Failure in creating device certificate & provisioning it
I am creating device certificate as per steps mentioned at
https://nordicsemiconductor.github.io/asset-tracker-cloud-docs/saga/docs/azure/GettingStarted/DeviceCredentials.html
Create root & intermediate certificates works fine,
But when we issue
node cli create-and-provision-device-cert
to create device certificate & provision it, it results in failure as follows:
node cli create-and-provision-device-cert --dk --debug --delete-private-key
Flasing certificate /dev/ttyACM0
Connecting to /dev/ttyACM0
Inactivity timeout 10 seconds
ERROR create-and-provision-device-cert failed!
ERROR Readline is not a constructor
Using Ubunto 20.x lts, using asset tracker 1.9x , firmware is created fine, it also works if I generate certificate using microsoft method for testing.
@oys Let me know if you need more information
  • Hi Pramod,
    A correct run should look like this:
    $ node cli create-and-provision-device-cert --dk --debug --delete-private-key
    /dev/ttyACM0 connected
    AT Host h
    w4 4001e504 2
    w4 4001e50c 1
    sleep 100
    rx 1000
    h
    w4 4001e504 1
    loadfile /home/mata/nrf-asset-tracker/azure/node_modules/@nordicsemiconductor/firmware-ci-device-helpers/at_host/91dk_at_host_increased_buf.hex
    rx 1000
    g
    exit
    AT Host SEGGER J-Link Commander V7.64 (Compiled Apr  1 2022 16:09:33)
    AT Host DLL version V7.64, compiled Apr  1 2022 16:09:18
    AT Host J-Link Command File read successfully.
    AT Host Processing script file...
    AT Host J-Link>h
    AT Host J-Link connection not established yet but required for command.
    AT Host Connecting to J-Link via USB...
    AT Host O.K.
    AT Host Firmware: J-Link OB-K22-NordicSemi compiled Dec  3 2021 15:46:55
    AT Host Hardware version: V1.00
    AT Host S/N: 960013621
    AT Host License(s): RDI, FlashBP, FlashDL, JFlash, GDB
    AT Host VTref=3.300V
    AT Host Target connection not established yet but required for command.
    AT Host Device "NRF9160_XXAA" selected.
    AT Host Connecting to target via SWD
    AT Host ConfigTargetSettings() start
    AT Host ---Setting ROM table---
    AT Host ConfigTargetSettings() end
    AT Host Found SW-DP with ID 0x6BA02477
    AT Host DPIDR: 0x6BA02477
    AT Host CoreSight SoC-400 or earlier
    AT Host Scanning AP map to find all available APs
    AT Host AP[7]: Stopped AP scan as end of AP map has been reached
    AT Host AP[0]: AHB-AP (IDR: 0x84770001)
    AT Host AP[1]: AHB-AP (IDR: 0x24770011)
    AT Host AP[2]: JTAG-AP (IDR: 0x12880000)
    AT Host AP[3]: APB-AP (IDR: 0x54770002)
    AT Host AP[4]: JTAG-AP (IDR: 0x12880000)
    AT Host AP[5]: JTAG-AP (IDR: 0x12880000)
    AT Host AP[6]: MEM-AP (IDR: 0x128800A1)
    AT Host Iterating through AP map to find AHB-AP to use
    AT Host AP[0]: Core found
    AT Host AP[0]: AHB-AP ROM base: 0xE00FF000
    AT Host CPUID register: 0x410FD212. Implementer code: 0x41 (ARM)
    AT Host Feature set: Mainline
    AT Host Found Cortex-M33 r0p2, Little endian.
