SERVER CONSOLE DEBUG: GDBServerConsole: onBackendConnect: gdb-server program client error Error: read ECONNRESET
Hi!
I'm developing a project on visual studio with ncs sdk V1.8.0. For a while, I was able to debug my project with no problem. But out of the blue, I'm no longer able to debug my project. I get the following error:
[2022-08-23T15:57:09.597Z] SERVER CONSOLE DEBUG: GDBServerConsole: onBackendConnect: gdb-server program client error Error: read ECONNRESET
There is the complete log:
[2022-08-23T15:57:09.458Z] SERVER CONSOLE DEBUG: onBackendConnect: gdb-server session connected. You can switch to "DEBUG CONSOLE" to see GDB interactions.
"C:\\Program Files (x86)\\SEGGER\\JLink\\JLinkGDBServerCL.exe" -singlerun -nogui -if swd -port 50000 -swoport 50001 -telnetport 50002 -device nRF52832_xxAA -select usb=483066063 -rtos "C:\\Program Files (x86)\\SEGGER\\JLink\\GDBServer\\RTOSPlugin_Zephyr.dll"
SEGGER J-Link GDB Server V7.58b Command Line Version
JLinkARM.dll V7.58b (DLL compiled Nov 16 2021 15:00:10)
Command line: -singlerun -nogui -if swd -port 50000 -swoport 50001 -telnetport 50002 -device nRF52832_xxAA -select usb=483066063 -rtos C:\Program Files (x86)\SEGGER\JLink\GDBServer\RTOSPlugin_Zephyr.dll
-----GDB Server start settings-----
GDBInit file:                  none
GDB Server Listening port:     50000
SWO raw output listening port: 50001
Terminal I/O port:             50002
Accept remote connection:      localhost only
Generate logfile:              off
Verify download:               off
Init regs on start:            off
Silent mode:                   off
Single run mode:               on
Target connection timeout:     0 ms
------J-Link related settings------
J-Link Host interface:         USB
J-Link script:                 none
J-Link settings file:          none
------Target related settings------
Target device:                 nRF52832_xxAA
Target interface:              SWD
Target interface speed:        4000kHz
Target endian:                 little
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link OB-SAM3U128 V3 compiled Feb  2 2021 16:48:08
Hardware: V3.00
S/N: 483066063
Checking target voltage...
Target voltage: 3.30 V
Listening on TCP/IP port 50000
Connecting to target...
[2022-08-23T15:57:09.598Z] SERVER CONSOLE DEBUG: onBackendConnect: gdb-server session closed
GDB server session ended. This terminal will be reused, waiting for next session to start...
What is the problem?
Thank you!
  • IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
      "platform": {
        "os": "win32",
        "osVersion": "Windows 10 Pro",
        "osKernel": "10.0.19042",
        "vscode": "1.70.2",
        "electron": "18.3.5",
        "node": "v16.13.2"
      "system": {
        "date": "2022-08-24T11:03:23.668Z",
        "vscodeRoot": "c:\\Users\\MaLu\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
        "vscodeUptime": "02:05:53",
        "osUptime": "30:24:41",
        "cpu": {
          "model": "Intel(R) Core(TM) i5-9400 CPU @ 2.90GHz",
          "speed": "2904 MHz",
          "count": 3
        "memory": {
          "total": "15.75 GB",
          "free": "6.60 GB"
      "workspace": {
        "name": "rapidM2M_M2_nRF91",
        "workspaceFile": null,
        "folders": [
          "d:\\work\\rapidM2M_M2_nRF91"
      "extensions": {
        "internal": {
            "version": "2022.7.242",
            "path": "c:\\Users\\MaLu\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2022.7.242-win32-x64",
            "isActive": true
            "version": "2022.7.21",
            "path": "c:\\Users\\MaLu\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2022.7.21",
            "isActive": true
            "version": "2022.7.36",
            "path": "c:\\Users\\MaLu\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2022.7.36",
            "isActive": true
            "version": "2022.7.24",
            "path": "c:\\Users\\MaLu\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2022.7.24",
            "isActive": true
        "external": {
          "marus25.cortex-debug": "1.6.0",
