I have this error while building my nRF connect project using segger embedded studio have you an Idea about how to fix it?
Please select 'Output' instead of 'Tasks', then copy the entire log and paste it here using Insert > Code. Thank you.
Marte
This the output:
Building ‘C:/Users/ghaaz/ncs/v1.9.0/zephyr/misc/empty_file.c’ from solution ‘build’ in configuration ‘Common’
Building ‘C:/Users/ghaaz/ncs/v1.9.0/zephyr/include/dt-bindings/gpio/gpio.h’ from solution ‘build’ in configuration ‘Common’
Building ‘C:/Users/ghaaz/ncs/v1.9.0/zephyr/include/dt-bindings/i2c/i2c.h’ from solution ‘build’ in configuration ‘Common’
Building ‘C:/Users/ghaaz/ncs/v1.9.0/zephyr/include/dt-bindings/pinctrl/nrf-pinctrl.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/misc/generated/syscalls.json’
Building ‘zephyr/misc/generated/struct_tags.json’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/driver-validation.h’
Building ‘zephyr/CMakeFiles/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/kobj-types-enum.h’
Building ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/otype-to-size.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/syscall_list.h’
Building ‘zephyr/CMakeFiles/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_offsets’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj’ from solution ‘build’ in configuration ‘Common’
2> Compiling ‘offsets.c’
Building ‘zephyr/offsets’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/offsets.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/offsets.h’
Building ‘zephyr/CMakeFiles/offsets_h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/offsets_h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/zephyr_generated_headers’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_..__nrf__drivers__hw_cc310’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_..__nrf__lib__fatal_error’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_app’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_arch__arm__core__aarch32’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_arch__arm__core__aarch32__cortex_m’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_arch__arm__core__aarch32__mpu’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_isr_tables’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_arch__common’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_drivers__clock_control’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_drivers__gpio’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_drivers__serial’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_drivers__timer’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_kernel’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_lib__libc__newlib’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_lib__posix’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_modules__hal_nordic__nrfx’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_soc__arm__common__cortex_m’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_soc__arm__nordic_nrf__nrf52’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_zephyr’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/autoconf.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/linker_zephyr_pre0.cmd’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/linker_zephyr_pre0.cmd’
Building ‘zephyr/CMakeFiles/linker_zephyr_pre0_script’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/linker_zephyr_pre0_script’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_zephyr_pre0’ from solution ‘build’ in configuration ‘Common’
