Unwanted "Leave" command from coordinator
Hello, I developed for my customer, a ZigBee coordinator in last 2019, using nRF5 SDK for Thread and Zigbee v3.2.0.
Now my customer has this issue:
- End Node connected via router, if router deads, the coordinator rejoin it but after few time send "leave" command to end node
Here attached WireShark log file of ZigBee radio communication
Some details:
- end node has NW address E3DF
- router has NW address D01B
- at line 14631 and following, the router deads
- at line 14680 starting end node routing search
- at line 14747 and followings rejon procedure
- at line 14850 Coordinator sends LEAVE command to end node E3DF
What is happened? Why Coordinator sends "Leave" command?
How can we avoid this unwanted behaviour?
Many thanks for your help!
Abele
  • Hi Abele,
    abe said:
    PS there are chances to migrate only the ZBOSS stack v3.1.0 to ZBOSS stack v3.3.0, and not all SDK?
    You must migrate the entire SDK if you are to migrate.
    abe said:
    it hasn't IAR EWARM project!!!
    Support for IAR and Keil was removed in v4.2. You can use either GCC or SES.
    I have an update from the developers:
    1. Migration from SDK v3.2 to SDK v4.X requires factory reset.
    2. For start I would suggest customer reproduces this issue and collects ZBOSS trace logs so maybe we can have an idea why is this happening in the first place.
      Also, can the same issue be reproduced with an unmodified coordinator or CLI example?
      Could customer also describe how their application works as this is based on the CLI sample?
      How big is this network? How many nodes are there?
    3. I have seen that the customer's coordinator device behaves in a strange manner - Link status is being sent 2 or even 3 times more frequent than it is supposed to - I don't have good explanation for this but it's concerning.
    4. I have seen that customer has some issues with the device - ZBOSS asserts were triggered which results in zb_nrf52840_abort() being called.
      https://devzone.nordicsemi.com/f/nordic-q-a/85117/zb_nrf52840_abort-function
      Have these issues been solved already?
      Also, was the device programmed to reset itself after zb_nrf52840_abort() is invoked in the customer's application?
    5. If customer is willing to share application's source code we may have a quick look at it. Making sure that there are no "unholy" things done or some shenanigans may be a good start.
    Marte
  • You must migrate the entire SDK if you are to migrate.
    then it is not possible to update only Zboss Stack? I have already done it from 3.0.0 to 3.1,0
    Zboss log need to be enabled (how we can do it?) and then we can try to reproduce the issue and register data. We must also "fisically" connect the serial out that is not provided on our boards
    In general, from  CLI sample is used only the Coordinator code part, in order to join on network some kind of end nodes.
    This brief summary of functionallity:
    - Start steering command to accept end node on network
    - FDS memory handle to store End Node data (such as cluster endpoint attributes values and so on)
    - BLE gatt used to read and write some ZigBee attributes
    - some attributes configured on autoreporting (tipically for ON/OFF status for bulbs and smart plug) and charge level for battery powered end nodes (such as door sensor, pusbutton, motion sensor ...)
    The networks we are using are 5 to 10 end nodes
    This is same on CLI original example of SDK3.2
    Yes solved
    I will ask to you if it agree your request
    This is not very simple to test ... but could you help us anyway to find the issue?
    Thanks for help
    Abele
  • Hi Abele,
    Thank you for providing the additional information!
    It is possible to do so, but the SDK might not be compatible with a different version of ZBOSS than it was made for. Additionally, platform certification points out one particular version of ZBOSS, so you will not be able to use platform certification if you use a different version of the ZBOSS stack than the SDK was certified with.
    This is described in the documentation here: Debugging, but what you need to do is to:
    • Replace the libzboss libraries in your project with the files located in <InstallFolder>/external/zboss/lib/debug
    • Configure the following in sdk_config.h:
    Configuration option Value for nRF52840 Value for nRF52833*
    NRF_LOG_DEFAULT_LEVEL 4 4
    NRF_LOG_BUFSIZE 65536 32768
    NRF_LOG_MSGPOOL_ELEMENT_COUNT 32 32
    NRF_LOG_MSGPOOL_ELEMENT_SIZE 40 40
    NRF_LOG_BACKEND_RTT_TX_RETRY_CNT 100 100
    SEGGER_RTT_CONFIG_BUFFER_SIZE_UP 32768 512
    • Then change these in main():
      ZB_SET_TRACE_LEVEL(ZIGBEE_TRACE_LEVEL);
      ZB_SET_TRACE_MASK(ZIGBEE_TRACE_MASK);
      to
      ZB_SET_TRACE_LEVEL(4);
      ZB_SET_TRACE_MASK(TRACE_SUBSYSTEM_ZCL | TRACE_SUBSYSTEM_ZDO | TRACE_SUBSYSTEM_NWK | TRACE_SUBSYSTEM_SECUR);
    The UART log from nRF Should output some character strings. Please save this log and upload it here so I can forward it to the developers for decoding.
    Marte
  • Thanks Marte
    I next days (or next week) I will arrange the needed modify to have Zboss Log Out and I will try to reproduce the issue (but it is not easy, the issue is randomly)
    As I have news I will send you the results
    Abele
  • Hi Abele,
    I have an update from the developers as well:
    1. Changing only ZBOSS libs should be only with the rest of the SDK - there were some major changes between SDK v3.2 and v4.X.
      I pretty sure that even attempt to change ZBOSS libs will require factory reset of the device.
    2. ZBOSS logs could also be configured to be printed over RTT so maybe the additional connector for serial is not required.
    3. Customer claims that the Link Status issue could be reproduced with the original CLI example.
      Could you ask them to how can it be reproduced? I have tried a bit but wasn't able to reproduce it.
    Marte
