Panic, when playing music
Hi
I have build a sample project nRF5430_audio for nRF5340 Auido DK(two DK, one for gateway, one for headset), following the guide:nRF5340 Audio — nRF Connect SDK 2.0.99 documentation (nordicsemi.com)
build the project:
python buildprog.py -c both -b debug -d both -p
add following to prj.conf
CONFIG_SW_CODEC_SBC=y
CONFIG_AUDIO_SOURCE_USB=y
CONFIG_TRANSPORT_CIS=y
after streaming for a while,the headset will panic:
HL [00:08:42.849,517] <wrn> audio_datapath: Invalid sdu_ref_us delta (9983) - Estimating sdu_ref_us
HL [00:08:44.309,600] <wrn> audio_datapath: Invalid sdu_ref_us delta (9983) - Estimating sdu_ref_us
HL [00:08:53.321,838] <wrn> sw_codec_select: PCM samples dropped
HL [00:08:53.321,868] <err> audio_datapath: Decoded audio has wrong size
HL [00:08:53.321,868] <err> audio_datapath: ERR_CHK Err_code: [-140] @ line: 815
HL [00:08:53.321,868] <err> os: r0/a1: 0x00000003 r1/a2: 0x00000003 r2/a3: 0x00000002
HL [00:08:53.321,899] <err> os: r3/a4: 0x20001e10 r12/ip: 0x00000002 r14/lr: 0x00017b85
HL [00:08:53.321,899] <err> os: xpsr: 0x41000000
HL [00:08:53.321,899] <err> os: s[ 0]: 0x00000000 s[ 1]: 0x00000000 s[ 2]: 0x00000000 s[ 3]: 0x00000000
HL [00:08:53.321,899] <err> os: s[ 4]: 0x00000000 s[ 5]: 0x00000000 s[ 6]: 0x00000000 s[ 7]: 0x00000000
HL [00:08:53.321,929] <err> os: s[ 8]: 0x00000000 s[ 9]: 0x00000000 s[10]: 0x00000000 s[11]: 0x00000000
HL [00:08:53.321,929] <err> os: s[12]: 0x00000000 s[13]: 0x00000000 s[14]: 0x00000000 s[15]: 0xffffffff
HL [00:08:53.321,929] <err> os: fpscr: 0x200002f0
HL [00:08:53.321,960] <err> os: Faulting instruction address (r15/pc): 0x0000651c
HL [00:08:53.321,960] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
HL [00:08:53.321,960] <err> os: Current thread: 0x20001688 (AUDIO DATAPATH)
HL [00:08:53.321,960] <err> error_handler: Caught system error -- reason 3. Entering infinite loop
so, i think there is a bug, is any patch for it?
thanks
  • and i will replace line815 with following:
    LOG_WRN("Wrong size of frame, mayge get a bad frame");
  • Yes, that should suffice.
    Let me know if you still experience this issue following the change!
    Karl
  • Hi, Karl
    after more than 8 hours of test, we got the following message:
    $ *** Booting Zephyr OS build v3.0.99-ncs1-rc1 ***
    HL [00:00:00.362,426] <dbg> nrf5340_audio_dk_nrf5340_cpuapp: core_config: Setting gpiote latency to r
    HL [00:00:00.362,487] <dbg> nrf5340_audio_dk_nrf5340_cpuapp: remoteproc_mgr_boot: Network MCU releas.
    HL [00:00:00.367,034] <dbg> main: main: nRF5340 APP core started
    HL [00:00:00.367,614] <inf> fw_info:
    nRF5340 Audio nRF5340 Audio DK cpuapp
    FW Version: 0.5.99
    Cmake run : Mon Jun 13 23:53:01 2022
    HL [00:00:00.367,614] <inf> fw_info: ------- DEBUG BUILD -------
    HL [00:00:00.367,645] <inf> fw_info:
    HEADSET left device
    HL [00:00:00.378,234] <dbg> board_version: version_search: Board ver search OK!. ADC reg val: 1760
    HL [00:00:00.378,234] <inf> board_version: Compatible board/HW version found: 1.0.0
    HL [00:00:00.388,824] <dbg> board_version: version_search: Board ver search OK!. ADC reg val: 1774
    HL [00:00:00.408,569] <inf> CS47L63: Tried to set supply, not supported
    HL [00:00:00.429,321] <dbg> HW_CODEC: cs47l63_comm_reg_conf_write: Busy waiting instead of writing t3
    HL [00:00:00.442,474] <wrn> bt_hci_core: Controller to host flow control not supported
    HL [00:00:00.445,281] <dbg> ble: on_bt_ready: Bluetooth initialized
    HL [00:00:00.571,197] <inf> ble: MAC: E1:28:5F:33:30:0E (random)
    HL [00:00:00.571,411] <inf> ble: Controller version: 3251
    HL [00:00:00.639,007] <dbg> HW_CODEC: cs47l63_comm_reg_conf_write: Busy waiting instead of writing t3
    HL [00:00:00.640,899] <dbg> ble: iso_bis_rx_sync_get: Start scanning...
