nrf52840 S140 Central DFU Bluetooth Zephyr 2.0.0 nrf52840 peripheral
We have nrf52840 S140 BLE Central device that currently connects to TI based sensors. I have implemented code that can upgrade those TI sensors' firmware using the TI BLE protocol.
Now we are developing our own BLE peripheral sensors also based on the nrf52840 but now using the newly supported Zephyr 2.0.0. RF connect stuff. I can update the sensors using the Nordic Android program (unauthenticated for now) and now need to implement upgrading BLE DFU using our central device which connects to a cellular gateway.
I do not want to reinvent the wheel, writing existing code, like I had to do with the TI sensors.
Could you point me to code that allows a Central device to update a peripheral device BLE DFU?
If not where can I look to reinvent another wheel?
Thanks David
  • I have been working on other things in this project and on other more urgent projects changes and fixes.
    Now I am back on this and still need to get this working somehow.
    If you could just write the correct APIs in every step, I may be able to advance this. quicker.
    One of my peripheral sensors stopped working when trying to measure its current.
    It is not detected by the SDK. Is there any way to brick a nRF52840 or have I just damaged a pin?
    Thanks David
  • DavidKaplan said:
    3) The Central will send a message to erase its slot#1 image
    Is Slot#1 correct?
    What API should I call?
    You should put the update into the secondary slot, so if you refer to the primary slot as slot#0 and the secondary slot as slot#1, then slot#1 is correct yes.
    Regarding what API to call to erase the secondary slot, you can take a look at the function img_mgmt_upload()-->img_mgmt_impl_erase_image_data() (called in response to an mcumgr upload command), as you can see, it uses the function flash_area_erase() to erase the secondary slot.
    DavidKaplan said:
    5) The Central will send a message to flash the 64K to Slot#1 at the specified offset.
    Take a look at the same function img_mgmt_impl_erase_image_data(), as mentioned above. It will write to the secondary slot using img_mgmt_impl_write_image_data()-->flash_img_buffered_write()-->stream_flash_buffered_write()
    If using fota_download+dfu_target_mcuboot (used by nRF91 to update appl.) the same function is used: dfu_target_write-->dfu_target_mcuboot_write()-->
    stream_flash_buffered_write().
    I guess it could work to just use flash_map.h-->flash_area_write() or flash.h-->flash_write, but as mentioned in the documentation, there are some advantages with using the Stream Flash API:
    "One typical use of a stream write operation is when receiving a new firmware image to be used in a DFU operation.
    There are several reasons why one might want to use buffered writes instead of writing the data directly as it is made available. Some devices have hardware limitations which does not allow flash writes to be performed in parallel with other operations, such as radio RX and TX. Also, fewer write operations result in faster response times seen from the application."
    DavidKaplan said:
    7) The Central will send a message to get the image's hash.
    Check how it's done in the function \zephyr\subsys\mgmt\mcumgr\lib\cmd\img_mgmt\src\img_mgmt.c-->img_mgmt_read_info(), which will read the version and build hash from the specified image slot.
    DavidKaplan said:
    8) The Central will send a message to "test" the image
    Check out how how the image management library does it: \zephyr\subsys\mgmt\mcumgr\lib\cmd\img_mgmt\include\img_mgmt\img_mgmt.h-->img_mgmt_state_set_pending()-->img_mgmt_impl_write_pending()-->boot_request_upgrade_multi()
    So you can set the image to a "test" (run once and then revert) state by running boot_request_upgrade_multi(int image_index, int permanent) with permanent=0, or confirm the image by setting permanent=1 (run image forever).
    DavidKaplan said:
    9) The Central will send a message to reset the peripheral.
    You can use \zephyr\lib\os\reboot.c-->sys_reboot() for this.
    DavidKaplan said:
    10) Upon reconnection, the Central will send a message to "confirm" the image.
    You can do this by running boot_write_img_confirmed() from within the app itself, like it's done in the http_update sample: https://github.com/nrfconnect/sdk-nrf/blob/v2.0.2/samples/nrf9160/http_update/application_update/src/main.c#L60
    DavidKaplan said:
    If the nRF Toolbox app is able to upgrade the peripheral, do I need any new prog.confg defines for the suggested API?
