Serial LTE Modem Program for nRF9160 with hardware flow control: Undeclared RTS pin enumeration
We need to enable hardware flow control in the serial LTE modem application (2.0.0 release) on the nRF9160 for use with an external MCU.
We have tried to do so with the following settings in the nrf9160dk_nrf9160_ns.conf file, trying both UART_0 (our preferred connection) and UART_2 (Nordic’s suggested connection):
CONFIG_SLM_CONNECT_UART_2=y
CONFIG_UART_0_NRF_HW_ASYNC_TIMER=2
CONFIG_UART_0_NRF_HW_ASYNC=y
CONFIG_SLM_WAKEUP_PIN=31
CONFIG_SLM_INDICATE_PIN=30
CONFIG_SLM_UART_HWFC_RUNTIME=y
The build fails with the following error:
	"resource": "/c:/nordic/v2.0.0/nrf/applications/serial_lte_modem/build/zephyr/include/generated/devicetree_unfixed.h",
	"owner": "cpptools",
	"severity": 8,
	"message": "'DT_N_S_soc_S_peripheral_40000000_S_uart_8000_P_rts_pin' undeclared (first use in this function); did you mean 'DT_N_S_soc_S_peripheral_40000000_S_uart_8000_P_status'?",
	"source": "gcc",
	"startLineNumber": 9186,
	"startColumn": 38,
	"endLineNumber": 9186,
	"endColumn": 38
Attempting to set hardware flow control during runtime with "AT#XSLMUART=115200, 1" also does not seem to work; it produces the following output from the LTE Link monitor:
2022-06-29T13:52:01.766Z DEBUG modem >> AT#XSLMUART?
2022-06-29T13:52:01.775Z DEBUG modem << #XSLMUART: 115200,0
2022-06-29T13:52:01.776Z DEBUG modem << OK
2022-06-29T13:52:09.875Z DEBUG modem >> AT#XSLMUART=115200,1
2022-06-29T13:52:09.883Z DEBUG modem << OK
2022-06-29T13:52:14.949Z DEBUG modem >> AT#XSLMUART?
2022-06-29T13:52:14.957Z DEBUG modem << #XSLMUART: 115200,0
2022-06-29T13:52:14.959Z DEBUG modem << OK
Could you please assist us in enabling hardware flow control?
Thank you.
  • Hi Charlie,
     Thank you for the info.
    The default configuration is #XSLUMUART:115200,1 after you do erase and flash, I suspect this is what you did.
    Yes, HWFC is still zero with an erase and flash, though it can be changed with the AT command.
    Below is the terminal output (with the serial redacted) from the nRF Connect extension in VS Code for the erase and flash:
    > Executing task: nRF Connect: Flash: serial_lte_modem/build (active) <
    Flashing build to undefined
    west flash -d c:\nordic\v2.0.0\nrf\applications\serial_lte_modem\build --skip-rebuild -r nrfjprog --dev-id  --erase
    -- west flash: using runner nrfjprog
    -- runners.nrfjprog: mass erase requested
    -- runners.nrfjprog: Flashing file: C:\nordic\v2.0.0\nrf\applications\serial_lte_modem\build\zephyr\merged.hex
    Parsing image file.
    Verifying programming.
    Verified OK.
    Applying pin reset.
    -- runners.nrfjprog: Board with serial number  flashed successfully.
    Terminal will be reused by tasks, press any key to close it.
    And the modem output in LTE Link monitor afterward:
    2022-07-05T14:07:29.567Z DEBUG modem << Ready
    2022-07-05T14:07:38.614Z DEBUG modem >> AT#XSLMUART?
    2022-07-05T14:07:38.622Z DEBUG modem << #XSLMUART: 115200,0
    2022-07-05T14:07:38.626Z DEBUG modem << OK
    Kimberly
  • Hi Kimberly,
    I tested on an nRF9160DK V1.1.0 with the following firmware yesterday.
    Can you try ncs200_serial_lte_modem_uart2hwfl_merged.hex built from my project ncs200_serial_lte_modem_uart2hwfl.zip?
    Please update modem firmware to v1.3.2 and report which nRF9160DK version you are using if this problem still exists.
    Charlie
  • Hi Charlie,
    Thank you for sending through the files. I will update when I've managed to test them.