          "ms-vscode.cpptools": "1.11.5",
          "ms-vscode-remote.remote-wsl-recommender": "0.0.15",
          "ms-vscode.js-debug": "1.70.0",
          "ms-vscode.js-debug-companion": "1.0.18",
          "ms-vscode.vscode-js-profile-table": "1.0.3",
          "keroc.hex-fmt": "1.0.0",
          "maziac.asm-code-lens": "1.10.2",
          "ms-vscode.hexeditor": "1.9.8",
          "tbd.pawn": "0.0.1",
          "twxs.cmake": "0.0.17",
          "ZixuanWang.linkerscript": "1.0.2"
      "tools": {
        "d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.14.1",
        "C:\\Program Files (x86)\\SEGGER\\JLink\\JLink.exe": "7.58b",
        "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.14.0",
        "nrfutil": "Not found",
        "d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\opt\\bin\\cmake.exe": "3.20.5",
        "d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\opt\\bin\\Scripts\\west.exe": "0.13.1",
        "d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\opt\\bin\\python.exe": "3.8.2",
        "d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\opt\\bin\\ninja.exe": "1.9.0",
        "d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\opt\\bin\\gperf.exe": "3.1",
        "d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\opt\\bin\\dtc.exe": "1.4.7",
        "d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\opt\\bin\\gn.exe": "2055",
        "d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\mingw64\\bin\\git.exe": "2.26.2.windows.1"
      "sdks": [
          "version": "1.4.0",
          "path": "d:\\work\\nRF_Connect_SDK\\v1.4.0"
          "version": "1.7.0",
          "path": "d:\\work\\nRF_Connect_SDK\\v1.7.0"
          "version": "1.6.1",
          "path": "d:\\work\\nRF_Connect_SDK\\v1.6.1"
          "version": "1.5.1",
          "path": "d:\\work\\nRF_Connect_SDK\\v1.5.1"
          "version": "1.8.0",
          "path": "d:\\work\\nRF_Connect_SDK\\v1.8.0"
          "version": "1.9.0",
          "path": "d:\\work\\nRF_Connect_SDK\\v1.9.0"
          "version": "1.9.1",
          "path": "d:\\work\\nRF_Connect_SDK\\v1.9.1"
          "version": "1.7.1",
          "path": "d:\\work\\nRF_Connect_SDK\\v1.7.1"
          "version": "2.0.0",
          "path": "d:\\work\\nRF_Connect_SDK\\v2.0.0"
          "version": "2.0.2",
          "path": "d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\v2.0.2"
      "toolchains": [
          "version": "1.4.0",
          "path": {
            "$mid": 1,
            "fsPath": "d:\\work\\nRF_Connect_SDK\\v1.4.0\\toolchain",
            "_sep": 1,
            "path": "/D:/work/nRF_Connect_SDK/v1.4.0/toolchain",
            "scheme": "file"
          "version": "1.5.1",
          "path": {
            "$mid": 1,
            "fsPath": "d:\\work\\nRF_Connect_SDK\\v1.5.1\\toolchain",
            "_sep": 1,
            "path": "/D:/work/nRF_Connect_SDK/v1.5.1/toolchain",
            "scheme": "file"
          "version": "1.6.1",
          "path": {
            "$mid": 1,
            "fsPath": "d:\\work\\nRF_Connect_SDK\\v1.6.1\\toolchain",
            "_sep": 1,
            "path": "/D:/work/nRF_Connect_SDK/v1.6.1/toolchain",
            "scheme": "file"
          "version": "1.7.0",
          "path": {
            "$mid": 1,
            "fsPath": "d:\\work\\nRF_Connect_SDK\\v1.7.0\\toolchain",
            "_sep": 1,
            "path": "/D:/work/nRF_Connect_SDK/v1.7.0/toolchain",
            "scheme": "file"
          "version": "1.7.1",
          "path": {
            "$mid": 1,
            "fsPath": "d:\\work\\nRF_Connect_SDK\\v1.7.1\\toolchain",
            "_sep": 1,
            "path": "/D:/work/nRF_Connect_SDK/v1.7.1/toolchain",
            "scheme": "file"
          "version": "1.8.0",
          "path": {
            "$mid": 1,
            "fsPath": "d:\\work\\nRF_Connect_SDK\\v1.8.0\\toolchain",
            "_sep": 1,
            "path": "/D:/work/nRF_Connect_SDK/v1.8.0/toolchain",
            "scheme": "file"
          "version": "1.9.0",
          "path": {
            "$mid": 1,
            "fsPath": "d:\\work\\nRF_Connect_SDK\\v1.9.0\\toolchain",