    AT Host FPUnit: 8 code (BP) slots and 0 literal slots
    AT Host Security extension: implemented
    AT Host Secure debug: enabled
    AT Host CoreSight components:
    AT Host ROMTbl[0] @ E00FF000
    AT Host [0][0]: E000E000 CID B105900D PID 000BBD21 DEVARCH 47702A04 DEVTYPE 00 Cortex-M33
    AT Host [0][1]: E0001000 CID B105900D PID 000BBD21 DEVARCH 47701A02 DEVTYPE 00 DWT
    AT Host [0][2]: E0002000 CID B105900D PID 000BBD21 DEVARCH 47701A03 DEVTYPE 00 FPB
    AT Host [0][3]: E0000000 CID B105900D PID 000BBD21 DEVARCH 47701A01 DEVTYPE 43 ITM
    AT Host [0][5]: E0041000 CID B105900D PID 002BBD21 DEVARCH 47724A13 DEVTYPE 13 ETM
    AT Host [0][6]: E0042000 CID B105900D PID 000BBD21 DEVARCH 47701A14 DEVTYPE 14 CSS600-CTI
    AT Host Cortex-M33 identified.
    AT Host PC = 0002FB1E, CycleCnt = 00121090
    AT Host R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000001
    AT Host R4 = 20017208, R5 = 2001E25D, R6 = 00000000, R7 = 00000000
    AT Host R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000
    AT Host R12= AAAAAAAA
    AT Host SP(R13)= 20023E18, MSP= 20024628, PSP= 20023E18, R14(LR) = 00046153
    AT Host XPSR = 61000000: APSR = nZCvq, EPSR = 01000000, IPSR = 000 (NoException)
    AT Host CFBP = 02000001, CONTROL = 02, FAULTMASK = 00, BASEPRI = 00, PRIMASK = 01
    AT Host MSPLIM = 20023E28
    AT Host PSPLIM = 20023CE8
    AT Host Security extension regs:
    AT Host MSP_S = 20002EC8, MSP_NS = 20024628
    AT Host MSPLIM_S = 200026C8, MSPLIM_NS = 20023E28
    AT Host PSP_S = 200024A8, PSP_NS = 20023E18
    AT Host PSPLIM_S = 20001588, PSPLIM_NS = 20023CE8
    AT Host CONTROL_S  = 02, FAULTMASK_S  = 00, BASEPRI_S  = 00, PRIMASK_S  = 00
    AT Host CONTROL_NS = 02, FAULTMASK_NS = 00, BASEPRI_NS = 00, PRIMASK_NS = 01
    AT Host FPS0 = 00000000, FPS1 = 00000000, FPS2 = 00000000, FPS3 = 00000000
    AT Host FPS4 = 00000000, FPS5 = 00000000, FPS6 = 00000000, FPS7 = 00000000
    AT Host FPS8 = 00000000, FPS9 = 00000000, FPS10= 00000000, FPS11= 00000000
    AT Host FPS12= 00000000, FPS13= 00000000, FPS14= 00000000, FPS15= 00000000
    AT Host FPS16= 00000000, FPS17= 00000000, FPS18= 00000000, FPS19= 00000000
    AT Host FPS20= 00000000, FPS21= 00000000, FPS22= 00000000, FPS23= 00000000
    AT Host FPS24= 00000000, FPS25= 00000000, FPS26= 00000000, FPS27= 00000000
    AT Host FPS28= 00000000, FPS29= 00000000, FPS30= 00000000, FPS31= 00000000
    AT Host FPSCR= 00000000
    AT Host J-Link>w4 4001e504 2
    AT Host Writing 00000002 -> 4001E504
    AT Host J-Link>w4 4001e50c 1
    AT Host Writing 00000001 -> 4001E50C
    AT Host J-Link>sleep 100
    AT Host Sleep(100)
    AT Host J-Link>rx 1000
    AT Host Reset delay: 1000 ms
    AT Host Reset type NORMAL: Resets core & peripherals via SYSRESETREQ & VECTRESET bit.
    AT Host Reset: ARMv8M core with Security Extension enabled detected.
    AT Host Reset: Halt core after reset via DEMCR.VC_CORERESET.
    AT Host Reset: Reset device via AIRCR.SYSRESETREQ.