    HL [00:00:00.642,517] <dbg> ble: iso_bis_rx_sync_get: Waiting for periodic advertising...
    HL [00:00:00.649,505] <wrn> audio_datapath: I2S RX overrun. Single msg
    HL [00:00:22.733,581] <inf> ble: Stop scanning...
    HL [00:00:22.733,947] <dbg> ble: iso_bis_rx_sync_get: Creating Periodic Advertising Sync...
    HL [00:00:22.735,870] <dbg> ble: iso_bis_rx_sync_get: Waiting for periodic sync
    HL [00:00:22.975,860] <dbg> ble: iso_bis_rx_sync_get: Periodic sync established
    HL [00:00:23.255,676] <dbg> ble: ble_trans_iso_init: Init finished
    HL [00:00:23.255,767] <dbg> audio_datapath: audio_datapath_tone_play: Tone started
    HL [00:00:23.255,798] <dbg> streamctrl: m_ble_transport_evt_handler: Received event = 0, current sta0
    HL [00:00:23.255,798] <inf> streamctrl: BLE evt connected
    HL [00:00:23.255,798] <dbg> streamctrl: m_ble_transport_evt_handler: Received event = 2, current sta1
    HL [00:00:23.255,798] <inf> streamctrl: BLE evt link ready
    HL [00:00:23.755,828] <dbg> audio_datapath: tone_stop_worker: Tone stopped
    HL [00:00:41.946,838] <dbg> streamctrl: m_button_evt_handler: Got btn evt from queue - id = 4, actio0
    HL [00:00:41.946,868] <dbg> ble: iso_bis_rx_sync_get: Already have sync, returning
    HL [00:00:41.946,868] <dbg> ble: iso_bis_rx_start: Trying to get sync...
    HL [00:00:42.017,181] <dbg> ble: iso_connected_cb: ISO Channel 0x20008f94 connected
    HL [00:00:42.017,272] <dbg> ble: iso_bis_rx_start: bt_iso_big_sync established
    HL [00:00:42.017,303] <dbg> streamctrl: m_button_evt_handler: Starting headset device
    HL [00:00:42.017,303] <dbg> streamctrl: m_ble_transport_evt_handler: Received event = 3, current sta3
    HL [00:00:42.017,303] <inf> streamctrl: BLE evt streaming
    HL [00:00:42.018,981] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:00:42.019,958] <wrn> audio_datapath: Data received, total underruns: 2
    HL [00:00:42.080,963] <wrn> audio_datapath: Data received, total underruns: 3
    HL [00:00:42.118,957] <inf> audio_datapath: Drft comp state: OFFSET
    HL [00:00:42.539,550] <inf> audio_datapath: Drft comp state: LOCKED
    HL [00:00:42.548,370] <inf> audio_datapath: Pres comp state: MEAS
    HL [00:00:42.658,355] <inf> audio_datapath: Pres comp state: WAIT
    HL [00:00:42.658,386] <dbg> audio_datapath: audio_datapath_presentation_compensation: Presentation d6
    HL [00:00:42.718,383] <inf> audio_datapath: Pres comp state: INIT
    HL [00:00:42.729,278] <inf> audio_datapath: Pres comp state: MEAS
    HL [00:00:42.838,378] <inf> audio_datapath: Pres comp state: LOCKED
    HL [00:00:56.211,059] <dbg> audio_datapath: audio_datapath_stream_out: Bad audio frame
    HL [00:00:56.211,120] <wrn> sw_codec_select: PCM samples dropped
    HL [00:00:56.211,120] <wrn> audio_datapath: Wrong size of frame, mayge get a bad frame
    HL [00:16:03.624,053] <inf> audio_datapath: sdu_ref_us not from consecutive frames
    HL [00:16:03.624,084] <inf> audio_datapath: Pres comp state: WAIT
    HL [00:16:03.625,213] <wrn> audio_datapath: Data received, total underruns: 16
    HL [00:16:03.674,072] <inf> audio_datapath: Pres comp state: INIT
    HL [00:16:03.684,051] <inf> audio_datapath: Pres comp state: MEAS
    HL [00:16:03.794,067] <inf> audio_datapath: Pres comp state: WAIT
    HL [00:16:03.794,097] <dbg> audio_datapath: audio_datapath_presentation_compensation: Presentation d7
    HL [00:16:03.854,064] <inf> audio_datapath: Pres comp state: INIT
    HL [00:16:03.864,074] <inf> audio_datapath: Pres comp state: MEAS
    HL [00:16:03.974,090] <inf> audio_datapath: Pres comp state: LOCKED
    HL [00:38:08.592,712] <dbg> audio_datapath: audio_datapath_stream_out: Bad audio frame
