How to switch to https://github.com/nrfconnect/sdk-zephyr main branch in ncs/v2.0.2?
After
west init -m github.com/.../sdk-nrf --mr v2.0.2
west update
I notice ncs/v2.0.2/zephyr has huge difference with github.com/.../sdk-zephyr main
Like there is no 52840 overlay in ncs/v2.0.2/zephyr/sample/driver/adc/board.
I try to delete ncs/v2.0.2/zephyr and git clone https://github.com/nrfconnect/sdk-zephy.
But not working still got message:
=== updating zephyr (zephyr):
Updating files: 100% (10642/10642), done.
HEAD is now at be360e7db2 [nrf fromtree] net: openthread: enable default software tx security in 1.3
WARNING: left behind zephyr branch "main"; to rebase onto the new HEAD:
git -C zephyr rebase be360e7db2db7e1f0e9fcac686a08e62e350bf55 main
How can I switch to sdk-zephyr main?
  • Hello again,
    Wols said:
    Sorry for the late reply.
    No problem at all - we can continue this whenever you have the chance, no worries! :)
    Wols said:
    It's really confusing me that I can't find the correct ncs SDK for useing ADC example on nrf52840dk_nrf52840.
    I am not sure what you mean by this, could you elaborate?
    We do not have a dedicated SAADC usage example in the nRF Connect SDK (similar to the peripheral example we had in the nRF5 SDK) if this is what you mean, but you could take a look here to see how you easily can use the SAADC in the nRF Connect SDK.
    Did you have a look at my remining questions from my previous comment? Did you do a fresh reinstallation of the nRF Connect SDK through the Toolchain Manager?
    Karl
  • Hi Karl,
    I have had reinstall nRF Connect SDK through the Toolchain Manager, but the sample " ncs/v2.0.2/zephyr/sample/driver/adc " still not working. (I guess this example works on my Linux just beacuse my environment is nasty... :'(  )
    And I think the reason I can't use the sample " ncs/v2.0.2/zephyr/sample/driver/adc ", is because there is no any nrf board config in adc/board, which means it's not support this example on nrf board.
    Now I am using " ncs/v2.0.2/zephyr/sample/board/nrf/bettery ", and trying to rewrite to fit my nrf52832dk(Which I currently have.).
    What the difference between the light_control example and " ncs/v2.0.2/zephyr/sample/board/nrf/bettery ",
    Are they both support nrf52832?
    Ah, now I understand what you meant in your previous comment, thank you for clarifying!
    The example does indeed not work on the Nordic platforms, since we differentiate between Analogue inputs and channels in our devices, as mentioned in the note you referred to earlier. The reason why our devices does this is the 'GPIO Crossbar' feature, that makes all the GPIOs available for most all of the peripherals - this flexible routing is the reason for the differentiation between Analogue inputs and ADC channels (which usually is 1-1 in other, less flexible devices).
    Yes, they are both supported. The main difference between the two is that the battery example is specific for the battery use-case (it outputs a battery charge percentage based on an approximation made of the specific battery's discharge curve), while the 'light_control' example I referenced earlier is more generic, i.e it only samples the voltage of a pin - without concern for what it is actually measuring.
    You can use either one as your guide to how you could use the SAADC on the nRF52832, but the light control example is likely easier to familiarize with, and more straight-to-the-point with regards to SAADC usage, in this case.
    Karl
  • Thanks Karl,
    But the light_control examle not work for me.
    Here is the erroe message.
    ../src/main.c: In function 'main':
    /home/wols/ncs/v2.0.2/boards/arm/furry_project/light_controller/build/zephyr/include/generated/devicetree_unfixed.h:4495:36: error: 'DT_N_S_soc_S_pwm_4001c000_P_label' undeclared (first use in this function); did you mean 'DT_N_S_soc_S_pwm_4001c000_P_reg'?
     4495 | #define DT_N_NODELABEL_pwm0        DT_N_S_soc_S_pwm_4001c000
    And in the battery  " ncs/v2.0.2/zephyr/sample/board/nrf/bettery " , when I connect pa0.03 to GND, the console still out put 3V, did I miss some thing?
    *** Booting Zephyr OS build v3.0.99-ncs1-4913-gf7b06162027d  ***
    [0:00:00.375]: 2971 mV; 0 pptt
    [0:00:05.312]: 2892 mV; 0 pptt
    [0:00:10.248]: 2965 mV; 0 pptt
    [0:00:15.185]: 2954 mV; 0 pptt
    [0:00:20.124]: 2983 mV; 0 pptt
    The 52dk52832 overlay I used.
    	zephyr,user {
    		io-channels = <&adc 0>, <&adc 1>, <&adc 7>;
    &adc {
    	#address-cells = <1>;
    	#size-cells = <0>;
    	channel@0 {
    		reg = <0>;
    		zephyr,gain = "ADC_GAIN_1_6";
    		zephyr,reference = "ADC_REF_INTERNAL";
    		zephyr,acquisition-time = <ADC_ACQ_TIME_DEFAULT>;
    		zephyr,input-positive = <NRF_SAADC_AIN1>; /* P0.03 */
    		zephyr,resolution = <12>;
    	channel@1 {
    		reg = <1>;
    		zephyr,input-positive = <NRF_SAADC_AIN2>;
    		// zephyr,oversampling = <8>;
    	channel@7 {
    		reg = <7>;
    		zephyr,gain = "ADC_GAIN_1_5";
    		zephyr,reference = "ADC_REF_VDD_1_4";
    		zephyr,vref-mv = <750>;
    		zephyr,input-positive = <NRF_SAADC_AIN6>; /* P0.30 */
    		zephyr,input-negative = <NRF_SAADC_AIN7>; /* P0.31 */
    &pwm0 {
    	//LED 2
    	ch0-pin = <14>;
  • OK, so in light control example this version is old dts type see Pin control.
    First step just delete  "ch0-pin = <14>;" to fix " rror: static assertion failed: "/soc/pwm@4001c000 has legacy *-pin properties defined although PINCTRL is enabled" " error.
    After this when compile will got error below
    light_controller/build/zephyr/include/generated/devicetree_unfixed.h:4337:36:
    error: 'DT_N_S_soc_S_pwm_4001c000_P_ch0_pin' undeclared (first use in this function);
    did you mean 'DT_N_S_soc_S_pwm_4001c000_P_ch0_inverted'?
    I think is because it can not get pwm pin, but I have no idea how to fix it, so just block all pwm code.
    And you can build then flash, you will see chanel 1  ADC(In my case is p0.02).
    You can edit ADC_1ST_CHANNEL_INPUT to select which AINx to read.
    But I am still lookin for the way to read muilt AINx same time
    Like read AIN1 AIN2 in a for loop.
    	for (size_t i = 0U; i < ARRAY_SIZE(adc_channels); i++) {
    		debug("- %s, channel %d: ",
    				adc_channels[i].dev->name,
    				adc_channels[i].channel_id);
    		(void)adc_sequence_init_dt(&adc_channels[i], &sequence);
    		err = adc_read(adc_channels[i].dev, &sequence);
    		if (err < 0) {
    			debug("Could not read (%d)\n", err);
    			continue;
    		} else {
    			debug("%"PRId16, buf);
    		/* conversion to mV may not be supported, skip if not */
    		val_mv = buf;
    		err = adc_raw_to_millivolts_dt(&adc_channels[i],
    							&val_mv);
    		if (err < 0) {
    			debug(" (value in mV not available)\n");
