Send mesh network data to clound via Raspberry pi Gateway
Hi Team,
I am working on NRF52832 based on the BLE mesh protocol
here I am using the Light_switch example of SDK - nrf5sdkformeshv500src
Here I am trying on transmit a bool data from Light_switch - Client to Light_switch - Server  which ran successfully
Now my need is i want to upload all received data  in Light_switch - server  to the Cloud with raspberry pi Gateway
How to collect the data from several Light_switch - Server  in the mesh network and send it to the raspberry pi gateway
kindly guide me, Thanks in Advance
Best Regards,
Venkatraaman J S.
    Are you familiar with Python ?
    At which step do you have an issue ?
    If you are new to embedded programming, I would suggest to find an easier solution, for example simply send the data you collect via UART and write an application on RPi to collect data in UART.
    You need to figure out how to communicate between RPi and nRF52 via UART first.
  • Hai Hung Bui,
    " how to communicate between RPi and nRF52 via UART first"
    this only I am looking for that only I referred to the
    https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.meshsdk.v5.0.0%2Fmd_scripts_README.html&cp=8_2_2_4_9
    Kindly tell me how to
    Best Regards,
    Venkatraaman J S
  • I'm not very familiar with RPi development. So I can't really help you here.
    There are other threat that people have managed to make it work:
    UART Connection NRF52832 with Raspberry Pi
    I would suggest you to get familiar with the UART communication between NRF52 and a PC (Windows/Linux) before you move to RPi.
  • Hi
    I have  well experience in python and raspberry pi
    pi@raspberrypi:~/nrf5sdkformeshv500src/scripts/interactive_pyaci $ dmesg | grep tty
    [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=954c2cb3-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [ 0.000402] printk: console [tty1] enabled
    [ 2.914593] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
    [ 2.917214] printk: console [ttyS0] disabled
    [ 2.917339] 3f215040.serial: ttyS0 at MMIO 0x3f215040 (irq = 86, base_baud = 50000000) is a 16550
    [ 2.917602] printk: console [ttyS0] enabled
    [ 5.356207] systemd[1]: Created slice system-getty.slice.
    [ 5.359099] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [ 18.942839] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
    pi@raspberrypi:~/nrf5sdkformeshv500src/scripts/interactive_pyaci $ sudo python interactive_pyaci.py -d /dev/ttyACM0
    To control your device, use d[x], where x is the device index.
    Devices are indexed based on the order of the COM ports specified by the -d option.
    The first device, d[0], can also be accessed using device.
    Type d[x]. and hit tab to see the available methods.
    Python 3.9.2 (default, Mar 12 2021, 04:06:34)
    Type 'copyright', 'credits' or 'license' for more information
    IPython 8.4.0 -- An enhanced Interactive Python. Type '?' for help.
    In [1]:
    I am stucking here only,
    as before I asked  "how to communicate between RPi and nRF52 via UART ?"
    I had opened the terminal
    Here my question is  how to receive data from the nordic board
    NOTE:
    connection:
    I had connected the nordic board with raspberry via USB
    Venkatraaman J S