    If you wan't to perform a DFU app from the phone using custom BLE commands and the APIs I suggested above, you can use the nRF Connect for Mobile app: https://www.nordicsemi.com/Products/Development-tools/nrf-connect-for-mobile
    If you want to perfom a DFU using mcumgr protocol, I suggest using the nRF Connect Device Manager app and follow the DFU guide.
    DavidKaplan said:
    Another quick question that is related.
    If I design the project with a mode that leaves the Peripherals always connected,
    I understand that I may be able to get an even lower Peripheral current drain.
    If a Peripheral is at the edge of the BLE signal range or there is a lot of interference ,
    will I end up wasting a lot for current?
    This is not my area of expertise. Could you open a new ticket and ask about it there. I think you will get better help then.
    Simon
  • I successfully upgraded a unit once but did not saved immediately the code and evidently changed something and it now fails when calling img_mgmt_impl_write_pending().
    I guess I could build a small project for the nRF52840-DK  using the serial uart interface.
    It is hard to debug break with the BLE running.
    In my main program when running the debugger it always says the image is not confirmed.
    I expected this to occur just once after DFU.
      // DFU upgraded and not confirmed, confirm
      if (!boot_is_img_confirmed()){
        err = boot_write_img_confirmed();
    	  if (err) {
    		  d_printf(LINE_INFO,kDbg_Error|kDbg_Display,"BootConfirmErr:%d",err);
        }else{
              d_printf(LINE_INFO,kDbg_Error|kDbg_Display,"BootConfirmed");
    Here is my DFU code if you see anything wrong.
    I could not find a way to set the global area_id except for setting it myself.
    I would think that some function should set it.
    g_img_mgmt_state.area_id = UPLOAD_FLASH_AREA_ID;
    #include <stddef.h>
    #include <string.h>
    #include <stdio.h>
    #include <errno.h>
    #include <kernel.h>
    #include <zephyr.h>
    #include <sys/printk.h>
    #include <zcbor_encode.h>
    #include <zcbor_decode.h>
    #include <zcbor_common.h>
    #include <zephyr/bluetooth/hci.h>
    #include <zephyr/bluetooth/hci_vs.h>
    #include <zephyr/bluetooth/conn.h>
    #include <zephyr/bluetooth/uuid.h>
    #include <zephyr/bluetooth/gatt.h>
    #include <bluetooth/gatt_dm.h>
    #include <zephyr/sys/byteorder.h>
    #include <bluetooth/services/dfu_smp.h>
    #include <sys/reboot.h>
    #include <zephyr/sys/ring_buffer.h>
    #include <dfu/mcuboot.h>
    #include <zephyr/dfu/mcuboot.h>
    #include <dfu/dfu_target.h>
    #include <dfu/dfu_target_stream.h>
    #include <dfu/dfu_target_mcuboot.h>
    #include <img_mgmt/img_mgmt_impl.h>
    #include <img_mgmt/img_mgmt.h>
    #include <img_mgmt/image.h>
    #include <storage/flash_map.h>
    #include <dfu/flash_img.h>
    #include <devicetree.h>
    #if FLASH_AREA_LABEL_EXISTS(image_1)
    	#define UPLOAD_FLASH_AREA_ID FLASH_AREA_ID(image_1)
    #include "aqua_def.h"
    #include "d_printf.h"
    #include "ami_ble.h"
    #include "ami_main_serv.h"
    #include "ami_setup_serv.h"
    #include "ami_learn_serv.h"
    #include "ami_transfer_serv.h"
    #include "ami_timer.h"
    #include "ami_dfu.h"
    #include "ami_watchdog.h"
    // define Ring buffers
    RING_BUF_ITEM_DECLARE_SIZE(dfu_ring_buf, AMI_DFU_RING_BUF_SIZE);
    // Variables
    ami_dfu_state_struct    *dfu_state = NULL;
    static struct	flash_img_context flash_img;
    // ami_dfu_HandlePacket
    //  Description
    //   Parses an incoming BLE image packet