    Kimberly
  • Hi Charlie,
    UART2 does not transmit to our external MCU with the hex file, a build from the provided zip or a build from the original program edited as above. Building produces the following warnings concerning  missing dependencies, which may be relevant:
    Serial LTE Modem:
    	"resource": "/c:/nordic/v2.0.0/nrf/applications/serial_lte_modem/boards/nrf9160dk_nrf9160_ns.conf",
    	"owner": "kconfig2",
    	"severity": 4,
    	"message": "CONFIG_UART_2_NRF_HW_ASYNC_TIMER couldn't be set. Missing dependencies:\nUART_2_NRF_HW_ASYNC && UART_2_NRF_UARTE",
    	"startLineNumber": 25,
    	"startColumn": 1,
    	"endLineNumber": 25,
    	"endColumn": 33
    	"severity": 4,
    	"message": "CONFIG_UART_2_NRF_HW_ASYNC was assigned the value y, but got the value n. Missing dependencies:\nUART_2_ASYNC && UART_2_NRF_UARTE",
    	"startLineNumber": 26,
    	"startColumn": 1,
    	"endLineNumber": 26,
    	"endColumn": 27
    Provided zip:
    	"resource": "/c:/nordic/v2.0.0/nrf/applications/ncs200_serial_lte_modem_uart2hwfl/prj.conf",
    	"severity": 4,
    	"message": "CONFIG_LOG_BACKEND_UART was assigned the value n, but got the value n. Missing dependencies:\nUART_CONSOLE",
    	"startLineNumber": 19,
    	"startColumn": 1,
    	"endLineNumber": 19,
    	"endColumn": 24
    	"severity": 4,
    	"message": "CONFIG_SLM_NRF52_DFU_LEGACY was assigned the value n, but got the value n. Missing dependencies:\nSLM_NRF52_DFU",
    	"startLineNumber": 104,
    	"startColumn": 1,
    	"endLineNumber": 104,
    	"endColumn": 28
    We are using a NRF9160_xxAA_REV2 connected to a NRF5340_xxAA_ENGD, with the 01 to 14 pin connections:
    The same issue is not seen with UART0.
    Kimberly
  • Hi Kimberly,
    Are you able to check with an oscilloscope or logic analyzer to see if there is any output?
    did not see the same warning in my building process on the nRF Connect for VS Code. You can find the following log file.
     Executing task: nRF Connect: Build: ncs200_serial_lte_modem_uart2hwfl/build (active)
    Building ncs200_serial_lte_modem_uart2hwfl
    west build --build-dir c:\NCS\myApps\ncs200_serial_lte_modem_uart2hwfl\build c:\NCS\myApps\ncs200_serial_lte_modem_uart2hwfl --pristine --board nrf9160dk_nrf9160_ns -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="c:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl" -DDTC_OVERLAY_FILE:STRING="c:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/boards/nrf9160dk_nrf9160_ns.overlay" -DCONF_FILE:STRING="c:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/prj.conf;c:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/boards/nrf9160dk_nrf9160_ns.conf"
    -- west build: making build dir c:\NCS\myApps\ncs200_serial_lte_modem_uart2hwfl\build pristine
    -- Application: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl
    -- Found Python3: C:/NCS/toolchains/v2.0.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: C:/NCS/v2.0.0/zephyr/.cache
    -- Zephyr version: 3.0.99 (C:/NCS/v2.0.0/zephyr)
    -- Found west (found suitable version "0.13.1", minimum required is "0.7.1")
    -- Board: nrf9160dk_nrf9160_ns, Revision: 0.7.0
    -- Found host-tools: zephyr 0.14.1 (C:/NCS/toolchains/v2.0.0/opt/zephyr-sdk)
    -- Found dtc: C:/NCS/toolchains/v2.0.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: zephyr 0.14.1 (C:/NCS/toolchains/v2.0.0/opt/zephyr-sdk)
    -- Found BOARD.dts: C:/NCS/v2.0.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns.dts
    -- Found devicetree overlay: c:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/boards/nrf9160dk_nrf9160_ns.overlay
    -- Generated zephyr.dts: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/zephyr/dts.cmake
    warning: Experimental symbol HTTP_CLIENT is enabled.
    warning: Experimental symbol NET_SOCKETS_OFFLOAD is enabled.
