pc_ble_driver_py.exceptions.NordicSemiException: Extended Error 0x05: The firmware version is too low.
Using  nfutil to dfu a package to nrf52832 using dongle nrf52840 on windows 10 and python 3.8.10
Able to access nrf52832 with nrconnect desktop (but can't get dfu to work with nrfdesktop.Case ID: 290417 ) I am able to get dfu to work with nrfConnect for android.
I am running the following command
nrfutil.exe dfu ble -pkg dfu_pkg_w_bl.2.5.8.release.zip -a D27F2A70D5BE -ic NRF52 -p COM4
Result:
[------------------------------------] 0%
File "nordicsemi\__main__.py", line 1545, in <module>
File "click\core.py", line 1137, in __call__
File "click\core.py", line 1062, in main
File "click\core.py", line 1668, in invoke
File "click\core.py", line 1404, in invoke
File "click\core.py", line 763, in invoke
File "nordicsemi\__main__.py", line 1205, in ble
File "nordicsemi\dfu\dfu.py", line 115, in dfu_send_images
File "nordicsemi\dfu\dfu.py", line 95, in _dfu_send_image
File "nordicsemi\dfu\dfu_transport_ble.py", line 526, in send_init_packet
File "nordicsemi\dfu\dfu_transport_ble.py", line 607, in __execute
File "nordicsemi\dfu\dfu_transport_ble.py", line 682, in __get_response
pc_ble_driver_py.exceptions.NordicSemiException: Extended Error 0x05: The firmware version is too low. For an application, the version must be greater than or equal to the current application. For a bootloader, it must be greater than the current version. This requirement prevents downgrade attacks.
[3372] Failed to execute script '__main__' due to unhandled exception!
The firmware revision string for the application on nrf52832 is 2.5.7
The firmware in the zip file is 2.5.8
I don't understand the error "firmware revision is to low.
Note:   The dongle is programmed with: Connectivity firmware version: ble-connectivity 4.1.4+Mar-11-2021-08-36-04. SoftDevice API version: 5. Baud rate: 1000000.
Please advise.
  • Thank you Vidar.
      1)I would like to make sure I understand the solution of running nrfutil two times.   The idea is that if the bootloader version is the same as the existing version, it can be rejected.  Then the second execution of nrfutil containing the  application download could proceed without error.  Do I understand your idea correctionly?
    2) I have a related issue that I need to mention.  We modify  bootloader code to also   transfer  firmware from the nordic chip to another chip that lacks bluetooth.  Sometimes we modify our code and in our version control system, the bootloader has a new version.    However, when I run nrfutil with this "updated bootloader",  the bootloader rejects it. Can you provide info on what needs to modified in the bootloader code so that the bootloader detects it as a new verision.
  • 1) Yes, your understanding is correct.
    2) Does the bootloader return any error codes? It could be that the new bootloader is to large to fit into the existing bootloader region (Memory layout). An important thing to note about bootloader updates is that you cannot change the start address through DFU, effectively limiting the size of future updates to the size initially allocated to your bootloader region.
    Does the new bootloader have the same start address in FLASH?
  • I am all set.  You can mark this issue as closed.  I forgot that i can't download a lower version of the bootloader thru ota.  I loaded lower version of bootloarder and firmware thru j-link and and able to OTA a higher version of bootloader and firmware.  This issue is resolved.
