nRF5340_Audio Build Error
Hello All,
Just to begin, I am an extreme novice when it comes to building/flashing FW so if I do not provide enough description or ask questions that may seem a bit surface level please keep that in mind, but I am happy to provide more info anything else that is needed to help with debugging!
I believe I have the prerequisites installed and I am trying to build the nrf5340_audio sample application, but when I run the following command:
python buildprog.py -c app -b release -d gateway
I get the following log and errors:
C:\Users\samietz\Desktop\nrf5340_audio_test\tools\buildprog>python buildprog.py -c app -b release -d gateway
|    snr     | snr conn |  device | only reboot  | core app programmed | core net programmed |
|    1000    |  ←[33mFalse←[0m   | headset | Not selected |     Not selected    |     Not selected    |
| 1050159080 |   ←[32mTrue←[0m   | gateway | Not selected |     Selected TBD    |     Not selected    |
Invoking build step
Run: west build C:\Users\samietz\Desktop\nrf5340_audio_test -b nrf5340_audio_dk_nrf5340_cpuapp -d C:\Users\samietz\Desktop\nrf5340_audio_test\build\dev_gateway\build_release
  File "c:\python38\lib\runpy.py", line 193, in _run_module_as_main
    return _run_code(code, main_globals, None,
  File "c:\python38\lib\runpy.py", line 86, in _run_code
    exec(code, run_globals)
  File "C:\Python38\Scripts\west.exe\__main__.py", line 7, in <module>
  File "c:\python38\lib\site-packages\west\app\main.py", line 793, in main
    app.run(argv or sys.argv[1:])
  File "c:\python38\lib\site-packages\west\app\main.py", line 109, in run
    self.run_command(argv)
  File "c:\python38\lib\site-packages\west\app\main.py", line 345, in run_command
    self.run_extension(args.command, argv)
  File "c:\python38\lib\site-packages\west\app\main.py", line 417, in run_extension
    command.run(args, unknown, self.topdir, manifest=self.manifest,
  File "c:\python38\lib\site-packages\west\commands.py", line 135, in run
    self.do_run(args, unknown)
  File "C:\Users\samietz\Desktop\nrf5340_audio_test\zephyr\scripts\west_commands\build.py", line 201, in do_run
    self._run_cmake(board, origin, self.args.cmake_opts)
  File "C:\Users\samietz\Desktop\nrf5340_audio_test\zephyr\scripts\west_commands\build.py", line 488, in _run_cmake
    run_cmake(final_cmake_args, dry_run=self.args.dry_run)
  File "C:\Users\samietz\Desktop\nrf5340_audio_test\zephyr\scripts/west_commands\zcmake.py", line 45, in run_cmake
    _ensure_min_version(cmake, dry_run)
  File "C:\Users\samietz\Desktop\nrf5340_audio_test\zephyr\scripts/west_commands\zcmake.py", line 277, in _ensure_min_version
    version_out = subprocess.check_output(cmd, stderr=subprocess.DEVNULL)
  File "c:\python38\lib\subprocess.py", line 411, in check_output
    return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
  File "c:\python38\lib\subprocess.py", line 489, in run
    with Popen(*popenargs, **kwargs) as process:
  File "c:\python38\lib\subprocess.py", line 854, in __init__
    self._execute_child(args, executable, preexec_fn, close_fds,
  File "c:\python38\lib\subprocess.py", line 1307, in _execute_child
    hp, ht, pid, tid = _winapi.CreateProcess(executable, args,
OSError: [WinError 193] %1 is not a valid Win32 application
  File "C:\Users\samietz\Desktop\nrf5340_audio_test\tools\buildprog\buildprog.py", line 417, in <module>
    __main()
  File "C:\Users\samietz\Desktop\nrf5340_audio_test\tools\buildprog\buildprog.py", line 400, in __main
    __build_module(build_cfg, options)
  File "C:\Users\samietz\Desktop\nrf5340_audio_test\tools\buildprog\buildprog.py", line 149, in __build_module
    raise Exception("cmake error: " + str(ret_val))
Exception: cmake error: 1
This was done while following the instructions here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/applications/nrf5340_audio/README.html#building-and-programming-using-script.
I have also tried building via the command line and also receive an error, but it's not the same as the above:
samietz@samietz0 MINGW64 ~/Desktop/nrf5340_audio_test
$ west build -b nrf5340_audio_dk_nrf5340_cpuapp --pristine -DCONFIG_AUDIO_DEV=2 -DCONF_FILE=prj_release.conf
WARNING: ZEPHYR_BASE=C:\ncs\v2.0.1\zephyr in the calling environment will be used,
but the zephyr.base config option in C:\Users\samietz\Desktop\nrf5340_audio_test is "zephyr"
which implies a different ZEPHYR_BASE=C:\Users\samietz\Desktop\nrf5340_audio_test\zephyr
To disable this warning in the future, execute 'west config --global zephyr.base-prefer env'
ERROR: source directory -DCONFIG_AUDIO_DEV=2 does not exist
FATAL ERROR: refusing to proceed without --force due to above error
Without an in-depth understanding of what is actually going on here I am a bit lost as to what is going wrong. Any help would be greatly appreciated!