    Parsing C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/Kconfig
    Loaded configuration 'C:/NCS/v2.0.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns_defconfig'
    Merged configuration 'c:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/prj.conf'
    Merged configuration 'c:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/boards/nrf9160dk_nrf9160_ns.conf'
    Configuration saved to 'C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/zephyr/.config'
    Kconfig header saved to 'C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 10.3.0
    -- The CXX compiler identification is GNU 10.3.0
    -- Found assembler: C:/NCS/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    -- Found Python3: C:/NCS/toolchains/v2.0.0/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
    Changed board to secure nrf9160dk_nrf9160 (NOT NS)
    === child image mcuboot -  begin ===
    loading initial cache file C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/mcuboot/child_image_preload.cmake
    Loading Zephyr default modules (Zephyr base (cached)).
    -- Application: C:/NCS/v2.0.0/bootloader/mcuboot/boot/zephyr
    -- Board: nrf9160dk_nrf9160, Revision: 0.7.0
    -- Found BOARD.dts: C:/NCS/v2.0.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
    -- Found devicetree overlay: C:/NCS/v2.0.0/bootloader/mcuboot/boot/zephyr/dts.overlay
    -- Generated zephyr.dts: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/mcuboot/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/mcuboot/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/mcuboot/zephyr/dts.cmake
    Parsing C:/NCS/v2.0.0/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration 'C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/mcuboot/zephyr/.config'
    No change to configuration in 'C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/mcuboot/zephyr/.config'
    No change to Kconfig header in 'C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/mcuboot/zephyr/include/generated/autoconf.h'
    MCUBoot bootloader key file: C:/NCS/v2.0.0/bootloader/mcuboot/root-ec-p256.pem
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/mcuboot
    === child image mcuboot -  end ===
    CMake Warning at C:\NCS\v2.0.0\nrf\modules\mcuboot\CMakeLists.txt:281 (message):
            --- WARNING: Using default MCUBoot key, it should not ---
            --- be used for production.                           ---
    Dropping partition 'nrf_modem_lib_trace' since its size is 0.
    -- Configuring done
    -- Generating done
    [1/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/NCS/v2.0.0/mbedtls/library/nist_kw.c.obj
    [2/379] Generating include/generated/version.h
    -- Zephyr version: 3.0.99 (C:/NCS/v2.0.0/zephyr), build: v3.0.99-ncs1
    [3/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/NCS/v2.0.0/mbedtls/library/base64.c.obj
    [4/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/pkcs12.c.obj
    [5/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/NCS/v2.0.0/mbedtls/library/version.c.obj
    [6/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/NCS/v2.0.0/mbedtls/library/platform.c.obj
    [7/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/NCS/v2.0.0/mbedtls/library/padlock.c.obj
    [8/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/NCS/v2.0.0/mbedtls/library/asn1parse.c.obj
    [9/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/pkparse.c.obj
    [10/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/NCS/v2.0.0/mbedtls/library/platform_util.c.obj
    [11/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/NCS/v2.0.0/mbedtls/library/asn1write.c.obj
    [12/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/NCS/v2.0.0/mbedtls/library/oid.c.obj
    [13/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/pem.c.obj
    [14/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/pkcs5.c.obj
    [15/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/dhm.c.obj
    [16/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/pk_wrap.c.obj
    [17/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/pkwrite.c.obj
    [18/379] Creating directories for 'tfm'
    [19/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/sha1.c.obj
    [20/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/cipher.c.obj
    [21/379] Creating directories for 'mcuboot_subimage'
    [22/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/pk.c.obj
    [23/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/sha256.c.obj
    [24/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/cipher_wrap.c.obj
    [25/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/aesni.c.obj
    [26/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/md5.c.obj
    [27/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/aria.c.obj
    [28/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/md.c.obj
    [29/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/ripemd160.c.obj
    [30/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/chachapoly.c.obj
    [31/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/ccm.c.obj
    [32/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/des.c.obj
    [33/379] No download step for 'tfm'
    [34/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/camellia.c.obj
    [35/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/cmac.c.obj
    [36/379] No download step for 'mcuboot_subimage'
    [37/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/ecp_curves.c.obj
    [38/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/sha512.c.obj
    [39/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/ecdh.c.obj
    [40/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/ecp.c.obj
    [41/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/ecdsa.c.obj