    AT Host J-Link>h
    AT Host PC = 00002108, CycleCnt = 00000000
    AT Host R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000
    AT Host R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000
    AT Host SP(R13)= 20013CE8, MSP= 20013CE8, PSP= 00000000, R14(LR) = FFFFFFFF
    AT Host XPSR = F9000000: APSR = NZCVQ, EPSR = 01000000, IPSR = 000 (NoException)
    AT Host CFBP = 00000000, CONTROL = 00, FAULTMASK = 00, BASEPRI = 00, PRIMASK = 00
    AT Host MSPLIM = 00000000
    AT Host PSPLIM = 00000000
    AT Host MSP_S = 20013CE8, MSP_NS = 00000000
    AT Host MSPLIM_S = 00000000, MSPLIM_NS = 00000000
    AT Host PSP_S = 00000000, PSP_NS = 20023E18
    AT Host PSPLIM_S = 00000000, PSPLIM_NS = 00000000
    AT Host CONTROL_S  = 00, FAULTMASK_S  = 00, BASEPRI_S  = 00, PRIMASK_S  = 00
    AT Host CONTROL_NS = 00, FAULTMASK_NS = 00, BASEPRI_NS = 00, PRIMASK_NS = 00
    AT Host J-Link>w4 4001e504 1
    AT Host Writing 00000001 -> 4001E504
    AT Host J-Link>loadfile /home/mata/nrf-asset-tracker/azure/node_modules/@nordicsemiconductor/firmware-ci-device-helpers/at_host/91dk_at_host_increased_buf.hex
    AT Host Downloading file [/home/mata/nrf-asset-tracker/azure/node_modules/@nordicsemiconductor/firmware-ci-device-helpers/at_host/91dk_at_host_increased_buf.hex]...
    AT Host Comparing flash   [000%]
    AT 010%]
    AT 010%]
    AT 050%]
    AT 100%] Done.
    AT Host Erasing flash     [000%]
    AT 040%]
    AT 045%]
    AT 100%] Done.
    AT Host Programming flash [000%]
    AT 000%]
    AT 000%]
    AT 095%]
    AT 100%] Done.
    AT Host J-Link: Flash download: Bank 2 @ 0x00000000: 2 ranges affected (94208 bytes)
    AT Host J-Link: Flash download: Total: 2.760s (Prepare: 0.122s, Compare: 0.011s, Erase: 1.286s, Program & Verify: 1.254s, Restore: 0.085s)
    AT Host J-Link: Flash download: Program & Verify speed: 73 KB/s
    AT Host O.K.
    AT Host J-Link>g
    AT Host J-Link>exit
    AT Host Script processing completed.
    /dev/ttyACM0 `��▒���/�0f2؛���q��X4t!T�Na!�"�c馗<�j)c`��q?I-~ �J!\-��    �?�r
    !\���8�
    !n�apc�
    ���`Mѥa�%l�!��!lm%i��
    !�{�*** Booting Zephyr OS build 0a904d0c176a  ***
    /dev/ttyACM0 The AT host sample started
    /dev/ttyACM0 AT> AT+CGSN=1
    /dev/ttyACM0 +CGSN: "352656100391948"
    /dev/ttyACM0 <AT +CGSN: "352656100391948"
    /dev/ttyACM0 OK
    /dev/ttyACM0 <AT OK
    IMEI: 352656100391948
    /dev/ttyACM0 AT> AT+CGMR
    /dev/ttyACM0 mfw_nrf9160_1.3.1
    /dev/ttyACM0 <AT mfw_nrf9160_1.3.1
    /dev/ttyACM0 OK
    /dev/ttyACM0 <AT OK
    /dev/ttyACM0 OK
    /dev/ttyACM0 <AT OK
    /dev/ttyACM0 AT> AT+CFUN=4
    /dev/ttyACM0 OK
