Problem using P0.02 with TF-M active
We are working on adding T-M to our middleware, and we discovered a pretty annoying side effect.
We are using NCS 2.0.0
One of our device is controlled using the gpio P0.02 of a nRF5340, with the code residing in non secure part of the application core.
Since TF-M has been added, the device does not turn on, and we verified it using a multimeter (the pin stays low).
I think the issue comes from the ```c CONFIG_NFCT_PINS_AS_GPIOS ``` configuration, which does not work when using TF-M, but it is just an intuition.
I've tried adding this code to tee/tf-m/trusted-firmware-m/platform/ext/nordic_nrf/common/nrf5340/target_cfg.c, but it has no effect
```c
nrf_gpio_pin_mcu_select(2, NRF_GPIO_PIN_MCUSEL_PERIPHERAL);
nrf_gpio_pin_mcu_select(3, NRF_GPIO_PIN_MCUSEL_PERIPHERAL);
Do you see where the problem comes from? We need to fix it ASAP, has this pin is VERY important on our device.
If not, we will have to throw away TF-M.
Regards
Giuliano