    [42/379] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [43/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/gcm.c.obj
    [44/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecjpake_oberon.c.obj
    [45/379] No update step for 'tfm'
    [46/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/ctr_drbg.c.obj
    [47/379] No update step for 'mcuboot_subimage'
    [48/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/entropy.c.obj
    [49/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/hkdf.c.obj
    [50/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/hmac_drbg.c.obj
    [51/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes_oberon.c.obj
    [52/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/rsa_alt_helpers.c.obj
    [53/379] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes.c.obj
    [54/379] No patch step for 'tfm'
    [55/379] No patch step for 'mcuboot_subimage'
    [56/379] Generating include/generated/driver-validation.h
    [57/379] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
    [58/379] No configure step for 'tfm'
    [58/379] Performing build step for 'tfm'
    [1/205] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/tfm_boot_data.o
    [2/205] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent/load_info_ns_agent.o
    [3/205] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/interface/src/tfm_psa_call_pack.o
    [4/205] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
    [5/205] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
    [6/205] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/static_load.o
    [7/205] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/arch/tfm_arch_v8m_main.o
    [8/205] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [9/205] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/psa_interface_thread.o
    [10/205] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/idle_partition/load_info_idle_sp.o
    [11/205] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memmove.o
    [12/205] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memset.o
    [13/205] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_strnlen.o
    [14/205] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memcmp.o
    [15/205] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memcpy.o
    [16/205] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/platform/tfm_platform_secure_api.o
    [17/205] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/spm/cmsis_psa/psa_interface_svc.o
    [18/205] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/service_api.o
    [19/205] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/crypto/tfm_crypto_secure_api.o
    [20/205] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [21/205] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
    [22/205] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/spm/cmsis_psa/psa_interface_thread.o
    [23/205] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_psa_call_pack.o
    [24/205] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
    [25/205] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/spm/cmsis_psa/psa_interface_sfn.o
    [26/205] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/ns_agent/load_info_ns_agent.o
    [27/205] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/idle_partition/load_info_idle_sp.o
    [28/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_alloc.o
    [29/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_cipher.o
    [30/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_init.o
    [31/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_mac.o
    [32/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_hash.o
    [33/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key.o
    [34/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_aead.o
    [35/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_derivation.o
    [36/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_asymmetric.o
    [37/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_rng.o
    [38/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/generated/secure_fw/partitions/crypto/auto_generated/intermedia_tfm_crypto.o
    [39/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_management.o
    [40/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/spm/cmsis_psa/psa_interface_thread.o
    [41/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/spm/cmsis_psa/psa_interface_svc.o
    [42/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/idle_partition/load_info_idle_sp.o
    [43/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/spm/cmsis_psa/psa_interface_sfn.o
    [44/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
    [45/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
    [46/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/ns_agent/load_info_ns_agent.o
    [47/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/interface/src/tfm_psa_call_pack.o
    [48/205] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [49/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/memory_buffer_alloc.o
    [50/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/psa_crypto_aead.o
    [51/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/psa_crypto_cipher.o
    [52/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/psa_crypto.o
    [53/205] Building C object platform/target/nrf9160/nrf_common/CMakeFiles/tfm_ns_scatter.dir/gcc/nordic_nrf_ns.ld
    [54/205] Building C object lib/fih/CMakeFiles/tfm_fih.dir/src/fih.o
    [55/205] Building C object lib/fih/CMakeFiles/tfm_fih.dir/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [56/205] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent/tfm_psa_api_veneers.o
