nRF82532 DTM firmware not communicating with nRF DTM desktop software
I am having trouble communicating with the nRF82532 and the DTM software.  I am using nRF5_SDK_17.1.0 which has the DTM firmware.  The project that I selected is: direct_test_mode_pca10040 for the Segger Embedded Studio for ARMv5.66.  The nRF DTM software version is 2.02.  Below is a copy of the log file from the DTM software:
2022-08-08T22:07:30.017Z DEBUG Application data folder: C:\Users\DevEng02\AppData\Roaming\nrfconnect\pc-nrfconnect-dtm
2022-08-08T22:07:30.133Z INFO Using nrf-device-lib-js version: 0.4.11
2022-08-08T22:07:30.133Z INFO Using nrf-device-lib version: 0.11.8
2022-08-08T22:07:30.133Z INFO Using nrfjprog DLL version: 10.15.4
2022-08-08T22:07:30.134Z INFO Using JLink version: JLink_V7.58b
2022-08-08T22:07:30.156Z DEBUG App pc-nrfconnect-dtm v2.0.2 official
2022-08-08T22:07:30.156Z DEBUG App path: C:\Users\DevEng02\.nrfconnect-apps\node_modules\pc-nrfconnect-dtm
2022-08-08T22:07:30.156Z DEBUG nRFConnect 3.11.1, required by the app is (^3.8.0)
2022-08-08T22:07:30.156Z DEBUG nRFConnect path: C:\Users\DevEng02\AppData\Local\Programs\nrfconnect\resources\app.asar
2022-08-08T22:07:30.156Z DEBUG HomeDir: C:\Users\DevEng02
2022-08-08T22:07:30.156Z DEBUG TmpDir: C:\Users\DevEng02\AppData\Local\Temp
2022-08-08T22:07:41.425Z INFO No firmware defined for selected device
2022-08-08T22:07:41.426Z INFO Please make sure the device has been programmed with a supported firmware
2022-08-08T22:07:41.436Z INFO Device selected successfully
2022-08-08T22:08:22.490Z INFO Running device setup
2022-08-08T22:08:22.490Z DEBUG DTM Transport: Create setup CMD with control: 0
2022-08-08T22:08:22.490Z DEBUG DTM Transport: Create setup CMD with parameter: 0
2022-08-08T22:08:22.490Z DEBUG DTM Transport: Create setup CMD with dc type: 00
2022-08-08T22:08:22.536Z DEBUG DTM Transport: Serialport is opened
2022-08-08T22:08:22.536Z DEBUG DTM Transport: Succeeded to open serialport
2022-08-08T22:08:22.537Z DEBUG DTM Transport: Sending data: 0x00 0x00
2022-08-08T22:08:23.538Z INFO DTM setup reset command failed
2022-08-08T22:08:23.538Z INFO Can not communicate with device. Make sure it is not in use by another application and that it has a Direct Test Mode compatible firmware.
I did reconfigure my UART port pins for the firmware as shown below from the include file:
// LEDs definitions for PCA10040
#define LEDS_NUMBER    4
#define LED_START      17
#define LED_1          17
#define LED_2          18
#define LED_3          19
#define LED_4          20
#define LED_STOP       20
#define LEDS_ACTIVE_STATE 0
#define LEDS_INV_MASK  LEDS_MASK
#define LEDS_LIST { LED_1, LED_2, LED_3, LED_4 }
#define BSP_LED_0      LED_1
#define BSP_LED_1      LED_2
#define BSP_LED_2      LED_3
#define BSP_LED_3      LED_4
#define BUTTONS_NUMBER 4
#define BUTTON_START   13
#define BUTTON_1       13
#define BUTTON_2       14
#define BUTTON_3       15
#define BUTTON_4       16
#define BUTTON_STOP    16
#define BUTTON_PULL    NRF_GPIO_PIN_PULLUP
#define BUTTONS_ACTIVE_STATE 0
#define BUTTONS_LIST { BUTTON_1, BUTTON_2, BUTTON_3, BUTTON_4 }
#define BSP_BUTTON_0   BUTTON_1
#define BSP_BUTTON_1   BUTTON_2
#define BSP_BUTTON_2   BUTTON_3
#define BSP_BUTTON_3   BUTTON_4
#define RX_PIN_NUMBER  4    // P0.08   KL4-TX-GRN  // 2022-08-01 -> FCC Test on BLE Rev C -> P0.04 pad A
#define TX_PIN_NUMBER  9    // P0.06   KL4-RX-YEL  // 2022-08-01 -> FCC Test on BLE Rev C -> P0.09 pad D
#define CTS_PIN_NUMBER 7    // P0.07
#define RTS_PIN_NUMBER 5    // P0.05
#define HWFC           true
#define SPIS_MISO_PIN   28  // SPI MISO signal.
#define SPIS_CSN_PIN    12  // SPI CSN signal.
#define SPIS_MOSI_PIN   25  // SPI MOSI signal.
#define SPIS_SCK_PIN    29  // SPI SCK signal.
#define SPIM0_SCK_PIN   29  // SPI clock GPIO pin number.
#define SPIM0_MOSI_PIN  25  // SPI Master Out Slave In GPIO pin number.
