Zephyr WS2812 Driver undefined reference to `__device_dts_ord_68'
I am trying to implement the Ws2812 driver on the NRF5340 based on the driver example.
The specific error I am getting is:
c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: zephyr/drivers/spi/libdrivers__spi.a(spi_nrfx_spim.c.obj):(.rodata.__compound_literal.1+0x0): undefined reference to `__device_dts_ord_68'
This is similar to this post:
 Implementing WS2812 Driver NCS (undefined reference to `__device_dts_ord_61')
 It seems like there is something missing in the configuration.
prj.conf:
#	BT
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="QuantaFlo 2.0""
CONFIG_BT_DEVICE_APPEARANCE=833
CONFIG_BT_MAX_PAIRED=1
CONFIG_BT_DEBUG_LOG=y
CONFIG_BT_MAX_CONN=1
#CONFIG_BT_L2CAP_TX_BUF_COUNT=5
# This example requires more workqueue stack
CONFIG_HEAP_MEM_POOL_SIZE=2048
#	SPI
CONFIG_SPI=y
#CONFIG_NRFX_SPIM=y
#CONFIG_NRFX_SPIM4=y
CONFIG_GPIO=n
CONFIG_CPLUSPLUS=y
CONFIG_LIB_CPLUSPLUS=y
CONFIG_NEWLIB_LIBC=y
# CONFIG_CONSOLE is not set
CONFIG_GPIO_NRFX=n
#CONFIG_NRFX_GPIOTE=y
#	USB
CONFIG_USB_DEVICE_STACK=y
CONFIG_USB_DEVICE_PRODUCT="SS QF2.0"
CONFIG_LOG=y
CONFIG_USB_DRIVER_LOG_LEVEL_ERR=y
CONFIG_USB_DEVICE_LOG_LEVEL_ERR=y
CONFIG_USB_DEVICE_PID=0x0501
CONFIG_USB_DEVICE_VID=0x2047
#	Logging
CONFIG_USE_SEGGER_RTT=y
#CONFIG_LOG_BACKEND_RTT=y
#	Neopixels
CONFIG_LED_STRIP=y
CONFIG_WS2812_STRIP=y
CONFIG_LED_STRIP_LOG_LEVEL_DBG=y
The overlay file:
&spi4 {
	compatible="nordic,nrf-spim";
	status = "ok";
	sck-pin = <36>;
	mosi-pin = <41>;
	miso-pin = <25>;
&zephyr_udc0 {
	cdc_acm_uart0 {
		compatible = "zephyr,cdc-acm-uart";
		label = "CDC_ACM_0";
#include <dt-bindings/led/led.h>
#define SPI_FREQ    4000000
#define ZERO_FRAME  0x40
#define ONE_FRAME   0x70
&spi2 {
	status = "okay";
	sck-pin = <0>;
	miso-pin = <0>;
	mosi-pin = <16>;
	led_strip: ws2812@0 {
		compatible = "worldsemi,ws2812-spi";
		label = "WS2812";
		/* SPI */
		reg = <0>; /* ignored, but necessary for SPI bindings */
		spi-max-frequency = <SPI_FREQ>;
		/* WS2812 */
		chain-length = <1>; /* arbitrary; change at will */
		color-mapping = <LED_COLOR_ID_GREEN
				 LED_COLOR_ID_RED
				 LED_COLOR_ID_BLUE>;
		spi-one-frame = <ONE_FRAME>;
		spi-zero-frame = <ZERO_FRAME>;
	aliases {
		led-strip = &led_strip;
Nothing in the other linked post seemed to help.
