NCS1.9.99, VSCode, peripheral_lbs_DFU
nRF5340-DK DFU got error:
IOS sending time out, android apk i have not fond.
Best regards
Best regards
1) You should not have to read the pin numbers from the application when pinctrl is used. That is the intention with the design, at least. But if you have to, then you can use the internal NRF_* macros as shown in the pinctrl test code. These can be used to decode the structure returned by PINCTRL_DT_DEV_CONFIG_GET().
https://github.com/nrfconnect/sdk-zephyr/blob/main/tests/drivers/pinctrl/nrf/src/main.c
2) Thanks for the clarification. Just so to confirm I understand it correctly, does this mean that DFU works now, and the only problem being that the device manager app is "wrongfully" reporting "time out" after an successful update?
thanks for reply,
1)
i2s_rxtx: &i2s0 {
status = "okay";
pinctrl-0 = <&i2s0_default_alt>;
pinctrl-names = "default";
&pinctrl {
i2s0_default_alt: i2s0_default_alt {
group1 {
psels = <NRF_PSEL(I2S_SCK_S, 0, 0X15)>,
<NRF_PSEL(I2S_LRCK_S, 1, 0X08)>,
<NRF_PSEL(I2S_SDOUT, 0, 0X13)>;
// <NRF_PSEL(I2S_SDIN, 0, 0xFF)>;
2)yes,it works now,
device manager app is not "wrongfully" reporting "time out" after an successful update.
time out means not successful update. it will RollBACK swap.
Steps I guess:
1.manager app connect to 5340,
2.manager app upload data,
3.5340 swap data,
4.5340 sys_reboot,No mark complete in mcu flash.
5.manager app connect again for confirm. 5340 will mark complete in mcu flash.
6.manager app get respond will show "complete ".
NCS1.9 This problem will not occur, don't need connect again.
maybe 5340 mark complete in step4, and respond to device manager app for show complete.
please check the problem is SDK bug?
Best regards
1) PINCTRL_DT_DEV_CONFIG_GET(DT_NODELABEL(i2s0)); should not expand to The__pinctrl_dev_config__device_dts_ord_DT_N_NODELABEL_test_device_ORD. Please make sure you are not using the macro with "test_device" as in the sample linked to.
2) This sounds like the correct behavior, the bootloader will roll back to the previous image if the update does not get confirmed. But you don't need to confirm it over BLE (which will lead to a timeout in your case). You can do a "confirm only" update instead of "test and confirm", or you can call img_mgmt_state_confirm() from the new application after it has booted up.
thank you very much,
do "confirm only" that ok,
not need connect again.
Best regards
