Error -22 in mqtt_connect() - nRF52840dk with Azure IoT Hub using OpenThread and TCP
I am attempting to connect a nRF52840dk to Azure IoT Hub using OpenThread and TCP. I combined the azure_iot_hub and azure_fota samples into one project, which ran successfully on an nRF9160dk using Connect SDK v1.9.1. I have modified that project for a nRF52840dk, OpenThread, TCP, and Connect SDK 2.0.0. I think that I am close, but I am getting error -22 ("invalid argument") in azure_iot_hub.c's mqtt_connect().
Wireshark capture using nRF sniffer:
Serial output (I added the "Error in zsock_connect!" log in mqtt_transport_socket_tls.c):
I've repurposed CONFIG_AZURE_IOT_HUB_STATIC_IPV4 to be an ipv6 address as seen in my prj further below. The getaddrinfo() DNS resolver is working, but I'd have to add a conversion from the returned ipv4 to ipv6 and I'd prefer to bypass that for now unless this is causing the issue. In azure_iot_hub.c's broket_init(), I changed &broker to &broker4 to resolve an error and made some other updates to switch from ipv4 to ipv6. These are the only changes I made in azure_iot_hub.c. The IoT Hub setup is kicked off in main() via err = azure_iot_hub_connect();
#if defined(CONFIG_AZURE_IOT_HUB_STATIC_IPV4)
static int broker_init(bool dps)
	//TB changed sockaddr's from sockaddr_in to sockaddr_in6
	struct sockaddr_in6 *broker4 =
		((struct sockaddr_in6 *)&broker);
	//TB changed "AF_INET" to "AF_INET6" twice and "&broker" to "&broker4" on 7/20/22
	inet_pton(AF_INET6, CONFIG_AZURE_IOT_HUB_STATIC_IPV4_ADDR,
		  &broker4->sin6_addr);//&broker->sin_addr);
	broker4->sin6_family = AF_INET6;
	broker4->sin6_port = htons(CONFIG_AZURE_IOT_HUB_PORT);
	//TB added:
	char ipv6_addr[NET_IPV6_ADDR_LEN];
	inet_ntop(AF_INET6, &broker4->sin6_addr.s6_addr, ipv6_addr,
				  sizeof(ipv6_addr));
	LOG_DBG("IPv6 address set in broker_init to %s", log_strdup(ipv6_addr));
	return 0;
prj.conf:
# Copyright (c) 2020 Nordic Semiconductor ASA
# General config
CONFIG_REBOOT=y
CONFIG_DEBUG=y
# Heap and stacks
CONFIG_HEAP_MEM_POOL_SIZE=6144
CONFIG_MAIN_STACK_SIZE=8192
# Log
CONFIG_LOG=y
CONFIG_PRINTK=y
CONFIG_SERIAL=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_LOG_BACKEND_UART=y
CONFIG_LOG_PROCESS_THREAD=y
CONFIG_LOG_MODE_IMMEDIATE=y
CONFIG_LOG_STRDUP_MAX_STRING=128
CONFIG_LOG_STRDUP_BUF_COUNT=50
CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=8096
##### booting and bootloader #####
CONFIG_BOOT_DELAY=1000
CONFIG_BOOT_BANNER=y
CONFIG_BOOTLOADER_MCUBOOT=y
##### DFU #####
CONFIG_DFU_TARGET=y
CONFIG_DFU_TARGET_MCUBOOT=y
CONFIG_IMG_MANAGER=y
CONFIG_MCUBOOT_IMG_MANAGER=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
##### for external flash support ####
CONFIG_NORDIC_QSPI_NOR=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_NORDIC_QSPI_NOR_STACK_WRITE_BUFFER_SIZE=16
CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
##### FLASH #####
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_STREAM_FLASH=y
