Error on commissioning step 'FindOperational' while pairing matter sample over ble-thread
I'm following this tutorial https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.0.0/nrf/ug_matter.html - I use the nrf52840 dongle as a co-processor connected to a raspberry pi running OTBR, nrf52840 DK flashed with matter door lock sample and I downloaded chip tool (release version 2.0.0) on my laptop with Linux. I want to connect the door lock sample to OTBR as described here. Unfortunately, step 6 causes the problem. When I execute this command:
./chip-tool-release pairing ble-thread 1000 hex:0e080000000000010000000300000f35060004001fffe0020811111111222222220708fd05128ef262a22b051000112233445566778899aabbccddeeff030e4f70656e54687265616444656d6f010212340410445f2b5ca6f2a93a55ce570a70efeecb0c0402a0f7f8 20202021 3840
I get the following error:
CHIP:DIS: Operational discovery failed for 0x00000000000003E8: ../../src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:174: CHIP Error 0x00000032: Timeout
and I have no idea what should be wrong. (Does it mean there is something wrong with OTBR? But if I execute `service otbr-agent status` on raspberry pi I get otbr-agent is running and for command  `ot-ctl state` the response is Leader.
Can anybody help me figure it out? Thank you.
If you want to see full output from the command, you can find it here.
  • Means I didn't understood your uestion exactly
  • Also charlie, I want you to know that my OTBR interface is wpan0 and my laptop Wi-Fi interface is wlp3s0 but when I'm giving command ifconfig in my PC, I'm getting like the below mentioned log
    ifconfig
    docker0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
            inet 172.17.0.1  netmask 255.255.0.0  broadcast 172.17.255.255
            inet6 fe80::42:acff:fecc:a2f3  prefixlen 64  scopeid 0x20<link>
            ether 02:42:ac:cc:a2:f3  txqueuelen 0  (Ethernet)
            RX packets 1653  bytes 1938148 (1.9 MB)
            RX errors 0  dropped 0  overruns 0  frame 0
            TX packets 931  bytes 72609 (72.6 KB)
            TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
    enp2s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
            inet 10.72.208.176  netmask 255.255.254.0  broadcast 10.72.209.255
            inet6 fe80::6812:dc5e:679d:ced6  prefixlen 64  scopeid 0x20<link>
            ether c0:3e:ba:3a:00:5b  txqueuelen 1000  (Ethernet)
            RX packets 86153  bytes 76838415 (76.8 MB)
            TX packets 45548  bytes 7520260 (7.5 MB)
    lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
            inet 127.0.0.1  netmask 255.0.0.0
            inet6 ::1  prefixlen 128  scopeid 0x10<host>
            loop  txqueuelen 1000  (Local Loopback)
            RX packets 339719  bytes 37653563 (37.6 MB)
            TX packets 339719  bytes 37653563 (37.6 MB)
    otbr0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
            inet 172.18.0.1  netmask 255.255.0.0  broadcast 172.18.255.255
            inet6 fd11:db8:1::1  prefixlen 64  scopeid 0x0<global>
            inet6 fe80::42:53ff:fe16:e76b  prefixlen 64  scopeid 0x20<link>
            inet6 fe80::1  prefixlen 64  scopeid 0x20<link>
            ether 02:42:53:16:e7:6b  txqueuelen 0  (Ethernet)
            RX packets 13331  bytes 12291175 (12.2 MB)
            TX packets 5645  bytes 432361 (432.3 KB)
    wlp3s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
            inet 192.168.219.214  netmask 255.255.255.0  broadcast 192.168.219.255
            inet6 fe80::8c72:bdf9:c67:5b53  prefixlen 64  scopeid 0x20<link>
            inet6 2409:40f2:101f:78e1:a1ca:b687:ed88:2b8b  prefixlen 64  scopeid 0x0<global>
            inet6 2409:40f2:101f:78e1:65fd:d681:2090:1810  prefixlen 64  scopeid 0x0<global>
            ether 28:cd:c4:c3:27:33  txqueuelen 1000  (Ethernet)
            RX packets 519676  bytes 545654304 (545.6 MB)
            TX packets 233204  bytes 61071612 (61.0 MB)
    I'm not understanding why there is no wpan0 interface in this and what is otbr0 exactly
  • Hi Varun,
    I assume you are following Overview  |  OpenThread to set up OTBR. Do you have RCP plugged in properly and detected? Unfortunately, I am not familiar with OTBR too much except for using it on RPI directly. I suggest you check with the OTBR developers here Issues · openthread/ot-br-posix (github.com).
    Some explanation about my previous suggestions:
    1) Matter(former Project CHIP) provides OTBR, commissioner tools in the beginning to help developers with their Matter accessaries development, but the setup process is complex and these tools may be less maintained now due to more commercial smart home ecosystems starting to support Matter. If you are just developing or testing Matter devices, I strongly suggest you use Apple Homekit(Homepod Mini), Google Home(Nest Hub), and so on for your development instead of setting up your own environment.
    2) If you still want to use the original Matter development environment, please make sure you tested with a known working Matter device (running Thread protocol for your test specifically) like Matter samples — nRF Connect SDK 2.4.0 documentation (nordicsemi.com), this will save some efforts to test with some uncertain device.
    Charlie