            "_sep": 1,
            "path": "/D:/work/nRF_Connect_SDK/v1.9.0/toolchain",
            "scheme": "file"
          "version": "1.9.1",
          "path": {
            "$mid": 1,
            "fsPath": "d:\\work\\nRF_Connect_SDK\\v1.9.1\\toolchain",
            "_sep": 1,
            "path": "/D:/work/nRF_Connect_SDK/v1.9.1/toolchain",
            "scheme": "file"
          "version": "2.0.0",
          "path": {
            "$mid": 1,
            "fsPath": "d:\\work\\nRF_Connect_SDK\\toolchains\\v2.0.0",
            "_sep": 1,
            "path": "/D:/work/nRF_Connect_SDK/toolchains/v2.0.0",
            "scheme": "file"
          "version": "2.0.2",
          "path": {
            "$mid": 1,
            "fsPath": "d:\\work\\nRF_Connect_SDK\\toolchains\\v2.0.2",
            "_sep": 1,
            "path": "/D:/work/nRF_Connect_SDK/toolchains/v2.0.2",
            "scheme": "file"
          "version": "2.0.2",
          "path": {
            "$mid": 1,
            "fsPath": "d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2",
            "_sep": 1,
            "path": "/D:/work/nRF_Connect_SDK/SDK_fresh_download/toolchains/v2.0.2",
            "scheme": "file"
      "connectedDevices": [
          "serialNumber": "601000337"
      "deviceProviders": [
        "nrfjprog"
      "config": {
          "topdir": "d:\\work\\nRF_Connect_SDK\\v2.0.2",
          "toolchain": {
            "path": "${nrf-connect.toolchain:2.0.2}"
          "ozonePath": "C:\\Program Files\\SEGGER\\Ozone\\Ozone.exe",
          "applications": [
            "${workspaceFolder}"
          "applicationOptions": {},
          "kconfig": {
            "interface": "kconfig"
          "welcome": {
            "showOnStartup": false
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [
          "enableTelemetry": false,
          "taskBindings": {},
          "debugging": {
            "backend": "Cortex-Debug"
          "activeAppFollowActiveEditor": true
          "terminalMode": "character"
        "marus25.cortex-debug": {
          "armToolchainPath": "C:\\Program Files (x86)\\GNU Tools ARM Embedded\\7 2018-q2-update\\bin",
          "armToolchainPrefix": "arm-none-eabi",
          "gdbPath": null,
          "objdumpPath": null,
          "JLinkGDBServerPath": null,
          "openocdPath": null,
          "pyocdPath": null,
          "PEGDBServerPath": null,
          "stutilPath": null,
          "stlinkPath": null,
          "stm32cubeprogrammer": null,
          "enableTelemetry": true,
          "registerUseNaturalFormat": true,
          "variableUseNaturalFormat": true,
          "dbgServerLogfile": null,
          "showRTOS": false,
          "showDevDebugOutput": "none"
      "environment": {
        "westExe": "west",
        "westEnv": {
          "ELECTRON_RUN_AS_NODE": "1",
          "HOME": "C:\\Users\\MaLu",
          "HOMEDRIVE": "C:",
          "HOMEPATH": "\\Users\\MaLu",
          "Path": "d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\mingw64\\bin;d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\mingw64\\libexec\\git-core;d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\opt\\bin;d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\arm-zephyr-eabi\\bin;d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\opt\\bin\\Scripts;C:\\Program Files\\RBTools\\bin;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\CMake\\bin;C:\\Program Files\\mingw-w64\\x86_64-8.1.0-win32-seh-rt_v6-rev0\\mingw64\\bin;C:\\Program Files\\TortoiseSVN\\bin;C:\\Keil_v5\\ARM\\ARMCC\\bin;C:\\Program Files (x86)\\rapidM2M_Toolset\\accessories\\rm2mPawn;C:\\Program Files\\otii;C:\\Program Files (x86)\\GNU Tools Arm Embedded\\7 2018-q2-update\\bin;C:\\Program Files\\010 Editor;C:\\Program Files (x86)\\GnuWin32\\bin;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\Program Files\\LLVM\\bin;C:\\Strawberry\\c\\bin;C:\\Strawberry\\perl\\site\\bin;C:\\Strawberry\\perl\\bin;C:\\Users\\MaLu\\AppData\\Local\\Programs\\nrfconnect\\nrfjprog;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\GNU Tools Arm Embedded\\7 