Using the DPPI on the nRF5340 to enable the ADC and GPIO toggling based on a hardware timer
I need to enable the ADC read and GPIO pin toggling to happen simultaneously at high precision, without using the MCU resources, approximately 15 us interval. After searching through this forum, I realized the only way to achieve this precision is to use DPPI in the nrfx drivers directly, instead of using the Zephyr drivers.
I successfully enabled the timer1 that triggers the ADC read configured in the DPPI, and another set of code to use the same timer that toggles the GPIO pin also configured in the DPPI but I cannot set them together. Here are snippets of my code for configuring DPPI:
/* Includes ------------------------------------------------------------------*/
#include <errno.h>
#include <logging/log.h>
#include <nrfx.h>
#include <nrfx_saadc.h>
#include <nrfx_timer.h>
#include <nrfx_gpiote.h>
#include <helpers/nrfx_gppi.h>
#include <nrfx_dppi.h>
#define SAMPLES_IN_BUFFER 	4
#define SAMPLE_RATE 		16000000//1000000UL
#define IRQ_PRIO_LOWEST 	0
#define GPIOTE_INTERRUPT_PRIORITY 1
#define GPIOTE_MCLK_SYNC_PIN_OUT 0
#define DIVIDER_COUNT 20
#define PIN 3
// READ1 channel
#define AIN5_READ1						1
#define AIN4_VCM_CHANNEL_INPUT 			NRF_SAADC_INPUT_AIN4
#define AIN5_READ1_MCU_CHANNEL_INPUT 	NRF_SAADC_INPUT_AIN5
LOG_MODULE_REGISTER(nrfx_sample, LOG_LEVEL_INF);
static void saadc_evt_handler(nrfx_saadc_evt_t const * p_event);
static void timer1_evt_handler(nrf_timer_event_t event_type, void * p_context);
static void timer_init(void);
static void saadc_init(void);
int16_t saadc_buf1[SAMPLES_IN_BUFFER];
nrfx_timer_t timer1 = NRFX_TIMER_INSTANCE(1);
void main(void)
	printk("nrfx_saadc sample on %s\n", CONFIG_BOARD);
	nrfx_err_t err;
	/* Connect SAADC IRQ to nrfx_saadc_irq_handler */
	IRQ_CONNECT(SAADC_IRQn, IRQ_PRIO_LOWEST, nrfx_isr, nrfx_saadc_irq_handler, 0);
	timer_init();
	saadc_init();
	// gpiote_init();
	/* Allocate a (D)PPI channel. */
	uint8_t dppi_channel_1;
	err = nrfx_dppi_channel_alloc(&dppi_channel_1);
	if (err != NRFX_SUCCESS) {
		LOG_ERR("(D)PPI channel 1 allocation error: %08x", err);
		return;
	/* Configure endpoints of the channel so that the TIMER1 CAPTURE0
	 * event is connected with the SAADC SAMPLE task. This means that each time
	 * TIMER1 reaches it's set compare value, the SAADC will sample all
	 * enabled channel once.
