Zigbee ZBOSS NCP HOST compile for ARMv7 (or other 32-bit arch)
I have compiled the Zigbee ZBOSS NCP HOST on an ARMv7 (32-bit) architecture according to the docs (https://developer.nordicsemi.com/nRF_Connect_SDK/doc/zboss/3.11.2.0/zboss_ncp_host.html). I have
compiled both the ZBOSS libraries (according to 'Rebuilding the ZBOSS libraries for host') and the simple_gw
application.
However when I run the application is segfaults almost immediately and the following is written in the log:
0 76fbcbf0 2022-7-28 14:0:15 0/0/000.000 /usr/src/debug/ncp-host/2.2.0-r0/src/common/zb_init_ncp.c:141  [INFO1] FFD build
1 76fbcbf0 2022-7-28 14:0:15 0/0/000.013 /usr/src/debug/ncp-host/2.2.0-r0/src/common/zb_init_ncp.c:145  [INFO1] sizes: g_zb 10420 sched 1356 bpool 6660 addr 1612
2 76fbcbf0 2022-7-28 14:0:15 0/0/000.014 /usr/src/debug/ncp-host/2.2.0-r0/src/common/zb_init_ncp.c:147  [INFO1] zcl 572
3 76fbcbf0 2022-7-28 14:0:15 0/0/000.014 /usr/src/debug/ncp-host/2.2.0-r0/src/common/zb_init_ncp.c:156  [INFO1] nvram 144
4 76fbcbf0 2022-7-28 14:0:15 0/0/000.014 /usr/src/debug/ncp-host/2.2.0-r0/src/common/zb_init_ncp.c:162  [INFO1] err_ind 4
5 76fbcbf0 2022-7-28 14:0:15 0/0/000.014 /usr/src/debug/ncp-host/2.2.0-r0/src/common/zb_init_ncp.c:169  [INFO1] scheduler q size 64
6 76fbcbf0 2022-7-28 14:0:15 0/0/000.014 /usr/src/debug/ncp-host/2.2.0-r0/src/common/zb_init_ncp.c:175  [INFO1] ZB_IOBUF_POOL_SIZE 40
  zbncp_ll_init_complete: (RX-IDLE : TX-IDLE)
           zbncp_ll_poll: @ time 0 [ack size 1159438920]
zbncp_ll_rx_start_receiving: (RX-IDLE)
   zbncp_ll_rx_set_state: (RX-IDLE --> RX-RECEIVING-HDR)
I suspect this as something to do with struct alignment as many structs in the source are packed and in the
ZBOSS library code some pointer arithmetic is done which is probably 64-bit specific. Is there an easy fix? Somehow
there must be as not many gateway's have 64-bit processors.
  • Hello Marte,
    I am facing a similar (the same?) issue as Daan.
    The NCP host application segfault when I try to run it on my target device that embed a nRF52833.
    I tried you suggested workaround by changing the CFLAGS but same as Daan, the problem persists.
    Here is the call stack of the crash:
    Program terminated with signal SIGSEGV, Segmentation fault.
    #0  0xf7aa82ee in strlen () from /lib/libc.so.6
    (gdb) bt
    #1  0xf7a94bc2 in __vfprintf_internal () from /lib/libc.so.6
    #2  0x009c18fa in zb_osif_trace_vprintf (f=0x1d28190, format=0x9e1310 ' ' <repeats 19 times>, ">>> timeout %zu%s [ack size %zu]", arglist=...) at zb_osif_file.c:408
    #3  0x009c1546 in zb_file_trace_vprintf (format=0x9e1310 ' ' <repeats 19 times>, ">>> timeout %zu%s [ack size %zu]", arglist=...) at zb_file_trace.c:310
    #4  0x009dd624 in zbncp_dbg_trace (fmt=0x9e1310 ' ' <repeats 19 times>, ">>> timeout %zu%s [ack size %zu]") at low_level/zbncp_debug.c:145
    #5  0x009dbc8a in zbncp_ll_poll (ll=0xa67150 <node+16>, q=0xff8498f8) at low_level/zbncp_ll_impl.c:1109
    #6  0x009d8978 in ncp_ll_quant (unused=255 '\377') at high_level/host/zb_ncp_ll_host.c:246
    #7  0x009c1f22 in zb_sched_loop_iteration () at zb_scheduler.c:276
    #8  0x009c3b00 in zboss_main_loop () at zb_zboss_api_common.c:84
    #9  0x009b1098 in main (argc=1, argv=0xff849b14) at simple_gw.c:209
    This was run on an azurewave AW-PU551 but cross-compiled with an armv7 toolchain. I tried to compile with an arm64 toolchain but got the following error:
    In file included from low_level/zbncp_mem.c:47:
    low_level/zbncp_debug.h:73:3: error: static assertion failed: "Static assertion failed"
       73 |   _Static_assert((cond), "Static assertion failed");
    low_level/zbncp_mem.c:49:1: note: in expansion of macro ‘ZBNCP_DBG_STATIC_ASSERT’
       49 | ZBNCP_DBG_STATIC_ASSERT(sizeof(void*) <= sizeof(zbncp_uintptr_t))
    ../../src/Options:138: recipe for target 'low_level/zbncp_mem.o' failed
    If you have a proper workaround it would be appreciated in the meantime I will try what Daan suggested and disable all debug logs.
    Benjamin
  • Hi Benjamin,
    Have you been able to test the workaround suggested by Daan?
    Marte
  • Hello Marte,
    Sorry for the delay. Yes I was and it seems to work as expected.
    Any news regarding a potential fix of the sample from the dev team? Did the stacktrace I shared help?
    Benjamin
  • Glad to hear that you also got it working. We are also still waiting on an official fix because now it is somewhat hacky to manually adjust an official SDK.
    I do not have any updates unfortunately. The issue has been reported to the company responsible for the stack, but I do not have any insight into their timeline.
    Marte