    HL [00:38:08.592,773] <wrn> sw_codec_select: PCM samples dropped
    HL [00:38:08.592,773] <wrn> audio_datapath: Wrong size of frame, mayge get a bad frame
    HL [00:38:59.018,371] <dbg> audio_datapath: audio_datapath_stream_out: Bad audio frame
    HL [00:38:59.018,432] <wrn> sw_codec_select: PCM samples dropped
    HL [00:38:59.018,432] <wrn> audio_datapath: Wrong size of frame, mayge get a bad frame
    HL [00:59:01.947,601] <dbg> audio_datapath: audio_datapath_stream_out: Bad audio frame
    HL [00:59:01.947,662] <wrn> sw_codec_select: PCM samples dropped
    HL [00:59:01.947,662] <wrn> audio_datapath: Wrong size of frame, mayge get a bad frame
    HL [01:30:39.962,249] <wrn> audio_datapath: In I2S TX underrun condition, total: 5000
    HL [02:04:10.084,564] <wrn> audio_datapath: In I2S TX underrun condition, total: 2015000
    HL [02:04:11.089,080] <dbg> audio_datapath: audio_datapath_stream_out: Bad audio frame
    HL [02:04:11.089,080] <inf> audio_datapath: sdu_ref_us not from consecutive frames
    HL [02:04:11.089,111] <inf> audio_datapath: Pres comp state: WAIT
    HL [02:04:11.089,141] <wrn> sw_codec_select: PCM samples dropped
    HL [02:04:11.089,172] <wrn> audio_datapath: Wrong size of frame, mayge get a bad frame
    HL [02:04:11.089,630] <wrn> audio_datapath: Data received, total underruns: 2016004
    HL [02:04:11.184,661] <inf> audio_datapath: Drft comp state: OFFSET
    HL [02:04:11.483,428] <inf> audio_datapath: Drft comp state: LOCKED
    HL [02:04:15.094,573] <wrn> audio_datapath: In I2S TX underrun condition, total: 2020000
    HL [02:25:15.171,630] <wrn> audio_datapath: In I2S TX underrun condition, total: 3280000
    HL [02:25:17.520,812] <inf> audio_datapath: sdu_ref_us not from consecutive frames
    HL [02:25:17.521,789] <wrn> audio_datapath: Data received, total underruns: 3282349
    HL [02:25:17.560,791] <inf> audio_datapath: Drft comp state: OFFSET
    HL [02:25:17.560,852] <inf> audio_datapath: Pres comp state: INIT
    HL [02:25:17.858,978] <inf> audio_datapath: Drft comp state: LOCKED
    HL [02:25:17.860,809] <inf> audio_datapath: Pres comp state: MEAS
    HL [02:25:17.970,825] <inf> audio_datapath: Pres comp state: WAIT
    HL [02:25:17.970,825] <dbg> audio_datapath: audio_datapath_presentation_compensation: Presentation d7
    HL [02:25:18.030,822] <inf> audio_datapath: Pres comp state: INIT
    HL [02:25:18.040,832] <inf> audio_datapath: Pres comp state: MEAS
    HL [02:25:18.150,817] <inf> audio_datapath: Pres comp state: LOCKED
    HL [02:46:37.444,976] <dbg> audio_datapath: audio_datapath_stream_out: Bad audio frame
    HL [02:46:37.445,037] <wrn> sw_codec_select: PCM samples dropped
    HL [02:46:37.445,037] <wrn> audio_datapath: Wrong size of frame, mayge get a bad frame
    HL [03:32:09.018,737] <inf> audio_datapath: sdu_ref_us not from consecutive frames
    HL [03:32:09.018,737] <inf> audio_datapath: Pres comp state: WAIT
    HL [03:32:09.019,897] <wrn> audio_datapath: Data received, total underruns: 3282632
    HL [03:32:09.068,725] <inf> audio_datapath: Pres comp state: INIT
    HL [03:32:09.078,735] <inf> audio_datapath: Pres comp state: MEAS
    HL [03:32:09.188,751] <inf> audio_datapath: Pres comp state: WAIT
    HL [03:32:09.188,751] <dbg> audio_datapath: audio_datapath_presentation_compensation: Presentation d7
    HL [03:32:09.248,748] <inf> audio_datapath: Pres comp state: INIT
    HL [03:32:09.258,728] <inf> audio_datapath: Pres comp state: MEAS
    HL [03:32:09.368,743] <inf> audio_datapath: Pres comp state: LOCKED
    HL [03:39:28.005,126] <inf> audio_datapath: sdu_ref_us not from consecutive frames
    HL [03:39:28.005,157] <inf> audio_datapath: Pres comp state: WAIT
    HL [03:39:28.006,317] <wrn> audio_datapath: Data received, total underruns: 3282765
