I have a nRF52840 Dongle. When I connected it for the first time to the Bluetooth Low Energy app of nRF Connect for Desktop, it loaded automatically the firmware. My question is simple: is this firmware source code available somewhere?
Have you considered other options such as using the built-in bluetooth?
If you mean the buid-in bluetooth of PC, no. I need to develop a dedicated BLE/USB dongle.
My project is composed by an inertial sensor that should send data to a PC. To avoid possible BLE compatibility issue with old OS, I think that a custom dongle is a good solution. So I need to develop a BLE central device, that communicates with my peripheral inertial sensor, with USB features and to speed up the process I was wondering if there is a good starting point around the Nordic environment.
That's it.
I agree that using the pc-ble-driver can be a good way to avoid compatibility problems across platforms. But there is another alternative which I think is easier to implement and that is if you run the Bluetooth application on the dongle itself. You can then have the application FW pass the sensor data to the PC similar to how it's done in the USBD BLE UART Example.
What do you mean? I have a BLE wireless device and it needs to comunicate with PC. So the dongle needs to have BLE as central and USB features. I think that we are talking about the same thing.
I'm using nRF Connect SDK and I can't find the example in my installation folder but I found this repository. I think it's the same concept.
Since I need a fast comunication, is the USBD the right choice? What about the guaranteed speed for USBD?
With the nRF connect ble and Dongle you are running a "Serialization" setup where the entire Bluetooth stack is being controlled by the PC (PC in this case is the same as the "Application board" illustration) So rather than writing the BLE application for the dongle using existing SDK libraries, you would have to write the Bluetooth application that interfaces with the Softdevice APIs on the PC.
Yes, equivalent sample in nRF connect SDK: Bluetooth: Central UART.
I don't have a benchmark for this and it would also depend a bit on how USB is configured. Although, it should always be faster than BLE.