CONFIG_STREAM_FLASH_ERASE=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# LED control
CONFIG_DK_LIBRARY=y
#CONFIG_DK_LIBRARY_INVERT_LEDS=n #not available in v2.0.0
#Openthread
CONFIG_OPENTHREAD_JOINER=y
CONFIG_NET_L2_OPENTHREAD=y
CONFIG_OPENTHREAD_SHELL=n
CONFIG_OPENTHREAD_CUSTOM_PARAMETERS="OPENTHREAD_CONFIG_JOINER_ENABLE=1"
CONFIG_OPENTHREAD_JOINER_AUTOSTART=y
CONFIG_OPENTHREAD_JOINER_PSKD="J01NME"
CONFIG_OPENTHREAD_THREAD_VERSION_1_2=y
#CONFIG_MBEDTLS_SHA1_C=n #TB commented
CONFIG_FPU=y
# TLS configuration #TB commented
#CONFIG_MBEDTLS_ENABLE_HEAP=y
#CONFIG_MBEDTLS_HEAP_SIZE=10240
#CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=2048
#CONFIG_MBEDTLS=y
#CONFIG_MBEDTLS_BUILTIN=n
#CONFIG_MBEDTLS_KEY_EXCHANGE_SOME_PSK_ENABLED=y
#CONFIG_MBEDTLS_KEY_EXCHANGE_PSK_ENABLED=y
#CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
##### OPENTHREAD #####
CONFIG_OPENTHREAD_NORDIC_LIBRARY_MASTER=y
CONFIG_OPENTHREAD_FTD=n
CONFIG_OPENTHREAD_MTD=y
CONFIG_OPENTHREAD_MTD_SED=n
CONFIG_OPENTHREAD_THREAD_STACK_SIZE=10240
CONFIG_OPENTHREAD_DEBUG=y
CONFIG_OPENTHREAD_L2_DEBUG=y
CONFIG_OPENTHREAD_MANUAL_START=y
# Enable Thread 1.2 features
CONFIG_OPENTHREAD_DUA=y
CONFIG_OPENTHREAD_MLR=y
CONFIG_OPENTHREAD_BACKBONE_ROUTER=y
CONFIG_OPENTHREAD_LINK_METRICS_INITIATOR=y
CONFIG_OPENTHREAD_LINK_METRICS_SUBJECT=y
CONFIG_OPENTHREAD_CSL_RECEIVER=y
# Network
CONFIG_NETWORKING=y
CONFIG_NET_IPV6_NBR_CACHE=n
CONFIG_NET_IPV6_MLD=n
# CONFIG_NET_RAW_MODE=n
CONFIG_NET_IPV6=y
CONFIG_NET_IPV4=n
CONFIG_NET_CONFIG_NEED_IPV4=n
CONFIG_NET_CONFIG_NEED_IPV6=y
# Network sockets
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_SOCKETS_POLL_MAX=4
CONFIG_NET_SOCKETS_TLS_MAX_CONTEXTS=2
# Enable TCP support
CONFIG_NET_TCP=y # Required for SOCKET STREAM
#CONFIG_NET_UDP=y # Testing UDP connection #TB commented
CONFIG_OPENTHREAD_TCP_ENABLE=n
#^from https://github.com/openthread/openthread/discussions/7784
# disable external crystal
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n
# enable synth crystal for powered devices
CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
# enable RC crystal for battery devices
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
CONFIG_NET_PKT_RX_COUNT=8
CONFIG_NET_PKT_TX_COUNT=8
CONFIG_NET_BUF_RX_COUNT=32
CONFIG_NET_BUF_TX_COUNT=32
# Network buffers
#CONFIG_NET_PKT_RX_COUNT=10
#CONFIG_NET_PKT_TX_COUNT=16
#CONFIG_NET_BUF_RX_COUNT=16
#CONFIG_NET_BUF_TX_COUNT=16
#^old values
# Kernel options
CONFIG_INIT_STACKS=y
# Increase set for threads with meta-irq priority
CONFIG_NUM_METAIRQ_PRIORITIES=1
# Logging
CONFIG_NET_LOG=y   #POWERSAVING
# Disable certain parts of Zephyr IPv6 stack
# Stack sizes configuration
CONFIG_NET_TX_STACK_SIZE=1200
CONFIG_NET_RX_STACK_SIZE=1500
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
# L2 OpenThread enabling
CONFIG_OPENTHREAD_L2_LOG_LEVEL_INF=y
# Enable ping sender support
CONFIG_OPENTHREAD_PING_SENDER=y
# Configure dependencies
CONFIG_NRF_802154_ENCRYPTION=y
CONFIG_IEEE802154_2015=y
CONFIG_IEEE802154_CSL_ENDPOINT=y
