I'm struggling when using PWM and DMA to generate a sine wave. I'm sure I'm not interpreting the documentation right, and I hope someone can point me in the right direction
I tried the following code
#include <stdio.h>
#include <string.h>
#include "nrf_drv_pwm.h"
#include "app_error.h"
#include "boards.h"
#include "bsp.h"
#include "app_timer.h"
#include "nrf_drv_clock.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
static nrf_drv_pwm_t m_pwm = NRF_DRV_PWM_INSTANCE(0);
static void init_bsp()
APP_ERROR_CHECK(nrf_drv_clock_init());
APP_ERROR_CHECK(app_timer_init());
void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info)
bsp_board_leds_on();
app_error_save_and_stop(id, pc, info);
static void demo(void)
NRF_LOG_INFO("Demo 1");
// This array cannot be allocated on stack (hence "static") and it must
// be in RAM (hence no "const", though its content is not changed).
static nrf_pwm_values_wave_form_t /*const*/ m_demo_seq_values[] =
500,500,500,1000,
578,578,578,1000,
655,655,655,1000,
727,727,727,1000,
794,794,794,1000,
854,854,854,1000,
905,905,905,1000,
946,946,946,1000,
976,976,976,1000,
994,994,994,1000,
1000,1000,1000,1000,
994,994,994,1000,
976,976,976,1000,
946,946,946,1000,
905,905,905,1000,
854,854,854,1000,
794,794,794,1000,
727,727,727,1000,
655,655,655,1000,
578,578,578,1000,
500,500,500,1000,
422,422,422,1000,
345,345,345,1000,
273,273,273,1000,
206,206,206,1000,
146,146,146,1000,
95,95,95,1000,
54,54,54,1000,
24,24,24,1000,
6,6,6,1000,
0,0,0,1000,
6,6,6,1000,
24,24,24,1000,
54,54,54,1000,
95,95,95,1000,
146,146,146,1000,
206,206,206,1000,
273,273,273,1000,
345,345,345,1000,
422,422,422,1000
static nrf_pwm_sequence_t const m_demo_seq =
.values.p_wave_form = &m_demo_seq_values,
.length = NRF_PWM_VALUES_LENGTH(m_demo_seq_values),
.repeats = 0,
.end_delay = 0
nrf_drv_pwm_config_t const config =
.output_pins =
ARDUINO_A0_PIN,
NRFX_PWM_PIN_NOT_USED,
.irq_priority = APP_IRQ_PRIORITY_LOWEST,
.base_clock = NRF_PWM_CLK_16MHz,
.count_mode = NRF_PWM_MODE_UP,
.top_value = 40,
.load_mode = NRF_PWM_LOAD_WAVE_FORM,
.step_mode = NRF_PWM_STEP_AUTO
APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm, &config, NULL));
(void)nrf_drv_pwm_simple_playback(&m_pwm, &m_demo_seq, 1,
NRF_DRV_PWM_FLAG_LOOP);
init_bsp();
NRF_LOG_INFO("PWM example started.");
demo();
for (;;)
// Wait for an event.
__WFE();
// Clear the event register.
__SEV();
__WFE();
NRF_LOG_FLUSH();
If I understand correctly how PWM works, with a 16MHz clock and a 1000 counter top, should give me a "pwm step" of 16kHz. Since I have 40 elements in the sine lookup table, the resulting sine frequency should be 400Hz. And I get something very close (minus the analog filtering part, that I'm still trying to figure out how to do properly)
In order to get to 10kHz, I need to reduce counter top to 40, and use 40 steps for the sine lookup table (or any similar combination, 40 and 40 just happens to work nicely with a 16Mz clock). Which seems rather low to get a good sine wave. I tried using the following, and sure enough I get a 10kHz wave
20,0,0,40,
23,0,0,40,
26,0,0,40,
29,0,0,40,
32,0,0,40,
34,0,0,40,
36,0,0,40,
38,0,0,40,
39,0,0,40,
40,0,0,40,
40,0,0,40,
40,0,0,40,
39,0,0,40,
38,0,0,40,
36,0,0,40,
34,0,0,40,
32,0,0,40,
29,0,0,40,
26,0,0,40,
23,0,0,40,
20,0,0,40,
17,0,0,40,
14,0,0,40,
11,0,0,40,
8,0,0,40,
6,0,0,40,
4,0,0,40,
2,0,0,40,
1,0,0,40,
0,0,0,40,
0,0,0,40,
0,0,0,40,
1,0,0,40,
2,0,0,40,
4,0,0,40,
6,0,0,40,
8,0,0,40,
11,0,0,40,
14,0,0,40,
17,0,0,40
Do I understand correctly the relationship between counter top and the values in the sequence array? Is there a way to do better than what I'm doing in generating a 10kHz sine wave? An old trick for memory limited processors was to store only the first 90 degrees of the sine table, and "mirror" it 4 times, as appropriate, but I could not think of a way to make it work here
Since I need only one channel, do I need to have the nrf_pwm_values_wave_form_t array to have all those 0 values, or is there a way to save memory?
Lastly, any idea why I get a "warning: initialization of 'const nrf_pwm_values_wave_form_t *' from incompatible pointer type 'nrf_pwm_values_wave_form_t (*)[20]' [-Wincompatible-pointer-types]" in line 88? I thought I used the pointers as defined by nrf_pwm.h
