[nRF Connect SDK]Force to make pairing(bonding)
Target nRF52832(nrf52dk_nrf52832)
SDK NCS v2.0.0
I'm testing NCS 2.0 with Android 12.
Making pairing with Android, I call two API when connected.
bt_set_bondable(true);
bt_conn_set_security(conn, BT_SECURITY_L4);
It worked well so far (under Android 11)
BTW Android 12 make trouble security level 1 error.
[log]
00> HS connected
00> HS Connected 4A:B4:CA:22:85:2D (random)
00> Connection parameters updated.
00> interval: 6, latency: 0, timeout: 500
00> Conn params updated: interval 7 ms, latency 0, timeout: 5000 ms
00> Security failed: 4A:B4:CA:22:85:2D (random) level 1 err 2
00> Disconnected: 4A:B4:CA:22:85:2D (random) (reason 34)
Can I have another option to make pairing automatically?
    It's always the central (master) that must send the first packet on a connection event. The peripheral (slave) can only send data after the master send a packet.
    In this case you can see that the central (master) does not send any packet for 100 connection events by looking at the "Event counter" column. So this must be a bug of some sort on the phone side.
    Kenneth
  • I'm sorry that last your message had been removed while I delete duplicated my message.
    MTK reply:
    The log provided by your company from beginning, as well as the latest linked log,
    It can be seen that the DUT initiated the security requsest, and the peer has not responded to DUT. After a period of time, the connection is disconnected. The entire pair time of smp cannot exceed 30s. It is impossible for MTK to re-modify the timeout time for each acl cmd. Since your customer finds out that the delay is estimated by the peer,MTK suggest that it should analyze from the peer.
    Your last message
    Tim Hwang said:
    BTW, Can I have workaround for changing auth timeout as 30 seconds?
    No.
    But that can be removed, and I believe we have already discussed removing it, but from my understanding you are seeing the same even when removed? Did they have an explaination to why removing it show the same issue?
    Kenneth
  • For workaround, I understand it.
    Here is test steps and my explanation.
    sample:\nrf\samples\bluetooth\peripheral_uart
    1) launch sample
    2) MTK search Nordic and send "request pairing" at "REF" time.
    3) Pairing request was sent from MTK to Nordic at 9.371. It causes timeout.
    4) I request to MTK for fixing delayed "pairing request".
    5) MTK's reply is that Nordic can handle it. because "The entire pair time of smp cannot exceed 30s"
    ..."MTK suggest that it should analyze from the peer.")
    6) What is your opinion about that? Is it acceptable?
    Can you share that specific log with me?
    Kenneth