Building ‘app/libapp.a’ from solution ‘build’ in configuration ‘Common’
3> Compiling ‘activations.cc’
4> Compiling ‘add.cc’
1> Compiling ‘add_n.cc’
2> Compiling ‘all_ops_resolver.cc’
1> Compiling ‘arg_min_max.cc’
3> Compiling ‘batch_to_space_nd.cc’
3> Compiling ‘cast.cc’
1> Compiling ‘ceil.cc’
4> Compiling ‘circular_buffer.cc’
2> Compiling ‘comparisons.cc’
3> Compiling ‘concatenation.cc’
1> Compiling ‘conv.cc’
4> Compiling ‘conv_common.cc’
1> Compiling ‘debug_log.cpp’
3> Compiling ‘debug_log.cpp’
2> Compiling ‘debug_log.cpp’
4> Compiling ‘debug_log.cpp’
1> Compiling ‘depthwise_conv.cc’
4> Compiling ‘depthwise_conv_common.cc’
2> Compiling ‘dequantize.cc’
3> Compiling ‘div.cc’
4> Compiling ‘ei_classifier_porting.cpp’
2> Compiling ‘ei_classifier_porting.cpp’
1> Compiling ‘ei_classifier_porting.cpp’
3> Compiling ‘ei_classifier_porting.cpp’
3> Compiling ‘ei_run_classifier_c.cpp’
4> Compiling ‘elementwise.cc’
2> Compiling ‘elu.cc’
1> Compiling ‘error_reporter.cc’
3> Compiling ‘ethosu.cc’
1> Compiling ‘exp.cc’
2> Compiling ‘expand_dims.cc’
4> Compiling ‘fast-dct-fft.cpp’
1> Compiling ‘fill.cc’
2> Compiling ‘flatbuffer_conversions.cc’
3> Compiling ‘floor.cc’
4> In file included from [01m[K../edge-impulse-sdk/dsp/dct/fast-dct-fft.cpp:29[m[K:
4> [01m[K../edge-impulse-sdk/dsp/dct/../numpy.hpp:[m[K In static member function '[01m[Kstatic int ei::numpy::welch_max_hold(float*, size_t, float*, size_t, size_t, size_t, bool)[m[K':
4> [01m[K../edge-impulse-sdk/dsp/dct/../numpy.hpp:2373:25:[m[K [01;35m[Kwarning: [m[Kcomparison of integer expressions of different signedness: '[01m[Kint[m[K' and '[01m[Ksize_t[m[K' {aka '[01m[Kunsigned int[m[K'} [[01;35m[K-Wsign-compare[m[K]
1> Compiling ‘fully_connected.cc’
4> Compiling ‘fully_connected_common.cc’
3> Compiling ‘greedy_memory_planner.cc’
4> Compiling ‘hard_swish.cc’
1> Compiling ‘kernel_runner.cc’
3> Compiling ‘kernel_util_lite.cc’
1> Compiling ‘kernel_util_micro.cc’
4> Compiling ‘kiss_fft.cpp’
1> Compiling ‘kiss_fftr.cpp’
3> Compiling ‘l2_pool_2d.cc’
4> Compiling ‘l2norm.cc’
1> Compiling ‘leaky_relu.cc’
3> Compiling ‘linear_memory_planner.cc’
1> Compiling ‘logical.cc’
3> Compiling ‘logistic.cc’
4> Compiling ‘main.cpp’
4> In file included from [01m[K.././edge-impulse-sdk/CMSIS/DSP/Include/arm_math.h:214[m[K,
4> from [01m[K.././edge-impulse-sdk/dsp/numpy.hpp:51[m[K,
4> from [01m[K.././edge-impulse-sdk/classifier/ei_model_types.h:27[m[K,
4> from [01m[K.././model-parameters/model_variables.h:27[m[K,
4> from [01m[K.././edge-impulse-sdk/classifier/ei_run_classifier.h:28[m[K,
4> from [01m[K../src/main.cpp:5[m[K:
4> [01m[K.././edge-impulse-sdk/CMSIS/DSP/Include/dsp/utils.h:45:[m[K [01;35m[Kwarning: [m[K"ROUND_UP" redefined
4> In file included from [01m[KC:/Users/ghaaz/ncs/v1.9.0/zephyr/include/kernel/sched_priq.h:9[m[K,
4> from [01m[KC:/Users/ghaaz/ncs/v1.9.0/zephyr/include/kernel_includes.h:23[m[K,
4> from [01m[KC:/Users/ghaaz/ncs/v1.9.0/zephyr/include/kernel.h:17[m[K,
4> from [01m[KC:/Users/ghaaz/ncs/v1.9.0/zephyr/include/zephyr.h:18[m[K,
4> from [01m[K../src/main.cpp:1[m[K:
4> [01m[KC:/Users/ghaaz/ncs/v1.9.0/zephyr/include/sys/util.h:154:[m[K [01;36m[Knote: [m[Kthis is the location of the previous definition
1> Compiling ‘maximum_minimum.cc’
4> In file included from [01m[K.././edge-impulse-sdk/classifier/ei_model_types.h:27[m[K,
