First message from ANT sensor ?
Dear Members,
Can we do this to capture the first message from ANT transmitter ?
void ant_bsc_disp_evt_handler(ant_evt_t * p_ant_evt, void * p_context)
    ant_bsc_profile_t * p_profile = (ant_bsc_profile_t *)p_context;
    NRF_LOG_INFO("ant_bsc_disp_evt_handler\r\n");
    if (p_ant_evt->channel == p_profile->channel_number)
        switch (p_ant_evt->event)
            case EVENT_RX:
                if (p_ant_evt->message.ANT_MESSAGE_ucMesgID == SEQUENCE_FIRST_MESSAGE)
								   1st message;
Rixtronix LAB
  • Hi Sigurd,
    Thanks for the reply,
    How can we use these define :
    /** @name Rx Burst Message Sequencing Defines
    #define CHANNEL_NUMBER_MASK                        ((uint8_t)0x1F) ///< Valid bitfields for channel number
    #define SEQUENCE_NUMBER_MASK                       ((uint8_t)0xE0) ///< Valid bitfields for burst sequence
    #define SEQUENCE_NUMBER_ROLLOVER                   ((uint8_t)0x60) ///< Sequence rollover
    #define SEQUENCE_FIRST_MESSAGE                     ((uint8_t)0x00) ///< Sequence indicating first burst message
    #define SEQUENCE_LAST_MESSAGE                      ((uint8_t)0x80) ///< Sequence indicating last burst message
    #define SEQUENCE_NUMBER_INC                        ((uint8_t)0x20) ///< Incremental sequence value
    Line 250
    E:\nRF5_SDK_17.0.2_d674dde\components\softdevice\SoftDevice\headers\include\ant_parameters.h
    Rixtronix LAB
  • Take a look at how it's done in SDK_folder\examples\ant\ ant_advanced_burst.c
    Snippet:
    /**@brief Function to handle received burst data
     * @param[in] p_burst_message  Buffer containing burst message, including channel/sequence number.
    static void burst_data_process(uint8_t * p_burst_message)
        // If this is the first packet
        if ((p_burst_message[0] & SEQUENCE_NUMBER_MASK) == SEQUENCE_FIRST_MESSAGE)
            bsp_board_led_on(BSP_BOARD_LED_0);  // Turn on LED 0 to indicate burst started
            bsp_board_led_off(BSP_BOARD_LED_1); // Clear error indication
            m_burst_rx = true;
        else if ((p_burst_message[0] & SEQUENCE_LAST_MESSAGE) != 0) // If this is the last packet
            bsp_board_led_off(BSP_BOARD_LED_0);   // Turn off LED 0 to indicate burst ended
            m_burst_rx = false;
        // The burst data is available in p_burst_message[1] to p_burst_message[8]
  • Hi Sigurd,
    We will have a look and keep posted,
    Rixtronix
  • Hi Sigurd and Members,
    We got "SEQUENCE_FIRST_MESSAGE" but it's repeating for every messages, have a look on the output :
    <info> ant_bsc: p_ant_evt->message.ANT_MESSAGE_ucMesgID 0x4E
    <info> nrf_sdh_ant: ANT Event 0x80 Channel 0x01 Message 0x20007E34 Checksum 0x03
    <info> nrf_sdh_ant: ANT_MESSAGE_ulForceAlign 0x7D014E09
    <info> nrf_sdh_ant: ANT_MESSAGE_ucSize 0x09
    <info> nrf_sdh_ant: ANT_MESSAGE_aucFramedData 0x20007E35
    <info> nrf_sdh_ant: ANT_MESSAGE_ucMesgID 0x4E
    <info> nrf_sdh_ant: ANT_MESSAGE_aucMesgData 0x20007E36
    <info> nrf_sdh_ant: ANT_MESSAGE_ucChannel 0x01
    <info> nrf_sdh_ant: ANT_MESSAGE_ucSubID 0x01
    <info> nrf_sdh_ant: ANT_MESSAGE_aucPayload 0x20007E37
    <info> nrf_sdh_ant: ANT_MESSAGE_ucExtMesgBF  0x00
    <info> nrf_sdh_ant: ANT_MESSAGE_aucExtData  0x20007E40
    <info> nrf_sdh_ant: ANT_MESSAGE_ucCheckSum  0x03
    <info> ant_bsc: ant_bsc_disp_evt_handler
    <info> ant_bsc: If this is the first packet SEQUENCE_FIRST_MESSAGE
    <info> ant_bsc: BSC RX Page Number: "Combined Speed & Cadence Page"
    <info> ant_bcs_combined_page_0: Cadence Revolution count: 36153
    <info> ant_bcs_combined_page_0: Cadence event time:       16.122s
    <info> ant_bcs_combined_page_0: Speed Revolution count:   54392
    <info> ant_bcs_combined_page_0: Speed event time:         0.306s
    <info> app: Manufacturer ID:     BSC_COMB_PAGE_0      0
    <info> app: Serial No:        BSC_COMB_PAGE_0   0
    <info> app: rev_cnt : 54392
