Client automatically reconnects to server after OTA DFU
I'm trying to implement OTA DFU in our custom App with our nRF52832 acting as the device to be upgraded.  Everything seems to work OK in that:
1. New image uploads to the device
2. App resets the device to transfer new image into correct area
3. App does a check to ensure the new image is OK, then confirms this with the device
4. App forces another software reset on the device
At this point, the device should start advertising again.  But for some reason it stays connected to the client.  I'm trying to work out how to prevent this happening, primarily as my App is only scanning for devices and grabbing the scan response data to update its info.  It only needs to connect when its going to do an OTA DFU.  But because it remains connected after the OTA DFU, things get all locked up.
Not sure if this needs to be driven from the client or the server side.  Client is an iOS device running our custom App.  I am also using the CTS on the server, so client and server are paired at some point.  I believe this is a requirement by Apple for devices to access CTS on an iOS device.
Any ideas how I can ensure that the client doesn't automatically reconnect to the server after the final reset at the completion of the OTA DFU?
Cheers,
Mike
  • Hi Aleksander,
    Thanks for that explanation - makes sense
    We're using NCS V1.9.1 to do our development.
    I'll follow up your other post with some logs from the nRF Connect App.  That App actually works, in that I don't get the automatic reconnect at the completion of the DFU (but it does hold the connection even if I press the 'disconnect' button in that App).  Its our custom App that is the issue, so maybe I need to get the App developers to dig a bit deeper into what their App is doing at the conclusion of the DFU
    I am using CTS so that I can update the time in my on-board RTC anytime there is a connection to the device via our App.  We time stamp events as they occur, and so want to ensure that the RTC is as close to the correct time as possible.  It also helps us set up the RTC during production.  As I understand it, pairing/bonding is a requirement of iOS to use the CTS.  I'd prefer not to have to pair/bond if I didn't need to.
    Our device spends most of its time in System OFF mode.  An event on a GPIO triggers it out of this mode, it grabs some details, stores some info into NVS, then goes back into System OFF.  That's probably 99.9% of its time.
    If someone wants to grab the information the device has stored, they trigger it out of System OFF via a different GPIO input, and whilst this GPIO input remains active, the device is advertising with data in the scan response packet indicating details on the events.  Our App picks this info up and displays it.  It also grabs the information stored in NVS and sends this to a database so we can collect all the information from the various devices.  If there is a firmware update available, then this can also be completed via our App whilst the device is advertising.  Its this part of the device's operation we're having issues with.  Our App developers needed the device to restart advertising after the DFU, so our App can reconnect and confirm that the DFU was successful.  After the App has confirmed this, it resets the device a second time.  The device will then restart advertising as the appropriate GPIO is still being held active.  Its at this point that our iOS device reconnects, when we don't want it to
    Cheers,
    Mike
  • Hi Mike,
    I think the combination of Directed advertising + bonded = auto reconnection.
    So if you disable directed advertising right after the new image is running it should be able to avoid reconnecting.
    Actively request a disconnection when an unwanted connection happens is a good failsafe solution in my opinion.
    Another option is to switch between different addresses. When you don't want to be connected or bonded you use a different advertising address. And when you want to be connected and bonded you return to the original address.
  • OK, so what we were able to ascertain is that it seemed to be device specific.  We are testing with two different devices (based on what our dev team have as their own handsets basically)
    1. iPhone 7, running iOS 15.5 - this would successfully disconnect from the device at the completion of the DFU
    2. iPhone 12/12Pro running iOS 15.5 - this would NOT disconnect from the device once the DFU had completed, even after issuing multiple software reset commands.
    So, we've resorted to a brute force method, and have a service/characteristic that we write to at the end of the DFU, that forces the device to disconnect the connection itself.  Seems to work on both the devices listed above.
    Not really sure why different devices behave differently, but we've got a solution that works
    Cheers,
    Mike
  • The reset command from Mcumgr should do the same. It should reboot the device after gracefully disconnecting. Perhaps check why it doesn't work as intended?
    We can see that reset command being issued my the Mcumgr with both the devices, and this then restarts our device and it then beings advertising.  But for some reason on the 12/12Pro, the phone would then reconnect and the only way for us to get our device to disconnect was to force it to stop advertising (we enable/disable this via a GPIO)
    Much as I'd like to understand why, the commerical realities of getting product to market dictate that "if you've got something that works, move on to the next issue"
    Cheers,
    Mike