    HL [03:39:28.055,145] <inf> audio_datapath: Pres comp state: INIT
    HL [03:39:28.065,155] <inf> audio_datapath: Pres comp state: MEAS
    HL [03:39:28.175,140] <inf> audio_datapath: Pres comp state: WAIT
    HL [03:39:28.175,170] <dbg> audio_datapath: audio_datapath_presentation_compensation: Presentation d7
    HL [03:39:28.235,168] <inf> audio_datapath: Pres comp state: INIT
    HL [03:39:28.245,178] <inf> audio_datapath: Pres comp state: MEAS
    HL [03:39:28.355,163] <inf> audio_datapath: Pres comp state: LOCKED
    HL [03:46:18.599,792] <inf> audio_datapath: sdu_ref_us not from consecutive frames
    HL [03:46:18.599,822] <inf> audio_datapath: Pres comp state: WAIT
    HL [03:46:18.600,952] <wrn> audio_datapath: Data received, total underruns: 3282798
    HL [03:46:18.649,810] <inf> audio_datapath: Pres comp state: INIT
    HL [03:46:18.659,790] <inf> audio_datapath: Pres comp state: MEAS
    HL [03:46:18.769,805] <inf> audio_datapath: Pres comp state: WAIT
    HL [03:46:18.769,805] <dbg> audio_datapath: audio_datapath_presentation_compensation: Presentation d7
    HL [03:46:18.829,803] <inf> audio_datapath: Pres comp state: INIT
    HL [03:46:18.839,813] <inf> audio_datapath: Pres comp state: MEAS
    HL [03:46:18.949,829] <inf> audio_datapath: Pres comp state: LOCKED
    HL [04:01:11.272,827] <dbg> audio_datapath: audio_datapath_stream_out: Bad audio frame
    HL [04:01:11.272,888] <wrn> sw_codec_select: PCM samples dropped
    HL [04:01:11.272,888] <wrn> audio_datapath: Wrong size of frame, mayge get a bad frame
    HL [04:55:04.378,692] <dbg> audio_datapath: audio_datapath_stream_out: Bad audio frame
    HL [04:55:04.378,753] <wrn> sw_codec_select: PCM samples dropped
    HL [04:55:04.378,753] <wrn> audio_datapath: Wrong size of frame, mayge get a bad frame
    HL [04:55:04.828,735] <dbg> audio_datapath: audio_datapath_stream_out: Bad audio frame
    HL [04:55:04.828,796] <wrn> sw_codec_select: PCM samples dropped
    HL [04:55:04.828,796] <wrn> audio_datapath: Wrong size of frame, mayge get a bad frame
    HL [04:55:05.388,732] <dbg> audio_datapath: audio_datapath_stream_out: Bad audio frame
    HL [04:55:05.388,763] <wrn> sw_codec_select: PCM samples dropped
    HL [04:55:05.388,793] <wrn> audio_datapath: Wrong size of frame, mayge get a bad frame
    HL [04:55:06.148,773] <dbg> audio_datapath: audio_datapath_stream_out: Bad audio frame
    HL [04:55:06.148,834] <wrn> sw_codec_select: PCM samples dropped
    HL [04:55:06.148,834] <wrn> audio_datapath: Wrong size of frame, mayge get a bad frame
    HL [04:55:10.209,075] <dbg> audio_datapath: audio_datapath_stream_out: Bad audio frame
    HL [04:55:10.209,136] <wrn> sw_codec_select: PCM samples dropped
    HL [04:55:10.209,136] <wrn> audio_datapath: Wrong size of frame, mayge get a bad frame
    HL [06:40:45.324,523] <dbg> audio_datapath: audio_datapath_stream_out: Bad audio frame
    HL [06:40:45.324,584] <wrn> sw_codec_select: PCM samples dropped
    HL [06:40:45.324,584] <wrn> audio_datapath: Wrong size of frame, mayge get a bad frame
    HL [06:59:24.373,840] <dbg> audio_datapath: audio_datapath_stream_out: Bad audio frame
    HL [06:59:24.373,901] <wrn> sw_codec_select: PCM samples dropped
    HL [06:59:24.373,901] <wrn> audio_datapath: Wrong size of frame, mayge get a bad frame
    maybe it useful for you
    thanks
  • Thank you for the update - I am glad to see that you were able to test for 8 hours continuously with so few bad frames / issues.
    Please do not hesitate to open a new ticket if you should encounter any issues or questions in the future.
    Good luck with your development! :)
    Karl
  • Hi, Karl
    ok, next we will test the LC3 codec
    thanks