    [57/205] Building ASM object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/nrf9160/gcc/startup_nrf9160_s.o
    [58/205] Building C object ns_log/CMakeFiles/tfm_ns_log.dir/tfm_log_raw.o
    [59/205] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
    [60/205] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent/load_info_ns_agent.o
    [61/205] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
    [62/205] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/idle_partition/load_info_idle_sp.o
    [63/205] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/common/faults.o
    [64/205] Building C object secure_fw/CMakeFiles/tfm_s.dir/spm/cmsis_psa/psa_interface_svc.o
    [65/205] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/interface/src/tfm_psa_call_pack.o
    [66/205] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [67/205] Building C object secure_fw/CMakeFiles/tfm_s.dir/spm/cmsis_psa/psa_interface_sfn.o
    [68/205] Building C object secure_fw/CMakeFiles/tfm_s.dir/spm/cmsis_psa/psa_interface_thread.o
    [69/205] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/utilities.o
    [70/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/ecjpake_oberon.o
    [71/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/rsa_alt_helpers.o
    [72/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/aes_oberon.o
    [73/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/aes.o
    [74/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/psa_crypto_client.o
    [75/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/psa_crypto_rsa.o
    [76/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/psa_crypto_hash.o
    [77/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/psa_crypto_ecp.o
    [78/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/psa_crypto_mac.o
    [79/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/random_ext.o
    [80/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/psa_crypto_storage.o
    [81/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/pem.o
    [82/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/psa_crypto_slot_management.o
    [83/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/psa_crypto_driver_wrappers.o
    [84/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/pkwrite.o
    [85/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/pkcs5.o
    [86/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/dhm.o
    [87/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/pkparse.o
    [88/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/pkcs12.o
    [89/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/cipher.o
    [90/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/pk_wrap.o
    [91/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/cipher_wrap.o
    [92/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/md.o
    [93/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/pk.o
    [94/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/sha512.o
    [95/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/sha256.o
    [96/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/ripemd160.o
    [97/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/sha1.o
    [98/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/camellia.o
    [99/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/aesni.o
    [100/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/des.o
    [101/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/md5.o
    [102/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/aria.o
    [103/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/ecdh.o
    [104/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/chachapoly.o
    [105/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/ccm.o
    [106/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/ecdsa.o
    [107/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/cmac.o
    [108/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/ecp_curves.o
    [109/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/hkdf.o
    [110/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/gcm.o
    [111/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/hmac_drbg.o
    [112/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/ecp.o
    [113/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/NCS/v2.0.0/mbedtls/library/rsa.o
    [114/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/NCS/v2.0.0/mbedtls/library/asn1parse.o
    [115/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/NCS/v2.0.0/mbedtls/library/base64.o
    [116/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/5c9ebf8b75281f0b27c0e5926e4c47c9/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [117/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/NCS/v2.0.0/mbedtls/library/asn1write.o
    [118/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/NCS/v2.0.0/mbedtls/library/oid.o
    [119/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/NCS/v2.0.0/mbedtls/library/bignum.o
    [120/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/NCS/v2.0.0/mbedtls/library/padlock.o
    [121/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/NCS/v2.0.0/mbedtls/library/platform.o
    [122/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/NCS/v2.0.0/mbedtls/library/nist_kw.o
    [123/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/NCS/v2.0.0/mbedtls/library/version.o
    [124/205] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/NCS/v2.0.0/mbedtls/library/platform_util.o
    [125/205] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\libmbedcrypto_base.a
    [126/205] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/tfm_hal_platform_common.o
    [127/205] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/spu.o
    [128/205] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/mpu_armv8m_drv.o
