nRF52 DK UART RX pin
I have been having two issues (possibly related) with the RX pin of the nRF52 DK (PCA10036) using the ble_app_uart example. I have been trying to characterize the problem so that this post makes as much sense as possible - and I don't waste anyone's time.
Background: My goal is to use the nRF52 DK as a BLE bridge between a phone/tablet app and an existing product that I work on. The product uses a Microchip PIC16 and has a UART hooked to a command parser, or, call it a simple shell. I chose the ble_app_uart project to use on the DK for obvious reasons and figured I could repoint the RX and TX pins to the header, turn off flow control, hook up TX/RX/GND, and then simply send and receive characters from the phone app.
I have had some success with this, although, I have experienced some issues which I will explain.
Disclaimer: I am an Embedded Software Engineer. I am not an Electrical Engineer although I know enough to get myself in to trouble.
Issues: (1) I chose pin 22 for TX which seems to work fine. The problem is with the RX pin. Pin 23 does not work at all for some reason, and I don't see anything else that already uses it. (Maybe this is a third problem.) When I choose a different pin, say Pin 24, I see this behavior:
If the UART in the DK is hooked up to the UART on the PIC on power-up, sometimes, the board will not boot. When I say "will not boot", I do not see LED1 blinking indicating "advertising". If I boot the board with nothing connected, LED1 will blink fine. As soon as I plug a jumper wire in to the Pin 24 slot on the header, LED1 goes out - as if the board is dead. This happens even if there is nothing connected to the other end of the jumper.
I can eventually get things working by alternating how I power up both sides and when I connect the UARTs together but it is not repeatable and therefore is bad for a customer demo.
(2) This problem may be related to (1) - and I have the same problem on the PIC side. If I power up the DK with the coin-cell and try to pull the cell to cycle power, LED1 will continue to blink as if power were being sourced through the UART. Again, as stated above, I am not an EE so perhaps this is a common behavior. To me, though, it is common to hook up two systems via UART and send messages back and forth.
Thanks for taking the time to read this - hopefully you have some thoughts...