    /dev/ttyACM0 <AT OK
    /dev/ttyACM0 AT> AT%CMNG=3,42,2
    /dev/ttyACM0 OK
    /dev/ttyACM0 <AT OK
    /dev/ttyACM0 AT> AT%KEYGEN=42,2,0,"CN=352656100391948","101010000"
    /dev/ttyACM0 %KEYGEN: "MIH2MIGaAgEAMBoxGDAWBgNVBAMMDzM1MjY1NjEwMDM5MTk0ODBZMBMGByqGSM49AgEGCCqGSM49AwEHA0IABMpbExoTaobz-NQv0ZRZ5EuoxycdXS-EUv23HgPLTJwiTET_luQ5-Gkd3wJqXT4LV7TYsu6jgTj_ascf-3_n0OOgHjAcBgkqhkiG9w0
    BCQ4xDzANMAsGA1UdDwQEAwIDqDAMBggqhkjOPQQDAgUAA0kAMEYCIQDiF7uUez3s29iG0S1GcuOG3B5f_yPMeAAaLhvBGQ9RsgIhAPkkgm5FxcME9d9OhbcJAsXg8n7FYH42tHW2OIUC6lf-.0oRDoQEmoQRBIVhM2dn3hQlQUDYxVDkwTViAwhgVjzEMRkIYKlggfu04JsZfjiBO
    lMf2jmjvo8mJRO0ulYft6wRsxrI9oNJQqdQ73UzJP7TZTMRRtHZQaFhA-2yKi-nYYUAcZyBt0f7LvYBzC7ufZnS7xCfNkfSpqBU5WLaTGcFfZfGkIFGBIb13L5Po3QyUh-Ay34c9bJbAqQ"
    /dev/ttyACM0 <AT %KEYGEN: "MIH2MIGaAgEAMBoxGDAWBgNVBAMMDzM1MjY1NjEwMDM5MTk0ODBZMBMGByqGSM49AgEGCCqGSM49AwEHA0IABMpbExoTaobz-NQv0ZRZ5EuoxycdXS-EUv23HgPLTJwiTET_luQ5-Gkd3wJqXT4LV7TYsu6jgTj_ascf-3_n0OOgHjAcBgkqhki
    G9w0BCQ4xDzANMAsGA1UdDwQEAwIDqDAMBggqhkjOPQQDAgUAA0kAMEYCIQDiF7uUez3s29iG0S1GcuOG3B5f_yPMeAAaLhvBGQ9RsgIhAPkkgm5FxcME9d9OhbcJAsXg8n7FYH42tHW2OIUC6lf-.0oRDoQEmoQRBIVhM2dn3hQlQUDYxVDkwTViAwhgVjzEMRkIYKlggfu04JsZf
    jiBOlMf2jmjvo8mJRO0ulYft6wRsxrI9oNJQqdQ73UzJP7TZTMRRtHZQaFhA-2yKi-nYYUAcZyBt0f7LvYBzC7ufZnS7xCfNkfSpqBU5WLaTGcFfZfGkIFGBIb13L5Po3QyUh-Ay34c9bJbAqQ"
    /dev/ttyACM0 OK
    /dev/ttyACM0 <AT OK
    /dev/ttyACM0 AT> AT+CFUN=1
    I doubt again if your device is connected. Is the Ubuntu 20.x running natively, WSL on Windows or VM? If you run Jlink, could you see the following information?
    JLinkExe
    Connecting to J-Link via USB...O.K.
    S/N: 960013621
    VTref=3.300V
    Type "connect" to establish a target connection, '?' for help
    J-Link>
    Charlie
  • $jlink
    bash: /usr/bin/jlink: No such file or directory
    Running jlink in shell gives above output, but in is installed, as you can see in attached screenshot.
    Whereas if I goto ubuntu softwares through gui, it shows segger jlink installed.
  • that was wrong command, correct out is
    $ JLinkExe
    SEGGER J-Link Commander V7.62b (Compiled Mar  8 2022 15:15:29)
    DLL version V7.62b, compiled Mar  8 2022 15:15:15
    S/N: 960042976
    VTref=3.300V
    J-Link>
  • If I use USB in JLinkExe, it shows the board, if I just use connect /dev/ttyACM0 it cant connect
    J-Link>USB
    Disconnecting from J-Link...O.K.
    S/N: 960042976
    VTref=3.300V
    I hope this helps you in finding the solution.
  • Hi Pramod,
    Does flashing the AT host manually work? And can you run AT commands? like AT+CGSN=1
    https://github.com/NordicSemiconductor/at_host-hex
    Charlie