    [129/205] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/spm_hal.o
    [130/205] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/tfm_hal_isolation.o
    [131/205] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/generated/secure_fw/partitions/platform/auto_generated/intermedia_tfm_platform.o
    [132/205] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/platform_sp.o
    [133/205] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [134/205] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/interface/src/tfm_psa_call_pack.o
    [135/205] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/spm/cmsis_psa/psa_interface_sfn.o
    [136/205] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/spm/cmsis_psa/psa_interface_svc.o
    [137/205] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/spm/cmsis_psa/psa_interface_thread.o
    [138/205] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
    [139/205] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
    [140/205] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/idle_partition/load_info_idle_sp.o
    [141/205] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/ns_agent/load_info_ns_agent.o
    [142/205] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/cmsis_drivers/Driver_Flash.o
    [143/205] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/nrfx_glue.o
    [144/205] Building C object platform/CMakeFiles/platform_s.dir/C_/NCS/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.o
    [145/205] Building C object platform/target/nrf9160/nrf_common/CMakeFiles/tfm_s_scatter.dir/gcc/nordic_nrf_s.ld
    [146/205] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_ioctl_core_s_api.o
    [147/205] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/hw_init.o
    [148/205] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_hal_nvic.o
    [149/205] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_platform_hal_ioctl.o
    [150/205] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/plat_test.o
    [151/205] Building C object platform/CMakeFiles/platform_s.dir/C_/NCS/v2.0.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.o
    [152/205] Building C object platform/CMakeFiles/platform_s.dir/C_/NCS/v2.0.0/nrf/modules/tfm/tfm/boards/common/dummy_otp.o
    [153/205] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/nrf9160/tfm_interrupts.o
    [154/205] Building C object platform/CMakeFiles/platform_s.dir/C_/NCS/v2.0.0/nrf/modules/tfm/tfm/boards/common/tfm_hal_platform.o
    [155/205] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/nrf9160/target_cfg.o
    [156/205] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_hal_memory_symbols.o
    [157/205] Building C object platform/CMakeFiles/platform_s.dir/C_/NCS/v2.0.0/nrf/modules/tfm/tfm/boards/common/dummy_provisioning.o
    [158/205] Building C object platform/CMakeFiles/platform_s.dir/C_/NCS/v2.0.0/nrf/modules/tfm/tfm/boards/src/tfm_ioctl_s_api.o
    [159/205] Building C object platform/CMakeFiles/platform_s.dir/C_/NCS/v2.0.0/nrf/modules/tfm/tfm/boards/src/tfm_platform_system.o
    [160/205] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_platform.o
    [161/205] Building C object platform/CMakeFiles/platform_s.dir/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
    [162/205] Building C object platform/CMakeFiles/platform_s.dir/__/secure_fw/spm/cmsis_psa/psa_interface_thread.o
    [163/205] Building C object platform/CMakeFiles/platform_s.dir/__/secure_fw/spm/cmsis_psa/psa_interface_svc.o
    [164/205] Building C object platform/CMakeFiles/platform_s.dir/__/interface/src/tfm_psa_call_pack.o
    [165/205] Building C object platform/CMakeFiles/platform_s.dir/__/secure_fw/spm/cmsis_psa/psa_interface_sfn.o
    [166/205] Building C object platform/CMakeFiles/platform_s.dir/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
    [167/205] Building C object platform/CMakeFiles/platform_s.dir/__/secure_fw/partitions/idle_partition/load_info_idle_sp.o
    [168/205] Building C object platform/CMakeFiles/platform_s.dir/__/secure_fw/partitions/ns_agent/load_info_ns_agent.o
    [169/205] Linking C static library platform\libplatform_s.a
    [170/205] Linking C static library secure_fw\partitions\platform\libtfm_psa_rot_partition_platform.a
    [171/205] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\libcrypto_service_mbedcrypto.a
    [172/205] Linking C static library secure_fw\partitions\crypto\libtfm_psa_rot_partition_crypto.a
    [173/205] Linking C static library secure_fw\partitions\lib\sprt\libtfm_sprt.a
    [174/205] Linking C static library secure_fw\spm\libtfm_spm.a
    [175/205] Linking C static library lib\fih\libtfm_fih.a
    [176/205] Linking C executable bin\tfm_s.axf
               FLASH:       32256 B        48 KB     65.63%
                 RAM:       34956 B        64 KB     53.34%
    [177/205] Generating ../bin/tfm_s.elf
    [178/205] Generating ../bin/tfm_s.bin
    [179/205] Generating ../bin/tfm_s.hex
    [180/205] Linking C static library secure_fw\libtfm_s_veneers.a
    [181/205] Building ASM object app/CMakeFiles/tfm_ns.dir/C_/NCS/v2.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/nrf9160/gcc/startup_nrf9160_ns.o
    [182/205] Building C object app/CMakeFiles/tfm_ns.dir/C_/NCS/v2.0.0/modules/tee/tf-m/tf-m-tests/CMSIS/RTOS2/RTX/Source/rtx_lib.o
    [183/205] Building C object app/CMakeFiles/tfm_ns.dir/C_/NCS/v2.0.0/modules/tee/tf-m/tf-m-tests/ns_interface/ns_client_ext/tz_shim_layer.o
    [184/205] Building C object app/CMakeFiles/tfm_ns.dir/C_/NCS/v2.0.0/modules/tee/tf-m/tf-m-tests/CMSIS/RTOS2/RTX/Config/RTX_Config.o
    [185/205] Building C object app/CMakeFiles/tfm_ns.dir/os_wrapper_cmsis_rtos_v2.o
    [186/205] Building C object app/CMakeFiles/tfm_ns.dir/main_ns.o
