As coordinator, mlme_associate_resp from 802, MAC-lib, gives ASSERTION FAILED
I am using the 802_15_4 MAC api to configure my device as a coordinator.
After it has been configured as a coordinator I want another device to connect to it.
I can see by sniffing the channel that an association request is sent from the device and I can see that an association_indication on the coordinator is received.
When I then try to send an association response with
void mlme_associate_resp(mlme_associate_resp_t * resp);
I get an assert fault from the precompiled library:
00> <info> app: Assertion info: fsm:20004dc4,s:0,e:9
00>
00> <error> app: Assertion fault: !(p_fsm->recursion_protection == 0) line: 310 file: sys_fsm.c
00>
00> <error> app: ASSERTION FAILED at sys_fsm.c:310
Further more, the association_response is not sent and the radio stack freezes, i.e. no mlme function calls will trigger a callback.
Anyone have a clue what the assert fault is from?
I am using the structure defined in the library and I have tried both static declaration and using malloc to keep the structure in memory long enough.
Sniffer trace:
associate_indication function:
void panEnterAssociateInd(mlme_associate_ind_t *association_indication)
    ShortAddress           shortaddr;
    Capability             capability;
    mlme_associate_resp_t *associate_response;
    Boolean                adlIsUpToDate; // Associated Device List is up to date.
    Boolean                pairingIsActive;
    Boolean                isOk;
    shortaddr  = UD_ADDR_NOT_ASSIGNED;
    capability = association_indication->capability_information;
    // Allocate a reponse message.                                       .
    associate_response = (mlme_associate_resp_t*)malloc(sizeof(mlme_associate_resp_t));
    IC_ERROR_ASSERT( associate_response != NULL );
    // Fill in reponse message for association denied case.
    (void)memcpy(&associate_response->device_address, &association_indication->device_address, sizeof(mac_addr_t));
    associate_response->assoc_short_address = shortaddr;
    associate_response->status = MAC_PAN_ACCESS_DENIED;
    // Free input message.
    if ( ( capability & (1 << ALLOCATE_ADDRESS_BIT) ) == 0 )
        // Device cannot handle short addresses. Association denied.
        mlme_associate_resp(associate_response);
        return;
    adlIsUpToDate = FALSE;
    if (asDevIsMemberMac((uint8_t*)&associate_response->device_address))
        /* shortaddr = asDevGetShortAddress( resp->msgData.associateRes.deviceAddress ); */
        shortaddr = asDevGetShortAddress((uint8_t*)&associate_response->device_address);
        if ( asDevGetCapability( shortaddr ) == capability )
            // Client is already in ADL with correct capability.
            adlIsUpToDate = TRUE;
            // Client is in ADL, but with wrong capability. Remove to allow new allocation.
            asDevRemove( shortaddr );
    if ( !adlIsUpToDate )
        if ( isTemporary( capability ) )
            if ( !asDevHasFreeSlot( TRUE ) )
                // Make room for a new temporary association by cleaning old entries.
                asDevRemoveTemporary();
            // Permanent
            if ( !asDevHasFreeSlot( FALSE ) )
                // List is full. Association denied.
                return;
        // Create a new address and add to ADL.
        shortaddr       = asDevGetNextFreeShortAddress();
        pairingIsActive = ( beaconPayload.protVerAndPairing & UD_BEACON_PAIRING_MASK ) != 0;
        isOk = asDevAdd( shortaddr,
                         (uint8_t*)&associate_response->device_address,
                         capability,
                         pairingIsActive,
                         TRUE );
        if ( !isOk )
            // Failed to insert in ADL. Pairing mode mismatch? Association denied.
            return;
    // Association is granted.
    associate_response->status = MAC_ASSOCIATION_SUCCESSFUL;
    urReportEvent( RADIO_EV_PAIRED, shortaddr, uhfpGetShortAddr() );
