Call to app_uart_put() not putting anything on the TX Line
I've been trying to get my call to app_uart_put() to actually place bytes on the TX pin. Interestingly enough, my call to app_uart_get() works fine and is able to receive all the commands on the RX pin. I am using SDK v17.0.2.
My code that initializes the UART is fairly boilerplate:
   if (!uart_instance_activated)
        uart_instance_activated = true;
        uint32_t err_code = NRF_SUCCESS;
        const app_uart_comm_params_t comm_params =
            UART_RX_PIN,
            UART_TX_PIN,
            UART_RTS_PIN_NUMBER,
            UART_CTS_PIN_NUMBER,
            UART_HWFC,
            false,
            NRF_UART_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                      uart_error_handle,
                APP_IRQ_PRIORITY_LOWEST,
                              err_code);
My code that calls app_uart_put()
uint8_t transportSend( const uint16_t bufferSize, uint8_t *pBuffer )
    if ( pBuffer == NULL )
        NRF_LOG_INFO("NULL?");
        return TRANSPORT_ERROR;
    uint32_t status = NRF_SUCCESS;
    while (app_uart_put(START_BYTE) != NRF_SUCCESS);
    nrf_delay_ms(10);
    for ( uint16_t i = 0; i < bufferSize; i++ )
        //NRF_LOG_INFO("pBuffer[%d] = %d", i, pBuffer[i]);
        // UART is spaming 0xFF so it has to be escaped
        if ( ( pBuffer[i] == START_BYTE ) ||
             ( pBuffer[i] == STOP_BYTE ) ||
             ( pBuffer[i] == ESCAPE_BYTE ) ||
             ( pBuffer[i] == 0xFF ) )
            //status = app_uart_put( ESCAPE_BYTE );
            while (app_uart_put(ESCAPE_BYTE) != NRF_SUCCESS);
            nrf_delay_ms(10);
            while (app_uart_put(escapeByte( pBuffer[i] )) != NRF_SUCCESS);
            nrf_delay_ms(10);
            while (app_uart_put(pBuffer[i]) != NRF_SUCCESS);
            nrf_delay_ms(10);
    } // end of for-loop
    while (app_uart_put(STOP_BYTE) != NRF_SUCCESS);
    nrf_delay_ms(10);
    return TRANSPORT_SUCCESS;
and Like I said, my code that calls app_uart_get() works just fine:
static int cala_getChar()
    uint8_t input = 0;
    app_uart_get(&input);
    return input;
Is app_uart_put() not being called correctly? Doubled checked sdk_config.h and NRFX_UART_ENABLED is 1
  • void cli_stop(void)
        ret_code_t ret = NRF_SUCCESS;
    #if CLI_OVER_USB_CDC_ACM
        ret = nrf_cli_stop(&m_cli_cdc_acm);
        APP_ERROR_CHECK(ret);
    #if CLI_OVER_UART
        NRF_LOG_INFO("Stopping CLI");
        // Please note, system must reset in order to recover normal CLI over-UART
        // operations.
        ret = nrf_cli_stop(&m_cli_uart);
        if (ret != NRF_SUCCESS)
            NRF_LOG_INFO("nrf_cli_stop() failed!");
        // Unintialize the CLI instance.
        ret = nrf_cli_uninit(&m_cli_uart);
            NRF_LOG_INFO("nrf_cli_uninit() failed!");