2018-q2-update\\bin;C:\\Users\\MaLu\\AppData\\Local\\Programs\\Python\\Python39\\Scripts\\;C:\\Users\\MaLu\\AppData\\Local\\Programs\\Python\\Python39\\;C:\\Users\\MaLu\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files\\CMake\\bin;C:\\Program Files\\mingw-w64\\x86_64-8.1.0-win32-seh-rt_v6-rev0\\mingw64\\bin;C:\\Users\\MaLu\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Keil_v5\\ARM\\ARMCC\\bin;C:\\Program Files (x86)\\rapidM2M_Toolset\\accessories\\rm2mPawn;C:\\Program Files (x86)\\GnuWin32\\bin;C:\\Program Files\\LLVM\\bin;C:\\Strawberry\\c\\bin;C:\\Strawberry\\perl\\site\\bin;C:\\Strawberry\\perl\\bin;C:\\Users\\MaLu\\AppData\\Local\\Programs\\nrfconnect\\nrfjprog;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin;",
          "ZEPHYR_BASE": "d:\\work\\nRF_Connect_SDK\\v2.0.2\\zephyr",
          "ZEPHYR_SDK_INSTALL_DIR": "d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\opt\\zephyr-sdk",
          "PYTHONPATH": "d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\opt\\bin;d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\opt\\bin\\Lib;d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\opt\\bin\\Lib\\site-packages",
          "Python3_ROOT": "d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\opt\\bin"
        "inherited": {
          "HOMEDRIVE": "C:",
          "Path": "C:\\Program Files\\RBTools\\bin;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\CMake\\bin;C:\\Program Files\\mingw-w64\\x86_64-8.1.0-win32-seh-rt_v6-rev0\\mingw64\\bin;C:\\Program Files\\TortoiseSVN\\bin;C:\\Keil_v5\\ARM\\ARMCC\\bin;C:\\Program Files (x86)\\rapidM2M_Toolset\\accessories\\rm2mPawn;C:\\Program Files\\otii;C:\\Program Files (x86)\\GNU Tools Arm Embedded\\7 2018-q2-update\\bin;C:\\Program Files\\010 Editor;C:\\Program Files (x86)\\GnuWin32\\bin;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\Program Files\\LLVM\\bin;C:\\Strawberry\\c\\bin;C:\\Strawberry\\perl\\site\\bin;C:\\Strawberry\\perl\\bin;C:\\Users\\MaLu\\AppData\\Local\\Programs\\nrfconnect\\nrfjprog;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\GNU Tools Arm Embedded\\7 2018-q2-update\\bin;C:\\Users\\MaLu\\AppData\\Local\\Programs\\Python\\Python39\\Scripts\\;C:\\Users\\MaLu\\AppData\\Local\\Programs\\Python\\Python39\\;C:\\Users\\MaLu\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files\\CMake\\bin;C:\\Program Files\\mingw-w64\\x86_64-8.1.0-win32-seh-rt_v6-rev0\\mingw64\\bin;C:\\Users\\MaLu\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Keil_v5\\ARM\\ARMCC\\bin;C:\\Program Files (x86)\\rapidM2M_Toolset\\accessories\\rm2mPawn;C:\\Program Files (x86)\\GnuWin32\\bin;C:\\Program Files\\LLVM\\bin;C:\\Strawberry\\c\\bin;C:\\Strawberry\\perl\\site\\bin;C:\\Strawberry\\perl\\bin;C:\\Users\\MaLu\\AppData\\Local\\Programs\\nrfconnect\\nrfjprog;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin;",
          "PATH": "C:\\Program Files\\RBTools\\bin;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\CMake\\bin;C:\\Program Files\\mingw-w64\\x86_64-8.1.0-win32-seh-rt_v6-rev0\\mingw64\\bin;C:\\Program Files\\TortoiseSVN\\bin;C:\\Keil_v5\\ARM\\ARMCC\\bin;C:\\Program Files (x86)\\rapidM2M_Toolset\\accessories\\rm2mPawn;C:\\Program Files\\otii;C:\\Program Files (x86)\\GNU Tools Arm Embedded\\7 2018-q2-update\\bin;C:\\Program Files\\010 Editor;C:\\Program Files (x86)\\GnuWin32\\bin;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\Program Files\\LLVM\\bin;C:\\Strawberry\\c\\bin;C:\\Strawberry\\perl\\site\\bin;C:\\Strawberry\\perl\\bin;C:\\Users\\MaLu\\AppData\\Local\\Programs\\nrfconnect\\nrfjprog;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\GNU Tools Arm Embedded\\7 2018-q2-update\\bin;C:\\Users\\MaLu\\AppData\\Local\\Programs\\Python\\Python39\\Scripts\\;C:\\Users\\MaLu\\AppData\\Local\\Programs\\Python\\Python39\\;C:\\Users\\MaLu\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files\\CMake\\bin;C:\\Program Files\\mingw-w64\\x86_64-8.1.0-win32-seh-rt_v6-rev0\\mingw64\\bin;C:\\Users\\MaLu\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Keil_v5\\ARM\\ARMCC\\bin;C:\\Program Files (x86)\\rapidM2M_Toolset\\accessories\\rm2mPawn;C:\\Program Files (x86)\\GnuWin32\\bin;C:\\Program Files\\LLVM\\bin;C:\\Strawberry\\c\\bin;C:\\Strawberry\\perl\\site\\bin;C:\\Strawberry\\perl\\bin;C:\\Users\\MaLu\\AppData\\Local\\Programs\\nrfconnect\\nrfjprog;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin;"