    //  Parameters
    //  Returns
    //   0 = OK
    int ami_dfu_HandlePacket(uint8_t *buf,uint16_t buf_pos,uint16_t len)
      // transfer_receive_cb
      int       err = 0;
      uint16_t  data_len;
      // FileRxOffset
      dfu_state->FileRxOffset.bytes[LSB_LO_BYTE] = buf[buf_pos++];
      dfu_state->FileRxOffset.bytes[LSB_HI_BYTE] = buf[buf_pos++];
      dfu_state->FileRxOffset.bytes[MSB_LO_BYTE] = buf[buf_pos++];
      dfu_state->FileRxOffset.bytes[MSB_HI_BYTE] = buf[buf_pos++];
      // If FileRxOffset==0 then FileSize sent
      if (!dfu_state->FileRxOffset.ulong){
        dfu_state->FileSize.bytes[LSB_LO_BYTE] = buf[buf_pos++];
        dfu_state->FileSize.bytes[LSB_HI_BYTE] = buf[buf_pos++];
        dfu_state->FileSize.bytes[MSB_LO_BYTE] = buf[buf_pos++];
        dfu_state->FileSize.bytes[MSB_HI_BYTE] = buf[buf_pos++];
      data_len = (len-buf_pos);
      // Something to write to Flash
      if (data_len){
        // Store image data
        if (dfu_state->FileRingWrOffset==dfu_state->FileRxOffset.ulong){
          uint16_t num_put = ring_buf_put(&dfu_ring_buf,&buf[buf_pos],data_len);
          if (num_put!=data_len) {
            dfu_state->err = AMI_DFU_CENTRAL_ERR_RING_OVERFLOW;
            d_printf(LINE_INFO,kDbg_Error|kDbg_General,"RingPut:%u Rx:%u Off:%ld",num_put,data_len,dfu_state->FileRxOffset.ulong);
            return err;
          }else{
                dfu_state->FileRingWrOffset += data_len;
        }else{
              // This was a retry that the Central did not received an acknowledgemnet
      return err;
    } // ami_dfu_HandlePacket
    // ami_dfu_HandleBlock
    //  Description
    //   Handles the incoming DFU image block
    //  Parameters
    //  Returns
    //  the offset to send back o the Central
    uint32_t ami_dfu_HandleBlock(void)
      static   uint8_t wr_buf[CONFIG_IMG_BLOCK_BUF_SIZE];
      bool     bLast      = false;
      // If there was a fatal error, just return the last error
      if (dfu_state->err){
        return dfu_state->err;
      // All bytes were received?
      bool bRxFinished = (dfu_state->FileRingWrOffset>=dfu_state->FileSize.ulong);
      do{
          // Peek and see how many bytes accumulated exist
          uint32_t accum_bytes = ring_buf_size_get(&dfu_ring_buf);
          // Wait to write until we have CONFIG_IMG_BLOCK_BUF_SIZE bytes or last packet
          if (accum_bytes<CONFIG_IMG_BLOCK_BUF_SIZE && !bRxFinished){
          // Don't write more than CONFIG_IMG_BLOCK_BUF_SIZE bytes at a time
          if (accum_bytes>CONFIG_IMG_BLOCK_BUF_SIZE){
            accum_bytes = CONFIG_IMG_BLOCK_BUF_SIZE;
          // Calculate the number of bytes left to write to flash
          uint32_t bytes_to_wr = (dfu_state->FileSize.ulong-dfu_state->FileWrOffset);
          // Last block to write?
          if (accum_bytes>=bytes_to_wr){
            accum_bytes = bytes_to_wr;
            bLast       = true;
          // Get the bytes from the ring buffer
          uint32_t data_len   = ring_buf_get(&dfu_ring_buf,wr_buf,accum_bytes);
          // Nothing to write?
          if (!data_len){
          // Write the data to the flash
          int err = img_mgmt_impl_write_image_data(dfu_state->FileWrOffset,wr_buf,data_len,bLast);
          if (err!=0) {
            dfu_state->err = AMI_DFU_CENTRAL_ERR_WR_BLOCK;
            d_printf(LINE_INFO,kDbg_Error|kDbg_General,"ImageWrErr:%d",err);
          }else{
                // Update last offset written
                dfu_state->FileWrOffset += data_len;
                // All of the image was written?