  • /dts-v1/;
    	#address-cells = < 0x1 >;
    	#size-cells = < 0x1 >;
    	model = "Nordic NRF5340 DK NRF5340 Application";
    	compatible = "nordic,nrf5340-dk-nrf5340-cpuapp";
    	chosen {
    		zephyr,entropy = &cryptocell;
    		zephyr,flash-controller = &flash_controller;
    		zephyr,console = &uart0;
    		zephyr,shell-uart = &uart0;
    		zephyr,uart-mcumgr = &uart0;
    		zephyr,bt-mon-uart = &uart0;
    		zephyr,bt-c2h-uart = &uart0;
    		zephyr,ipc_shm = &sram0_shared;
    		zephyr,sram = &sram0_image;
    		zephyr,flash = &flash0;
    		zephyr,code-partition = &slot0_partition;
    		zephyr,sram-secure-partition = &sram0_s;
    		zephyr,sram-non-secure-partition = &sram0_ns;
    	aliases {
    		led0 = &led0;
    		led1 = &led1;
    		led2 = &led2;
    		led3 = &led3;
    		pwm-led0 = &pwm_led0;
    		sw0 = &button0;
    		sw1 = &button1;
    		sw2 = &button2;
    		sw3 = &button3;
    		bootloader-led0 = &led0;
    		status-leds = &status_leds;
    	soc {
    		compatible = "nordic,nRF5340-CPUAPP-QKAA", "nordic,nRF5340-CPUAPP", "nordic,nRF53", "simple-bus";
    		interrupt-parent = < &nvic >;
    		ranges;
    		nvic: interrupt-controller@e000e100 {
    			compatible = "arm,v8m-nvic";
    			reg = < 0xe000e100 0xc00 >;
    			interrupt-controller;
    			#interrupt-cells = < 0x2 >;
    			arm,num-irq-priority-bits = < 0x3 >;
    			phandle = < 0x1 >;
    		systick: timer@e000e010 {
    			compatible = "arm,armv8m-systick";
    			reg = < 0xe000e010 0x10 >;
    			status = "disabled";
    		ficr: ficr@ff0000 {
    			compatible = "nordic,nrf-ficr";
    			reg = < 0xff0000 0x1000 >;
    			status = "okay";
    		uicr: uicr@ff8000 {
    			compatible = "nordic,nrf-uicr";
    			reg = < 0xff8000 0x1000 >;
    			status = "okay";
    		sram0: memory@20000000 {
    			compatible = "mmio-sram";
    			reg = < 0x20000000 0x80000 >;
    		peripheral@50000000 {
    			ranges = < 0x0 0x50000000 0x10000000 >;
    			regulators: regulator@4000 {
    				compatible = "nordic,nrf-regulators";
    				reg = < 0x4000 0x1000 >;
    				status = "okay";
    			clock: clock@5000 {
    				compatible = "nordic,nrf-clock";
    				reg = < 0x5000 0x1000 >;
    				interrupts = < 0x5 0x1 >;
    				status = "okay";
    				label = "CLOCK";
    			power: power@5000 {
    				compatible = "nordic,nrf-power";
    				status = "okay";
    			i2c0: i2c@8000 {
    				#size-cells = < 0x0 >;
    				reg = < 0x8000 0x1000 >;
    				clock-frequency = < 0x186a0 >;
    				interrupts = < 0x8 0x1 >;
    				label = "I2C_0";
    			spi0: spi@8000 {
    				label = "SPI_0";
    			uart0: uart@8000 {
    				status = "okay";
    				label = "UART_0";
    				current-speed = < 0x1c200 >;
    				tx-pin = < 0x14 >;
    				rx-pin = < 0x16 >;
    				rx-pull-up;
    				rts-pin = < 0x13 >;
    				cts-pin = < 0x15 >;
    				cts-pull-up;
    			i2c1: arduino_i2c: i2c@9000 {
    				reg = < 0x9000 0x1000 >;
    				interrupts = < 0x9 0x1 >;
    				status = "okay";
    				label = "I2C_1";
    				sda-pin = < 0x22 >;
    				scl-pin = < 0x23 >;
    			spi1: spi@9000 {
    				label = "SPI_1";
    			uart1: arduino_serial: uart@9000 {
    				label = "UART_1";
    				tx-pin = < 0x21 >;
    				rx-pin = < 0x20 >;
    				rx-pull-up;
    			spi4: arduino_spi: spi@a000 {
    				reg = < 0xa000 0x1000 >;
    				interrupts = < 0xa 0x1 >;