    [187/205] Building C object app/CMakeFiles/tfm_api_ns.dir/C_/NCS/v2.0.0/modules/tee/tf-m/trusted-firmware-m/interface/src/tfm_crypto_ipc_api.o
    C:/NCS/v2.0.0/modules/tee/tf-m/trusted-firmware-m/interface/src/tfm_crypto_ipc_api.c: In function 'psa_key_derivation_get_capacity':
    C:\NCS\v2.0.0\modules\tee\tf-m\trusted-firmware-m\interface\src\tfm_crypto_ipc_api.c:1413:18: warning: initialization discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
     1413 |         {.base = &(operation->handle), .len = sizeof(uint32_t)},
    [188/205] Building C object app/CMakeFiles/tfm_api_ns.dir/C_/NCS/v2.0.0/modules/tee/tf-m/trusted-firmware-m/interface/src/tfm_psa_ns_api.o
    [189/205] Building C object app/CMakeFiles/tfm_api_ns.dir/C_/NCS/v2.0.0/modules/tee/tf-m/trusted-firmware-m/interface/src/tfm_platform_ipc_api.o
    [190/205] Building C object app/CMakeFiles/tfm_api_ns.dir/tfm_ns_interface.o
    [191/205] Building C object platform/CMakeFiles/platform_ns.dir/ext/target/nordic_nrf/common/core/services/src/tfm_ioctl_core_ns_api.o
    [192/205] Building C object platform/CMakeFiles/platform_ns.dir/ext/target/nordic_nrf/common/core/nrfx_glue.o
    [193/205] Building C object platform/CMakeFiles/platform_ns.dir/ext/target/nordic_nrf/common/core/cmsis_drivers/Driver_USART.o
    [194/205] Building C object platform/CMakeFiles/platform_ns.dir/C_/NCS/v2.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_uarte.o
    [195/205] Building C object platform/CMakeFiles/platform_ns.dir/C_/NCS/v2.0.0/nrf/modules/tfm/tfm/boards/common/dummy_uart_stdout.o
    [196/205] Building C object platform/CMakeFiles/platform_ns.dir/ext/target/nordic_nrf/common/core/plat_test.o
    [197/205] Building C object platform/CMakeFiles/platform_ns.dir/C_/NCS/v2.0.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.o
    [198/205] Building C object platform/CMakeFiles/platform_ns.dir/C_/NCS/v2.0.0/nrf/modules/tfm/tfm/boards/src/tfm_ioctl_ns_api.o
    [199/205] Linking C static library platform\libplatform_ns.a
    [200/205] Linking C static library app\libtfm_api_ns.a
    [201/205] Linking C static library ns_log\libtfm_ns_log.a
    [202/205] Linking C executable bin\tfm_ns.axf
               FLASH:        8420 B     376320 B      2.24%
                 RAM:       13952 B       192 KB      7.10%
    [203/205] Generating ../bin/tfm_ns.hex
    [204/205] Generating ../bin/tfm_ns.elf
    [205/205] Generating ../bin/tfm_ns.bin
    [64/379] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a
    [65/379] Performing build step for 'mcuboot_subimage'
    [1/66] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [2/66] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [3/66] Generating include/generated/offsets.h
    [4/66] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [5/66] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
    [6/66] Building C object zephyr/CMakeFiles/zephyr.dir/C_/NCS/v2.0.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [7/66] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [8/66] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [9/66] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [10/66] Generating linker_zephyr_pre1.cmd
    [11/66] Generating linker_zephyr_pre0.cmd
    [12/66] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
    [13/66] Building C object CMakeFiles/app.dir/C_/NCS/v2.0.0/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
    [14/66] Building C object CMakeFiles/app.dir/C_/NCS/v2.0.0/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
    [15/66] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [16/66] Building C object CMakeFiles/app.dir/C_/NCS/v2.0.0/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj
    [17/66] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [18/66] Building C object CMakeFiles/app.dir/C_/NCS/v2.0.0/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
    [19/66] Building C object CMakeFiles/app.dir/C_/NCS/v2.0.0/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
    [20/66] Building C object CMakeFiles/app.dir/main.c.obj
    [21/66] Building C object CMakeFiles/app.dir/C_/NCS/v2.0.0/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
    [22/66] Building C object zephyr/boards/boards/arm/nrf9160dk_nrf9160/CMakeFiles/boards__arm__nrf9160dk_nrf9160.dir/nrf52840_reset.c.obj
    [23/66] Building C object CMakeFiles/app.dir/C_/NCS/v2.0.0/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
    [24/66] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
    [25/66] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/rtt_console.c.obj
    [26/66] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [27/66] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [28/66] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [29/66] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [30/66] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [31/66] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
    [32/66] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [33/66] Building C object CMakeFiles/app.dir/C_/NCS/v2.0.0/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
    [34/66] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
    [35/66] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [36/66] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
    [37/66] Linking C static library zephyr\libzephyr.a
    [38/66] Linking C static library zephyr\boards\boards\arm\nrf9160dk_nrf9160\libboards__arm__nrf9160dk_nrf9160.a
    [39/66] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
    [40/66] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
    [41/66] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
    [42/66] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
    [43/66] Linking C static library zephyr\drivers\console\libdrivers__console.a
