I'm currently getting the CTS info out of my iPhone and storing it in my RTC, that talks with my nRF52832 via I2C. All seems to work.
But my Dev Team are now wanting the time in UTC, which means I also need Time Zone and Daylight Savings Time info. The standard API's that Nordic provide only seems to extract the Current Time:
/**@brief "Exact Time 256" field of the Current Time characteristic. */ struct bt_cts_exact_time_256 { uint16_t year; uint8_t month; uint8_t day; uint8_t hours; uint8_t minutes; uint8_t seconds; uint8_t day_of_week; uint8_t fractions256; }; /**@brief "Adjust Reason" field of the Current Time characteristic. */ struct bt_cts_adjust_reason { uint8_t manual_time_update : 1; uint8_t external_reference_time_update : 1; uint8_t change_of_time_zone : 1; uint8_t change_of_daylight_savings_time : 1; }; /**@brief Data structure for the Current Time characteristic. */ struct bt_cts_current_time { struct bt_cts_exact_time_256 exact_time_256; struct bt_cts_adjust_reason adjust_reason; };
What I also need is the Local Time info.
Has anyone done this before, and if so, can you give me a bit of guidance on how to go about this?
I assume I need to create a new struct, a-la:
/** Local Time Information Characteristic structure */ struct bt_cts_local_time { int8_t timeZone; /**< Current Time Zone */ uint8_t dst; /**< Daylight Saving Time value */ };
And then when I read the CTS from my phone, I need to index the Local Time characteristic from the CTS and copy it into an instance of the above struct. Does that sound correct?
Its this last step I'm not 100% sure of, nor how to go about implementing it, so any guidance will be warmly received :-)
Cheers,
Mike