    				status = "ok";
    				label = "SPI_4";
    				sck-pin = < 0x24 >;
    				miso-pin = < 0x19 >;
    				mosi-pin = < 0x29 >;
    				cs-gpios = < &arduino_header 0x10 0x1 >;
    			i2c2: i2c@b000 {
    				reg = < 0xb000 0x1000 >;
    				interrupts = < 0xb 0x1 >;
    				label = "I2C_2";
    			spi2: spi@b000 {
    				status = "okay";
    				label = "SPI_2";
    				sck-pin = < 0x0 >;
    				miso-pin = < 0x0 >;
    				mosi-pin = < 0x10 >;
    				status_leds: ws2812@0 {
    					label = "WS2812";
    					reg = < 0x0 >;
    					spi-max-frequency = < 0x3d0900 >;
    					chain-length = < 0x1 >;
    					color-mapping = < 0x2 0x1 0x3 >;
    					spi-one-frame = < 0x70 >;
    					spi-zero-frame = < 0x40 >;
    			uart2: uart@b000 {
    				label = "UART_2";
    			i2c3: i2c@c000 {
    				reg = < 0xc000 0x1000 >;
    				interrupts = < 0xc 0x1 >;
    				label = "I2C_3";
    			spi3: spi@c000 {
    				label = "SPI_3";
    			uart3: uart@c000 {
    				label = "UART_3";
    			adc: adc@e000 {
    				compatible = "nordic,nrf-saadc";
    				reg = < 0xe000 0x1000 >;
    				interrupts = < 0xe 0x1 >;
    				status = "okay";
    				label = "ADC_0";
    				#io-channel-cells = < 0x1 >;
    				phandle = < 0x6 >;
    			timer0: timer@f000 {
    				compatible = "nordic,nrf-timer";
    				status = "okay";
    				reg = < 0xf000 0x1000 >;
    				cc-num = < 0x6 >;
    				interrupts = < 0xf 0x1 >;
    				prescaler = < 0x0 >;
    				label = "TIMER_0";
    			timer1: timer@10000 {
    				status = "okay";
    				reg = < 0x10000 0x1000 >;
    				cc-num = < 0x6 >;
    				interrupts = < 0x10 0x1 >;
    				label = "TIMER_1";
    			timer2: timer@11000 {
    				status = "okay";
    				reg = < 0x11000 0x1000 >;
    				cc-num = < 0x6 >;
    				interrupts = < 0x11 0x1 >;
    				label = "TIMER_2";
    			rtc0: rtc@14000 {
    				compatible = "nordic,nrf-rtc";
    				reg = < 0x14000 0x1000 >;
    				cc-num = < 0x4 >;
    				interrupts = < 0x14 0x1 >;
    				status = "okay";
    				clock-frequency = < 0x8000 >;
    				prescaler = < 0x1 >;
    				label = "RTC_0";
    			rtc1: rtc@15000 {
    				reg = < 0x15000 0x1000 >;
    				cc-num = < 0x4 >;
    				interrupts = < 0x15 0x1 >;
    				status = "okay";
    				label = "RTC_1";
    			dppic: dppic@17000 {
    				compatible = "nordic,nrf-dppic";
    				reg = < 0x17000 0x1000 >;
    				status = "okay";
    				label = "DPPIC";
    			wdt: wdt0: watchdog@18000 {
    				compatible = "nordic,nrf-watchdog";
    				reg = < 0x18000 0x1000 >;
    				interrupts = < 0x18 0x1 >;
    				status = "okay";
    				label = "WDT";
    			wdt1: watchdog@19000 {
    				reg = < 0x19000 0x1000 >;
    				interrupts = < 0x19 0x1 >;
    				label = "WDT_1";
    			egu0: egu@1b000 {
    				compatible = "nordic,nrf-egu";
    				reg = < 0x1b000 0x1000 >;
    				interrupts = < 0x1b 0x1 >;
    				status = "okay";
    			egu1: egu@1c000 {
    				reg = < 0x1c000 0x1000 >;
    				interrupts = < 0x1c 0x1 >;
    				status = "okay";
    			egu2: egu@1d000 {
    				reg = < 0x1d000 0x1000 >;
    				interrupts = < 0x1d 0x1 >;
    				status = "okay";
    			egu3: egu@1e000 {
    				reg = < 0x1e000 0x1000 >;
    				interrupts = < 0x1e 0x1 >;
    				status = "okay";
    			egu4: egu@1f000 {
    				reg = < 0x1f000 0x1000 >;
    				interrupts = < 0x1f 0x1 >;
    				status = "okay";
