Multilink Central/Peripherals ID
Hello everyone,
I am working with the SDK v17.1.0 with the DK nRF52832 with the examples of ble_app_uart and ble_app_uart_c.
I want to have several peripheral boards that send data to a central board.
But I also want to have control over the slave I am questionning, so I want each slave to have its own ID.
First I looked on
Thank you everyone!
  • Hello, thank you for the answer.
    I am having trouble to built the array. In one hand, I have the conn_handle which is a hexadecimal value  that I need to put on the first line of the array and on the other hand, I have the MAC address of 6 bytes that I need to put on the second line of the array.
    I tried to create my own type based on a char but I only print nonsense
    Hee is the code I tried:
    #define MAX_MAC_HANDLE_MAP_LENGTH 100
    typedef char addr;
    static addr mac_handle_map[2][MAX_MAC_HANDLE_MAP_LENGTH] = {"0"}; /**< Array of MAC address corresponding with connection handle
    with 20 devices max */
    static addr mac_addr_str[6], conn_handle_str[6];
    sprintf(mac_addr_str, "%02x%02x%02x%02x%02x%02x",
    p_connected->peer_addr.addr[0],
    p_connected->peer_addr.addr[1],
    p_connected->peer_addr.addr[2],
    p_connected->peer_addr.addr[3],
    p_connected->peer_addr.addr[4],
    p_connected->peer_addr.addr[5]
    sprintf(conn_handle_str, "%x", p_scan_evt->params.connected.conn_handle);
    //NRF_LOG_INFO("%s\n\n\n", conn_handle_str);
    //NRF_LOG_INFO("%s\n\n\n", mac_addr_str);
    mac_handle_map[0][p_scan_evt->params.connected.conn_handle] = conn_handle_str;
    mac_handle_map[1][p_scan_evt->params.connected.conn_handle] = mac_addr_str;
    NRF_LOG_INFO("Handler %s with MAC address %s\n\n\n",
    mac_handle_map[0][p_scan_evt->params.connected.conn_handle],
    mac_handle_map[1][p_scan_evt->params.connected.conn_handle]);
    Would something like this work:
    static ble_gap_addr_t m_mac_handle_map[NRF_SDH_BLE_TOTAL_LINK_COUNT];
    /**@brief Function for handling Scanning Module events.
    static void scan_evt_handler(scan_evt_t const * p_scan_evt)
        ret_code_t err_code;
        switch(p_scan_evt->scan_evt_id)
             case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
                  err_code = p_scan_evt->params.connecting_err.err_code;
             } break;
             case NRF_BLE_SCAN_EVT_CONNECTED:
                 uint16_t conn_handle = p_scan_evt->params.connected.conn_handle;
                 ble_gap_evt_connected_t const * p_connected =
                                   p_scan_evt->params.connected.p_connected;
                 NRF_LOG_INFO("Connection handle 0x%x",
                 memcpy(&m_mac_handle_map[conn_handle], &p_connected->peer_addr,
                    sizeof(m_mac_handle_map[0]));
                 // Scan is automatically stopped by the connection.
                 NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
             } break;
    ? I'm simply using the connection handle as the array index. I'm also not converting the address to a hex string.
    Yes it works fine, thank you very much!