    [44/66] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/C_/NCS/v2.0.0/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
    [45/66] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [46/66] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [47/66] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [48/66] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
    [49/66] Linking C static library zephyr\drivers\flash\libdrivers__flash.a
    [50/66] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
    [51/66] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
    [52/66] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
    [53/66] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [54/66] Linking C static library app\libapp.a
    [55/66] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [56/66] Linking C static library modules\mcuboot\boot\bootutil\zephyr\libmcuboot_util.a
    [57/66] Linking C static library zephyr\kernel\libkernel.a
    [58/66] Linking C executable zephyr\zephyr_pre0.elf
    [59/66] Generating dev_handles.c
    [60/66] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
    [61/66] Linking C executable zephyr\zephyr_pre1.elf
    [62/66] Generating linker.cmd
    [63/66] Generating isr_tables.c, isrList.bin
    [64/66] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [65/66] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
    [66/66] Linking C executable zephyr\zephyr.elf
               FLASH:       32724 B        48 KB     66.58%
                SRAM:       17568 B     178968 B      9.82%
            IDT_LIST:          0 GB         2 KB      0.00%
    [67/379] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/include/tfm_ioctl_core_api.h
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/outputs/EXTERNAL/NRF/MODULES/TFM/TFM/BOARDS/NRF9160
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/outputs/EXTERNAL/NRF/MODULES/TFM/TFM/BOARDS/NRF9160/tfm_ns.axf
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/outputs/EXTERNAL/NRF/MODULES/TFM/TFM/BOARDS/NRF9160/tfm_ns.bin
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/outputs/EXTERNAL/NRF/MODULES/TFM/TFM/BOARDS/NRF9160/tfm_ns.elf
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/outputs/EXTERNAL/NRF/MODULES/TFM/TFM/BOARDS/NRF9160/tfm_ns.hex
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/outputs/EXTERNAL/NRF/MODULES/TFM/TFM/BOARDS/NRF9160/tfm_ns.map
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/outputs/EXTERNAL/NRF/MODULES/TFM/TFM/BOARDS/NRF9160/tfm_s.axf
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/outputs/EXTERNAL/NRF/MODULES/TFM/TFM/BOARDS/NRF9160/tfm_s.bin
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/outputs/EXTERNAL/NRF/MODULES/TFM/TFM/BOARDS/NRF9160/tfm_s.elf
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/outputs/EXTERNAL/NRF/MODULES/TFM/TFM/BOARDS/NRF9160/tfm_s.hex
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/outputs/EXTERNAL/NRF/MODULES/TFM/TFM/BOARDS/NRF9160/tfm_s.map
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/lib/s_veneers.o
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/include/psa/client.h
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/include/psa/error.h
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/include/psa_manifest/sid.h
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/include/tfm_api.h
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/include/tfm_ns_interface.h
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/include/psa_config.h
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/include/tfm_ns_client_ext.h
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/include/tfm_psa_call_pack.h
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/include/psa/crypto_extra.h
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/include/psa/crypto_compat.h
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/include/psa/crypto.h
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/include/psa/crypto_client_struct.h
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/include/psa/crypto_sizes.h
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/include/psa/crypto_struct.h
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/include/psa/crypto_types.h
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/include/psa/crypto_values.h
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/include/tfm_crypto_defs.h
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/include/tfm_platform_api.h
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/src/tfm_psa_ns_api.c
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/src/tfm_ns_interface.c.example
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/src/tfm_crypto_ipc_api.c
    -- Installing: C:/NCS/myApps/ncs200_serial_lte_modem_uart2hwfl/build/tfm/install/interface/src/tfm_platform_ipc_api.c
    [357/379] Linking C executable zephyr\zephyr_pre0.elf
    [361/379] Linking C executable zephyr\zephyr_pre1.elf
    [366/379] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
    [368/379] No install step for 'mcuboot_subimage'
    [369/379] Completed 'mcuboot_subimage'
    [370/379] Linking C executable zephyr\zephyr.elf
               FLASH:      233812 B     376320 B     62.13%
                SRAM:       95636 B     178968 B     53.44%
    [371/379] Generating zephyr/tfm_nonsecure.hex
    [372/379] Generating zephyr/mcuboot_primary_app.hex
    [373/379] Generating zephyr/mcuboot_primary.hex
    [374/379] Generating ../../zephyr/app_update.bin
    [375/379] Generating ../../zephyr/dfu_application.zip
    [376/379] Generating ../../zephyr/app_signed.hex
    [377/379] Generating ../../zephyr/app_test_update.hex
    [378/379] Generating ../../zephyr/app_moved_test_update.hex
    [379/379] Generating zephyr/merged.hex
    Charlie