	nrfx_gppi_channel_endpoints_setup(dppi_channel_1,
		nrfx_timer_event_address_get(&timer1, NRF_TIMER_EVENT_COMPARE0),
		nrf_saadc_task_address_get(NRF_SAADC, NRF_SAADC_TASK_SAMPLE));
	/* Enable (D)PPI channel. */
	err = nrfx_dppi_channel_enable(dppi_channel_1);
		LOG_ERR("Failed to enable (D)PPI channel 1, error: %08x", err);
		return;
	LOG_INF("(D)PPI configured, leaving main()");
	nrfx_timer_enable(&timer1);
	printk("TIMER1 started\n");
	nrfx_err_t err = NRFX_SUCCESS;
	if(p_event->type == NRFX_SAADC_EVT_DONE)
		printk("SAADC sampled: \nREAD1\tREAD2\tREAD3\tREAD4\n");
		for(uint8_t i = 0; i < p_event->data.done.size; i++)
			printk("%hi\t", p_event->data.done.p_buffer[i]);
		printk("\n");
	else if(p_event->type == NRFX_SAADC_EVT_CALIBRATEDONE)
		printk("SAADC calibrated.\n");
	else if(p_event->type == NRFX_SAADC_EVT_BUF_REQ)
		printk("SAADC buffer requested\n");
		err = nrfx_saadc_buffer_set(saadc_buf1, SAMPLES_IN_BUFFER);
		if(err != NRFX_SUCCESS)
			LOG_ERR("Error! Could not set buffer1: %d\n", err);
	else if(p_event->type == NRFX_SAADC_EVT_FINISHED)
		printk("SAADC finished sampling\n\n");
	// Nothing to do here, the timer's IRQ is not enabled
	nrfx_timer_config_t timer_cfg = NRFX_TIMER_DEFAULT_CONFIG;
	err = nrfx_timer_init(&timer1, &timer_cfg, timer1_evt_handler);
		LOG_ERR("Error! Could not initialize TIMER1: %d\n", err);
	nrfx_timer_extended_compare(&timer1, NRF_TIMER_CC_CHANNEL0, nrfx_timer_us_to_ticks(&timer1, 1000000), NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
	nrfx_saadc_channel_t saadc_channel_read1 = NRFX_SAADC_DEFAULT_CHANNEL_DIFFERENTIAL(AIN5_READ1_MCU_CHANNEL_INPUT, AIN4_VCM_CHANNEL_INPUT, AIN5_READ1);
	nrfx_saadc_adv_config_t saadc_adv_cfg = NRFX_SAADC_DEFAULT_ADV_CONFIG;
	saadc_adv_cfg.start_on_end = true;
	err = nrfx_saadc_init(IRQ_PRIO_LOWEST);
		LOG_ERR("Error! Could not initialize SAADC: %d\n", err);
	err = nrfx_saadc_offset_calibrate(NULL);
		LOG_ERR("Error! Could not calibrate offset: %d\n", err);
	err = nrfx_saadc_channel_config(&saadc_channel_read1);
		LOG_ERR("Error! Could not configure SAADC channel 1: %d\n", err);
	err = nrfx_saadc_advanced_mode_set((1 << AIN5_READ1), NRF_SAADC_RESOLUTION_10BIT, &saadc_adv_cfg, saadc_evt_handler);
		LOG_ERR("Error! Could not set advanced SAADC mode: %d\n", err);
	err = nrfx_saadc_mode_trigger();
		LOG_ERR("Error! Could trigger mode: %d\n", err);
void gpiote_init(void)
    LOG_INF("nrfx_gpiote sample on %s", CONFIG_BOARD);
    nrfx_err_t err;
    err = nrfx_gpiote_init(GPIOTE_INTERRUPT_PRIORITY);
        LOG_ERR("nrfx_gpiote_init error: %08x", err);
        return;
    nrfx_gpiote_out_config_t const out_config = NRFX_GPIOTE_CONFIG_OUT_TASK_TOGGLE(false);
    /* Initialize output pin. SET task will turn the LED on,
     * CLR will turn it off and OUT will toggle it.
    err = nrfx_gpiote_out_init(PIN, &out_config);
    if (err != NRFX_SUCCESS )
        LOG_ERR("nrfx_gpiote_out_init error: %08x", err);
    timer_cfg.mode = NRF_TIMER_MODE_TIMER;
    nrfx_timer_extended_compare(&timer1, NRF_TIMER_CC_CHANNEL0, DIVIDER_COUNT/2, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
    uint8_t channel;
    err = nrfx_dppi_channel_alloc(&channel);
    nrfx_gpiote_pin_t gpiote_mclk_sync_pin_out = PIN;
    nrfx_gppi_channel_endpoints_setup(channel, nrfx_timer_event_address_get(&timer1, NRF_TIMER_EVENT_COMPARE0), nrfx_gpiote_out_task_addr_get(gpiote_mclk_sync_pin_out));
    nrfx_gppi_channels_enable(BIT(channel));
    nrfx_gpiote_out_task_enable(PIN);
In the API reference, DPPI does not allow one task or event to associate with more than one channel. In my case, ideally, I would like to toggle the GPIO pin based on the timer1 and also triggers the ADC read every time the GPIO toggles, at the rising edge and falling edge.
