Extended advertising stops after connection gets established in nRF Connect SDK
Hello..
I tried implementing a simple application using nRF Connect SDK, which sends data in a connection event using notifications. This is the base code for a test application which requires the peripheral to operate in the connectable (and non-scannable) undirected advertising mode. According to the BLE specs, this is only achievable using advertising extensions.
The connection gets established successfully and I am also able to see the notification data using nRF Connect App for Android. However, once the peripheral enters connection, it stops advertising, and does not re-start advertising even after getting disconnected. The only way it starts advertising again is resetting the peripheral. After a lot of struggle, this is the current status:
  •  Inside the connection disconnected callback function, I called the extended advertising start function, and this worked perfectly. Once the peripheral gets disconnected, it resumes extended advertising.
  • However, this is not the desired behavior. I want the peripheral to keep advertising once it enters the connection mode so that it is also visible to other devices. I searched and came across the following GitHub link and few other links referenced in this discussion that pointed out the exactly same issue:
    https://github.com/zephyrproject-rtos/zephyr/issues/33897
    The suggested workaround in this discussion is to call the extended advertising start function inside the advertising connected callback (using the bt_le_ext_adv_cb callback struct) inside the bt_le_ext_adv_create() function. I tried doing this, exactly the same way as I called the extended advertising start function inside the disconnected callback function earlier.
    But this does not seem to work. I keep on getting either the ENOMEM error (error -12), or the error log shown in the picture:
The same method works with the disconnected callback but fails with the advertising connected callback. Is there anything that I might have missed?
The proj.config file looks like this:
# Increased stack due to settings API usage
CONFIG_BT=y
CONFIG_BT_DEBUG_LOG=y
CONFIG_BT_SMP=y
CONFIG_BT_SIGNING=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_ATT_PREPARE_COUNT=5
CONFIG_BT_PRIVACY=y
CONFIG_BT_DEVICE_NAME="Zephyr Peripheral Sample Long Name"
CONFIG_BT_DEVICE_APPEARANCE=833
CONFIG_BT_DEVICE_NAME_DYNAMIC=y
CONFIG_BT_DEVICE_NAME_MAX=65
CONFIG_BT_KEYS_OVERWRITE_OLDEST=y
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_BT_BUF_ACL_RX_SIZE=251
CONFIG_BT_L2CAP_TX_MTU=247
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=n
CONFIG_BT_USER_DATA_LEN_UPDATE=y
CONFIG_BT_LL_SW_SPLIT=y
CONFIG_BT_EXT_ADV=y
CONFIG_BT_CTLR_ADV_EXT=y
CONFIG_BT_CTLR_ADVANCED_FEATURES=y
CONFIG_BT_CTLR_ADV_DATA_BUF_MAX=6
CONFIG_BT_MAX_CONN=20
nRF52840 has been used as the peripheral. Could you please look into this once and suggest a suitable workaround?
  • Sukriti said:
    If use two sets (as used in the sample) and I make the second advertising set connectable, would it mean allowing two simultaneous connections
    Yes, you should be able to connect to two devices with different advertising sets.
    You say that the multiple advertising sets sample only starts the second advertising after disconnection? That is not what the sample does by default though, it creates both advertising sets one at a time, starting one and creating the next adv. set afterwards. It should not be necessary to connect/disconnect at all to see both advertising sets started.
    	err = non_connectable_adv_create(); //advertising set 1
    	if (err) {
    		return;
    	printk("Non-connectable advertising started\n");
    	err = connectable_adv_create(); //advertising set 2
    	if (err) {
    		return;
    	printk("Connectable advertising started\n");
    Simon
  • Oh, I'm sorry, yes you're right. I got confused while typing, wanted to say something else. I actually wanted to say that the connectable advertising set resumes only after getting disconnected. You said that i should be able to start the same advertising set after getting connected to a device. But I had already tried doing that, and i got the errors that i attached.
    And in the sample, the second advertising set starts once the device gets connected (not the same set). The same set starts only after getting disconnected. I hope I'm able to convey where I'm getting stuck.
  • Hi Simon, thanks for the help. The issue got resolved, you can close the ticket!
  • Hi Sukriti! Could you share with me how you could solve this?