    			egu5: egu@20000 {
    				reg = < 0x20000 0x1000 >;
    				interrupts = < 0x20 0x1 >;
    				status = "okay";
    			pwm0: pwm@21000 {
    				compatible = "nordic,nrf-pwm";
    				reg = < 0x21000 0x1000 >;
    				interrupts = < 0x21 0x1 >;
    				status = "okay";
    				label = "PWM_0";
    				#pwm-cells = < 0x1 >;
    				ch0-pin = < 0x1c >;
    				phandle = < 0x4 >;
    			pwm1: pwm@22000 {
    				reg = < 0x22000 0x1000 >;
    				interrupts = < 0x22 0x1 >;
    				label = "PWM_1";
    			pwm2: pwm@23000 {
    				reg = < 0x23000 0x1000 >;
    				interrupts = < 0x23 0x1 >;
    				label = "PWM_2";
    			pwm3: pwm@24000 {
    				reg = < 0x24000 0x1000 >;
    				interrupts = < 0x24 0x1 >;
    				label = "PWM_3";
    			pdm0: pdm@26000 {
    				compatible = "nordic,nrf-pdm";
    				reg = < 0x26000 0x1000 >;
    				interrupts = < 0x26 0x1 >;
    				label = "PDM_0";
    			i2s0: i2s@28000 {
    				compatible = "nordic,nrf-i2s";
    				reg = < 0x28000 0x1000 >;
    				interrupts = < 0x28 0x1 >;
    				label = "I2S_0";
    			ipc: ipc@2a000 {
    				compatible = "nordic,nrf-ipc";
    				reg = < 0x2a000 0x1000 >;
    				interrupts = < 0x2a 0x1 >;
    				status = "okay";
    				label = "IPC";
    			qspi: qspi@2b000 {
    				compatible = "nordic,nrf-qspi";
    				reg = < 0x2b000 0x1000 >, < 0x10000000 0x10000000 >;
    				reg-names = "qspi", "qspi_mm";
    				interrupts = < 0x2b 0x1 >;
    				status = "okay";
    				label = "QSPI";
    				sck-pin = < 0x11 >;
    				io-pins = < 0xd >, < 0xe >, < 0xf >, < 0x10 >;
    				csn-pins = < 0x12 >;
    				mx25r64: mx25r6435f@0 {
    					compatible = "nordic,qspi-nor";
    					reg = < 0x0 >;
    					writeoc = "pp4io";
    					readoc = "read4io";
    					sck-frequency = < 0x7a1200 >;
    					label = "MX25R64";
    					jedec-id = [ C2 28 17 ];
    					sfdp-bfp = [ E5 20 F1 FF FF FF FF 03 44 EB 08 6B 08 3B 04 BB EE FF FF FF FF FF 00 FF FF FF 00 FF 0C 20 0F 52 10 D8 00 FF 23 72 F5 00 82 ED 04 CC 44 83 68 44 30 B0 30 B0 F7 C4 D5 5C 00 BE 29 FF F0 D0 FF FF ];
    					size = < 0x4000000 >;
    					has-dpd;
    					t-enter-dpd = < 0x2710 >;
    					t-exit-dpd = < 0x88b8 >;
    			qdec0: qdec@33000 {
    				compatible = "nordic,nrf-qdec";
    				reg = < 0x33000 0x1000 >;
    				interrupts = < 0x33 0x1 >;
    				label = "QDEC_0";
    			qdec1: qdec@34000 {
    				reg = < 0x34000 0x1000 >;
    				interrupts = < 0x34 0x1 >;
    				label = "QDEC_1";
    			usbd: zephyr_udc0: usbd@36000 {
    				compatible = "nordic,nrf-usbd";
    				reg = < 0x36000 0x1000 >;
    				interrupts = < 0x36 0x1 >;
    				num-bidir-endpoints = < 0x1 >;
    				num-in-endpoints = < 0x7 >;
    				num-out-endpoints = < 0x7 >;
    				num-isoin-endpoints = < 0x1 >;
    				num-isoout-endpoints = < 0x1 >;
    				status = "okay";
    				label = "USBD";
    				cdc_acm_uart0 {
    			flash_controller: flash-controller@39000 {
    				compatible = "nordic,nrf53-flash-controller";
    				reg = < 0x39000 0x1000 >;
    				label = "NRF_FLASH_DRV_NAME";
    				flash0: flash@0 {
    					compatible = "soc-nv-flash";
    					label = "NRF_FLASH";
    					erase-block-size = < 0x1000 >;
    					write-block-size = < 0x4 >;
    					reg = < 0x0 0x100000 >;
    					partitions {
    						boot_partition: partition@0 {
    							label = "mcuboot";
    							reg = < 0x0 0x10000 >;