Can you suggest a method to seamlessly enable the ADC read and GPIO pin toggling with the timer1 configured in DPPI? Maybe there is a way to set a GPIO pin to the PWM based on the timer1 while triggering the ADC read in DPPI?
Thanks!
  • Kenneth, the SAADC still doesn't work with your code but I managed to make it work!
    The SAADC driver worked with the following code, but this helper layer didn't work to assign a single event to trigger multiple tasks:
    	nrfx_gppi_channel_endpoints_setup(dppi_channel,
    	err = nrfx_dppi_channel_enable(dppi_channel);
    		LOG_ERR("Failed to enable (D)PPI channel, error: %08x", err);
    		return;
    So, instead of setting:
    NRF_SAADC->SUBSCRIBE_START = DPPIC_SUBSCRIBE_CHG_EN_EN_Msk | dppi_channel_0;
    I modified it to:
    NRF_SAADC->SUBSCRIBE_SAMPLE = DPPIC_SUBSCRIBE_CHG_EN_EN_Msk | dppi_channel_0;
    Then the GPIO pin toggling worked simultaneously with the SAADC read!
    Here is the portion of the code that allowed me to do that:
    	uint8_t dppi_channel;
    	err = nrfx_dppi_channel_alloc(&dppi_channel);
    		LOG_ERR("(D)PPI channel allocation error: %08x", err);
    		return;
    	NRF_TIMER1->PUBLISH_COMPARE[0] = DPPIC_SUBSCRIBE_CHG_EN_EN_Msk | dppi_channel;
    	NRF_SAADC->SUBSCRIBE_SAMPLE = DPPIC_SUBSCRIBE_CHG_EN_EN_Msk | dppi_channel;
    	NRF_GPIOTE->SUBSCRIBE_OUT[1] = DPPIC_SUBSCRIBE_CHG_EN_EN_Msk | dppi_channel;
    	LOG_INF("DPPI configured");
    	LOG_INF("nrfx_gpiote initialized");
    Can you clarify why the original helper layer didn't work but this publish/subscribe method worked? I was able to find another approach here, and it ties the publish and subscribe sets like this:
    	/* Tie it all together */
    	nrf_gpiote_publish_set(NRF_GPIOTE_EVENTS_IN_0, dppi_ch_1);
    	nrf_gpiote_publish_set(NRF_GPIOTE_EVENTS_IN_1, dppi_ch_2);
    	nrf_timer_subscribe_set(timer.p_reg, NRF_TIMER_TASK_START, dppi_ch_1);
    	nrf_timer_subscribe_set(timer.p_reg, NRF_TIMER_TASK_STOP, dppi_ch_2);
    	nrf_timer_subscribe_set(timer.p_reg, NRF_TIMER_TASK_CAPTURE0, dppi_ch_2);
    I wonder which approach works best with setting up the DPPI module because I intend to use the DPPI more widely now and then. Can you explain why this approach failed to read the ADC channel but only the GPIO pin toggling worked:
    	uint8_t dppi_channel_0, dppi_channel_01;
    	err = nrfx_dppi_channel_alloc(&dppi_channel_0);
    		LOG_ERR("(D)PPI channel 0 allocation error: %08x", err);
    		return;
    	nrfx_gppi_channel_endpoints_setup(dppi_channel_0,
    	err = nrfx_dppi_channel_enable(dppi_channel_0);
    		LOG_ERR("Failed to enable (D)PPI channel 0, error: %08x", err);
    		return;
    		nrfx_gpiote_out_task_addr_get(PIN));
    		return;
    	nrfx_gppi_channels_enable((1 << dppi_channel_0) | (1 << dppi_channel_1));
    Thank you for leading to the answer I was looking for!
    Ted
  • I must admit I was not paying attention to whether you were using START or SAMPLE, my main focus was how to setup publish to several subscribers. But you are right, you should use SAMPLE to actually SAMPLE the analog input, while START simply prepare the ADC for the SAMPLE task. In general you may find the hardware description useful:
    https://infocenter.nordicsemi.com/topic/ps_nrf5340/saadc.html
    In terms of which api to use when setting up the publish and subscribe, I was looking at how you can write to the registers directly, but you can also setup this with a more convenient api like you have found also (they do the same, one is just a wrapper around the other).
    Glad to hear you have made it work!
    Kenneth
