Mcuboot failing to load SMP SVR application on nRF5340 DK
I'm trying to follow the MCUBoot + SMP SVR example on this page: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/README.html#smp-svr-sample
MCUBoot flashes just fine, but when I try to flash the signed binary of the SMP SVR application, MCUBoot only sees zeroes in the application header. I've added some debugging in MCUBoot so I can monitor why it's failing when trying to load the SMP SVR application:
*** Booting Zephyr OS build zephyr-v3.1.0-678-gd0a788669e15 ***
I: Starting bootloader
I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Boot source: none
W: Failed reading image headers; Image=0
E: MAB boot_is_header_valid -- header magic (0x00000000) doesn't match (0x96f3b83d)
E: MAB boot_validate_slot -- boot_is_header_valid result = 0
E: MAB boot_validate_slot -- fih_not_eq result = 1
E: Image in the primary slot is not valid!
E: Unable to find bootable image
Can you advise on what could be the issue?
This is on an nRF5340 DK.