        "toolchainPath": "d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2",
        "toolchainBinPath": "d:\\work\\nRF_Connect_SDK\\SDK_fresh_download\\toolchains\\v2.0.2\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin",
        "toolchainVersion": "2.0.2"
      "terminal": {
        "shell": null,
        "defaultProfile": null
    Can confirm that downgrading the Cortex-Debug Extension fixed the problem!
    We have received reports of this and are working on a solution. At present, the workaround is, as mentioned by @manuel hulliger  to downgrade the Cortex-Debug extension to the previous version (v1.4.4)
    -Priyanka
  • From what I can tell, it has to do with the version of gdb that Segger JLink GDB server is using. Cortex-Debug is only allowing versions 9 and above, whereas according to Cortex-Debug the JLink GDB server is based on version 8. I've tried upgrading to the latest Jlink software package but same problem.
  • I started having this issue when Cortex Debug upgraded to 1.6.0 two days ago.  Ripping my hair out even though I'm mostly bald on top.  Anyway, I can confirm that downgrading to Cortex Debug 1.4.4 restored debugging capability.
    VS Code Support Info
      "platform": {
        "os": "win32",
        "osKernel": "10.0.19043",
        "vscode": "1.70.2",
        "node": "v16.13.2"
      "system": {
        "date": "2022-08-24T20:46:22.146Z",
        "vscodeRoot": "c:\\Users\\*****\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
        "vscodeUptime": "00:10:08",
        "osUptime": "15:22:45",
        "cpu": {
          "model": "Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz",
          "speed": "3392 MHz",
          "count": 4
        "memory": {
          "total": "15.94 GB",
          "free": "6.76 GB"
      "workspace": {
        "name": "Untitled (Workspace)",
        "workspaceFile": "1632414378869",
        "folders": [
          "c:\\ncsVs\\projects\\bluetooth\\central_multi_NUS_V3_teardown",
          "c:\\ncsVs\\projects\\bluetooth\\central_yardalert_V4"
      "extensions": {
        "internal": {
            "path": "c:\\Users\\**********\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2022.7.242-win32-x64",
            "isActive": true
            "path": "c:\\Users\\**********\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2022.7.21",
            "isActive": true
            "path": "c:\\Users\\**********\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2022.7.36",
            "isActive": true
            "path": "c:\\Users\\**********\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2022.7.24",
            "isActive": true
        "external": {
          "marus25.cortex-debug": "1.4.4",
      "tools": {
        "c:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\arm-none-eabi-gcc.exe": "9-2019-q4-major",
        "C:\\Program Files\\SEGGER\\JLink\\JLink.exe": "7.70a",
        "C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.17.3",
        "c:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\cmake.exe": "3.20.5",
        "c:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\Scripts\\west.exe": "0.12.0",
        "c:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\python.exe": "3.8.2",
        "c:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\ninja.exe": "1.9.0",
        "c:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\gperf.exe": "3.1",
        "c:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\dtc.exe": "1.4.7",
        "c:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\gn.exe": "1977",
        "c:\\ncs\\v1.9.1\\toolchain\\mingw64\\bin\\git.exe": "2.26.2.windows.1"
      "sdks": [
          "version": "1.9.1",
          "path": "c:\\ncs\\v1.9.1"
      "toolchains": [
          "version": "1.9.1",
          "path": {
            "$mid": 1,