4> [01m[K.././edge-impulse-sdk/dsp/numpy.hpp:[m[K In static member function '[01m[Kstatic int ei::numpy::welch_max_hold(float*, size_t, float*, size_t, size_t, size_t, bool)[m[K':
4> [01m[K.././edge-impulse-sdk/dsp/numpy.hpp:2373:25:[m[K [01;35m[Kwarning: [m[Kcomparison of integer expressions of different signedness: '[01m[Kint[m[K' and '[01m[Ksize_t[m[K' {aka '[01m[Kunsigned int[m[K'} [[01;35m[K-Wsign-compare[m[K]
4> In file included from [01m[K.././edge-impulse-sdk/dsp/spectral/spectral.hpp:28[m[K,
4> from [01m[K.././edge-impulse-sdk/classifier/ei_run_dsp.h:27[m[K,
4> from [01m[K.././edge-impulse-sdk/classifier/ei_run_classifier.h:34[m[K,
4> [01m[K.././edge-impulse-sdk/dsp/spectral/feature.hpp:[m[K In static member function '[01m[Kstatic int ei::spectral::feature::extract_spectral_analysis_features_v2(ei::matrix_t*, ei::matrix_t*, ei_dsp_config_spectral_analysis_t*, float)[m[K':
4> [01m[K.././edge-impulse-sdk/dsp/spectral/feature.hpp:422:31:[m[K [01;35m[Kwarning: [m[Kcomparison of integer expressions of different signedness: '[01m[Kint[m[K' and '[01m[Ksize_t[m[K' {aka '[01m[Kunsigned int[m[K'} [[01;35m[K-Wsign-compare[m[K]
3> Compiling ‘memory.cpp’
2> Compiling ‘memory_helpers.cc’
3> Compiling ‘micro_allocator.cc’
1> Compiling ‘micro_error_reporter.cc’
4> [01m[K.././edge-impulse-sdk/dsp/numpy.hpp:2392:43:[m[K [01;35m[Kwarning: [m[K'[01m[Ksaved_point[m[K' may be used uninitialized in this function [[01;35m[K-Wmaybe-uninitialized[m[K]
1> Compiling ‘micro_interpreter.cc’
4> Compiling ‘micro_profiler.cc’
4> Compiling ‘micro_string.cc’
2> Compiling ‘micro_time.cc’
4> Compiling ‘micro_utils.cc’
2> Compiling ‘mli_slicers.cc’
2> Compiling ‘mul.cc’
4> Compiling ‘neg.cc’
3> Compiling ‘op_resolver.cc’
1> Compiling ‘pack.cc’
4> Compiling ‘pad.cc’
1> Compiling ‘pooling.cc’
4> Compiling ‘prelu.cc’
3> Compiling ‘processing.cpp’
2> Compiling ‘quantization_util.cc’
4> Compiling ‘quantize.cc’
1> Compiling ‘quantize_common.cc’
3> Compiling ‘recording_micro_allocator.cc’
4> Compiling ‘recording_simple_memory_allocator.cc’
2> Compiling ‘reduce.cc’
1> Compiling ‘reshape.cc’
4> Compiling ‘resize_nearest_neighbor.cc’
1> Compiling ‘round.cc’
4> Compiling ‘schema_utils.cc’
3> Compiling ‘scratch_buf_mgr.cc’
2> Compiling ‘scratch_buffers.cc’
3> Compiling ‘shape.cc’
2> Compiling ‘simple_memory_allocator.cc’
1> Compiling ‘softmax.cc’
1> Compiling ‘softmax_common.cc’
3> Compiling ‘space_to_batch_nd.cc’
4> Compiling ‘split.cc’
2> Compiling ‘split_v.cc’
4> Compiling ‘squeeze.cc’
1> Compiling ‘strided_slice.cc’
3> Compiling ‘sub.cc’
2> Compiling ‘svdf.cc’
1> Compiling ‘svdf_common.cc’
3> Compiling ‘system_setup.cc’
2> Compiling ‘tanh.cc’
3> Compiling ‘tensor_utils.cc’
4> Compiling ‘test_helpers.cc’
3> Compiling ‘tflite_detection_postprocess.cc’
1> Compiling ‘trained_model_compiled.cpp’
2> Compiling ‘transpose_conv.cc’
2> Compiling ‘unpack.cc’
3> Compiling ‘zeros_like.cc’
3> Compiling ‘arm_abs_f16.c’
1> Compiling ‘arm_abs_f32.c’
2> Compiling ‘arm_abs_q15.c’
4> Compiling ‘arm_abs_q31.c’
1> Compiling ‘arm_abs_q7.c’
3> Compiling ‘arm_add_f16.c’
2> Compiling ‘arm_add_f32.c’
4> Compiling ‘arm_add_q15.c’
3> Compiling ‘arm_add_q31.c’
1> Compiling ‘arm_add_q7.c’
2> Compiling ‘arm_and_u16.c’
4> Compiling ‘arm_and_u32.c’
1> Compiling ‘arm_and_u8.c’
3> Compiling ‘arm_avgpool_s8.c’
2> Compiling ‘arm_barycenter_f16.c’
4> Compiling ‘arm_barycenter_f32.c’
1> Compiling ‘arm_bitonic_sort_f32.c’
4> Compiling ‘arm_bitreversal.c’
2> Compiling ‘arm_bitreversal2.c’
3> Compiling ‘arm_bitreversal_f16.c’
1> Compiling ‘arm_bubble_sort_f32.c’
