Storing and accessing PDM data from microphone input
Hi
I'm new to programming and recently started working on nrf52832.
I'm working on a wearable device that monitors patient's vital. I'm using MP34DB02 digital microphone to record patient breathing to detect difficulty in breathing. I can't read input from the mic and creating and accessing pdm data stored in buffer. This is the code I have so far:
ret_code_t drv_audio_enable(void)
        nrf_delay_ms(100);
        //Start audio capture
        return nrf_drv_pdm_start();
ret_code_t drv_audio_disable(void)
        ret_code_t status;
        //Stop audio capture
        status = nrf_drv_pdm_stop();
        if(status!= NRF_SUCCESS)
          return status;
        return NRF_SUCCESS;
static void drv_audio_pdm_event_handler(nrf_drv_pdm_evt_t const * const p_evt)
    int16_t *p_buffer_released = p_evt->buffer_released;
    if(p_evt->buffer_requested)
       int16_t *p_buffer;
       if(!p_buffer)
          NRF_LOG_WARNING("%s(): WARNING: Cannot allocate audio buffer!", __func__);
          //We have to provide fresh buffer to keep PDM running.
          //Since pool is empty, our sole option is to reuse the released buffer.
          if(p_buffer_released)
             p_buffer          = p_buffer_released;
             p_buffer_released = NULL;
       if(p_buffer)
          NRF_LOG_DEBUG("Buffer Request: 0x%08X%s",
                         p_buffer,
                         (p_buffer == p_evt->buffer_released) ?"(reusing released buffer)":"");
          APP_ERROR_CHECK(nrf_drv_pdm_buffer_set(p_buffer, CONFIG_PDM_BUFFER_SIZE_SAMPLES));
        NRF_LOG_DEBUG("Buffer Release: 0x%08X", p_buffer_released);
ret_code_t drv_audio_init(void)
    nrf_drv_pdm_config_t pdm_cfg = NRF_DRV_PDM_DEFAULT_CONFIG(clk_audio,
                                                              dout);
    ret_code_t err_code; // a variable to hold error code value
    pdm_cfg.gain_l      = CONFIG_PDM_GAIN;
    pdm_cfg.gain_r      = CONFIG_PDM_GAIN;
    pdm_cfg.edge = NRF_PDM_EDGE_LEFTFALLING;
    nrf_gpio_cfg_output(lrsel);
    nrf_gpio_pin_clear(lrsel);
    NRF_LOG_FLUSH(); // flushing is important, if you set the deffered to 1, if deffered is set to 0 then we don't need to flush the log buffer.
    //Initialize PDM driver
    return nrf_drv_pdm_init(&pdm_cfg, drv_audio_pdm_event_handler);
// initialize the Logger so that we can print msgs on the logger
  NRF_LOG_INFO("Application Started");
  NRF_LOG_FLUSH(); // flushing is necessary if deferred is set to 1(check this video tutorial to know it better)
  APP_ERROR_CHECK(drv_audio_init());
  drv_audio_enable();
  //nrf_delay_ms(100);
  drv_audio_disable();
What am I missing?
Regards
Raj
  • I get constant values from the start and its always 0x00000001 and once in a while it displays 0x20001EA8. It's the same with every parameter I change. Here is the modified code for the PDM part of the program:
    int BLE_TEXT(uint8_t bletext[90])
        if(connected)
            uint16_t length=strlen(bletext);ble_nus_data_send(&m_nus, bletext, &length, m_conn_handle);
            nrf_gpio_pin_clear(ledPin);
            nrf_gpio_pin_set(ledPin);
            nrf_delay_ms(100);
            ret_code_t status;
              return status;
            return NRF_SUCCESS;
           int16_t *p_buffer;
           if(!p_buffer)
           //   NRF_LOG_WARNING("%s(): WARNING: Cannot allocate audio buffer!", __func__);
           //   //We have to provide fresh buffer to keep PDM running.
           //   //Since pool is empty, our sole option is to reuse the released buffer.
                 sprintf(lcdtext,"\n\rBuffer is released");BLE_TEXT(lcdtext);
           if(p_buffer)
              //NRF_LOG_DEBUG("Buffer Request: 0x%08X%s",
              //               p_buffer,
              //               (p_buffer == p_evt->buffer_released) ?"(reusing released buffer)":"");
              sprintf(lcdtext,"\n\rBuffer Request: 0x%08X %s",
                             p_buffer,
              BLE_TEXT(lcdtext);
       if(p_evt->buffer_released)
            //NRF_LOG_DEBUG("Buffer Release: 0x%08X", p_buffer_released);
            sprintf(lcdtext,"\n\rBuffer Release: 0x%08X", p_buffer_released);BLE_TEXT(lcdtext);
            sprintf(lcdtext,"\n\rBuffer Release: 0x%08X", p_evt->buffer_released);BLE_TEXT(lcdtext);
    ret_code_t drv_audio_init(/*nrf_balloc_t const *p_buffer_pool, drv_audio_buffer_handler_t buffer_handler*/)
        dout);
        pdm_cfg.mode        = 1;
        pdm_cfg.clock_freq  = 134217728; //1 MHz
    /**@brief Application main function.
