Using a Timer Expiry Function
Hope that works !
I want to keep perform some task periodically .. probably using tick timer of every 1 ms, so that only after every 4000ms, i can perform some task.
How do i implement it ?
Any API / example i can refer to ?
I implemented my requirement using the timer API. ..
Hi Deep,
This is quite late, BUT in kernel.h you will also find uint32_t k_uptime_get() which returns you the milliseconds since boot. This will won't be affected by changes to the SysTick configuration presumably.
/** * @brief Get system uptime. * * This routine returns the elapsed time since the system booted, * in milliseconds. * * @note * While this function returns time in milliseconds, it does * not mean it has millisecond resolution. The actual resolution depends on * @kconfig{CONFIG_SYS_CLOCK_TICKS_PER_SEC} config option. * * @return Current uptime in milliseconds. */ static inline int64_t k_uptime_get(void) { return k_ticks_to_ms_floor64(k_uptime_ticks()); }