2> Compiling ‘arm_cfft_f16.c’
4> Compiling ‘arm_cfft_f32.c’
3> Compiling ‘arm_cfft_f64.c’
1> Compiling ‘arm_cfft_init_f16.c’
2> Compiling ‘arm_cfft_init_f32.c’
4> Compiling ‘arm_cfft_init_f64.c’
3> Compiling ‘arm_cfft_init_q15.c’
2> Compiling ‘arm_cfft_init_q31.c’
1> Compiling ‘arm_cfft_q15.c’
4> Compiling ‘arm_cfft_q31.c’
3> Compiling ‘arm_cfft_radix2_f16.c’
2> Compiling ‘arm_cfft_radix2_f32.c’
1> Compiling ‘arm_cfft_radix2_init_f16.c’
4> Compiling ‘arm_cfft_radix2_init_f32.c’
3> Compiling ‘arm_cfft_radix2_init_q15.c’
1> Compiling ‘arm_cfft_radix2_init_q31.c’
2> Compiling ‘arm_cfft_radix2_q15.c’
4> Compiling ‘arm_cfft_radix2_q31.c’
3> Compiling ‘arm_cfft_radix4_f16.c’
1> Compiling ‘arm_cfft_radix4_f32.c’
4> Compiling ‘arm_cfft_radix4_init_f16.c’
2> Compiling ‘arm_cfft_radix4_init_f32.c’
3> Compiling ‘arm_cfft_radix4_init_q15.c’
1> Compiling ‘arm_cfft_radix4_init_q31.c’
4> Compiling ‘arm_cfft_radix4_q15.c’
2> Compiling ‘arm_cfft_radix4_q31.c’
3> Compiling ‘arm_cfft_radix8_f16.c’
1> Compiling ‘arm_cfft_radix8_f32.c’
1> Compiling ‘arm_clip_f16.c’
3> Compiling ‘arm_clip_f32.c’
4> Compiling ‘arm_clip_q15.c’
2> Compiling ‘arm_clip_q31.c’
1> Compiling ‘arm_clip_q7.c’
3> Compiling ‘arm_cmplx_conj_f16.c’
4> Compiling ‘arm_cmplx_conj_f32.c’
2> Compiling ‘arm_cmplx_conj_q15.c’
1> Compiling ‘arm_cmplx_conj_q31.c’
4> Compiling ‘arm_cmplx_dot_prod_f16.c’
3> Compiling ‘arm_cmplx_dot_prod_f32.c’
1> Compiling ‘arm_cmplx_dot_prod_q15.c’
2> Compiling ‘arm_cmplx_dot_prod_q31.c’
4> Compiling ‘arm_cmplx_mag_f16.c’
3> Compiling ‘arm_cmplx_mag_f32.c’
2> Compiling ‘arm_cmplx_mag_q15.c’
1> Compiling ‘arm_cmplx_mag_q31.c’
4> Compiling ‘arm_cmplx_mag_squared_f16.c’
3> Compiling ‘arm_cmplx_mag_squared_f32.c’
2> Compiling ‘arm_cmplx_mag_squared_q15.c’
4> Compiling ‘arm_cmplx_mag_squared_q31.c’
1> Compiling ‘arm_cmplx_mult_cmplx_f16.c’
3> Compiling ‘arm_cmplx_mult_cmplx_f32.c’
2> Compiling ‘arm_cmplx_mult_cmplx_q15.c’
4> Compiling ‘arm_cmplx_mult_cmplx_q31.c’
1> Compiling ‘arm_cmplx_mult_real_f16.c’
3> Compiling ‘arm_cmplx_mult_real_f32.c’
2> Compiling ‘arm_cmplx_mult_real_q15.c’
4> Compiling ‘arm_cmplx_mult_real_q31.c’
1> Compiling ‘arm_common_tables.c’
3> Compiling ‘arm_common_tables_f16.c’
4> Compiling ‘arm_concatenation_s8_w.c’
2> Compiling ‘arm_concatenation_s8_x.c’
2> Compiling ‘arm_concatenation_s8_y.c’
4> Compiling ‘arm_concatenation_s8_z.c’
2> Compiling ‘arm_const_structs.c’
3> Compiling ‘arm_const_structs_f16.c’
4> Compiling ‘arm_convolve_1_x_n_s8.c’
2> Compiling ‘arm_convolve_1x1_HWC_q7_fast_nonsquare.c’
3> Compiling ‘arm_convolve_1x1_s8_fast.c’
4> Compiling ‘arm_convolve_HWC_q15_basic.c’
3> Compiling ‘arm_convolve_HWC_q15_fast.c’
2> Compiling ‘arm_convolve_HWC_q15_fast_nonsquare.c’
4> Compiling ‘arm_convolve_HWC_q7_RGB.c’
4> In file included from [01m[K.././edge-impulse-sdk/CMSIS/DSP/Include/dsp/fast_math_functions.h:30[m[K,
4> from [01m[K.././edge-impulse-sdk/CMSIS/DSP/Include/arm_common_tables.h:33[m[K,
4> from [01m[K.././edge-impulse-sdk/CMSIS/NN/Include/arm_nnsupportfunctions.h:33[m[K,
4> from [01m[K../edge-impulse-sdk/CMSIS/NN/Source/ConvolutionFunctions/arm_convolve_HWC_q7_RGB.c:32[m[K:
4> [01m[K../edge-impulse-sdk/CMSIS/NN/Source/ConvolutionFunctions/arm_convolve_HWC_q7_RGB.c:[m[K In function '[01m[Karm_convolve_HWC_q7_RGB[m[K':
4> [01m[K.././edge-impulse-sdk/CMSIS/DSP/Include/arm_math_memory.h:61:33:[m[K [01;35m[Kwarning: [m[Kdereferencing type-punned pointer will break strict-aliasing rules [[01;35m[K-Wstrict-aliasing[m[K]