                if (dfu_state->FileWrOffset>=dfu_state->FileSize.ulong){
                  int image_slot = 1;
                  struct image_version ver;
                  uint8_t  hash;
                  uint32_t flags;
                  bool permanent = false;
                  err = img_mgmt_read_info(image_slot,&ver,&hash,&flags);
                  if (err==0){
                    err = img_mgmt_impl_write_pending(image_slot,permanent);
                    if (err==0){
                      d_printf(LINE_INFO,kDbg_Error|kDbg_General,"FinishedDFU");
                    }else{
                          dfu_state->err = AMI_DFU_CENTRAL_ERR_SET_PENDING;
                  }else{
                        dfu_state->err = AMI_DFU_CENTRAL_ERR_RD_INFO;
                        d_printf(LINE_INFO,kDbg_Error|kDbg_General,"ImageInfoErr:%d",err);
                  // Reset after reply
                  ami_state->reset_secs = 2;
      }while (bRxFinished);
      return dfu_state->FileRxOffset.ulong;
    } // ami_dfu_HandleBlock
    // ami_dfu_Start
    //  Description
    //   Inits the dfu state and sets the dfu streaming buffer
    //  Parameters
    //  Returns
    //   0 = OK
    int ami_dfu_Start(void)
      // Clear dfu state
      memset(dfu_state,0,sizeof(ami_dfu_state_struct));
      // Reset dfu ring buffer
      ring_buf_reset(&dfu_ring_buf);
      // Erase upload slot
      int err = img_mgmt_impl_erase_slot();
      if (err!=0){
        dfu_state->err = AMI_DFU_CENTRAL_ERR_ERASE;
        d_printf(LINE_INFO,kDbg_Error|kDbg_General,"ImageEraseErr:%d", err);
        return err;
      // Init Flash stream writer (CONFIG_IMG_BLOCK_BUF_SIZE)
      err = flash_img_init(&flash_img);
      if (err!=0){
        d_printf(LINE_INFO,kDbg_Error|kDbg_General,"FlashInitErr:%d", err);
        dfu_state->err = AMI_DFU_CENTRAL_ERR_IMAGE_INIT;
        return err;
      return err;
    } // ami_dfu_Start
    // ami_dfu_Init
    //  Description
    //   Alolocates memory
    //  Parameters
    //  Returns
    //   0 = OK
    int ami_dfu_Init(void)
      int err = 0;
      // Allocate memory
      dfu_state  = k_malloc(sizeof(ami_dfu_state_struct));
      while (!dfu_state);
      return err;
    } // ami_dfu_Init
    Thanks David
  • Hello David,
    I would just like to point you to this solution I just completed: https://github.com/simon-iversen/ncs_samples/tree/master/central_smp_client_dfu
    With this sample you will be able to perform a DFU from one nRF52840DK to another nRF52840DK
    This sample seems to address the exact issue this post is about.
    Let me know if you still want me to look into your last questions.
    Simon
  • After trying to implement the nRF52840 BLE DFU without SMP & ZCBOR from my nRF52840  central device which worked 2/3 of the time, I am back to trying to get your code to work on my central.
    I am using Zephyr ncs v.2.2.0 and have made the two changes in the zcbor_decode.c file and have added the
    CONFIG_ZCBOR=y
    CONFIG_ZCBOR_STOP_ON_ERROR=y
    defines in both my central an my sensors.
    At first I was getting an error after the second packet where I got -122 which seems to be a too large of a packet. Maybe the sensor just disconnected.
