Toolchain bash prompt in NCS v2.0.0
I would like to be able to open a bash prompt with the nRF Connect SDK (NCS) v2.0.0 toolchain environment loaded without going through Toolchain Manager ("open bash" option).
Using NCS v1.9.1, I would run "git-bash.exe" located in the "v1.9.1/toolchain" folder. A bash prompt would open, the current directory would be the root NCS v1.9.1 folder, and I could run west commands just fin.
Using NCS v2.0.0, I run "git-bash.exe" located in the "toolchains/v2.0.0" folder. A bash prompt opens, but the current directory is "/" (the "toolchains/v2.0.0" folder) and when I run west, I get a "command not found" error. I also tried running "git-cmd.exe", which opens a command prompt, but again west is not recognized as a command.
For NCS v2.0.0, using Toolchain Manager to open bash or open command prompt works just fine.
Any suggestions? Is this a defect in NCS v2.0.0?
Thanks!
  • I did not specify, but did you start the terminal from the toolchain manager? That is always required, and is a pre-requisite for what I described in my previous post:
  • Einar,
    The point of my original post was that I would like to start a bash prompt that loads the correct Zephyr/west environment WITHOUT using Toolchain Manager. This was possible in NCS v1.9.1 by running "git-bash.exe", but this does not work in v2.0.0.
    After running "git-bash.exe in NCS v1.9.1:
    abkirchhoff@xxxxIND MINGW64 ~/NordicSdk/v1.9.1
    $ west -V
    West version: v0.12.0
    After running "git-bash.exe in NCS v2.0.0:
    abkirchhoff@xxxxIND MINGW64 /
    $ west -V
    bash: west: command not found
    Hopefully, that clarifies the issue. If an update to NCS and/or Toolchain Manager is required, that is fine, but if you have a workaround, that would be great! Using Toolchain Manager to open the bash prompt works fine, but I don't know how to re-create what it is doing to load the correct environment for the bash prompt.
  • Ah, sorry. It seems I only skimmed the original post before replying (as there is a known issue with building out of tree projects even when opening from Toolchain Manager that came to mind).
    As you write, opening the correct environment without going through the Toolchain Manager GUI was straightforward earlier, but not in 2.0.0. There has been a couple of complaints about this but we do not have any other method at the time being. That said, most of what you need should be in <Toolchain manager install location>\toolchains\v2.0.0\environment.json, so it should be possible to extract that info and put it into your own script, setting those environment variables.
  • Thanks for pointing me to the environment.json file. I was able to add that list of paths and create the other two environment variables with my own script that I can source after opening a bash prompt. I also source the "zephyr/zephyr-env.sh" file to create additional variables. Thanks again!
  • Any follow up on this? I'm suffering the same issue