4> [01m[K../edge-impulse-sdk/CMSIS/NN/Source/ConvolutionFunctions/arm_convolve_HWC_q7_RGB.c:125:26:[m[K [01;36m[Knote: [m[Kin expansion of macro '[01m[K__SIMD32[m[K'
4> [01m[K../edge-impulse-sdk/CMSIS/NN/Source/ConvolutionFunctions/arm_convolve_HWC_q7_RGB.c:158:26:[m[K [01;36m[Knote: [m[Kin expansion of macro '[01m[K__SIMD32[m[K'
3> Compiling ‘arm_convolve_HWC_q7_basic.c’
2> Compiling ‘arm_convolve_HWC_q7_basic_nonsquare.c’
4> Compiling ‘arm_convolve_HWC_q7_fast.c’
3> Compiling ‘arm_convolve_HWC_q7_fast_nonsquare.c’
2> Compiling ‘arm_convolve_s8.c’
4> Compiling ‘arm_convolve_wrapper_s8.c’
3> Compiling ‘arm_copy_f16.c’
2> Compiling ‘arm_copy_f32.c’
4> Compiling ‘arm_copy_q15.c’
3> Compiling ‘arm_copy_q31.c’
2> Compiling ‘arm_copy_q7.c’
4> Compiling ‘arm_cos_f32.c’
3> Compiling ‘arm_cos_q15.c’
1> Compiling ‘arm_cos_q31.c’
2> Compiling ‘arm_dct4_f32.c’
4> Compiling ‘arm_dct4_init_f32.c’
3> Compiling ‘arm_dct4_init_q15.c’
1> Compiling ‘arm_dct4_init_q31.c’
2> Compiling ‘arm_dct4_q15.c’
4> Compiling ‘arm_dct4_q31.c’
1> Compiling ‘arm_depthwise_conv_3x3_s8.c’
3> Compiling ‘arm_depthwise_conv_s8.c’
2> Compiling ‘arm_depthwise_conv_s8_opt.c’
4> Compiling ‘arm_depthwise_conv_u8_basic_ver1.c’
1> Compiling ‘arm_depthwise_conv_wrapper_s8.c’
3> Compiling ‘arm_depthwise_separable_conv_HWC_q7.c’
2> Compiling ‘arm_depthwise_separable_conv_HWC_q7_nonsquare.c’
1> Compiling ‘arm_dot_prod_f16.c’
4> Compiling ‘arm_dot_prod_f32.c’
3> Compiling ‘arm_dot_prod_q15.c’
1> Compiling ‘arm_dot_prod_q31.c’
2> Compiling ‘arm_dot_prod_q7.c’
4> Compiling ‘arm_elementwise_add_s8.c’
3> Compiling ‘arm_elementwise_mul_s8.c’
1> Compiling ‘arm_entropy_f16.c’
2> Compiling ‘arm_entropy_f32.c’
4> Compiling ‘arm_entropy_f64.c’
3> Compiling ‘arm_f16_to_float.c’
1> Compiling ‘arm_f16_to_q15.c’
2> Compiling ‘arm_fill_f16.c’
4> Compiling ‘arm_fill_f32.c’
3> Compiling ‘arm_fill_q15.c’
1> Compiling ‘arm_fill_q31.c’
2> Compiling ‘arm_fill_q7.c’
3> Compiling ‘arm_float_to_f16.c’
4> Compiling ‘arm_float_to_q15.c’
1> Compiling ‘arm_float_to_q31.c’
2> Compiling ‘arm_float_to_q7.c’
3> Compiling ‘arm_fully_connected_mat_q7_vec_q15.c’
4> Compiling ‘arm_fully_connected_mat_q7_vec_q15_opt.c’
1> Compiling ‘arm_fully_connected_q15.c’
2> Compiling ‘arm_fully_connected_q15_opt.c’
3> Compiling ‘arm_fully_connected_q7.c’
4> Compiling ‘arm_fully_connected_q7_opt.c’
1> Compiling ‘arm_fully_connected_s8.c’
2> Compiling ‘arm_heap_sort_f32.c’
3> Compiling ‘arm_insertion_sort_f32.c’
1> Compiling ‘arm_kullback_leibler_f16.c’
4> Compiling ‘arm_kullback_leibler_f32.c’
2> Compiling ‘arm_kullback_leibler_f64.c’
3> Compiling ‘arm_logsumexp_dot_prod_f16.c’
1> Compiling ‘arm_logsumexp_dot_prod_f32.c’
4> Compiling ‘arm_logsumexp_f16.c’
2> Compiling ‘arm_logsumexp_f32.c’
3> Compiling ‘arm_mat_add_f16.c’
1> Compiling ‘arm_mat_add_f32.c’
4> Compiling ‘arm_mat_add_q15.c’
2> Compiling ‘arm_mat_add_q31.c’
3> Compiling ‘arm_mat_cholesky_f16.c’
1> Compiling ‘arm_mat_cholesky_f32.c’
4> Compiling ‘arm_mat_cholesky_f64.c’
2> Compiling ‘arm_mat_cmplx_mult_f16.c’
1> Compiling ‘arm_mat_cmplx_mult_f32.c’
3> Compiling ‘arm_mat_cmplx_mult_q15.c’
4> Compiling ‘arm_mat_cmplx_mult_q31.c’
2> Compiling ‘arm_mat_cmplx_trans_f16.c’
1> Compiling ‘arm_mat_cmplx_trans_f32.c’
3> Compiling ‘arm_mat_cmplx_trans_q15.c’
2> Compiling ‘arm_mat_cmplx_trans_q31.c’
4> Compiling ‘arm_mat_init_f16.c’
1> Compiling ‘arm_mat_init_f32.c’
3> Compiling ‘arm_mat_init_q15.c’
2> Compiling ‘arm_mat_init_q31.c’
4> Compiling ‘arm_mat_inverse_f16.c’
