cannot enter bootloader mode on nrf52840 dongle anymore
Dear all,
I could happily flash my firmware to my nrf52840 upon pressing reset button. When pressing the reset button the diode on the board started to beat red and via command:
nrfutil dfu usb-serial -pkg blinky.zip -p /dev/ttyACM0
I could easily write a new firmware.
Today I found a pair of scissors accidentally touching my board on GPIO pins, I immediately removed the scissors knowing it could potentially damage the board via short circuit. I removed the board from USB port and plugged it back. The application written on the flash is working correctly, it is a bluetooth flash button service, which can be controlled via Android app NRF Blinky. The diode can be controller correctly, it flashes upon command and also the button sends notification to my Android phone. So far it seems allright.
BUT, after I long press the reset button to enter bootloader mode, the diode does not glow read like heartbeat anymore, it tries to glow red and starts flashing red randomly like a current it flowing throught the diode randomly. Therefore I cannot write any new firmware to my board.
Moreover, I used to recover my dongle when accidentally locking my nrf52840 via OpenOCD, but right now, it cannot even connect to the device yielding:
Error: Error connecting DP : cannot read IDR
Does anyone know how to resolve this issue?
I suspect I damaged partially my board shortcutting it but I still wonder wheter there is a sort of a utility I can verify what is wrong exactly with my board. Just the bootloader might be corrupted but it is very suspicious that OpenOCD cannot communicate with the MCU via OpenOCD anymore.
Thank you very much
  • Just to make it clear. I had one nrf52840 dongle which I could program via pressing the button (the one on the side), it started to heartbeat with glowing the diode red and I could program it. After some action this dongle does not heartbeat glow RED diode any more after pressing the button it somehow randomly flashes red, but obviously does not enter DFU mode.The only way I can program this dongle is via OpenOCD since the DFU mode is broken.
    Since I want to compare the broken dongle with a working piece I bought yesterday another one which enters the DFU mode correctly.
    In order to enter DFU without pressing the button, I downloaded NRF Connect for Desktop for Linux, but I do not know how to enter the DFU mode. What I did so far.
    I plugged the fully working nrf52840 dongle into USB,started nrf connect for desktop and opened the Programmer but in the log window I see a red line with this statement (obviously loading a windows library).
    Failed to get the library versions: JLINKARM_DLL_COULD_NOT_BE_OPENED (Origin: "Failed to get module versions.")
    But do not see my dongle anywhere.
    After physically pressing the reset button I see my device when pressing the arrow on the right side of button with label "SELECT DEVICE", moreover another error appears:
    Error when fetching device versions: readFwInfo error (Origin: "Error when running nrfdl_fw_read_info")
    Now I see my device as /dev/ttyACM0
    I did not plugin my faulty USB dongle yet, so far working with the fully working one.
    But I see my device only after manually entering the DFU mode, but the goal is to enter DFU mode in the software and I do not know why that is why I am asking whether I need a STLINK/SEGGER probe for that, since I do not see any button/switch/command how to enter the DFU mode in software.
  • It is programmer of version 3.0.3
    Supported engine NRF Connect:
    3.11.1
  • There is a value of 3V on the left side of the  reset button (having the USB connector on the left side) and 0V on the right side of the reset button in both DFU and normal mode.
    The same applies to my corrupted dongle, also 3V on left side and 0V on right side.
    I can measure some other voltage readings but I would love to have some hint what could be the possible fault.
    Now I have uploaded stock firmware from Nordic on my faulty dongle. It seems like upon RESET button press or plugging in the dongle into USB port it tries to glow the diode like in DFU mode, but immediately it turns to that weird red random flashing. Moreover the NRF Connect for desktop does not see the device at all, seems like the dongle really does not enter the DFU mode.
    Sorry to waste your time repairing dongle for 10$, but it is more of a getting to know what the problem actually is and to learn a bit more from my own mistakes.
  • I also experience this strange behaviour. When connecting to OpenOCD, I connect the device to Raspberry via USB HUB. But many times I see the output of OpenOCD:
    Error: Error connecting DP: cannot read IDR
    This means the board is not connected but obviously it is plugged in USB port.
    Many times the board is connected to OpenOCD, I can read the status, but I cannot erase the memory and I cannot flash the memory, it looks like it is connected but it is doing weird things. The only way how can I overcome these issues it that I hold the board tightly in USB port but this is strange, it used to work without any pressing the board firmly, it was just plugged in the USB port and I could happily flash it over OpenOCD.
    Could it be that the internal voltage regulator is doing some nasty things?
    But the fact that my program runs very find whenever I plug the dongle to USB does not support this hypothesis.
    Just now I remembed that experienced this fast random RED light flashing when there was something wrong with the powering of the board, it looked like to board detected malformed input voltage and it started to flash RED fast.
    Do you happen to know if there is any piece of information what the regular fast RED light flashing means? The fast red light looked random to me, but now I see that it might be pretty regular, just much faster than when entering DFU mode, it seems like when trying to enter DFU mode, it might check the voltage regulator or some voltage level and if it is wrong then it refuses to enter DFU just to protect from flashing the memory inconsistently and signals the error via fast red light flashing.
    Could there be something wrong with the internal voltage regulator? Isn't there any log I can trace what is happening exactly?
  • Actually, funny thing happened to me this weekend. After desoldering everything what was attached to the dongle. I plugged it is to laptop USB, it slowed down the pace of RED blinking but still not like DFU mode, but after manual RESET, it started to glow exactly like DFU mode, I mean the heartbeat red glow. I managed to repeat it once more, but not anymore from that time on, now still blinking red fast unable to enter DFU again.
    I checked the board with magnifying glass but I don't see any crack on any part moreover I checked for short circuit current draw, but the board draws approximately 8mA  after pressing the reset button, the working dongle draws approximately 6.7mA in DFU mode.
    The voltage level of VBUS is 5V and OUT is 2.99V.
    Have no idea where to start and what to check on the board.
