nRF5340 non-simultaneous netcore updates with external QSPI
Development Environment: VS Code on Windows 10, SDK: 2.0.0, HW: nRF5340 Development Kit
I am trying to perform just a network core update on the nRF5340 DK based off of the smp_svr sample where the secondary slot for incoming updates is on an external QSPI. Using the Device Manager app, I can perform application core updates without issue, but when doing a network core update, MCUBoot seems to interpret the incoming image as an application core update no matter what. Which causes a second boot cycle as it swaps the images back.
uart:~$ *** Booting Zephyr OS build v3.0.99-ncs1 ***
I: Starting bootloader
I: Primary image: magic=good, swap_type=0x4, copy_done=0x1, image_ok=0x1
I: Secondary image: magic=good, swap_type=0x2, copy_done=0x3, image_ok=0x3
I: Boot source: none
I: Swap type: test
I: Starting swap using move algorithm.
I: Bootloader chainload address offset: 0xc000
I: Primary image: magic=good, swap_type=0x2, copy_done=0x1, image_ok=0x3
I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Swap type: revert
[00:00:00.017,791] <inf> smp_sample: build time: Jul 6 2022 15:24:46
[00:00:00.041,656] <inf> smp_bt_sample: Bluetooth initialized
[00:00:00.045,532] <inf> smp_bt_sample: Advertising successfully started
I have an overlay both top level and the child images containing:
// Choose the external flash to be used by partition manager (and allow MCUBoot to use external flash)
	chosen {
		nordic,pm-ext-flash = &mx25r64;
And the following config files:
prj.conf:
## Bootloader
# Enable mcumgr.
CONFIG_MCUBOOT_IMAGE_VERSION="1.0.0+0"
CONFIG_MCUMGR=y
CONFIG_MCUBOOT_IMG_MANAGER=y
CONFIG_IMG_MANAGER=y
CONFIG_MCUMGR_CMD_IMG_MGMT=y
CONFIG_MCUMGR_CMD_OS_MGMT=y
# Some command handlers require a large stack.
CONFIG_MAIN_STACK_SIZE=2048
# Ensure an MCUboot-compatible binary is generated andcanp update the net core
CONFIG_BOOTLOADER_MCUBOOT=y
# Enable flash operations.
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_STREAM_FLASH_ERASE=y
# QSPI for External Flash
CONFIG_SPI=n
CONFIG_NORDIC_QSPI_NOR=y
CONFIG_NORDIC_QSPI_NOR_STACK_WRITE_BUFFER_SIZE=16
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
# Enable logging
CONFIG_LOG=y
CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN=y
# Enable shell commands.
CONFIG_SHELL=y
CONFIG_MCUMGR_CMD_SHELL_MGMT=y
## BLE
# Allow for large Bluetooth data packets.
CONFIG_BT_L2CAP_TX_MTU=498
CONFIG_BT_BUF_ACL_RX_SIZE=502
CONFIG_BT_BUF_ACL_TX_SIZE=502
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
# Enable the Bluetooth mcumgr transport (unauthenticated).
CONFIG_MCUMGR_SMP_BT=y
CONFIG_MCUMGR_SMP_BT_AUTHEN=n
CONFIG_MCUMGR_SMP_BT_CONN_PARAM_CONTROL=y
# Enable the Shell mcumgr transport.
CONFIG_MCUMGR_SMP_SHELL=y
# Enable the mcumgr Packet Reassembly feature over Bluetooth and its configuration dependencies.
# MCUmgr buffer size is optimized to fit one SMP packet divided into five Bluetooth Write Commands,
# transmitted with the maximum possible MTU value: 498 bytes.
CONFIG_MCUMGR_SMP_REASSEMBLY_BT=y
CONFIG_MCUMGR_BUF_SIZE=2475
CONFIG_OS_MGMT_MCUMGR_PARAMS=y
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_DEBUG_THREAD_INFO=y
CONFIG_DEBUG_OPTIMIZATIONS=y
child_image/mcuboot.conf:
# MCUboot requires a large stack size, otherwise an MPU fault will occur
CONFIG_MAIN_STACK_SIZE=10240
# Net Core Update Support?
CONFIG_PCD_APP=y
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_STREAM_FLASH=y
CONFIG_FLASH_SIMULATOR=y
CONFIG_FLASH_SIMULATOR_DOUBLE_WRITES=y
CONFIG_FLASH_SIMULATOR_STATS=n
CONFIG_MULTITHREADING=y
# This must be increased to accommodate the bigger images.
CONFIG_BOOT_MAX_IMG_SECTORS=256
# External QSPI secondary slot
# Various Things to Be small enough but still have logging prints
CONFIG_SIZE_OPTIMIZATIONS=y
CONFIG_DEBUG_OPTIMIZATIONS=n
CONFIG_LOG=y
CONFIG_LOG_MODE_MINIMAL=y # former CONFIG_MODE_MINIMAL
CONFIG_LOG_DEFAULT_LEVEL=0
Am I missing something here? I do notice when I debug to MCUBoot's loader.c line 982, where the vector table of the image is grabbed, the loaded data seems to be from the internal flash rather than the external memory. I have gone through the thread here nRF5340 Netcore firmware update using external flash - Nordic Q&A - Nordic DevZone - Nordic DevZone (nordicsemi.com) but my behavior isn't lining up and discussion is all on pre 2.0.0 SDKs. I tried UPGRADE_ONLY but it seems to do the same thing but not be able to revert back and so end up in a boot loop. As said in the title I have no need for simultaneous updates, I am just trying to perform core updates one at a time from the external QSPI.
Attached at the bottom is my minimal reproduction based off of smp_svr. Would greatly appreciate any assistance or pointers on this.
D Miller
smp_svr_ext_qspi.zip
