reading incorrect data from fstorage after using J-Link script to upgrade firmware
Before using J-Link script to upgrade firmware,  offsetStart (0x0) and offsetEnd (0x32E06) are correct. But after using J-Link script to upgrade firmware, offsetStart (0xADDEFE01) and offsetEnd (0x1EF1FFFF) are not correct.
log messages of before using J-Link script to upgrade firmware.
 0> <debug> app: endAddr=0x7FFFF
 0> <debug> app: startAddr=0x7F000
 0> <debug> app: nrf_fstorage_read() e
 0>
 0> <debug> app: nrf_fstorage_read() x
 0>
 0> <debug> app: record
 0>
 0> <debug> app: offsetStart=0x0
 0>
 0> <debug> app: offsetEnd=0x32E06
log messages of after using J-Link script to upgrade firmware.
 0>
 0>
 0>
 0> <debug> app: offsetStart=0xADDEFE01
 0>
 0> <debug> app: offsetEnd=0x1EF1FFFF
  • 3782.fstorage.h
    #include "app_timer.h"
    #include "error.h"
    #include "fds_flash.h"
    #include "fstorage.h"
    #include "nrf_delay.h"
    #include "nrf_fstorage.h"
    #include "nrf_fstorage_sd.h"
    #include "nrf_fstorage_nvmc.h"
    #include "nrf_log.h"
    #include "nrf_soc.h"
    #include "spi_flash.h"
    #define FSTORAGE_PAGE_NUM    1
    #define FSTORAGE_WAIT_CNT    1000
    static bool _gFstorageInitialized = false;
    static bool _gFstorageEraseDone   = true;
    static bool _gFstorageWriteDone   = true;
    static bool _gFstoragePageDirty   = true;
    static fstorage_state_t _gFstorageState = FSTORAGE_STATE_UNKNOWN;
    static uint8_t _gData[RECORD_LEN] = {0};
    static void _fstorageEvtHandler(nrf_fstorage_evt_t * p_evt);
    NRF_FSTORAGE_DEF(nrf_fstorage_t _gFstorage) =
        /* Set a handler for fstorage events. */
        .evt_handler = _fstorageEvtHandler,
        /* These below are the boundaries of the flash space assigned to this instance of fstorage.
         * You must set these manually, even at runtime, before nrf_fstorage_init() is called.
         * The function _fstorageGetEndAddr() can be used to retrieve the last address on the
         * last page of flash available to write data. */
        .start_addr = 0x7F000,
        .end_addr   = 0x7FFFF,
    static void _fstorageEvtHandler(nrf_fstorage_evt_t * pEvt) {
        NRF_LOG_DEBUG("Evt e\n");
        switch (pEvt->id) {
            case NRF_FSTORAGE_EVT_WRITE_RESULT:
                NRF_LOG_DEBUG("Evt w\n");
                _gFstorageState     = FSTORAGE_STATE_WRITTEN;
                if (pEvt->result != NRF_SUCCESS) {
                   NRF_LOG_WARNING("fstorage writing failed %d bytes at address 0x%x.",
                                pEvt->len, pEvt->addr);
                } else {
                    NRF_LOG_DEBUG("NRF_FSTORAGE_EVT_WRITE_RESULT ok");
            } break;
            case NRF_FSTORAGE_EVT_ERASE_RESULT:
                NRF_LOG_DEBUG("Evt er\n");
                _gFstorageState     = FSTORAGE_STATE_ERASED;
                    NRF_LOG_WARNING("fstorage erased failed %d page from address 0x%x.",
                } else {
                    NRF_LOG_DEBUG("NRF_FSTORAGE_EVT_ERASE_RESULT ok");
                    _gFstoragePageDirty = false;
            } break;
         NRF_LOG_DEBUG("Evt x\n");
    static uint32_t _fstorageGetEndAddr(void) {
        const uint32_t bootloaderAddr = BOOTLOADER_ADDRESS;
        const uint32_t pageSz         = NRF_FICR->CODEPAGESIZE;
        const uint32_t codeSz         = NRF_FICR->CODESIZE;
        return (bootloaderAddr != 0xFFFFFFFF ?
