updated compared to the initial code you posted? if yes, can you share the updated project?
    Have you implemented the event handler for the lte_lc library, which can give you notifications on what is happening on the network side?
    Håkon