CONFIG_NET_PKT_TXTIME=y
CONFIG_NET_PKT_TIMESTAMP=y
CONFIG_OPENTHREAD_MAC_SOFTWARE_TX_SECURITY_ENABLE=n
# CSL configuration
CONFIG_OPENTHREAD_CSL_RECEIVE_TIME_AHEAD=3000
CONFIG_OPENTHREAD_CSL_MIN_RECEIVE_ON=300
# Azure IoT Hub library
CONFIG_AZURE_IOT_HUB=y
CONFIG_AZURE_IOT_HUB_DEVICE_ID="mynrf52840dk"
# Host name must be configured if DPS is not used
CONFIG_AZURE_IOT_HUB_HOSTNAME="my-iot-hub.azure-devices.net"
# Change the security tag to the tag where relevant certificates are provisioned
CONFIG_AZURE_IOT_HUB_SEC_TAG=42
# Uncomment to get more verbose logging when debugging
CONFIG_AZURE_IOT_HUB_LOG_LEVEL_DBG=y
CONFIG_AZURE_IOT_HUB_LOG_LEVEL_WRN=y
#Use manual certificates
CONFIG_USE_MANUAL_IOTHUB_CERTS=y
CONFIG_AZURE_IOT_HUB_PROVISION_CERTIFICATES=y
CONFIG_AZURE_IOT_HUB_STATIC_IPV4=y
CONFIG_AZURE_IOT_HUB_STATIC_IPV4_ADDR="64:ff9b::myio:thub"
CONFIG_AZURE_IOT_HUB_NATIVE_TLS=n
#CONFIG_AZURE_IOT_HUB_CERTIFICATES_FILE keep = default
# Azure FOTA
# Download Client
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_1024=y
CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_INF=y
CONFIG_DOWNLOAD_CLIENT_BUF_SIZE=2300
# DFU Target
CONFIG_DFU_TARGET=y
# Application update support
# Image manager
# FOTA Download
CONFIG_FOTA_DOWNLOAD=y
CONFIG_FOTA_DOWNLOAD_PROGRESS_EVT=y
# Azure FOTA
CONFIG_CJSON_LIB=y
#CONFIG_ZEPHYR_CJSON_MODULE=y
CONFIG_AZURE_FOTA=y
CONFIG_AZURE_FOTA_APP_VERSION_AUTO=y
CONFIG_AZURE_FOTA_TLS=y
CONFIG_FW_INFO=y
# Change the security tag to the tag where the certificates are provisioned
# for the server where the FOTA image is hosted
CONFIG_AZURE_FOTA_SEC_TAG=42
# Uncomment the below line to get more debug logging
# CONFIG_AZURE_FOTA_LOG_LEVEL_DBG=y
CONFIG_NEWLIB_LIBC=y
CONFIG_EXTERNAL_LIBC=n
CONFIG_CJSON_LIB=y
CONFIG_NORDIC_SECURITY_BACKEND=y
CONFIG_NRF_SECURITY=y
CONFIG_MBEDTLS=y
CONFIG_MBEDTLS_CFG_FILE="config-tls-generic.h"
CONFIG_NET_TCP_ISN_RFC6528=n
CONFIG_OPENTHREAD_MBEDTLS_CHOICE=n
# Select OpenThread nRF Security backends
CONFIG_OPENTHREAD_NRF_SECURITY_CHOICE=n
# Generic networking options
CONFIG_NET_CONNECTION_MANAGER=n
CONFIG_NET_TCP_LOG_LEVEL_DBG=y
CONFIG_LOG_STRDUP_BUF_COUNT=20
# DNS Settings
CONFIG_DNS_RESOLVER=y
CONFIG_DNS_SERVER_IP_ADDRESSES=y
CONFIG_DNS_SERVER1="64:ff9b::0808:0808"
#CONFIG_OPENTHREAD_DNS_CLIENT=y
CONFIG_MBEDTLS_CIPHER_MODE_CBC=y
Certificate format:
"-----BEGIN CA CERTIFICATE-----\n"
"abcd+efgh\n"
"ijkl/mnop\n"
"-----END CA CERTIFICATE-----\n"
"-----BEGIN CLIENT CERTIFICATE-----\n"
"abcd+efgh\n"
"ijkl/mnop\n"
"-----END CLIENT CERTIFICATE-----\n"
"-----BEGIN PRIVATE KEY-----\n"
"abcd+efgh\n"
"ijkl/mnop\n"
"-----END PRIVATE KEY-----\n"
Per this DevZone ticket and this Microsoft documentation, maybe I am missing something with the CBC ciphers and MBedTLS? TCP messages appear to be going back and forth between the IoT Hub MQTT and my OpenThread end device in the Wireshark sniffer trace, so hopefully I am close to the finish line. Thank you in advance for the assistance.