    01-05 10:47 05/01/2023 08:47:49 |  05/01/2023 10:48:04[.ami_vibe.c:1148] #1 DFUpos:129000 len:1000
    01-05 10:47 05/01/2023 08:47:49 |  05/01/2023 10:48:04[.ami_vibe.c:1148] #1 DFUpos:130000 len:1000
    01-05 10:47 05/01/2023 08:47:49 |  05/01/2023 10:48:04[.ami_vibe.c:1962] ...[ami_ble.c:1703] StartScanConnect#1 FD:2C:12:F9:D6:03
    01-05 10:47 05/01/2023 08:47:52 |  05/01/2023 10:48:07[.ami_vibe.c:1962] ...[ami_ble.c:1733] DiscoveryStarted
    01-05 10:47 05/01/2023 08:47:57 |  05/01/2023 10:48:12[.ami_vibe.c:1962] ...[ami_ble.c: 609] MainHandlesOK
    01-05 10:48 05/01/2023 08:48:00 |  05/01/2023 10:48:15[.ami_vibe.c:1962] ...[ami_ble.c: 636] SetupHandlesOK
    01-05 10:48 05/01/2023 08:48:00 |  05/01/2023 10:48:15[.ami_vibe.c:1962] ...[ami_ble.c: 725] DISHandlesOK
    01-05 10:48 05/01/2023 08:48:01 |  05/01/2023 10:48:16[.ami_vibe.c:1962] ...[ami_ble.c: 670] TransferHandlesOK
    01-05 10:48 05/01/2023 08:48:02 |  05/01/2023 10:48:16[.ami_vibe.c:1962] ...[ami_ble.c: 739] SMPHandlesOK
    01-05 10:48 05/01/2023 08:48:12 |  05/01/2023 10:48:26[.ami_vibe.c:1962] ...[ami_smp.c: 671] DFU:0/373928
    01-05 10:48 05/01/2023 08:48:22 |  05/01/2023 10:48:36[.ami_vibe.c:1962] ...[ami_smp.c: 671] DFU:50/373928
    01-05 10:48 05/01/2023 08:48:22 |  05/01/2023 10:48:37[.ami_vibe.c:1962] ...[ami_smp.c: 780] bt_dfu_smp_command failed with -122
    01-05 10:48 05/01/2023 08:48:24 |  05/01/2023 10:48:38[.ami_vibe.c:1962] ...[ami_ble.c:1394] DisconnectTimeout
    01-05 10:48 05/01/2023 08:48:24 |  05/01/2023 10:48:39[.ami_vibe.c:1962] ...[ami_ble.c:2492] DFUConnectFinishedErr:5
    Now, in my latest code, I must have changed something, since the smp_upload_rsp_proc() is not being called but I do not get an error when calling bt_dfu_smp_command().
    01-05 15:43 05/01/2023 13:43:00 |  05/01/2023 15:43:14[.ami_vibe.c:1148] #1 DFUpos:130000 len:1000
    01-05 15:43 05/01/2023 13:43:00 |  05/01/2023 15:43:14[.ami_vibe.c:1941] ...[ami_ble.c:1703] StartScanConnect#1 FD:2C:12:F9:D6:03
    01-05 15:43 05/01/2023 13:43:03 |  05/01/2023 15:43:17[.ami_vibe.c:1941] ...[ami_ble.c:1733] DiscoveryStarted
    01-05 15:43 05/01/2023 13:43:08 |  05/01/2023 15:43:22[.ami_vibe.c:1941] ...[ami_ble.c: 609] MainHandlesOK
    01-05 15:43 05/01/2023 13:43:11 |  05/01/2023 15:43:25[.ami_vibe.c:1941] ...[ami_ble.c: 636] SetupHandlesOK
    01-05 15:43 05/01/2023 13:43:11 |  05/01/2023 15:43:26[.ami_vibe.c:1941] ...[ami_ble.c: 725] DISHandlesOK
    01-05 15:43 05/01/2023 13:43:12 |  05/01/2023 15:43:26[.ami_vibe.c:1941] ...[ami_ble.c: 670] TransferHandlesOK
    01-05 15:43 05/01/2023 13:43:12 |  05/01/2023 15:43:27[.ami_vibe.c:1941] ...[ami_ble.c: 739] SMPHandlesOK
    01-05 15:43 05/01/2023 13:43:13 |  05/01/2023 15:43:27[.ami_vibe.c:1941] ...[ami_smp.c: 659] DFU:0/373928
    Can you think of any reason that the callback is never called?
    Is there any reason that your code would not work with the zcbor_decode.c file changes on v2.2.0 ?
    I will try to continue next week and compare my code to see what has happened.
    I can DFU from my phone with the nRFConnect app on Android.
    Thanks David
  • Related