                bootloaderAddr : (codeSz * pageSz)-1);
    static bool _fstorageIsEraseNeeded(void) {
        return _gFstoragePageDirty;
    static uint32_t _fstorageRoundUpU32(const uint32_t len) {
        if (len % sizeof(uint32_t)) {
            return (len + sizeof(uint32_t) - (len % sizeof(uint32_t)));
        return len;
    static void power_manage(void)
    #ifdef SOFTDEVICE_PRESENT
        (void) sd_app_evt_wait();
    #else
        __WFE();
    int _fstorageWait(const uint32_t timeOutCnt) {
    #if 0
        NRF_LOG_DEBUG("timeOutCnt=%u\n", timeOutCnt);
        const uint32_t startCnt   = app_timer_cnt_get();
        NRF_LOG_DEBUG("startCnt=%u\n", startCnt);
        uint32_t endCnt;
        uint32_t diffCnt;
        do {
            endCnt           = app_timer_cnt_get();
            diffCnt          = app_timer_cnt_diff_compute(endCnt, startCnt);
            if (diffCnt >= timeOutCnt) {
                NRF_LOG_WARNING("_fstorage wait timeout\n");
                return ERROR_FSTORAGE_WAIT_TIMEOUT;
            if (_gFstorageEraseDone && _gFstorageWriteDone) {
        } while (true);
        NRF_LOG_DEBUG("endCnt=%u\n", endCnt);
    //#else
        //while (nrf_fstorage_is_busy(&_gFstorage))
        while (!_gFstorageEraseDone || !_gFstorageWriteDone) {
            NRF_LOG_DEBUG("pm e\n");
            power_manage();
            NRF_LOG_DEBUG("pm x\n");
    		return 0;
    int _fstorageRead(const uint32_t addr, const uint32_t len, uint8_t* data) {
        if (!_gFstorageInitialized) {
            return ERROR_FSTORAGE_UNINITIALIZED;
        NRF_LOG_DEBUG("nrf_fstorage_read() e\n");
        const ret_code_t errCode = nrf_fstorage_read(&_gFstorage, addr, data, len);
        if (errCode != NRF_SUCCESS) {
            NRF_LOG_WARNING("nrf_fstorage_read() failed 0x%x\n", errCode);
            return ERROR_FSTORAGE_READ_FAIL;
        NRF_LOG_DEBUG("nrf_fstorage_read() x\n");
        return 0;
    int _fstorageWrite(const uint32_t addr, const uint32_t len, void const* pData) {
        if (!_gFstorageEraseDone) {
            return ERROR_FSTORAGE_ERASE_ON_GOING;
        if (!_gFstorageWriteDone) {
            return ERROR_FSTORAGE_WRITE_ON_GOING;
        _gFstorageWriteDone = false;
        _gFstorageState     = FSTORAGE_STATE_WRITING;
        const uint32_t wlen = _fstorageRoundUpU32(len);
        NRF_LOG_DEBUG("nrf_fstorage_write() e\n");
        const ret_code_t retCode = nrf_fstorage_write(&_gFstorage, addr, pData, wlen, NULL);
        if (retCode != NRF_SUCCESS) {
            NRF_LOG_WARNING("nrf_fstorage_write() failed 0x%x", retCode);
            return ERROR_FSTORAGE_WRITE_FAIL;
        NRF_LOG_DEBUG("nrf_fstorage_write() x\n");
        _fstorageWait(FSTORAGE_WAIT_CNT);
        return 0;
    static void _fstoragePrintInfo(void) {
        NRF_LOG_INFO("========| flash info |========");
        NRF_LOG_INFO("erase unit:   %d bytes", _gFstorage.p_flash_info->erase_unit);
        NRF_LOG_INFO("program unit: %d bytes", _gFstorage.p_flash_info->program_unit);
        NRF_LOG_INFO("end address: 0x%x",      _fstorageGetEndAddr());
        NRF_LOG_INFO("==============================");
    int fstorageInit(void) {
        // initializing variables
        const ret_code_t errCode = nrf_fstorage_init(&_gFstorage, &nrf_fstorage_sd, NULL);
            NRF_LOG_WARNING("nrf_fstorage_init() failed 0x%x", errCode);
            return ERROR_FSTORAGE_INITIALIZE_FAIL;
        _fstoragePrintInfo();
        _gFstorageInitialized = true;
        return 0;
    int fstorageErase(const uint32_t addr, const uint32_t pagesCnt) {
        _gFstorageEraseDone = false;
        _gFstorageState     = FSTORAGE_STATE_ERASING;