            "fsPath": "c:\\ncs\\v1.9.1\\toolchain",
            "_sep": 1,
            "path": "/C:/ncs/v1.9.1/toolchain",
            "scheme": "file"
          "serialNumber": "682292739"
          "serialNumber": "683681506"
        "nrfjprog"
      "config": {
          "topdir": "${nrf-connect.sdk:1.9.1}",
          "toolchain": {
            "path": "${nrf-connect.toolchain:1.9.1}"
          "ozonePath": "",
          "applications": [
            "${workspaceFolder}",
          "kconfig": {
          "welcome": {
            "showOnStartup": true
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "taskBindings": {},
          "debugging": {
          "armToolchainPath": null,
          "gdbPath": null,
          "pyocdPath": null,
          "stutilPath": null,
          "stlinkPath": null,
          "flattenAnonymous": false,
          "showRTOS": false,
      "environment": {
        "westExe": "west",
        "westEnv": {
          "HOME": "***************",
          "HOMEDRIVE": "C:",
          "HOMEPATH": "**********",
          "Path": "c:\\ncs\\v1.9.1\\toolchain\\mingw64\\bin;c:\\ncs\\v1.9.1\\toolchain\\mingw64\\libexec\\git-core;c:\\ncs\\v1.9.1\\toolchain\\opt\\bin;c:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\Scripts;C:\\Users\\**********\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\**********\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\**********\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\**********\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Program Files\\Eclipse Foundation\\jdk-8.0.302.8-hotspot\\bin;C:\\Program Files\\Microsoft MPI\\Bin\\;C:\\Program Files (x86)\\Atmel\\AVR Tools\\AVR Toolchain\\bin;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\Program Files (x86)\\Windows Kits\\8.1\\Windows Performance Toolkit\\;C:\\Program Files (x86)\\EaseUS\\Todo Backup\\bin;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\STMicroelectronics\\STM32 ST-LINK Utility\\ST-LINK Utility;C:\\Users\\**********\\AppData\\Local\\SourceTree\\SourceTree\\git_local\\bin;C:\\Program Files\\Microchip\\xc16\\v1.50\\bin;C:\\Program Files\\dotnet\\;C:\\Program Files\\Microsoft SQL Server\\130\\Tools\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\150\\DTS\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\150\\DTS\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\170\\Tools\\Binn\\;C:\\Program Files (x86)\\Microchip\\MPLAB C32 Suite\\bin;C:\\Program Files\\Microchip\\xc16\\v1.60\\bin;C:\\Program Files\\Git\\cmd;C:\\nburn\\pcbin;C:\\nburn\\gcc-m68k\\bin;C:\\nburn\\gcc-m68k\\msys\\1.0\\bin;C:\\Program Files (x86)\\dotnet\\;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\**********\\AppData\\Local\\Programs\\Python\\Python39\\Scripts\\;C:\\Users\\**********\\AppData\\Local\\Programs\\Python\\Python39\\;C:\\Users\\**********\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\**********\\AppData\\Local\\GitHubDesktop\\bin;C:\\Users\\**********\\flutter\\bin;C:\\Users\\**********\\AppData\\Local\\Android\\Sdk\\tools;C:\\Users\\**********\\AppData\\Local\\Android\\Sdk\\platform-tools;;C:\\SysGCC\\avr\\bin;C:\\Users\\**********\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\**********\\.dotnet\\tools;C:\\Users\\**********\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
          "ZEPHYR_BASE": "c:\\ncs\\v1.9.1\\zephyr",
          "GNUARMEMB_TOOLCHAIN_PATH": "c:\\ncs\\v1.9.1\\toolchain\\opt",
          "ZEPHYR_TOOLCHAIN_VARIANT": "gnuarmemb",
          "PYTHONPATH": "c:\\ncs\\v1.9.1\\toolchain\\opt\\bin;c:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\Lib;c:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\Lib\\site-packages",
          "Python3_ROOT": "c:\\ncs\\v1.9.1\\toolchain\\opt\\bin"
        "inherited": {
          "HOME": "*********",
          "HOMEDRIVE": "C:",
          "HOMEPATH": "\\Users\\**********",