#define SPIM0_MISO_PIN  28  // SPI Master In Slave Out GPIO pin number.
#define SPIM0_SS_PIN    12  // SPI Slave Select GPIO pin number.
#define SPIM1_SCK_PIN   2   // SPI clock GPIO pin number.
#define SPIM1_MOSI_PIN  3   // SPI Master Out Slave In GPIO pin number.
#define SPIM1_MISO_PIN  4   // SPI Master In Slave Out GPIO pin number.
#define SPIM1_SS_PIN    5   // SPI Slave Select GPIO pin number.
#define SPIM2_SCK_PIN   12  // SPI clock GPIO pin number.
#define SPIM2_MOSI_PIN  13  // SPI Master Out Slave In GPIO pin number.
#define SPIM2_MISO_PIN  14  // SPI Master In Slave Out GPIO pin number.
#define SPIM2_SS_PIN    15  // SPI Slave Select GPIO pin number.
// serialization APPLICATION board - temp. setup for running serialized MEMU tests
#define SER_APP_RX_PIN              23    // UART RX pin number.
#define SER_APP_TX_PIN              24    // UART TX pin number.
#define SER_APP_CTS_PIN             2     // UART Clear To Send pin number.
#define SER_APP_RTS_PIN             25    // UART Request To Send pin number.
#define SER_APP_SPIM0_SCK_PIN       27     // SPI clock GPIO pin number.
#define SER_APP_SPIM0_MOSI_PIN      2      // SPI Master Out Slave In GPIO pin number
#define SER_APP_SPIM0_MISO_PIN      26     // SPI Master In Slave Out GPIO pin number
#define SER_APP_SPIM0_SS_PIN        23     // SPI Slave Select GPIO pin number
#define SER_APP_SPIM0_RDY_PIN       25     // SPI READY GPIO pin number
#define SER_APP_SPIM0_REQ_PIN       24     // SPI REQUEST GPIO pin number
// serialization CONNECTIVITY board
#define SER_CON_RX_PIN              24    // UART RX pin number.
#define SER_CON_TX_PIN              23    // UART TX pin number.
#define SER_CON_CTS_PIN             25    // UART Clear To Send pin number. Not used if HWFC is set to false.
#define SER_CON_RTS_PIN             2     // UART Request To Send pin number. Not used if HWFC is set to false.
#define SER_CON_SPIS_SCK_PIN        27    // SPI SCK signal.
#define SER_CON_SPIS_MOSI_PIN       2     // SPI MOSI signal.
#define SER_CON_SPIS_MISO_PIN       26    // SPI MISO signal.
#define SER_CON_SPIS_CSN_PIN        23    // SPI CSN signal.
#define SER_CON_SPIS_RDY_PIN        25    // SPI READY GPIO pin number.
#define SER_CON_SPIS_REQ_PIN        24    // SPI REQUEST GPIO pin number.
#define SER_CONN_CHIP_RESET_PIN     11    // Pin used to reset connectivity chip
// Arduino board mappings
#define ARDUINO_SCL_PIN             27    // SCL signal pin
#define ARDUINO_SDA_PIN             26    // SDA signal pin
#define ARDUINO_AREF_PIN            2     // Aref pin
#define ARDUINO_13_PIN              25    // Digital pin 13
#define ARDUINO_12_PIN              24    // Digital pin 12
#define ARDUINO_11_PIN              23    // Digital pin 11
#define ARDUINO_10_PIN              22    // Digital pin 10
#define ARDUINO_9_PIN               20    // Digital pin 9
#define ARDUINO_8_PIN               19    // Digital pin 8
#define ARDUINO_7_PIN               18    // Digital pin 7
#define ARDUINO_6_PIN               17    // Digital pin 6
#define ARDUINO_5_PIN               16    // Digital pin 5
#define ARDUINO_4_PIN               15    // Digital pin 4
#define ARDUINO_3_PIN               14    // Digital pin 3
#define ARDUINO_2_PIN               13    // Digital pin 2
#define ARDUINO_1_PIN               12    // Digital pin 1
#define ARDUINO_0_PIN               11    // Digital pin 0
#define ARDUINO_A0_PIN              3     // Analog channel 0
#define ARDUINO_A1_PIN              4     // Analog channel 1
#define ARDUINO_A2_PIN              28    // Analog channel 2
#define ARDUINO_A3_PIN              29    // Analog channel 3
#define ARDUINO_A4_PIN              30    // Analog channel 4
#define ARDUINO_A5_PIN              31    // Analog channel 5
If I try to debug, I end up in an exception handler after most step commands.  If I set a breakpoint in the main loop, I can make it to the breakpoint within the main loop but any subsequent step commands cause the exception to occur.  If I try to run the debug version of the DTM firmware in the IDE, the firmware will automatically end up in the exception handler.
I am using a 32 MHz crystal and I am setup to use the DCDC regulator mode if that should be taken into account.
Any ideas?
Allen Shea
  • Hello Simon,
    As I stated before, I am using a custom board.  I have only defined pin 9 as use in the serial configuration.  I have looked through the sdk_config.h file and did not see any references to the pin 9.  Not really sure where else to look for conflicts.  As for trying a different pin, I will see if we can get P0.02 to work since it is exposed.
    Allen
