Sending I2S data via BLE using queue
I am writing an application that reads data from the I2S interface, adds it to a queue and sends it via BLE (the code I have implemented so far is added at the end of this post).
In a previous thread (https://devzone.nordicsemi.com/f/nordic-q-a/87656/create-custom-event-to-trigger-updating-data-in-gatt-table), I have reached a state where I am able to send arbitrary data via BLE. I also know that reading data from the I2S works. However, integrating those parts into one application causes the application to run into an error (all 4 LEDs on my nRF52 DK are on).
EDIT: For clarification: the nRF is advertising and I can connect to it from nRF Connect for Desktop and Mobile. The problem starts when I enable notifications and the code, thereby, enters the if-clause in line 46 in my main function (i2s_transfer becomes true).
The code is based on the ble_app_template and the I2S loopback example. I'm using the nRF52 DK, nRF5 SDK 17.1.0 with S132 and Segger emStudio 5.42a.
Could there be too many interrupts that call the data_handler so that the rest of the code cannot be executed (I'm sampling with ~ 44 kHz, so the buffer of 256 bytes will be filled quickly)? I'm also thinking that the allocated RAM could be insufficient (I attach my section placement macros below).
Can anybody suggest a fix that I can try or an alternative implementation to achieve what I have mentioned above? Any help is appreciated.
CODE:
The section placement macros:
FLASH_PH_START=0x0
FLASH_PH_SIZE=0x80000
RAM_PH_START=0x20000000
RAM_PH_SIZE=0x10000
FLASH_START=0x26000
FLASH_SIZE=0x5a000
RAM_START=0x20002ad8
RAM_SIZE=0xd528
Here are the relevant declarations:
#define I2S_DATA_BLOCK_WORDS    256
static uint32_t m_buffer_rx[2][I2S_DATA_BLOCK_WORDS];
static uint32_t m_buffer_tx[2][I2S_DATA_BLOCK_WORDS];
NRF_QUEUE_DEF(uint8_t, m_queue, 3072, NRF_QUEUE_MODE_OVERFLOW);
uint8_t m_array[244] = {0};
Here is my main function:
/**@brief Function for application main entry.
    bool erase_bonds;
    uint8_t err_code;
    // Initialize.
    log_init();
    timers_init();
    power_management_init();
    // Initialize TWI/ I2C & Setup ADC
    twi_adc_configuration();
    // Initialize i2s
    err_code = i2s_init();
    if (err_code == NRF_SUCCESS)
        NRF_LOG_INFO("I2S successfully initialized.");
        NRF_LOG_INFO("Error initializing I2S.");
    // Initialize BLE
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
    NRF_LOG_INFO("Template example started.");
    // Start advertising
    advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
        if (i2s_transfer)
            // start i2s
            err_code = start_i2s();
                NRF_LOG_INFO("I2S started");
                NRF_LOG_INFO("Failed starting I2S");
            if (nrf_queue_utilization_get(&m_queue) >= 244)
                // get data from the queue
                err_code = nrf_queue_read(&m_queue, &m_array, sizeof(m_array));
                if ((err_code != NRF_SUCCESS) &&
                        (err_code != NRF_ERROR_INVALID_STATE) &&
                        (err_code != NRF_ERROR_BUSY) &&
                        (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
                // send data via BLE
                err_code = ble_aas_value_update(&m_aas, &m_array);
                if (err_code == NRF_ERROR_RESOURCES)
                    NRF_LOG_DEBUG("error resources");
                    if (ble_ready != true)
                        idle_state_handle();
                    ble_ready = false;
    nrf_drv_i2s_stop();
    NRF_LOG_FLUSH();
    bsp_board_leds_off();
My start_i2s function:
int start_i2s()
    uint32_t err_code = NRF_SUCCESS;
    nrf_drv_i2s_buffers_t const initial_buffers = {
        .p_tx_buffer = NULL,
        .p_rx_buffer = m_buffer_rx[0],
    err_code = nrf_drv_i2s_start(&initial_buffers, I2S_DATA_BLOCK_WORDS, 0);
    return err_code;
and my data handler:
static void data_handler(nrf_drv_i2s_buffers_t const * p_released,
                         uint32_t                      status)
    // 'nrf_drv_i2s_next_buffers_set' is called directly from the handler
    // each time next buffers are requested, so data corruption is not
    // expected.
    ASSERT(p_released);
    // When the handler is called after the transfer has been stopped
    // (no next buffers are needed, only the used buffers are to be
    // released), there is nothing to do.
    if (!(status & NRFX_I2S_STATUS_NEXT_BUFFERS_NEEDED))
        return;
    // First call of this handler occurs right after the transfer is started.
    // No data has been transferred yet at this point, so there is nothing to
    // check. Only the buffers for the next part of the transfer should be
    // provided.
    if (!p_released->p_rx_buffer)
        // .p_tx_buffer = m_buffer_tx[1] changed to .p_tx_buffer = NULL, since we only receive data
        nrf_drv_i2s_buffers_t const next_buffers = {
            .p_rx_buffer = m_buffer_rx[1],
        APP_ERROR_CHECK(nrf_drv_i2s_next_buffers_set(&next_buffers));
        uint16_t i;
        uint32_t const * p_word = NULL;
        uint8_t sample[3];
        for (i = 0; i < I2S_DATA_BLOCK_WORDS; ++i)
            p_word = &mp_block_to_check[i];
            //decompose 32-bit sample and discard msb
            sample[0] = ((uint8_t const *)p_word)[0];
            sample[1] = ((uint8_t const *)p_word)[1];
            sample[2] = ((uint8_t const *)p_word)[2];
            printf("\n %2x%2x%2x", sample[0], sample[1], sample[2]);
            // copy data to the queue
            ret_code_t err_code;
            err_code = nrf_queue_write(&m_queue, &sample, sizeof(sample));
            NRF_LOG_DEBUG("data added to queue.");
        // The driver has just finished accessing the buffers pointed by
        // 'p_released'. They can be used for the next part of the transfer
        // that will be scheduled now.
        APP_ERROR_CHECK(nrf_drv_i2s_next_buffers_set(p_released));