          "Path": "C:\\Users\\**********\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\**********\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\**********\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\**********\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Program Files\\Eclipse Foundation\\jdk-8.0.302.8-hotspot\\bin;C:\\Program Files\\Microsoft MPI\\Bin\\;C:\\Program Files (x86)\\Atmel\\AVR Tools\\AVR Toolchain\\bin;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\Program Files (x86)\\Windows Kits\\8.1\\Windows Performance Toolkit\\;C:\\Program Files (x86)\\EaseUS\\Todo Backup\\bin;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\STMicroelectronics\\STM32 ST-LINK Utility\\ST-LINK Utility;C:\\Users\\**********\\AppData\\Local\\SourceTree\\SourceTree\\git_local\\bin;C:\\Program Files\\Microchip\\xc16\\v1.50\\bin;C:\\Program Files\\dotnet\\;C:\\Program Files\\Microsoft SQL Server\\130\\Tools\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\150\\DTS\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\150\\DTS\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\170\\Tools\\Binn\\;C:\\Program Files (x86)\\Microchip\\MPLAB C32 Suite\\bin;C:\\Program Files\\Microchip\\xc16\\v1.60\\bin;C:\\Program Files\\Git\\cmd;C:\\nburn\\pcbin;C:\\nburn\\gcc-m68k\\bin;C:\\nburn\\gcc-m68k\\msys\\1.0\\bin;C:\\Program Files (x86)\\dotnet\\;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\**********\\AppData\\Local\\Programs\\Python\\Python39\\Scripts\\;C:\\Users\\**********\\AppData\\Local\\Programs\\Python\\Python39\\;C:\\Users\\**********\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\**********\\AppData\\Local\\GitHubDesktop\\bin;C:\\Users\\**********\\flutter\\bin;C:\\Users\\**********\\AppData\\Local\\Android\\Sdk\\tools;C:\\Users\\**********\\AppData\\Local\\Android\\Sdk\\platform-tools;;C:\\SysGCC\\avr\\bin;C:\\Users\\**********\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\**********\\.dotnet\\tools;C:\\Users\\**********\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
          "PATH": "C:\\Users\\**********\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\**********\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\**********\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\**********\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Program Files\\Eclipse Foundation\\jdk-8.0.302.8-hotspot\\bin;C:\\Program Files\\Microsoft MPI\\Bin\\;C:\\Program Files (x86)\\Atmel\\AVR Tools\\AVR Toolchain\\bin;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\Program Files (x86)\\Windows Kits\\8.1\\Windows Performance Toolkit\\;C:\\Program Files (x86)\\EaseUS\\Todo Backup\\bin;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\STMicroelectronics\\STM32 ST-LINK Utility\\ST-LINK Utility;C:\\Users\\**********\\AppData\\Local\\SourceTree\\SourceTree\\git_local\\bin;C:\\Program Files\\Microchip\\xc16\\v1.50\\bin;C:\\Program Files\\dotnet\\;C:\\Program Files\\Microsoft SQL Server\\130\\Tools\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\150\\DTS\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\150\\DTS\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\170\\Tools\\Binn\\;C:\\Program Files (x86)\\Microchip\\MPLAB C32 Suite\\bin;C:\\Program Files\\Microchip\\xc16\\v1.60\\bin;C:\\Program Files\\Git\\cmd;C:\\nburn\\pcbin;C:\\nburn\\gcc-m68k\\bin;C:\\nburn\\gcc-m68k\\msys\\1.0\\bin;C:\\Program Files (x86)\\dotnet\\;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\**********\\AppData\\Local\\Programs\\Python\\Python39\\Scripts\\;C:\\Users\\**********\\AppData\\Local\\Programs\\Python\\Python39\\;C:\\Users\\**********\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\**********\\AppData\\Local\\GitHubDesktop\\bin;C:\\Users\\**********\\flutter\\bin;C:\\Users\\**********\\AppData\\Local\\Android\\Sdk\\tools;C:\\Users\\**********\\AppData\\Local\\Android\\Sdk\\platform-tools;;C:\\SysGCC\\avr\\bin;C:\\Users\\**********\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\**********\\.dotnet\\tools;C:\\Users\\**********\\AppData\\Local\\Programs\\Microsoft VS Code\\bin"
        "toolchainPath": "c:\\ncs\\v1.9.1\\toolchain",
        "toolchainBinPath": "c:\\ncs\\v1.9.1\\toolchain\\opt\\bin",
        "toolchainVersion": "1.9.1"
      "terminal": {
        "shell": null,
