nRF5340 BLE transmit power
Hi Sirs,
in nRF5340, is it doable for  to adjust the power index of different channels of BLE_1M or 2M, in terms of SW code  (if there is then where? or NVRAM like setting (read-out/modify/fill back, and effective right after re-power on and won't vanish from then on until change setting doing agin?
Also it is not doable to change the power index via HCI command dynamiclly druing the test?
Thanks
WilsonChen
  • Hello Wilson Chen,
    Thank you for your patience. The summer holidays have begun here in Norway, and so DevZone is operating at reduced capacity.
    I will be handling this inquiry while Øivind is away.
    I have forwarded your follow-up questions to the developers, and I will let you know as soon as they get back to me.
    Karl
  • Hello again, Wilson Chen
    1. By mpsl_tx_power or TX power envelope, during the FCC certificate testing in between BLE 1M, 2M channels, can we set different power limit and change dynamically or need to flash FW or data in and reboot to tak effective?
    Tx power envelope can be set for every channel on every PHY separately. That means that if the customer prepares two sets of Tx power envelopes: one for BLE 1M, the other for BLE 2M, each describing the envelope to be applied for channels 0-39 when operating on a given PHY, then that should be applied dynamically.
    Thing to take into account here is that BLE Tx power is interpreted as SoC power. If any Front End Module is used, the user must calculate the envelopes on their own, offseting them with gain added by the FEM, if needed.
    2. Even BLE is hopping mode in natural, Nordic should have test command to fix the channel for power meter or spectrum analyzer reading the power (RMS), correct?
    Could you clarify what you mean by this question? Are you asking whether we have an API that will make the communication happen on a specific channel (no hopping)? If not, please clarify what you are asking about here.
    3. why the FEM (nRF21540) mode control is comoing from nRF9160 instead of nRF5340, while most control pins of nRF21540 coming from nRF5340
    The developers were not quite sure what was meant with this question, since none of the Nordic designs are using nRF9160 with a nRF5340 and nRF21540 - is this in reference to a custom board you are working with? If so, could you provide some more information about how this is set up, so that we may better advise you.
    Karl
  • For NCS v2.2.0, you now don't need to edit hci_rpmsg or create your own serialization solution.  For example, I was able to run the HCI Power Control sample app on the app core of the nRF5340 and was able to read the default TX Power with only the unmodified running on the network core.