    {//1
        int count=1;
        nrf_gpio_pin_dir_set(ledPin,NRF_GPIO_PIN_DIR_OUTPUT);
        nrf_gpio_pin_dir_set(lrsel,NRF_GPIO_PIN_DIR_OUTPUT);
        nrf_gpio_pin_dir_set(clk_audio,NRF_GPIO_PIN_DIR_OUTPUT);
        nrf_gpio_pin_dir_set(dout,NRF_GPIO_PIN_DIR_INPUT);
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        advertising_start();
        nrf_delay_ms(100);
        sprintf(lcdtext,"\n\n\tStarting application...\n");BLE_TEXT(lcdtext);
      uint8_t bletext[100];
      while(1)
        if((connected==false)&(advertising_initiated==false))
             {//3
               advertising_initiated=true;
             }//3
        sprintf(bletext,"\n\rReading %d",count);
        count++;
        BLE_TEXT(bletext);
        drv_audio_enable();
        nrf_delay_ms(1000);
  • Hi Raj,
    Could you provide minimal sample project and the steps which I can follow to test it?
    Note that if you have any private information which you don't want to be publicly visible there is a possibility to make the case private.
    Dejan
  • Hi Dejan
    Here's the code for reading the microphone data through NUS. I'm not sure how to send the entire project to you over here. Please let me know how I can send it.
    I use a custom made application to read the data through the COM port and sometimes PuTTY at a baud rate of 115200. We use MP34DB02 digital microphone. You can find the datasheet here. Hope this helps.
    Regards
    Raj
    #define ENABLE_TRACE false
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include <stdlib.h>
    #include "nordic_common.h"
     int BLE_TEXT();
    #include "nrf_drv_spi.h"
    #include "nrf_drv_rtc.h"
    #include "nrf_drv_clock.h"
    #include "boards.h"
    #include "app_error.h"
    #include "nrf_drv_twi.h"
    #include "nrf_delay.h"
    #include "nrf_gpio.h"
    #include "SparkFun_Bio_Sensor_Hub_Library.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_drv_timer.h"
    #include "nrf_calendar.h"
    //PDM for mic
    #include "nrf_drv_pdm.h"
    #include "nrf_pdm.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define lrsel      NRF_GPIO_PIN_MAP(0,17)
    #define clk_audio  NRF_GPIO_PIN_MAP(0,18)
    #define dout       NRF_GPIO_PIN_MAP(0,19)
    #define ledPin    NRF_GPIO_PIN_MAP(0,30)
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "*Insert Device Name*"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define TEST_STRING "Nordic"
    #define SPI_INSTANCE  0 /**< SPI instance index. */
    #define COMPARE_COUNTERTIME  (3UL)
    #define CONFIG_PDM_BUFFER_SIZE_SAMPLES 320                                          //Buffer for mic input
    // <o> PDM Decimation Filter Gain <0x00-0x50>
    // <i> For details on the PDM decimation filter, see the 'Decimation filter' section in the nRF52 Product Specification document.
    #define CONFIG_PDM_GAIN 0x28
    static volatile bool buffer_request;
    uint8_t lcdtext[40],bletext[150];
    static bool connected = false, advertising_initiated=true,write_to_memory=false;
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
        if(connected)
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                //BLE_TEXT("Connected");
                connected=true;
                advertising_initiated=false;
                //printf("Disconnected");
                //nrf_gpio_pin_set(ledPin);
                //MAX20303_LED1_on();MAX20303_LED2_off();MAX20303_LED3_on();
                //turn on LED on nrf52832
                //NRF_LOG_FLUSH();
                //BLE_TEXT("Disconnected");
                connected=false;
                //NRF_LOG_DEBUG("PHY update request.");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        //NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
          //            p_gatt->att_mtu_desired_central,
            //          p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    static void log_init(void)
            //nrf_pwr_mgmt_run();
            nrf_delay_ms(100);
            ret_code_t status;
              return status;
            return NRF_SUCCESS;
           int16_t *p_buffer;
           //if(!p_buffer)
           if(p_buffer)
              //               p_buffer,
              sprintf(lcdtext,"\n\rBuffer Request: 0x%08X%s",
                             p_buffer,
              BLE_TEXT(lcdtext);
    ret_code_t drv_audio_init()
        dout);
        pdm_cfg.mode        = 1;
        pdm_cfg.clock_freq  = 138412032; //1.032 MHz
    {//1
        int count=1;
        nrf_gpio_pin_set(lrsel);
        log_init();
        timers_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        nrf_delay_ms(100);
      while(1)
             {//3
             }//3
        count++;
        BLE_TEXT(bletext);
        drv_audio_enable();
        nrf_delay_ms(1000);
  • BTW I used the ble_app_uart example for the program and added necessary PDM drivers and libraries.
  • Hi Raj,
    You could take a look at the PDM code example and related discussion in PDM code implementation and testing.
    Dejan
