NRF52833 SLEEP MODE & WAKEUP THROUGH GPIO INTERRUPT.
Hi All,
         I have implemented sleep mode in the firmware. I am using NRF52833 in my project. When the device is in idle state it goes in sleep mode. Now I wanted to wakeup the device through GPIO interrupt. How can I wake up the device? The sleep mode is implemented as below in the attached code.
#define AQ_USER_BUTTON          NRF_GPIO_PIN_MAP(0,4)
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
//bool erase_bonds;
   switch(pin)
      case AQ_USER_BUTTON:
              NRF_LOG_INFO("ADVERTISING START\r\n");
              advertising_start(false);
 void gpio_init(void)
    ret_code_t err_code;
    nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(false);
    in_config.pull = NRF_GPIO_PIN_PULLUP;
    err_code = nrf_drv_gpiote_in_init(AQ_USER_BUTTON, &in_config, in_pin_handler);
    nrf_drv_gpiote_in_event_enable(AQ_USER_BUTTON, true);
	  sleep = 1;
	  NRF_LOG_INFO("SLEEP MODE ENTER\r\n");
	  // Prepare wakeup buttons.
	  // APP_ERROR_CHECK(err_code);
		uint32_t err_code;
		switch (ble_adv_evt) {
		case BLE_ADV_EVT_FAST:
		NRF_LOG_INFO("Fast advertising.");
		case BLE_ADV_EVT_IDLE:
		sleep_mode_enter();
Is my code correct? what code needs to be put to wakeup the device from sleep mode and then advertise it again??
  • How do you configure/setup the timer? Are you using RTC/app_timer or the TIMER peripheral? As long as you only enter System ON idle mode, not System OFF, the timer can run during the sleep period. The timer will then wakeup the chip every 20 second. If you shut down the timer when going to sleep, you need to restart it when you press the button to wakeup.
    Please post your code to show what you are doing and what is not working.
