nrf52840 S140 Central DFU Bluetooth Zephyr 2.0.0 nrf52840 peripheral
We have nrf52840 S140 BLE Central device that currently connects to TI based sensors. I have implemented code that can upgrade those TI sensors' firmware using the TI BLE protocol.
Now we are developing our own BLE peripheral sensors also based on the nrf52840 but now using the newly supported Zephyr 2.0.0. RF connect stuff. I can update the sensors using the Nordic Android program (unauthenticated for now) and now need to implement upgrading BLE DFU using our central device which connects to a cellular gateway.
I do not want to reinvent the wheel, writing existing code, like I had to do with the TI sensors.
Could you point me to code that allows a Central device to update a peripheral device BLE DFU?
If not where can I look to reinvent another wheel?
Thanks David
  • DavidKaplan said:
    Finally!
    Hurray!
    I still remember you asking if it is possible to stream the data directly instead of storing it in the flash of the SMP Central.
    We do not have a solution for that, so you will have to make it yourself if you need it.
    But now that you can perform an update from the SMP Client with flash storage, it is a good starting point!
    DavidKaplan said:
    Could you point me to a current thread about adding back the key to the bootloader in Zephyr v2.2.0 ?
    Official documentation can be found at Adding MCUboot as an immutable bootloader.
    I have an unofficial sample of adding this using CMake for relative paths at MCUboot Custom Key with SMP Server.
    Sigurd Hellesvik
  • Hello everyone,
    I am trying to get the smp_client_ble sample to work, provided in: https://github.com/hellesvik-nordic/samples_for_nrf_connect_sdk/tree/main/bootloader_samples/client_smp/smp_client_ble
    However it seems that the ZCBOR library has been updated and the included patch does not work anymore. I tried following this ticket and doing some changes, for example increasing the size of the array version_key and changing functions like zcbor_new_decode_state() to match the lastest ZCBOR update, however the image list, upload, and confirm are not working at all.
    I am getting the following errors:
    1) image list:
    f3--- 8 messages dropped ---
    bed5ea8b2112f4cc6a153cdc7f2fc11c2c485a221d317bf5135
          bootable: true
    Decoding error, pending value (err: 11)
    2) upload
     --- 11 messages dropped ---
                                           | (0/483328 bytes)Error in image upload response: 1
    3) test
    Decoding error, start_decode images->list  (err: 10)
    Here are the errors with CONFIG_ZCBOR_VERBOSE enabled:
    1) image list:
    zcbor_map_start_decode New backup (level 0)
    zcbor_tstr_decode rem: 133, cur: 0x66, ec: 0xfffffff0, err: 0, value_extract
    zcbor_list_start_decode New backup (level 1)
    zcbor_map_start_decode New backup (level 2)
    zcbor_tstr_decode rem: 124, cur: 0x64, ec: 0xfffffff0, err: 0, value_extract
    zcbor_int32_decode zcbor_int_decode rem: 119, cur: 0x0, ec: 0xffffffef, err: 0, value_extract
    zcbor_tstr_decode rem: 118, cur: 0x67, ec: 0xffffffee, err: 0, value_extract
    zcbor_tstr_decode rem: 110, cur: 0x65, ec: 0xffffffed, err: 0, value_extract
    zcbor_tstr_decode rem: 104, cur: 0x64, ec: 0xffffffec, err: 0, value_extract
    zcbor_bstr_decode rem: 99, cur: 0x58, ec: 0xffffffeb, err: 0, value_extract
    zcbor_tstr_decode rem: 65, cur: 0x68, ec: 0xffffffea, err: 0, value_extract
    zcbor_bool_expect zcbor_simple_expect zcbor_simple_decode zcbor_simple_decode rem: 56, cur: 0xf5, ec: 0xffffffe9, err: 0, value_extract
    zcbor_tstr_decode rem: 55, cur: 0x67, ec: 0xffffffe8, err: 0, value_extract
    zcbor_bool_expect zcbor_simple_expect zcbor_simple_decode zcbor_simple_decode rem: 47, cur: 0xf4, ec: 0xffffffe7, err: 0, value_extract
    simple value 20 != 21
    ZCBOR_FAIL rem: 47, cur: 0xf4, ec: 0xffffffe7, err: 11, WEST_TOPDIR/modules/lib/zcbor/src/zcbor_decode.c:1081
          bootable: true
    2) upload:
    rem: 299, cur: 0x65, ec: 0x0, err: 0, value_encode_len
    rem: 293, cur: 0x0, ec: 0x1, err: 0, value_encode_len
    rem: 292, cur: 0x64, ec: 0x2, err: 0, value_encode_len
    rem: 287, cur: 0x58, ec: 0x3, err: 0, value_encode_len
    rem: 135, cur: 0x63, ec: 0x4, err: 0, value_encode_len
    rem: 131, cur: 0x1a, ec: 0x5, err: 0, value_encode_len
    rem: 126, cur: 0x63, ec: 0x6, err: 0, value_encode_len
    rem: 122, cur: 0x0, ec: 0x7, err: 0, value_encode_len
    rem: 121, cur: 0x63, ec: 0x8, err: 0, value_encode_len
    rem: 117, cur: 0x45, ec: 0x9, err: 0, value_encode_len
    rem: 111, cur: 0x67, ec: 0xa, err: 0, value_encode_len
    rem: 103, cur: 0xf4, ec: 0xb, err: 0, value_encode_len
     --- 10 messages dropped ---
                                            | (0/483328 bytes)zcbor_map_start_decode New backup (level 0)
    zcbor_tstr_decode rem: 5, cur: 0x62, ec: 0xfffffff0, err: 0, value_extract
    zcbor_int32_decode zcbor_int_decode rem: 2, cur: 0x1, ec: 0xffffffef, err: 0, value_extract
    3) test:
    rem: 299, cur: 0x64, ec: 0x0, err: 0, value_encode_len
    rem: 294, cur: 0x58, ec: 0x1, err: 0, value_encode_len
    rem: 260, cur: 0x67, ec: 0x2, err: 0, value_encode_len
    rem: 252, cur: 0xf4, ec: 0x3, err: 0, value_encode_len
    zcbor_list_start_decode ZCBOR_ERR(10) ZCBOR_FAIL rem: 2, cur: 0x1, ec: 0xffffffef, err: 10, WEST_TOPDIR/modules/lib/zcbor/src/zcbor_decode.c:51
    ZCBOR_FAIL rem: 2, cur: 0x1, ec: 0xffffffef, err: 10, WEST_TOPDIR/modules/lib/zcbor/src/zcbor_decode.c:648
    any help on this would be greatly appreciated
    regards,
    Omar