    						slot0_partition: partition@10000 {
    							label = "image-0";
    							reg = < 0x10000 0x40000 >;
    						slot0_ns_partition: partition@50000 {
    							label = "image-0-nonsecure";
    							reg = < 0x50000 0x30000 >;
    						slot1_partition: partition@80000 {
    							label = "image-1";
    							reg = < 0x80000 0x40000 >;
    						slot1_ns_partition: partition@c0000 {
    							label = "image-1-nonsecure";
    							reg = < 0xc0000 0x30000 >;
    						scratch_partition: partition@f0000 {
    							label = "image-scratch";
    							reg = < 0xf0000 0xa000 >;
    						storage_partition: partition@fa000 {
    							label = "storage";
    							reg = < 0xfa000 0x6000 >;
    			kmu: kmu@39000 {
    				compatible = "nordic,nrf-kmu";
    				interrupts = < 0x39 0x1 >;
    				status = "okay";
    			vmc: vmc@81000 {
    				compatible = "nordic,nrf-vmc";
    				reg = < 0x81000 0x1000 >;
    				status = "okay";
    			gpio0: gpio@842500 {
    				compatible = "nordic,nrf-gpio";
    				gpio-controller;
    				reg = < 0x842500 0x300 >;
    				#gpio-cells = < 0x2 >;
    				label = "GPIO_0";
    				status = "okay";
    				port = < 0x0 >;
    				phandle = < 0x3 >;
    			gpio1: gpio@842800 {
    				gpio-controller;
    				reg = < 0x842800 0x300 >;
    				ngpios = < 0x10 >;
    				label = "GPIO_1";
    				status = "okay";
    				port = < 0x1 >;
    				phandle = < 0x5 >;
    		spu: spu@50003000 {
    			compatible = "nordic,nrf-spu";
    			reg = < 0x50003000 0x1000 >;
    			interrupts = < 0x3 0x1 >;
    			status = "okay";
    		gpiote: gpiote0: gpiote@5000d000 {
    			compatible = "nordic,nrf-gpiote";
    			reg = < 0x5000d000 0x1000 >;
    			interrupts = < 0xd 0x5 >;
    			status = "okay";
    			label = "GPIOTE_0";
    		cryptocell: crypto@50844000 {
    			compatible = "nordic,nrf-cc312";
    			reg = < 0x50844000 0x1000 >;
    			label = "CRYPTOCELL";
    			status = "okay";
    			cryptocell312: crypto@50845000 {
    				compatible = "arm,cryptocell-312";
    				reg = < 0x50845000 0x1000 >;
    				interrupts = < 0x44 0x1 >;
    				label = "CRYPTOCELL312";
    		gpiote1: gpiote@4002f000 {
    			reg = < 0x4002f000 0x1000 >;
    			interrupts = < 0x2f 0x5 >;
    			label = "GPIOTE_1";
    	pinctrl: pin-controller {
    		compatible = "nordic,nrf-pinctrl";
    	cpus {
    		cpu@0 {
    			device_type = "cpu";
    			compatible = "arm,cortex-m33f";
    			reg = < 0x0 >;
    			swo-ref-frequency = < 0x3d09000 >;
    			mpu: mpu@e000ed90 {
    				compatible = "arm,armv8m-mpu";
    				reg = < 0xe000ed90 0x40 >;
    				arm,num-mpu-regions = < 0x8 >;
    	leds {
    		compatible = "gpio-leds";
    		led0: led_0 {
    			gpios = < &gpio0 0x1c 0x1 >;
    			label = "Green LED 0";
    		led1: led_1 {
    			gpios = < &gpio0 0x1d 0x1 >;
    			label = "Green LED 1";
    		led2: led_2 {
    			gpios = < &gpio0 0x1e 0x1 >;
    			label = "Green LED 2";
    		led3: led_3 {
    			gpios = < &gpio0 0x1f 0x1 >;
    			label = "Green LED 3";
    	pwmleds {
    		compatible = "pwm-leds";
    		pwm_led0: pwm_led_0 {
    			pwms = < &pwm0 0x1c >;
    	buttons {
    		compatible = "gpio-keys";
    		button0: button_0 {
    			gpios = < &gpio0 0x17 0x11 >;
    			label = "Push button 1";
    		button1: button_1 {
    			gpios = < &gpio0 0x18 0x11 >;
    			label = "Push button 2";
