NRF5340 Dk jlink CDC UART Connection issue.
HI,
I want help to fix the nrf5340 Dk. I have worked fine with the DK for a long time. But, Suddenly  I can't be able to connect the DK with my PC. I can able to connect PDK and another DK also.
I have to attach one Video for your reference. Kindly, Check and help me to fix this issue.
Thanks & Regards
Navin.
  • Hi Jarad,
    ou can use the VDD header on the DK and measure the voltage directly on it.
    3.02V is comming
    Could you use nRF Command Line tools instead, and  add the log option:
    I have attached the log file below for your reference.
    [2022-Jul-22 11:04:52] [ info] --------------------------------------------------------------------------------
    [2022-Jul-22 11:04:52] [ info] nrfjprog --ids --log
    [2022-Jul-22 11:04:52] [ info] nrfjprog version 10.16.0 external
    [2022-Jul-22 11:04:52] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
    [2022-Jul-22 11:04:52] [ info] Library loaded, loading member functions.
    [2022-Jul-22 11:04:52] [ info] Member functions succesfully loaded.
    [2022-Jul-22 11:04:52] [debug] [ Client] - open
    [2022-Jul-22 11:04:52] [debug] [ Client] - start
    [2022-Jul-22 11:04:52] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 0c281330-1767-40c2-a484-55e0cbb15d29.
    [2022-Jul-22 11:04:52] [trace] [ Client] - Command open executed for 104 milliseconds with result 0
    [2022-Jul-22 11:04:52] [debug] [ Client] - enum_emu_snr
    [2022-Jul-22 11:04:52] [trace] [ Client] - Command enum_emu_con_info executed for 15 milliseconds with result 0
    [2022-Jul-22 11:04:52] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2022-Jul-22 11:04:52] [debug] [  JLink] - Logger sink registered in JLink logger
    [2022-Jul-22 11:04:52] [debug] [  nRFXX] - open
    [2022-Jul-22 11:04:52] [debug] [  nRFXX] - just_check_family
    [2022-Jul-22 11:04:52] [debug] [SeggerBackend] - open_dll
    [2022-Jul-22 11:04:52] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2022-Jul-22 11:04:52] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink\JLink_x64.dll.
    [2022-Jul-22 11:04:52] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2022-Jul-22 11:04:52] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2022-Jul-22 11:04:52] [debug] [SeggerBackend] - dll_version
    [2022-Jul-22 11:04:52] [ info] [SeggerBackend] - Segger dll version 7.68.  loaded.
    [2022-Jul-22 11:04:52] [trace] [ Worker] - Command open executed for 14 milliseconds with result 0
    [2022-Jul-22 11:04:52] [debug] [  nRFXX] - enum_emu_con_info
    [2022-Jul-22 11:04:52] [debug] [SeggerBackend] - is_connected_to_emu
    [2022-Jul-22 11:04:52] [debug] [SeggerBackend] - enum_emu_con_info
    [2022-Jul-22 11:04:52] [trace] [ Worker] - Command enum_emu_con_info executed for 4 milliseconds with result 0
    [2022-Jul-22 11:04:52] [trace] [ Client] - Command close executed for 32 milliseconds with result 0
    [2022-Jul-22 11:04:52] [debug] [ Client] - terminate
    [2022-Jul-22 11:04:52] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2022-Jul-22 11:04:52] [debug] [  nRFXX] - close
    [2022-Jul-22 11:04:52] [debug] [SeggerBackend] - close
    [2022-Jul-22 11:04:52] [debug] [SeggerBackend] - disconnect_from_emu
    [2022-Jul-22 11:04:52] [debug] [SeggerBackend] - Segger Backend closed.
    [2022-Jul-22 11:04:52] [debug] [  nRFXX] - nRF family DLL closed
    [2022-Jul-22 11:04:52] [trace] [ Worker] - Command close executed for 30 milliseconds with result 0
    [2022-Jul-22 11:04:52] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2022-Jul-22 11:04:52] [trace] [ Worker] - Executed 4 commands for 48 milliseconds
    [2022-Jul-22 11:04:52] [debug] [ Client] - Worker process exited with code: 0
    [2022-Jul-22 11:04:52] [debug] [ Client] - Child process terminated with result 0
    [2022-Jul-22 11:04:52] [trace] [ Client] - Executed 4 commands for 151 milliseconds
    Thanks & Regards,
    Navin
  • Hi there Navin,
    Thank you for the log. I need to ask you to do a couple more things:
    1. Can you try to list the debugger again but without the log option. Like this nrfjprog --ids. Can you then share what is reported by nrfjprog. It should report an error if it's not able to list the debugger.
    2. Can you try to flash the DK with the an example such as the blinky example from vs code. What error does it report? Can you share the full error report?
    Thank you!
    regards
    Jared
  • hi Jared,
    I have tested the above. I didn't get anything
    While trying to flash the board it shows the device not connected error.
    Thanks & Regards
    Navin
  • Can you share the screenshot as you did for nrfjprog --ids when you try to flash it?
  • Hi jared,
    Thanks & Regards
    Navin