  • I'm having trouble replying to your comment directly, but good thought. I only have a nRF52840dk and nRF52840dongle with me right now, so it took a while for me to convert the echo server sample for the latter. I have the sample successfully running over OpenThread and UDP. I'll attempt to reconfigure it for OpenThread and TCP and report back with any progress and Wireshark traces.
  • I am using the nRF52840dk as the client and nRF52840dongle as the server in the echo client/server sample. The client sends the TCP "SYN" message to the server, but the server does not send a "SYN,ACK" back and leaves the client to time out (error 116). The poster in the OpenThread GitHub discussion also received this error. I've attached my project files in case they can be of use in debugging. I added some code from the OpenThread CLI example at the beginning of the server main() so that I can use the serial monitor over USB.
    Is there a way to resolve this so that I can use TCP and OpenThread in this echo client/server example?
    Client build command:
    $ west build -b nrf52840dk_nrf52840 -- -DCONF_FILE="prj.conf overlay-ot.conf"
    Server build command:
    $ west build -b nrf52840dongle_nrf52840 -- -DCONF_FILE="prj.conf overlay-ot.conf" -DOVERLAY_CONFIG="overlay-usb.conf" -DDTC_OVERLAY_FILE="usb.overlay"
    Client serial output:
    uart:~$ *** Booting Zephyr OS build v3.0.99-ncs1  ***
    [00:00:05.073,913] <inf> net_l2_openthread: State changed! Flags: 0x0800c00b Current role: disabled
    [00:00:06.157,928] <inf> net_l2_openthread: State changed! Flags: 0x08000000 Current role: disabled
    [00:00:06.242,156] <inf> net_l2_openthread: State changed! Flags: 0x08000000 Current role: disabled
    [00:00:06.369,049] <inf> net_l2_openthread: State changed! Flags: 0x18040100 Current role: disabled
    [00:00:06.469,055] <inf> net_l2_openthread: Join success
    [00:00:06.469,635] <inf> net_l2_openthread: State changed! Flags: 0x1800101f Current role: detached
    [00:00:08.279,724] <inf> net_l2_openthread: State changed! Flags: 0x301b32b7 Current role: child
    [00:00:08.280,517] <inf> net_echo_client_sample: Run echo client
    [00:00:08.280,578] <inf> net_echo_client_sample: Network connected
    [00:00:08.280,639] <inf> net_echo_client_sample: Starting...