    		button2: button_2 {
    			gpios = < &gpio0 0x8 0x11 >;
    			label = "Push button 3";
    		button3: button_3 {
    			gpios = < &gpio0 0x9 0x11 >;
    			label = "Push button 4";
    	arduino_header: connector {
    		compatible = "arduino-header-r3";
    		gpio-map-mask = < 0xffffffff 0xffffffc0 >;
    		gpio-map-pass-thru = < 0x0 0x3f >;
    		gpio-map = < 0x0 0x0 &gpio0 0x4 0x0 >, < 0x1 0x0 &gpio0 0x5 0x0 >, < 0x2 0x0 &gpio0 0x6 0x0 >, < 0x3 0x0 &gpio0 0x7 0x0 >, < 0x4 0x0 &gpio0 0x19 0x0 >, < 0x5 0x0 &gpio0 0x1a 0x0 >, < 0x6 0x0 &gpio1 0x0 0x0 >, < 0x7 0x0 &gpio1 0x1 0x0 >, < 0x8 0x0 &gpio1 0x4 0x0 >, < 0x9 0x0 &gpio1 0x5 0x0 >, < 0xa 0x0 &gpio1 0x6 0x0 >, < 0xb 0x0 &gpio1 0x7 0x0 >, < 0xc 0x0 &gpio1 0x8 0x0 >, < 0xd 0x0 &gpio1 0x9 0x0 >, < 0xe 0x0 &gpio1 0xa 0x0 >, < 0xf 0x0 &gpio1 0xb 0x0 >, < 0x10 0x0 &gpio1 0xc 0x0 >, < 0x11 0x0 &gpio1 0xd 0x0 >, < 0x12 0x0 &gpio1 0xe 0x0 >, < 0x13 0x0 &gpio1 0xf 0x0 >, < 0x14 0x0 &gpio1 0x2 0x0 >, < 0x15 0x0 &gpio1 0x3 0x0 >;
    		phandle = < 0x2 >;
    	arduino_adc: analog-connector {
    		compatible = "arduino,uno-adc";
    		io-channel-map = < 0x0 &adc 0x0 >, < 0x1 &adc 0x1 >, < 0x2 &adc 0x2 >, < 0x3 &adc 0x3 >, < 0x4 &adc 0x4 >, < 0x5 &adc 0x5 >;
    	reserved-memory {
    		ranges;
    		sram0_image: image@20000000 {
    			reg = < 0x20000000 0x70000 >;
    		sram0_s: image_s@20000000 {
    			reg = < 0x20000000 0x40000 >;
    		sram0_ns: image_ns@20040000 {
    			reg = < 0x20040000 0x30000 >;
    		sram0_shared: memory@20070000 {
    			reg = < 0x20070000 0x10000 >;
    It searches for led-strip in the DT, so you'll need to alias your status_leds to this:
    led-strip = &status_leds;
    Could you try this and see if it works?
    PS: your mosi/miso pins are still set to P0.00.
    Håkon
    I am trying to use the same LED and below is my overlay:
    &spi0
            status = "okay";
            pinctrl-0 = <&spi2_default>;
            pinctrl-1 = <&spi2_sleep>;
                    /* SPI */
                    spi-max-frequency = < SPI_FREQ >;
                    /* WS2812 */
                                     LED_COLOR_ID_RED
                                     LED_COLOR_ID_BLUE>;
    where pin controls are defined as this:
            spi2_default: spi2_default {
                    group1 { psels = <NRF_PSEL(SPIM_SCK, 1, 10)>,
                            <NRF_PSEL(SPIM_MOSI, 1, 00)>,
                            <NRF_PSEL_DISCONNECTED(SPIM_MISO)>;
            spi2_sleep: spi2_sleep {
                            low-power-enable;
    This works but when I try to use "NRF_PSEL_DISCONNECTED(SPIM_SCK)" the MOSI line does not send any data. The following message is given:
    [00:00:02.977,630] <err> spi_nrfx_spim: Timeout waiting for transfer complete
    [00:00:02.977,935] <err> app: couldn't update strip: -116
    My understanding of the LED driver is that it only needs the MOSI pins and I would like to be able to utilize the other GPIO pins. Thank you for your help!
    - Brady
    You are posting in a ~1 year old case. If the below does not help, I would recommend that you open up a new thread.
    The default timeout for a SPI transaction is 200 ms. This is set via. CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE.
    If you send a large amount of data over SPIM, you might need to relax this delay (to for instance 1000 ms).
    Håkon