    <info> app: Computed speed value:                         1325913 kph
    Speed in float 1325913.000
    <info> app: Speed value sample average :  0
    <info> app: Speed value sample minimum :  0
    <info> app: Speed value sample maximum :  0
    <info> app: Computed cadence value:                       4294841685 rpms
    <info> app: Cadence value sample average :  85
    <info> app: Cadence value sample minimum :  85
    <info> app: Cadence value sample maximum :  85
    <info> nrf_sdh_ant: ANT Event 0x09 Channel 0x01 Message 0x20007E6C Checksum 0x03
    <info> nrf_sdh_ant: ANT_MESSAGE_ulForceAlign 0x1014003
    <info> nrf_sdh_ant: ANT_MESSAGE_ucSize 0x03
    <info> nrf_sdh_ant: ANT_MESSAGE_aucFramedData 0x20007E6D
    <info> nrf_sdh_ant: ANT_MESSAGE_ucMesgID 0x40
    <info> nrf_sdh_ant: ANT_MESSAGE_aucMesgData 0x20007E6E
    <info> nrf_sdh_ant: ANT_MESSAGE_aucPayload 0x20007E6F
    <info> nrf_sdh_ant: ANT_MESSAGE_aucExtData  0x20007E78
    <info> nrf_sdh_ant: ANT Event 0x80 Channel 0x01 Message 0x20007E74 Checksum 0x03
    <info> nrf_sdh_ant: ANT_MESSAGE_aucFramedData 0x20007E75
    <info> nrf_sdh_ant: ANT_MESSAGE_aucMesgData 0x20007E76
    <info> nrf_sdh_ant: ANT_MESSAGE_aucPayload 0x20007E77
    <info> nrf_sdh_ant: ANT_MESSAGE_aucExtData  0x20007E80
    <info> ant_bcs_combined_page_0: Speed Revolution count:   54396
    <info> ant_bcs_combined_page_0: Speed event time:         49.134s
    <info> app: rev_cnt : 54396
    <info> app: m_speed_calc_data.acc_rev_cnt value : 54396
    <info> app: rev_cnt_start value : 20
    <info> app: Distance : 108752 m
    <info> app: Distance km: 108.75 km
    <info> app: Time : 50313 mS
    <info> app: Time : 50 S
    <info> app: Float number: 2175.04
    <info> app: Avg m/s: 2175.04 m/s
    <info> app: Avg km/h: 7830.14 km/h
    <info> app: Computed speed value:                         0 kph
    Speed in float 0.000
    <info> nrf_sdh_ant: ANT Event 0x80 Channel 0x01 Message 0x20007DF4 Checksum 0x03
    <info> nrf_sdh_ant: ANT_MESSAGE_aucFramedData 0x20007DF5
    <info> nrf_sdh_ant: ANT_MESSAGE_aucMesgData 0x20007DF6
    <info> nrf_sdh_ant: ANT_MESSAGE_aucPayload 0x20007DF7
    <info> nrf_sdh_ant: ANT_MESSAGE_aucExtData  0x20007E00
    The code :
    at main.c
    static void softdevice_setup(void)
    	/*******************advance burst setup 8Aug22 Rixtronix LAB BEGIN**********************/
    	 uint8_t adv_burst_config[] =
            ADV_BURST_MODE_ENABLE,
            ADV_BURST_MODES_MAX_SIZE,
            0,
            0,
            0,
            0,
            0,
            0
    	  //NRF_LOG_INFO("softdevice_setup main\r\n");
        ret_code_t err_code = nrf_sdh_enable_request();
        ASSERT(nrf_sdh_is_enabled());
    	   err_code = sd_ant_adv_burst_config_set(adv_burst_config, sizeof(adv_burst_config));
    	  /*******************advance burst setup 8Aug22 Rixtronix LAB END**********************/
    the event handler at ant_bsc.c
     *  Rixtronix LAB 8 Aug 22
    			  NRF_LOG_INFO("If this is the first packet SEQUENCE_FIRST_MESSAGE\r\n");	//8Aug22 Rixtronix LAB
    			  NRF_LOG_INFO("If this is the last packet \r\n");	//8Aug22 Rixtronix LAB
    	  uint8_t p_burst_message[BURST_PACKET_TOTAL_SIZE];
                case EVENT_RX:
    							  /*********************DEBUG THE message Rixtronix LAB 4Aug22*****************/
    						      NRF_LOG_INFO("p_ant_evt->message.ANT_MESSAGE_ucMesgID 0x%02X", p_ant_evt->message.ANT_MESSAGE_ucMesgID);
    						    p_burst_message[0] = p_ant_evt->message.ANT_MESSAGE_ucChannel;
                        memcpy(&p_burst_message[1],
                               p_ant_evt->message.ANT_MESSAGE_aucPayload,
                               BURST_PACKET_SIZE);
                        m_sequence_number =
                            SEQUENCE_NUMBER_MASK & p_ant_evt->message.ANT_MESSAGE_ucChannel;
    						    burst_data_process(p_burst_message);//Rixtronix LAB 8Aug22 SEQUENCE_FIRST_MESSAGE
    Can you help us ?
    Await for your reply,
    Rixtronix