1> Compiling ‘arm_mat_inverse_f32.c’
3> Compiling ‘arm_mat_inverse_f64.c’
2> Compiling ‘arm_mat_ldlt_f32.c’
4> Compiling ‘arm_mat_ldlt_f64.c’
1> Compiling ‘arm_mat_mult_f16.c’
3> Compiling ‘arm_mat_mult_f32.c’
2> Compiling ‘arm_mat_mult_f64.c’
4> Compiling ‘arm_mat_mult_fast_q15.c’
3> Compiling ‘arm_mat_mult_fast_q31.c’
1> Compiling ‘arm_mat_mult_q15.c’
2> Compiling ‘arm_mat_mult_q31.c’
4> Compiling ‘arm_mat_mult_q7.c’
4> Compiling ‘arm_mat_scale_f16.c’
1> Compiling ‘arm_mat_scale_f32.c’
2> Compiling ‘arm_mat_scale_q15.c’
3> Compiling ‘arm_mat_scale_q31.c’
3> Compiling ‘arm_mat_solve_lower_triangular_f16.c’
2> Compiling ‘arm_mat_solve_lower_triangular_f32.c’
3> Compiling ‘arm_mat_solve_lower_triangular_f64.c’
2> Compiling ‘arm_mat_solve_upper_triangular_f16.c’
1> Compiling ‘arm_mat_solve_upper_triangular_f32.c’
3> Compiling ‘arm_mat_solve_upper_triangular_f64.c’
1> Compiling ‘arm_mat_sub_f16.c’
2> Compiling ‘arm_mat_sub_f32.c’
4> Compiling ‘arm_mat_sub_f64.c’
1> Compiling ‘arm_mat_sub_q15.c’
2> Compiling ‘arm_mat_sub_q31.c’
3> Compiling ‘arm_mat_trans_f16.c’
4> Compiling ‘arm_mat_trans_f32.c’
1> Compiling ‘arm_mat_trans_f64.c’
2> Compiling ‘arm_mat_trans_q15.c’
3> Compiling ‘arm_mat_trans_q31.c’
4> Compiling ‘arm_mat_trans_q7.c’
2> Compiling ‘arm_mat_vec_mult_f16.c’
1> Compiling ‘arm_mat_vec_mult_f32.c’
3> Compiling ‘arm_mat_vec_mult_q15.c’
4> Compiling ‘arm_mat_vec_mult_q31.c’
2> Compiling ‘arm_mat_vec_mult_q7.c’
1> Compiling ‘arm_max_f16.c’
3> Compiling ‘arm_max_f32.c’
3> Compiling ‘arm_max_no_idx_f16.c’
4> Compiling ‘arm_max_no_idx_f32.c’
1> Compiling ‘arm_max_pool_s8.c’
2> Compiling ‘arm_max_q15.c’
4> Compiling ‘arm_max_q31.c’
3> Compiling ‘arm_max_q7.c’
2> Compiling ‘arm_mean_f16.c’
1> Compiling ‘arm_mean_f32.c’
4> Compiling ‘arm_mean_q15.c’
2> Compiling ‘arm_mean_q31.c’
3> Compiling ‘arm_mean_q7.c’
1> Compiling ‘arm_merge_sort_f32.c’
4> Compiling ‘arm_merge_sort_init_f32.c’
2> Compiling ‘arm_min_f16.c’
3> Compiling ‘arm_min_f32.c’
1> Compiling ‘arm_min_q15.c’
4> Compiling ‘arm_min_q31.c’
2> Compiling ‘arm_min_q7.c’
3> Compiling ‘arm_mult_f16.c’
1> Compiling ‘arm_mult_f32.c’
4> Compiling ‘arm_mult_q15.c’
2> Compiling ‘arm_mult_q31.c’
3> Compiling ‘arm_mult_q7.c’
1> Compiling ‘arm_mve_tables.c’
4> Compiling ‘arm_mve_tables_f16.c’
2> Compiling ‘arm_negate_f16.c’
3> Compiling ‘arm_negate_f32.c’
1> Compiling ‘arm_negate_q15.c’
4> Compiling ‘arm_negate_q31.c’
2> Compiling ‘arm_negate_q7.c’
3> Compiling ‘arm_nn_accumulate_q7_to_q15.c’
1> Compiling ‘arm_nn_activations_q15.c’
4> Compiling ‘arm_nn_activations_q7.c’
2> Compiling ‘arm_nn_add_q7.c’
3> Compiling ‘arm_nn_depthwise_conv_nt_t_padded_s8.c’
1> Compiling ‘arm_nn_depthwise_conv_nt_t_s8.c’
4> Compiling ‘arm_nn_depthwise_conv_s8_core.c’
2> Compiling ‘arm_nn_mat_mul_core_1x_s8.c’
3> Compiling ‘arm_nn_mat_mul_core_4x_s8.c’
1> Compiling ‘arm_nn_mat_mult_kernel_q7_q15.c’
2> Compiling ‘arm_nn_mat_mult_kernel_q7_q15_reordered.c’
3> Compiling ‘arm_nn_mat_mult_kernel_s8_s16.c’
4> Compiling ‘arm_nn_mat_mult_kernel_s8_s16_reordered.c’
2> Compiling ‘arm_nn_mat_mult_nt_t_s8.c’
1> Compiling ‘arm_nn_mat_mult_s8.c’
3> Compiling ‘arm_nn_mult_q15.c’
4> Compiling ‘arm_nn_mult_q7.c’
1> Compiling ‘arm_nn_vec_mat_mult_t_s8.c’
3> In file included from [01m[K.././edge-impulse-sdk/CMSIS/DSP/Include/dsp/fast_math_functions.h:30[m[K,
3> from [01m[K.././edge-impulse-sdk/CMSIS/DSP/Include/arm_common_tables.h:33[m[K,
3> from [01m[K.././edge-impulse-sdk/CMSIS/NN/Include/arm_nnsupportfunctions.h:33[m[K,
