Hi every body.
I have trying without success to attach an event handler function to the TWI.
I am reading a temperature and humidity sensor using I2C. In polling mode everything is working perfectly but when I try to attach a callback function, that function is never called.
Any idea about what I am doing wrong?
Here is the code I am implementing:
// ########## M.I. BSP ##########
#include "bsp_handler.h"
// ########## M.I. Lib ##########
#include "board.h"
#include "uart_handler.h"
#include "nrfx_twim.h"
// i2c parameters for SHT35
#define SHT35_I2C_ADDRESS 0x44
#define CMD_SOFT_RST0 0xA2 // soft reset command LSB
#define CMD_SOFT_RST1 0x30 // soft reset command MSB
#define HIGH_REP_WITH_STRCH0 0x06 // request command LSB
#define HIGH_REP_WITH_STRCH1 0x2C // request command MSB
#define NRF52833_XXAA
static const char messageBuffer[] =
"*** DEMO EHAL-I2C Driver ***\r\n"
"*** Website: https://monitoreointeligente.com/ ***\r\n";
// setup UART
uart_instance SerialExt(UART0_PORT_AVAILABLE);
uint8_t StringDebug[SERIAL_BUFFER_SIZE] = {};
uint8_t rx_buffer[SERIAL_BUFFER_SIZE] = {};
uint8_t tx_buffer[SERIAL_BUFFER_SIZE] = {};
// setup I2C
nrfx_twim_t i2c_instance = NRFX_TWIM_INSTANCE(0);
uint8_t i2c_rx[6] = {0};
uint8_t i2c_tx[2] = {CMD_SOFT_RST1, CMD_SOFT_RST0};
void i2cEventHandler(nrfx_twim_evt_t const *p_event, void *p_context)
int n;
switch(p_event->type)
case NRFX_TWIM_EVT_BUS_ERROR:
n = sprintf((char*)StringDebug, "Error\r\n");
SerialExt.write(StringDebug, false, n);
case NRFX_TWIM_EVT_DATA_NACK:
n = sprintf((char*)StringDebug, "Data Nack\r\n");
case NRFX_TWIM_EVT_DONE:
n = sprintf((char*)StringDebug, "Done!\r\n");
halSetup();
int n;
float temp;
float humidity;
nrfx_twim_xfer_desc_t tx_config;
nrfx_twim_xfer_desc_t rx_config;
// setup UART
SerialExt.setup(rx_buffer, SERIAL_BUFFER_SIZE, tx_buffer, SERIAL_BUFFER_SIZE, '\n');
SerialExt.write((uint8_t*)messageBuffer, false, sizeof(messageBuffer));
// setup I2C
nrfx_twim_config_t i2c0_config = NRFX_TWIM_DEFAULT_CONFIG(17, 16);
i2c0_config.interrupt_priority = 2;
//if(nrfx_twim_init(&i2c_instance, &i2c0_config, NULL, NULL) == NRFX_SUCCESS)
if(nrfx_twim_init(&i2c_instance, &i2c0_config, i2cEventHandler, NULL) == NRFX_SUCCESS)
n = sprintf((char*)StringDebug, "I2C init OK!\r\n");
nrfx_twim_enable(&i2c_instance);
tx_config = NRFX_TWIM_XFER_DESC_TX(SHT35_I2C_ADDRESS, i2c_tx, sizeof(i2c_tx));
rx_config = NRFX_TWIM_XFER_DESC_RX(SHT35_I2C_ADDRESS, i2c_rx, sizeof(i2c_rx));
if(nrfx_twim_xfer(&i2c_instance, &tx_config, NRFX_TWIM_FLAG_NO_XFER_EVT_HANDLER) == NRFX_SUCCESS)
n = sprintf((char*)StringDebug, "Soft Reset command sent!\r\n");
while (true)
// request command
i2c_tx[0] = HIGH_REP_WITH_STRCH1;
i2c_tx[1] = HIGH_REP_WITH_STRCH0;
if(nrfx_twim_xfer(&i2c_instance, &tx_config, NRFX_TWIM_FLAG_REPEATED_XFER) == NRFX_SUCCESS)
n = sprintf((char*)StringDebug, "Temp/Humidity command sent!\r\n");
if(nrfx_twim_xfer(&i2c_instance, &rx_config, NRFX_TWIM_FLAG_REPEATED_XFER) == NRFX_SUCCESS)
// mapping values
temp = (175.0 / 65535.0) * (((int16_t)i2c_rx[0] << 8 ) | (int16_t)i2c_rx[1]) - 45;
humidity = (100.0 / 65535.0) * (((int16_t)i2c_rx[3] << 8) | (int16_t)i2c_rx[4]);
n = sprintf((char*)StringDebug, "Data received temp: %.2f humidity %.2f\r\n", temp, humidity);
tx_config = NRFX_TWIM_XFER_DESC_TXRX(SHT35_I2C_ADDRESS, i2c_tx, sizeof(i2c_tx), i2c_rx, sizeof(i2c_rx));
// mapping values
memset(i2c_rx, 0, sizeof(i2c_rx));
k_msleep(1000);
Here is the prj.conf
# Enable the UART driver CONFIG_UART_ASYNC_API=y CONFIG_NRFX_UARTE0=y CONFIG_UART_0_ASYNC=y CONFIG_SERIAL=y CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_UART_0_INTERRUPT_DRIVEN=n CONFIG_UART_USE_RUNTIME_CONFIGURE=y CONFIG_NEWLIB_LIBC_FLOAT_PRINTF=y # Enable I2C CONFIG_I2C=y CONFIG_I2C_NRFX=y CONFIG_NRFX_TWIM=y CONFIG_NRFX_TWIM0=y CONFIG_NRFX_TWIM1=n CONFIG_NRFX_PRS=y CONFIG_NRFX_PRS_BOX_0=y # Heap memory pool and Stack memory size 256/1024/4096/16384 CONFIG_HEAP_MEM_POOL_SIZE=1024 #CONFIG_MAIN_STACK_SIZE=16384 # Enable gpio CONFIG_GPIO=y # Enable timer CONFIG_NRFX_TIMER=y CONFIG_NRFX_TIMER0=y CONFIG_NRFX_TIMER1=y CONFIG_NRFX_TIMER2=y CONFIG_NRFX_TIMER3=y CONFIG_NRFX_TIMER4=y # Heap memory pool 256/1024/4096/16384 CONFIG_HEAP_MEM_POOL_SIZE=1024 # C++ config CONFIG_NEWLIB_LIBC=y CONFIG_CPLUSPLUS=y #CONFIG_CPP_STATIC_INIT_GNU=y
