I am developing a peripheral in ble, and I receive the following error when I disconnect a new connection within the connection callback.
[00:00:07.533,966] <wrn> bt_att: att_get: Not connected
[00:00:07.631,561] <err> bt_conn: bt_conn_send_cb: not connected!
I have also seen this error when I repeatedly connect to the peripheral:
[02:11:23.832,550] <err> bt_conn: bt_conn_send_cb: not connected!
The connected callback simply looks at the connection info (bt_conn_get_info) and then disconnects(bt_conn_disconnect).
The errors are inconsistent. They don't always happen, and they're not always the same.
Often I see the bt_att issue on the first connection, but not always.
I am repeatedly connecting to the peripheral at a fast rate using the nRF Connect phone app.
Interestingly, when the peripheral disconnects the phone as described, the phone sometimes gets stuck in a re-connection loop. This is how the subscriptions are coming in so quickly in some cases.
To be clear though, I do frequently see the very simple case described above on the first connection and no looping.
Notably, the return value from the bt_conn_disconnect is 0 (success) on those errors.
Question - what is the right way to use the API to avoid these errors? I want to be able to disconnect new connections within the connected callback.
Thanks.