3> from [01m[K../edge-impulse-sdk/CMSIS/NN/Source/NNSupportFunctions/arm_nn_mult_q15.c:31[m[K:
3> [01m[K../edge-impulse-sdk/CMSIS/NN/Source/NNSupportFunctions/arm_nn_mult_q15.c:[m[K In function '[01m[Karm_nn_mult_q15[m[K':
3> [01m[K.././edge-impulse-sdk/CMSIS/DSP/Include/arm_math_memory.h:61:33:[m[K [01;35m[Kwarning: [m[Kdereferencing type-punned pointer will break strict-aliasing rules [[01;35m[K-Wstrict-aliasing[m[K]
3> [01m[K../edge-impulse-sdk/CMSIS/NN/Source/NNSupportFunctions/arm_nn_mult_q15.c:98:10:[m[K [01;36m[Knote: [m[Kin expansion of macro '[01m[K__SIMD32[m[K'
3> [01m[K../edge-impulse-sdk/CMSIS/NN/Source/NNSupportFunctions/arm_nn_mult_q15.c:99:10:[m[K [01;36m[Knote: [m[Kin expansion of macro '[01m[K__SIMD32[m[K'
4> from [01m[K../edge-impulse-sdk/CMSIS/NN/Source/NNSupportFunctions/arm_nn_mult_q7.c:31[m[K:
4> [01m[K../edge-impulse-sdk/CMSIS/NN/Source/NNSupportFunctions/arm_nn_mult_q7.c:[m[K In function '[01m[Karm_nn_mult_q7[m[K':
4> [01m[K../edge-impulse-sdk/CMSIS/NN/Source/NNSupportFunctions/arm_nn_mult_q7.c:80:10:[m[K [01;36m[Knote: [m[Kin expansion of macro '[01m[K__SIMD32[m[K'
3> Compiling ‘arm_nntables.c’
4> Compiling ‘arm_not_u16.c’
2> Compiling ‘arm_not_u32.c’
3> Compiling ‘arm_not_u8.c’
1> Compiling ‘arm_offset_f16.c’
2> Compiling ‘arm_offset_f32.c’
4> Compiling ‘arm_offset_q15.c’
3> Compiling ‘arm_offset_q31.c’
1> Compiling ‘arm_offset_q7.c’
2> Compiling ‘arm_or_u16.c’
4> Compiling ‘arm_or_u32.c’
3> Compiling ‘arm_or_u8.c’
1> Compiling ‘arm_pool_q7_HWC.c’
2> Compiling ‘arm_power_f16.c’
4> Compiling ‘arm_power_f32.c’
1> In file included from [01m[K.././edge-impulse-sdk/CMSIS/DSP/Include/dsp/fast_math_functions.h:30[m[K,
1> from [01m[K.././edge-impulse-sdk/CMSIS/DSP/Include/arm_common_tables.h:33[m[K,
1> from [01m[K.././edge-impulse-sdk/CMSIS/NN/Include/arm_nnsupportfunctions.h:33[m[K,
1> from [01m[K../edge-impulse-sdk/CMSIS/NN/Source/PoolingFunctions/arm_pool_q7_HWC.c:32[m[K:
1> [01m[K../edge-impulse-sdk/CMSIS/NN/Source/PoolingFunctions/arm_pool_q7_HWC.c:[m[K In function '[01m[Kcompare_and_replace_if_larger_q7[m[K':
1> [01m[K.././edge-impulse-sdk/CMSIS/DSP/Include/arm_math_memory.h:61:33:[m[K [01;35m[Kwarning: [m[Kdereferencing type-punned pointer will break strict-aliasing rules [[01;35m[K-Wstrict-aliasing[m[K]
1> [01m[K../edge-impulse-sdk/CMSIS/NN/Source/PoolingFunctions/arm_pool_q7_HWC.c:78:10:[m[K [01;36m[Knote: [m[Kin expansion of macro '[01m[K__SIMD32[m[K'
1> [01m[K../edge-impulse-sdk/CMSIS/NN/Source/PoolingFunctions/arm_pool_q7_HWC.c:[m[K In function '[01m[Kaccumulate_q7_to_q15[m[K':
1> [01m[K../edge-impulse-sdk/CMSIS/NN/Source/PoolingFunctions/arm_pool_q7_HWC.c:122:10:[m[K [01;36m[Knote: [m[Kin expansion of macro '[01m[K__SIMD32[m[K'
1> [01m[K../edge-impulse-sdk/CMSIS/NN/Source/PoolingFunctions/arm_pool_q7_HWC.c:125:10:[m[K [01;36m[Knote: [m[Kin expansion of macro '[01m[K__SIMD32[m[K'
3> Compiling ‘arm_power_q15.c’
2> Compiling ‘arm_power_q31.c’
4> Compiling ‘arm_power_q7.c’
1> Compiling ‘arm_q15_to_f16.c’
3> Compiling ‘arm_q15_to_float.c’
2> Compiling ‘arm_q15_to_q31.c’
4> Compiling ‘arm_q15_to_q7.c’
1> Compiling ‘arm_q31_to_float.c’
3> Compiling ‘arm_q31_to_q15.c’
2> Compiling ‘arm_q31_to_q7.c’
4> Compiling ‘arm_q7_to_float.c’
1> Compiling ‘arm_q7_to_q15.c’
3> Compiling ‘arm_q7_to_q15_no_shift.c’
2> Compiling ‘arm_q7_to_q15_reordered_no_shift.c’
4> Compiling ‘arm_q7_to_q15_reordered_with_offset.c’
1> Compiling ‘arm_q7_to_q15_with_offset.c’
