Flash and debug fail in Visual Studio Code.
I tried building and debugging the sample "https_client" using the method described here.
But debugging fails. Debugging stops prematurely because the source file cannot be found.
Module: nRF9160-DK
SDK: Connect SDK v2.0.0
firmware: mfw_nrf9160_1.3.2.zip
The settings and extended functions when creating the application, and the contents of the output are as follows.
Settings
extension
output
We will also send you the logs output during build, flash, and debug, so please check them.
3113.log_build.txt
Flashing build to undefined
west flash -d c:\Users\protec\Desktop\https_client\build --skip-rebuild -r nrfjprog --dev-id 960007184
-- west flash: using runner nrfjprog
-- runners.nrfjprog: Flashing file: C:\Users\protec\Desktop\https_client\build\zephyr\merged.hex
Parsing image file.
Verifying programming.
Verified OK.
Applying pin reset.
-- runners.nrfjprog: Board with serial number 960007184 flashed successfully.
Cortex-Debug: VSCode debugger extension version 1.6.0 git(3026299). Usaage info: https://github.com/Marus/cortex-debug#usage
Warn: c:/Users/protec/Desktop/https_client/build/zephyr/merged.hex is not an ELF file format. Some features won't work -- Globals, Locals, disassembly, etc.Launching GDB: "c:\\ncs\\toolchains\\v2.0.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb-no-py.exe" -q --interpreter=mi2
    IMPORTANT: Set "showDevDebugOutput": "raw" in "launch.json" to see verbose GDB transactions here. Very helpful to debug issues or report problems
Launching gdb-server: "C:\\Program Files (x86)\\SEGGER\\JLink\\JLinkGDBServerCL.exe" -singlerun -nogui -if swd -port 50000 -swoport 50001 -telnetport 50002 -device nRF9160_xxAA -select usb=960007184 -rtos "C:\\Program Files (x86)\\SEGGER\\JLink\\GDBServer\\RTOSPlugin_Zephyr.dll"
    Please check TERMINAL tab (gdb-server) for output from C:\Program Files (x86)\SEGGER\JLink\JLinkGDBServerCL.exe
GNU gdb (Zephyr SDK 0.14.1) 9.2
Copyright (C) 2020 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "--host=x86_64-host_w64-mingw32 --target=arm-zephyr-eabi".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<https://github.com/zephyrproject-rtos/sdk-ng/issues>.
Find the GDB manual and other documentation resources online at:
    <http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word".
0x0001244e in ?? ()
Program stopped, probably due to a reset and/or halt issued by debugger
add symbol table from file "c:/Users/protec/Desktop/https_client/build/zephyr/zephyr.elf"
(y or n) [answered Y; input not from terminal]
Reading symbols from c:/Users/protec/Desktop/https_client/build/zephyr/zephyr.elf...
add symbol table from file "c:/Users/protec/Desktop/https_client/build/tfm/bin/tfm_s.elf"
Reading symbols from c:/Users/protec/Desktop/https_client/build/tfm/bin/tfm_s.elf...
2
Resetting target
[New Remote target]
[New Thread 536955656]
[New Thread 536956032]
[Switching to Thread 536955840]
Thread 2 hit Temporary breakpoint 1, main () at C:/ncs/v2.0.0/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/cmsis_psa/main.c:130
130	    __ASM volatile(
[New Remote target]
build settings
I would be very happy if you could tell me how to solve it.
(In this state, nothing was displayed even when connected to LTE Link Monitor.)
    thank you for your answer.
    Attach support information.
    IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
      "platform": {
        "os": "win32",
        "osVersion": "Windows 10 Home",
        "osKernel": "10.0.19044",
        "vscode": "1.70.2",
        "electron": "18.3.5",
        "node": "v16.13.2"
      "system": {
        "date": "2022-08-29T00:32:13.451Z",
        "vscodeRoot": "c:\\Users\\protec\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
        "vscodeUptime": "00:01:26",
        "osUptime": "444:02:21",
        "cpu": {
          "model": "Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz",
          "speed": "2304 MHz",
          "count": 4
        "memory": {
          "total": "15.81 GB",
          "free": "6.47 GB"
      "workspace": {
        "name": "未設定 (ワークスペース)",
        "workspaceFile": "1658473311128",
        "folders": [
          "c:\\Users\\protec\\Desktop\\hello_world",
          "c:\\Users\\protec\\Desktop\\https_client",
          "c:\\Users\\protec\\Desktop\\at_client"
      "extensions": {
        "internal": {
            "version": "2022.7.242",
            "path": "c:\\Users\\protec\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2022.7.242-win32-x64",
            "isActive": false
            "version": "2022.7.21",
            "path": "c:\\Users\\protec\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2022.7.21",
            "isActive": true
            "version": "2022.7.36",
            "path": "c:\\Users\\protec\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2022.7.36",
            "isActive": true
            "version": "2022.7.24",
            "path": "c:\\Users\\protec\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2022.7.24",
            "isActive": true
        "external": {
          "marus25.cortex-debug": "1.4.4",
          "ms-vscode.cpptools": "1.11.5",
          "ms-vscode-remote.remote-wsl-recommender": "0.0.15",
          "ms-vscode.js-debug": "1.70.0",
          "ms-vscode.js-debug-companion": "1.0.18",
          "ms-vscode.vscode-js-profile-table": "1.0.3",
          "MS-CEINTL.vscode-language-pack-ja": "1.70.8170911",
          "ms-vscode.cmake-tools": "1.11.26",
          "twxs.cmake": "0.0.17"
      "tools": {
        "c:\\ncs\\toolchains\\v2.0.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.14.1",
        "C:\\Program Files (x86)\\SEGGER\\JLink\\JLink.exe": "7.66a",
        "C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.16.0",
        "nrfutil": "Not found",
        "c:\\ncs\\toolchains\\v2.0.0\\opt\\bin\\cmake.exe": "3.20.5",
        "c:\\ncs\\toolchains\\v2.0.0\\opt\\bin\\Scripts\\west.exe": "0.13.1",
        "c:\\ncs\\toolchains\\v2.0.0\\opt\\bin\\python.exe": "3.8.2",
        "c:\\ncs\\toolchains\\v2.0.0\\opt\\bin\\ninja.exe": "1.9.0",
        "c:\\ncs\\toolchains\\v2.0.0\\opt\\bin\\gperf.exe": "3.1",
        "c:\\ncs\\toolchains\\v2.0.0\\opt\\bin\\dtc.exe": "1.4.7",
        "c:\\ncs\\toolchains\\v2.0.0\\opt\\bin\\gn.exe": "2039",
        "c:\\ncs\\toolchains\\v2.0.0\\mingw64\\bin\\git.exe": "2.26.2.windows.1"
      "sdks": [
          "version": "2.0.0",
          "path": "c:\\ncs\\v2.0.0"
      "toolchains": [
          "version": "2.0.0",
          "path": {
            "$mid": 1,
            "fsPath": "c:\\ncs\\toolchains\\v2.0.0",
            "_sep": 1,
            "path": "/C:/ncs/toolchains/v2.0.0",
            "scheme": "file"
      "connectedDevices": [
          "serialNumber": "960007184"
      "deviceProviders": [
        "nrfjprog"
      "config": {
          "topdir": "${nrf-connect.sdk:2.0.0}",
          "toolchain": {
            "path": "${nrf-connect.toolchain:2.0.0}"
          "ozonePath": "",
          "applications": [
          "applicationOptions": {},
          "kconfig": {
            "interface": "kconfig"
          "welcome": {
            "showOnStartup": true
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "enableTelemetry": true,
          "taskBindings": {},
          "debugging": {
            "backend": "Cortex-Debug"
          "activeAppFollowActiveEditor": true
          "terminalMode": "character"
        "marus25.cortex-debug": {
          "armToolchainPath": null,
          "armToolchainPrefix": "arm-none-eabi",
          "gdbPath": null,
          "objdumpPath": null,
          "JLinkGDBServerPath": null,
          "openocdPath": null,
          "pyocdPath": null,
          "PEGDBServerPath": null,
          "stutilPath": null,
          "stlinkPath": null,
          "stm32cubeprogrammer": null,
          "flattenAnonymous": false,
          "registerUseNaturalFormat": true,
          "variableUseNaturalFormat": true,
          "dbgServerLogfile": null,
          "showRTOS": false,
          "showDevDebugOutput": "none"
      "environment": {
        "westExe": "west",
        "westEnv": {
          "ELECTRON_RUN_AS_NODE": "1",
          "HOME": "C:\\Users\\protec",
          "HOMEDRIVE": "C:",
          "HOMEPATH": "\\Users\\protec",