        NRF_LOG_WARNING("nrf_fstorage_erase() e\n");
        const ret_code_t errCode = nrf_fstorage_erase(&_gFstorage, addr, pagesCnt, NULL);
            NRF_LOG_WARNING("nrf_fstorage_erase() failed 0x%x", errCode);
            return ERROR_FSTORAGE_ERASE_FAIL;
        NRF_LOG_WARNING("nrf_fstorage_erase() x\n");
        return 0;
    int fstorageReadRecord(const uint32_t addr, record_t* pRecord) {
        if (_fstorageRead(addr, RECORD_LEN, _gData) != 0) {
            return ERROR_FDS_READ_FAIL;
        data2Record(_gData, pRecord);
        return 0;
    int fstorageUpdateRecord(const record_data_type_t type, const record_t* pRecord) {
        const uint32_t addr = fstorageGetStartAddr();
        NRF_LOG_DEBUG("type=%d, addr=0x%x\n", type, addr);
        const fstorage_state_t state = fstorageGetState();
        NRF_LOG_DEBUG("state=%d\n", state);
        switch (type) {
            case RECORD_DATA_TYPE_START:
                NRF_LOG_DEBUG("START E\n");
                if ((state == FSTORAGE_STATE_UNKNOWN)) {
                    fstorageErase(addr, 1);
                } else if (state == FSTORAGE_STATE_ERASED) {
                    record_t record;
                    record.offsetStart = norFlashGetStartOffset();
                    record.offsetEnd   = norFlashGetStartOffset();
                    nrf_cal_get_datetime(&record.timeStart);
                    nrf_cal_get_datetime(&record.timeEnd);
                    recordPrintRecord("record", &record);
                    fstorageWriteRecord(addr, &record);
                NRF_LOG_DEBUG("START x\n");
            case RECORD_DATA_TYPE_END:
                NRF_LOG_DEBUG("END E\n");
                static record_t record;
                if ((state == FSTORAGE_STATE_UNKNOWN) || (state == FSTORAGE_STATE_WRITTEN)) {
                    if (fstorageReadRecord(addr, &record) != 0) {
                        NRF_LOG_WARNING("fstorageReadRecord(0x%x) failed\n", addr);
                    recordPrintRecord("record r", &record);
                    record.offsetEnd = pRecord->offsetEnd;
                    record.timeEnd   = pRecord->timeEnd;
                    recordPrintRecord("record w", &record);
                NRF_LOG_DEBUG("END X");
        return 0;
    int fstorageWaitUpdateRecordFinish(void) {
        record_t record;
        record.offsetEnd   = norFlashGetWrittenOffset();
        if (fstorageUpdateRecord(RECORD_DATA_TYPE_END, &record) != 0) {
            NRF_LOG_WARNING("fstorageUpdateRecord(%d) failed\n", RECORD_DATA_TYPE_END);
        return 0;
    int fstorageWriteRecord(const uint32_t addr, record_t* pRecord) {
        record2Data(pRecord, _gData);
        if (_fstorageWrite(addr, RECORD_LEN, _gData) != 0) {
        return 0;
    bool fstorageGetInitialized(void) {
        return _gFstorageInitialized;
    bool fstorageGetEraseDone(void) {
        return _gFstorageEraseDone;
    bool fstorageGetWriteDone(void) {
        return _gFstorageWriteDone;
    bool fstorageGetPageDirty(void) {
    uint32_t fstorageGetStartAddr(void) {
        const uint32_t eraseUnit = _gFstorage.p_flash_info->erase_unit;
        const uint32_t endAddr = _fstorageGetEndAddr();
        uint32_t startAddr;
        if (bootloaderAddr == 0xFFFFFFFF) {
            startAddr = endAddr - FSTORAGE_PAGE_NUM * eraseUnit + 1;
        } else {
            startAddr = bootloaderAddr - FSTORAGE_PAGE_NUM * eraseUnit + 1;
        NRF_LOG_DEBUG("endAddr=0x%x", endAddr);
        NRF_LOG_DEBUG("startAddr=0x%x", startAddr);
        return startAddr;
    fstorage_state_t fstorageGetState(void) {
        return _gFstorageState;
  • Can you install bleak Python package with the following command?
    pip3 install bleak