    [00:00:08.280,914] <dbg> net_tcp: tcp_conn_ref: (main): conn: 0x2001f5b8, ref_count: 1
    [00:00:08.280,944] <dbg> net_tcp: tcp_conn_alloc: (main): conn: 0x2001f5b8
    [00:00:08.281,280] <dbg> net_tcp: net_tcp_connect: (main): context: 0x2000fa1c, local: ::, remote: fdde:ad00:beef::2
    [00:00:08.281,402] <dbg> net_tcp: net_tcp_connect: (main): conn: 0x2001f5b8 src: fdde:ad00:beef::1, dst: fdde:ad00:beef::2
    [00:00:08.281,555] <dbg> net_tcp: tcp_in: (main):  [LISTEN Seq=2243461376 Ack=0]
    [00:00:08.281,829] <dbg> net_tcp: tcp_out_ext: (main): SYN Seq=2243461376 Len=0
    [00:00:08.282,012] <dbg> net_tcp: tcp_send_process_no_lock: (main): SYN Seq=2243461376 Len=0
    [00:00:08.282,257] <dbg> net_tcp: tcp_send: (main): SYN Seq=2243461376 Len=0
    [00:00:08.282,348] <dbg> net_tcp: tcp_in: (main): LISTEN->SYN_SENT
    [00:00:08.482,543] <dbg> net_tcp: tcp_send_process_no_lock: (tcp_work): SYN Seq=2243461376 Len=0 in_retransmission
    [00:00:08.482,757] <dbg> net_tcp: tcp_send: (tcp_work): SYN Seq=2243461376 Len=0
    [00:00:08.683,044] <dbg> net_tcp: tcp_send_process_no_lock: (tcp_work): SYN Seq=2243461376 Len=0 in_retransmission
    [00:00:08.683,227] <dbg> net_tcp: tcp_send: (tcp_work): SYN Seq=2243461376 Len=0
    [00:00:08.883,544] <dbg> net_tcp: tcp_send_process_no_lock: (tcp_work): SYN Seq=2243461376 Len=0 in_retransmission
    [00:00:08.883,728] <dbg> net_tcp: tcp_send: (tcp_work): SYN Seq=2243461376 Len=0
    [00:00:09.084,045] <dbg> net_tcp: tcp_send_process_no_lock: (tcp_work): SYN Seq=2243461376 Len=0 in_retransmission
    [00:00:09.084,228] <dbg> net_tcp: tcp_send: (tcp_work): SYN Seq=2243461376 Len=0
    [00:00:09.284,545] <dbg> net_tcp: tcp_send_process_no_lock: (tcp_work): SYN Seq=2243461376 Len=0 in_retransmission
    [00:00:09.284,729] <dbg> net_tcp: tcp_send: (tcp_work): SYN Seq=2243461376 Len=0
    [00:00:09.485,046] <dbg> net_tcp: tcp_send_process_no_lock: (tcp_work): SYN Seq=2243461376 Len=0 in_retransmission
    [00:00:09.485,229] <dbg> net_tcp: tcp_send: (tcp_work): SYN Seq=2243461376 Len=0
    [00:00:09.685,546] <dbg> net_tcp: tcp_send_process_no_lock: (tcp_work): SYN Seq=2243461376 Len=0 in_retransmission
    [00:00:09.685,760] <dbg> net_tcp: tcp_send: (tcp_work): SYN Seq=2243461376 Len=0
    [00:00:09.886,047] <dbg> net_tcp: tcp_send_process_no_lock: (tcp_work): SYN Seq=2243461376 Len=0 in_retransmission
    [00:00:09.886,230] <dbg> net_tcp: tcp_send: (tcp_work): SYN Seq=2243461376 Len=0
    [00:00:10.086,547] <dbg> net_tcp: tcp_send_process_no_lock: (tcp_work): SYN Seq=2243461376 Len=0 in_retransmission
    [00:00:10.086,730] <dbg> net_tcp: tcp_send: (tcp_work): SYN Seq=2243461376 Len=0
    [00:00:10.287,048] <dbg> net_tcp: tcp_send_process_no_lock: (tcp_work): SYN Seq=2243461376 Len=0 in_retransmission
    [00:00:10.287,078] <dbg> net_tcp: tcp_conn_unref_debug: (tcp_work): conn: 0x2001f5b8, ref_count=1 (tcp_send_process():535)
    [00:00:10.287,109] <dbg> net_tcp: tcp_conn_unref_debug: (tcp_work): conn: 0x2001f5b8 is waiting on connect semaphore
    [00:00:11.282,440] <dbg> net_tcp: tcp_conn_unref_debug: (main): conn: 0x2001f5b8, ref_count=1 (net_tcp_connect():2497)
    [00:00:11.282,592] <dbg> net_tcp: net_tcp_connect: (main): conn: 0x2001f5b8, ret=-116
    [00:00:11.282,653] <err> net_echo_client_sample: Cannot connect to TCP remote (IPv6): 116
    [00:00:11.282,653] <inf> net_echo_client_sample: Stopping...