          "Path": "c:\\ncs\\toolchains\\v2.0.0\\mingw64\\bin;c:\\ncs\\toolchains\\v2.0.0\\mingw64\\libexec\\git-core;c:\\ncs\\toolchains\\v2.0.0\\opt\\bin;c:\\ncs\\toolchains\\v2.0.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;c:\\ncs\\toolchains\\v2.0.0\\arm-zephyr-eabi\\bin;c:\\ncs\\toolchains\\v2.0.0\\opt\\bin\\Scripts;C:\\Users\\protec\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\protec\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\protec\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\protec\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\GCC for Renesas RX 8.3.0.202002-GNURX-ELF\\rx-elf\\rx-elf\\bin;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\dotnet\\;C:\\Program Files\\Microsoft SQL Server\\130\\Tools\\Binn\\;c:\\Program Files (x86)\\Microsoft SQL Server\\100\\Tools\\Binn\\;c:\\Program Files\\Microsoft SQL Server\\100\\Tools\\Binn\\;c:\\Program Files\\Microsoft SQL Server\\100\\DTS\\Binn\\;C:\\Program Files\\Thorlabs\\Thorlabs OSA;C:\\Program Files\\Thorlabs\\Thorlabs OSA\\bin;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\Program Files\\Thorlabs Redstone OSA;C:\\Program Files\\Thorlabs Redstone OSA\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\protec\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\protec\\.dotnet\\tools;;C:\\Users\\protec\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
          "ZEPHYR_BASE": "c:\\ncs\\v2.0.0\\zephyr",
          "ZEPHYR_SDK_INSTALL_DIR": "c:\\ncs\\toolchains\\v2.0.0\\opt\\zephyr-sdk",
          "PYTHONPATH": "c:\\ncs\\toolchains\\v2.0.0\\opt\\bin;c:\\ncs\\toolchains\\v2.0.0\\opt\\bin\\Lib;c:\\ncs\\toolchains\\v2.0.0\\opt\\bin\\Lib\\site-packages",
          "Python3_ROOT": "c:\\ncs\\toolchains\\v2.0.0\\opt\\bin"
        "inherited": {
          "HOMEDRIVE": "C:",
          "Path": "C:\\Users\\protec\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\protec\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\protec\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\protec\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\GCC for Renesas RX 8.3.0.202002-GNURX-ELF\\rx-elf\\rx-elf\\bin;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\dotnet\\;C:\\Program Files\\Microsoft SQL Server\\130\\Tools\\Binn\\;c:\\Program Files (x86)\\Microsoft SQL Server\\100\\Tools\\Binn\\;c:\\Program Files\\Microsoft SQL Server\\100\\Tools\\Binn\\;c:\\Program Files\\Microsoft SQL Server\\100\\DTS\\Binn\\;C:\\Program Files\\Thorlabs\\Thorlabs OSA;C:\\Program Files\\Thorlabs\\Thorlabs OSA\\bin;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\Program Files\\Thorlabs Redstone OSA;C:\\Program Files\\Thorlabs Redstone OSA\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\protec\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\protec\\.dotnet\\tools;;C:\\Users\\protec\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
          "PATH": "C:\\Users\\protec\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\protec\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\protec\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\protec\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\GCC for Renesas RX 8.3.0.202002-GNURX-ELF\\rx-elf\\rx-elf\\bin;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\dotnet\\;C:\\Program Files\\Microsoft SQL Server\\130\\Tools\\Binn\\;c:\\Program Files (x86)\\Microsoft SQL Server\\100\\Tools\\Binn\\;c:\\Program Files\\Microsoft SQL Server\\100\\Tools\\Binn\\;c:\\Program Files\\Microsoft SQL Server\\100\\DTS\\Binn\\;C:\\Program Files\\Thorlabs\\Thorlabs OSA;C:\\Program Files\\Thorlabs\\Thorlabs OSA\\bin;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\Program Files\\Thorlabs Redstone OSA;C:\\Program Files\\Thorlabs Redstone OSA\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\protec\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\protec\\.dotnet\\tools;;C:\\Users\\protec\\AppData\\Local\\Programs\\Microsoft VS Code\\bin"
        "toolchainPath": "c:\\ncs\\toolchains\\v2.0.0",
        "toolchainBinPath": "c:\\ncs\\toolchains\\v2.0.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin",
        "toolchainVersion": "2.0.0"
      "terminal": {
        "shell": null,
        "defaultProfile": null
  • Hi Norio,
    I have asked internally and will get back to you soon.
    -Priyanka
  • Hi Norio,
    From your debug log,
    It looks like your debugging is working.
    -Priyanka
    Thank you for your answer.
    When you say debugging works, do you mean I can debug in Visual Studio Code?
    When debugging https_client with Visual Studio Code, the main thread of "C:\ncs\v2.0.0\modules\tee\tf-m\trusted-firmware-m\secure_fw\spm\cmsis_psa\main.c" in the SDK will stop.
    Why am I getting the problem "cannot open source file" in "main.c"?
  • Hi Norio,
    Could you attach a screenshot or log of this? i.e. the problem "cannot open source file" in "main.c"
    -Priyanka