2> In file included from [01m[K.././edge-impulse-sdk/CMSIS/DSP/Include/dsp/fast_math_functions.h:30[m[K,
2> from [01m[K.././edge-impulse-sdk/CMSIS/DSP/Include/arm_common_tables.h:33[m[K,
2> from [01m[K.././edge-impulse-sdk/CMSIS/NN/Include/arm_nnsupportfunctions.h:33[m[K,
2> from [01m[K../edge-impulse-sdk/CMSIS/NN/Source/NNSupportFunctions/arm_q7_to_q15_reordered_no_shift.c:31[m[K:
2> [01m[K../edge-impulse-sdk/CMSIS/NN/Source/NNSupportFunctions/arm_q7_to_q15_reordered_no_shift.c:[m[K In function '[01m[Karm_q7_to_q15_reordered_no_shift[m[K':
2> [01m[K.././edge-impulse-sdk/CMSIS/DSP/Include/arm_math_memory.h:61:33:[m[K [01;35m[Kwarning: [m[Kdereferencing type-punned pointer will break strict-aliasing rules [[01;35m[K-Wstrict-aliasing[m[K]
2> [01m[K../edge-impulse-sdk/CMSIS/NN/Source/NNSupportFunctions/arm_q7_to_q15_reordered_no_shift.c:106:10:[m[K [01;36m[Knote: [m[Kin expansion of macro '[01m[K__SIMD32[m[K'
2> [01m[K../edge-impulse-sdk/CMSIS/NN/Source/NNSupportFunctions/arm_q7_to_q15_reordered_no_shift.c:107:10:[m[K [01;36m[Knote: [m[Kin expansion of macro '[01m[K__SIMD32[m[K'
3> Compiling ‘arm_q7_to_q31.c’
2> Compiling ‘arm_quick_sort_f32.c’
4> Compiling ‘arm_relu6_s8.c’
1> Compiling ‘arm_relu_q15.c’
3> Compiling ‘arm_relu_q7.c’
2> Compiling ‘arm_reshape_s8.c’
4> Compiling ‘arm_rfft_f32.c’
1> Compiling ‘arm_rfft_fast_f16.c’
3> Compiling ‘arm_rfft_fast_f32.c’
2> Compiling ‘arm_rfft_fast_f64.c’
4> Compiling ‘arm_rfft_fast_init_f16.c’
1> Compiling ‘arm_rfft_fast_init_f32.c’
3> Compiling ‘arm_rfft_fast_init_f64.c’
2> Compiling ‘arm_rfft_init_f32.c’
4> Compiling ‘arm_rfft_init_q15.c’
1> Compiling ‘arm_rfft_init_q31.c’
3> Compiling ‘arm_rfft_q15.c’
2> Compiling ‘arm_rfft_q31.c’
4> Compiling ‘arm_rms_f16.c’
1> Compiling ‘arm_rms_f32.c’
3> Compiling ‘arm_rms_q15.c’
2> Compiling ‘arm_rms_q31.c’
4> Compiling ‘arm_scale_f16.c’
1> Compiling ‘arm_scale_f32.c’
3> Compiling ‘arm_scale_q15.c’
2> Compiling ‘arm_scale_q31.c’
4> Compiling ‘arm_scale_q7.c’
1> Compiling ‘arm_selection_sort_f32.c’
3> Compiling ‘arm_shift_q15.c’
4> Compiling ‘arm_shift_q31.c’
2> Compiling ‘arm_shift_q7.c’
1> Compiling ‘arm_sin_f32.c’
3> Compiling ‘arm_sin_q15.c’
4> Compiling ‘arm_sin_q31.c’
2> Compiling ‘arm_softmax_q15.c’
1> Compiling ‘arm_softmax_q7.c’
4> Compiling ‘arm_softmax_s8.c’
3> Compiling ‘arm_softmax_u8.c’
2> Compiling ‘arm_softmax_with_batch_q7.c’
1> Compiling ‘arm_sort_f32.c’
2> Compiling ‘arm_sort_init_f32.c’
1> Compiling ‘arm_sqrt_q15.c’
4> Compiling ‘arm_sqrt_q31.c’
3> Compiling ‘arm_std_f16.c’
2> Compiling ‘arm_std_f32.c’
1> Compiling ‘arm_std_q15.c’
3> Compiling ‘arm_std_q31.c’
4> Compiling ‘arm_sub_f16.c’
2> Compiling ‘arm_sub_f32.c’
1> Compiling ‘arm_sub_q15.c’
3> Compiling ‘arm_sub_q31.c’
4> Compiling ‘arm_sub_q7.c’
2> Compiling ‘arm_svdf_s8.c’
1> Compiling ‘arm_var_f16.c’
3> Compiling ‘arm_var_f32.c’
4> Compiling ‘arm_var_q15.c’
2> Compiling ‘arm_var_q31.c’
1> Compiling ‘arm_vexp_f16.c’
3> Compiling ‘arm_vexp_f32.c’
4> Compiling ‘arm_vinverse_f16.c’
2> Compiling ‘arm_vlog_f16.c’
1> Compiling ‘arm_vlog_f32.c’
3> Compiling ‘arm_weighted_sum_f16.c’
4> Compiling ‘arm_weighted_sum_f32.c’
2> Compiling ‘arm_xor_u16.c’
1> Compiling ‘arm_xor_u32.c’
3> Compiling ‘arm_xor_u8.c’
4> Compiling ‘common.c’
Building ‘zephyr/libzephyr.a’ from solution ‘build’ in configuration ‘Common’
1> Archiving ‘libapp.a’
3> Assembling ‘soc_nrf_common.S’
4> Compiling ‘bitarray.c’
2> Compiling ‘cbprintf.c’
1> Error starting process C:\Users\ghaaz\ncs\v1.9.0\toolchain\opt/bin/arm-none-eabi-ar
Build failed