    [00:00:11.282,684] <dbg> net_tcp: net_tcp_recv: (main): context: 0x2000fa1c, cb: (nil), user_data: (nil)
    [00:00:11.282,745] <dbg> net_tcp: net_tcp_unref: (main): context: 0x2000fa1c, conn: (nil)
    [00:00:58.507,049] <inf> net_l2_openthread: State changed! Flags: 0x00000064 Current role: router
    uart:~$
    Server serial output:
    uart:~$ ot commissioner joiner add * J01NME 100000
    Done
    [17:32:11.505,340] <inf> net_l2_openthread: State changed! Flags: 0x00000200 Current role: leader
    ~ Discovery Request from 02e6f8644e3bc496: version=3,joiner=1
    Commissioner: Joiner start 168f10653fbf2cf3
    Commissioner: Joiner connect 168f10653fbf2cf3
    Commissioner: Joiner finalize 168f10653fbf2cf3
    Commissioner: Joiner end 168f10653fbf2cf3
    [17:34:19.737,365] <inf> net_l2_openthread: State changed! Flags: 0x00000400 Current role: leader
    [17:35:10.656,890] <inf> net_l2_openthread: State changed! Flags: 0x00000800 Current role: leader
    uart:~$
    echo_client.tar.gzecho_server.tar.gz
  • I had a case previously where I think I managed to make TCP work with the echo server and client.
    It is from 1.8.0, so I do not know if the changes to the projects translate directly to 2.0.x.
    So if you test this, I recommend that you try it with 1.8.0 first (just to see) , and then 2.0.x.
    Here is my answer (from a private case) copied directly:
    To showcase how this can work, I will describe how I two samples can be changed to make TCP work with OpenThread.
    These are the Zephyr Echo Client and the Zephyr Echo Server.
    To make these support TCP over OpenThread, add the following configurations to overlay-ot.conf of both samples:
    CONFIG_NET_TCP=y
    CONFIG_OPENTHREAD_TCP_ENABLE=y
    Now built the samples with:
    west build -p -b nrf52840dk_nrf52840 -- -DOVERLAY_CONFIG="overlay-ot.conf"
    The sample code does not seem to initialize the OpenThread connection automatically, so they will not be able to connect automatically without changes.
    However, we can use the serial console to set up OpenThread and test TCP.
    After flashing the code to the devices, use the "ot" console commands to give the network the same panid, channel and networkkey.
    Then use the following command on the socket_server to find its IPv6 addresses:
    net ipv6
    Use one of the autoconf addresses (I will refer to it as <ipv6>), and port set in common.h (4242):
    Then use the commands on the socket_client:
    net tcp connect <ipv6> 4242
    net tcp send "hello openthread tcp"
    Does this still work?
    Sigurd Hellesvik
  • After my previous answer, I added another answer, but DevZone does not show it.
    Seems like files are still attached to the case though, so you should be able to download them from the side menu
    Sigurd Hellesvik
  • Thank you - those files and command line examples in your previous post helped me get the server and client successfully connected, as well as a TCP message successfully sent between the two ("hello 12345" or "68 65 6c 6c 6f 20 31 32 33 34 35" in hex, as you can see below). I used v1.9.1 because it was easier for me to git checkout than v1.8.1 for some reason. I am also using two nRF52840DK's now, since I was able to get a second DK. I can confirm that this also works the same way with v2.0.1 after doing a git checkout and west update to that version.
    It is good that I am able to do TCP now in this way - thank you!
    Is there a way to get the messages streaming continuously upon OpenThread network joining, as the original echo client/server demo works for UDP (instead of needing to manually connect and send via "net tcp ..." in the command line)?
    I attempt to set the ipv6 addresses equal to "fd00::1" (client) and "fd00::2" (server) in the prj.conf, but I cannot connect using these addresses and instead must create the TCP connection to the server address highlighted below.
    # Client:
    CONFIG_NET_CONFIG_MY_IPV6_ADDR="fd00::1"
    CONFIG_NET_CONFIG_PEER_IPV6_ADDR="fd00::2"
    # Server:
    CONFIG_NET_CONFIG_MY_IPV6_ADDR="fd00::2"
    CONFIG_NET_CONFIG_PEER_IPV6_ADDR="fd00::1"
